| Posted: Sun Oct 10, 2010 12:36 pm Post subject: |
| David_Web wrote: | I guess the problem now is finding good quality glasses that is not expensive.
Ill probably never go the VP route as I tie in exclusively with a HTPC. Have you thought about a kit with ether glasses or glasses + sync thingie?
I am more and more happy that I am going to run a 1.5m wide screen. For an 8" Marquee I should still be able to get an OK picture.
BTW have you looked at the Teensy? http://www.pjrc.com/teensy/index.html
Might be hard doing any advanced sync circuit for cheaper. And you can use it for anything else.
If you want it might even be possible to tie it in with the computer to tap sync directly (or get eye order reliably)
It does support both USB and RS232. |
Moome is going to be providing a shutter glasses output on his next generation of EXT and internal HDMI to RGBHV converters. Moome's output will supply industry standard TTL to drive TTL glasses or IR transmitters.
As of right now I plan to use the Samsung 3D glasses. If you are quick and patient on eBay you can get them open boxed for around $50 a pair give or take. I just ordered two pair and they will be here Monday. Universal industry standard emitters are due out next month that will support glasses from any manufacturer. Glasses are only going to get cheaper as they are not very advanced pieces of equipment and competition will drive the price down hard.
USB will not be part of anything I do. A major hurdle for USB shutter glasses timing would be to actually get the timing correct for the glasses with respect to the screen. I don't know how NVIDIA does this, and this might be why so many people have reported ghosting with the NVIDIA system. It will be different on every computer and might not even remain constant from day to day, movie to movie, or even throughout an entire movie or gaming session.
On a HTPC you will be supplying frame sequential anyway so the best thing to do in my opinion would be to get glasses sync from the Vsync pulse off the projector. This is what I am doing now and what Moome will offer soon.
the_maniac
Joined: 10 Jul 2009 Posts: 111 Location: Austria - Europe
| Posted: Sun Oct 10, 2010 1:05 pm Post subject: |
| Quote: | | Universal industry standard emitters are due out next month that will support glasses from any manufacturer. |
do you have a reliable source for this ? can you post a link ?
_________________ www.diy-community.de
| Posted: Sun Oct 10, 2010 1:06 pm Post subject: |
| the_maniac wrote: | | Quote: | | Universal industry standard emitters are due out next month that will support glasses from any manufacturer. |
do you have a reliable source for this ? can you post a link ? |
I can't give out info on this yet. A few more weeks...
| Posted: Mon Oct 18, 2010 10:09 pm Post subject: |
I got a preproduction universal emitter last week and it works pretty well... except it doesn't work perfectly with the Samsung glasses and those are the ones I really wanted to use. It might be correctable though with a timing circuit.
| Posted: Fri Oct 22, 2010 11:11 am Post subject: |
I've been working on one of the newer commercial 3D systems the past two days. It's an Nvidia based computer node video source system, that uses three of these computers to run two digitals in a blend setup.
The Nvidia cards they're using are the high end Stereo (or 3D) rendering cards. The cards can do custom resolutions, but they also have selectable resolutions already in place. Unlike the other and previous version of these cards I'm familiar with that has selectable but common rates, these only show 60hz, 72hz and 75hz.
So I asked one of our computer engineers about those resolutions, and that the two blended projectors for once was not running 96hz or above. And why are they using 60hz...
His response was "Frame Doubling"
I'll get back to this later when I get back, because I have to head back out and wrap things up.
Hey SC, I'm dealing with the Picat**** upgrade. Titans!
kodomo
| Posted: Mon Oct 25, 2010 11:17 am Post subject: |
[quote="CIR Engineering"]
craigr[/quote]
Being one of those recently buying one of the 'old' Moome cards ('lucky' me), I wonder wether there will be an upgrade option (or otherwise how to get VSync from the projector - do you tap it from the HDMI card, or do you have an analogue setup?).
I guess the mentioned universal std. emitters are not going to be plugged into the HDMI path between the source and the projector, but rather get VSync from the upcoming cards, are they? (Is an HDMI plugin box feasible at all - timing-wise?)
| Posted: Mon Oct 25, 2010 1:15 pm Post subject: |
| kodomo wrote: |
I guess the mentioned universal std. emitters are not going to be plugged into the HDMI path between the source and the projector, but rather get VSync from the upcoming cards, are they? (Is an HDMI plugin box feasible at all - timing-wise?) |
You will probably have both options. Lumagen is most likely coming out with an inline HDMI syn extractor that will work with the Radiance processors to drive shutter glasses. Moome will also be providing a shutter glasses sync and will most likely provide an upgrade path for existing FULLHD input cards and external boxes.
dochlywd
Joined: 25 Apr 2006 Posts: 346 Location: Saint Louis, Missouri
| Posted: Mon Oct 25, 2010 3:38 pm Post subject: |
So Craig,
Is Moome going to be the solution for those of us that purchase the XS that doesn't have the trigger outs??? It's sounds like it will be and that will be a huge relief since I debated on the XS or XE over this very same issue.
Doc
| Posted: Mon Oct 25, 2010 6:14 pm Post subject: |
| dochlywd wrote: | So Craig,
Doc |
Yes and no.
As it stands right now, and this is subject to change...
Lumagen is planning CRT 3D support on both the XS and XE processors. Lumagen is not planning to use the trigger outputs from the XE to drive the glasses anymore. Instead, one of two options is being considered at this time and it will come down to factors that I can't discuss.
The first option is that Lumagen will build and support an external HDMI dongle that will be installed between the HDMI cable running between Radiance and projector. It will use a proprietary data transmission through the Ethernet channel to communicate with the Lumagen 3D glasses dongle in order to polarize (right / left eyes) and also time the glasses' TTL sync signal with the frames (shutter timing).
If this approach is taken, Jim (Lumagen) has already agreed to give Moome the HDMI protocol so that Moome would be capable of adding this feature to the existing 3D output of his next generation cards. In other words, the Moome would be compliant with the Lumagen sync instructions and be able to distinguish right eye and left eye timing so that the polarity can be right with 100% accuracy.
So if the above all works out (this is preliminary) a consumer who has a Radiance processor would be able to opt for either the Lumagen HDMI sync dongle OR a Moome built HDMI transcoder with 3D Lumagen sync capability.
The other option being considered by Lumagen is adding a physical connection for 3D glasses TTL somewhere on the VP box its self. In this scenario you would need to ship your Radiance to Lumagen to have the new plug installed. In addition, Lumagen may or may not even build a 3D timing protocol that could be sent over HDMI because it is not needed for Lumagen if the physical connector is on the VP. However, Lumagen may still decide to creat the protocal just for Moome to use on his boards.
So either way on the XS or XE you will have an option from Lumagen of some kind to get 3D glasses TTL extraction on CRT.
Also Moome will have a 3D glasses TTL output on his cards no matter if it has Lumagen support or not. Moome can get TTL timing directly from the Vsync pulse on his cards (which is what I have been doing all these weeks). So Moome cards will have an output to time 3D glasses. This can be used with either Lumagen or with a HTPC or any other source.
The disadvantage to having sync extraction on the Moome board based only on the vertical pulse, is that there is no way to know the polarity. This is because in analog both the left and right pulses will look the same. What this means is that every time you start a movie you will need to verify that the polarity is correct and there will be a 50/50 chance that it is right. Also, if you FF, RW, pause for a while, or drop a frame you may lose correct polarity and then have to switch it manually. This is done with a toggle switch on the board so I consider it a pita if one were to have to do this at least every movie.
So the cleanest option will be to have a solution that can get correct polarity every time and not need constant manual adjustments. The Lumagen 3D glasses output will do this for certain, and the Moome might be able to do it just as perfectly provided Lumagen creates the protocol.
Confused yet?
dochlywd
| Posted: Mon Oct 25, 2010 7:17 pm Post subject: |
Actually, this last post has given me the best understanding of it yet!!!!!
Thanks!
| Posted: Mon Oct 25, 2010 7:26 pm Post subject: |
Hmmm, not sure if either would work for a blend situation where the blend scaler is after the lumagen unless the blend VP will pass the signal on the ethernet channel in the HDMI/DVI cable. And I do not think that the Tv -ones DVI has that capability. I do hear they might be coming out with a new unit next year that might be HDMI, so i'll have to pass.
Only way i could see it working in my set up might be if they do add the second output as a separate configurable so you could match the output rate of that output to what the blend scaler is outputting, then the dongle would work on that ouput of the lumagen for the glasses to sync to.
Make sense Craig?
| Posted: Mon Oct 25, 2010 10:40 pm Post subject: |
| Nashou66 wrote: |
Make sense Craig?
Athanasios |
I think with a second output config off the Lumagen (if that's what you mean), you will likely go out of phase with your glasses due to any lag in the Tv -one.
The Vsync pulse off the projector I would think should be fine because both projectors operate in time with each other. You will have to deal with the mixed polarity though.
| Posted: Mon Oct 25, 2010 11:06 pm Post subject: |
| CIR Engineering wrote: | | Nashou66 wrote: |
Make sense Craig?
Athanasios |
craigr |
So the Moome card would do that then( supply the Vsync) with out having to sync to the Radiance's?
speedyandre
| Posted: Tue Oct 26, 2010 10:11 pm Post subject: |
I wonder about the capabilities of my PS3 80GB, it has the new 3.50 firmware with 3D support for games and blu-ray
Because the PS3 only has HDMI 1.3 the bandwidth is limited but it still puts out 1080p 3D with limited audio (standard dts).
It would be nice to be able to mess with my PS3 and a scaler to get a 3D picture on my 1292 (s).
What I understand from some simple reviews is that you can play a 3D blu-ray on a 3D tv.
That said I suppose the HDMI signal seems to be compatible for tv's and probably also for a scaler
With an upgraded Moome box I maybe can use shutterglasses.
Otherwise I like to know how a polarised screen with passive glasses will perform regarding to the light output.
In that case I need 2 1292's and a scaler with 2 hdmi outputs to get it done.
Because all of this is already in place here except a compatibel scaler it wouldn't be that hard to make a 3D setup
My Vps 3800 has 2 outputs but I'm affraid there won't be a trick to alter the 2 hdmi outputs ...
André
_________________ I'll be broke
dokworm
| Posted: Wed Oct 27, 2010 12:03 am Post subject: |
This is very impressive, but all sounds pricey and complicated.
I take it this is to be able to have a click and go solution for 3D blurays on CRT? That you just pop your 3DBD in the 3D capable player, plug all this stuff in and turn your glasses on and go?
As far as I can tell, most CRT owners will be stuck at 720P 96Hz at best, with only the few truly high-end CRTs capable of higher resolution and refresh rates.
For that resolution you can purchase a 720P 3D capable digital for about $500, so the solution would have to be pretty cheap to be worthwhile.
Of course if you are running a PC you can watch 3D on your CRT now, there is free software (SSIF-Sucka) available to rip 3DBDs to any other 3D format (side by side, over/under, 2 separate streams etc.) and you can watch them in 3D using Peter Wimmer's Stereoscopic player software right now on your CRT.
Or you could encode them to field interlaced 1080i (1920x540 per eye) and burn them to disc and watch on any BD player, PVR or whatever.
If you want sync extraction for DVI/HDMI that has already been done over at MTBS
http://www.mtbs3d.com/phpBB/viewtopic.php?f=26&t=9790&start=30
and driver circuits for the older style 3D glasses can be made for a few dollars.
So for the PC owners, you can do this now for very little money, it is more hassle than just putting a disc in and pressing play, but you get the same quality end result.
I'm keen on seeing what lumagen and Moome come out with though!
-Dok
| CIR Engineering wrote: | | dochlywd wrote: | So Craig,
Doc |
Yes and no.
Confused yet?
craigr |
dokworm
| Posted: Wed Oct 27, 2010 12:16 am Post subject: |
| speedyandre wrote: | I wonder about the capabilities of my PS3 80GB, it has the new 3.50 firmware with 3D support for games and blu-ray
André |
If you are looking at a passive setup, then a HTPC with dual monitor outputs would probably be your best bet. Peter Wimmer's stereoscopic player (http://www.3dtv.at/Products/Player/Index_en.aspx) will feed the streams to the two projectors and you don't have to worry about glasses drivers, sync extraction or any of that stuff.
You will just need a passive glasses, a silver screen, polarising sheets for the front of each projector and effectively a 'stack' setup for the two projectors, and a HTPC that can drive the pair of them.
A lot of work, but the flight-sim nutters have been doing it for ages, plus you get full 1080P per eye.
dokworm
mhalsan
Joined: 09 Nov 2007 Posts: 146 Location: Astoria, Oregon
| Posted: Wed Oct 27, 2010 2:48 am Post subject: |
| dokworm wrote: | | speedyandre wrote: | I wonder about the capabilities of my PS3 80GB, it has the new 3.50 firmware with 3D support for games and blu-ray
André |
A lot of work, but the flight-sim nutters have been doing it for ages, plus you get full 1080P per eye. |
Polarized 3D on its own is a time-consuming project, but not particularly difficult. Patience is required to get everything well-matched between the two projectors. New problems will arise! Any difference in black and white levels, gamma, color temp, convergence, focus, etc. is HIGHLY visible and distracting. The silver screen itself, having a gain of 2.4, had a noticeable hot spot- I finally found a use for the contrast modulator boards that have been gathering dust for three years. Finally, plan on re-adjusting 2D setup memories; even with the polarizing filters hinged away from the projector, the silver screen performs far, far differently than the white matte I had before.
3D Blu-Ray playback with dual-output support continues to be elusive, due to the DRM on the discs themselves. I'm hesitant to get involved with SlySoft's product; as we speak the government is looking to blacklist such sites (Google "COICA Legislation"). Their software apparently requires continuous updating, which would render the software useless if their site was blocked. I would have liked to believe that the USA would never have considered censorship of the web, but that's another topic.
I did write Lumagen to express support for dual-projector 3D functionality; I think this feature is very low on their list. On Peter Wimmer's site, his FAQ mentions that 3D blu-ray playback is on their list, but with no timetable set. I would suspect that either a hardware or software solution will eventually be available, hopefully sometime next year.
Thanks, Mark
_________________ Sigh. We are getting aggravated (yes, we are....)
dokworm
| Posted: Wed Oct 27, 2010 3:14 am Post subject: |
I've been talking with Peter, and BD support for playback isn't far away.
I don't see a problem with Slysoft, the software only needs updating as new protection mechanisms come to light, even if support stopped tomorrow, it will still decode everything on the market today. That legislation would take an amazing amount of time to get through, and would be difficult to implement. I don't think you would have a problem in the near future, and once you have ripped your disc, the software is not required for playback at all. Plus there are plenty of other decryption solutions outside of Slysoft's offerings, including some free ones.
Anyway, just want to point out that I am watching the latest 3DBD movie releases right now on my CRT projector, in 3D and it works, but I wouldn't spend lots of money to get a turnkey solution, the CRT projectors just aren't up to it I'm afraid.
It is impressive that we can get them to work at all, most of them predate HDTV let alone HD 3D and Bluray, but their lack of brightness and green-phosphor lag and lack of high refresh rates at 1080P make this interesting only from a hobby point of view, a cheap 120Hz DLP actually gives a more enjoyable viewing experience.
I love my CRT projectors, but for 3D, they just don't give the quality that I want.
mhalsan
| Posted: Thu Oct 28, 2010 12:14 am Post subject: |
| dokworm wrote: | I've been talking with Peter, and BD support for playback isn't far away.
I love my CRT projectors, but for 3D, they just don't give the quality that I want. |
So....if I already have Peter Wimmer's payer, all I need is "SSIF Sucka?" I'm not familiar with that- does it take care of everything or do I still need AnyDVD HD? Googling that title doesn't bring up much.....I'm curious now....
Thanks, Mark
