3D... It's working :)
Goto page Previous  1, 2, 3 ... 14, 15, 16, 17, 18  Next
Posted: Wed Apr 27, 2011 12:19 am    Post subject:
atomiccow wrote:
Huge Kudos to Craig for creating an environment where CRT'rs have a place to come make 3D happen.
I have long wanted to do 3D with my CRT projector. But I appreciate the logic in buying an affordable digital
just for that purpose.
This dude is no joke. Smile
I now have 3D working on both my HTPC and as well my PS3 without issue! On my HTPC I'm using Windows 7 Professional/Arcsoft Total Media Theater 5 paired with a Phenom II quad clocked at about 3.8ghz and an ATI 5830 Video card.
Tonight I tried a side by side encode of Avatar 3D and it works flawlessly on the HTPC as well as Blu Ray 3D. Too Cool!
Kudo's to Craig and the kind gentlemen over at Lumagen! Thumbs Up
Posted: Wed Apr 27, 2011 1:27 am    Post subject:
Oh and Avatar 3D KICKS ASS!
Posted: Wed Apr 27, 2011 5:47 pm    Post subject:
Hi Guys,
I was in Yosemite National Park with my family all last week and was totally off the grid... no cell phone, no internet. And then I was busy working on some Titan DP projectors. I am starting to get caught up now with emails and phone calls so I can finally post.
JohnHWman wrote:
Hello to all,
With the great help of Craig (thank-you Sir Wink ) I finally got some time yesterday evening to fire-up 3D display on my G90 (driven with Oppo BDP-93 and Radiance XS (last FW 041011)+CRT 3D dongle+GEN2 IR).
First, as per Craig's recommandations here, I've setuped my own 1280x720p95.9 display mode with a 166.182617MHz pixelclock (~109.33KHz Hsync). I carefully tweaked this mode with H_Porches at lowest values (88/44/108 pixels) and V_Porches as high as possible (100/5/315 lines) to let the green phosphore having time to decrease and reduce ghosting. Like you Alan, I can just get the 16/9 screen filled with Vertical size (coarse and fine) at MAX values (without the G90 boards mod.).
Just keep in mind that the longer you watch the easier it becomes to see ghosting. You can get an eye for it so in IMHO it is best to run as many vertical blanking lines as possible so that you never have the opportunity to actually develop a good eye for seeing ghosting Wink
JohnHWman wrote:
Immediatly, I found that the Radiance failed to detect 3D 'fseq' mode ([AUTO] setting detect the BDP-93 source as SbS 3D mode Confused ). So I forced the 'frame sequential' 3D mode on the XS+ and got the correct image on screen Thumbs Up . I've leaved the glasses delay time to 0.0ms because 3D looks very good with this default setting Shocked
Just so that everyone is clear, the output mode of the Radiance for 3D MUST be set to Fsqe or it will not work reliably or it might not work at all. Do not leave the 3D output mode set to auto or fram-packed. Please be sure to set the 3D mode to frame-sequential.
JohnHWman wrote:
I had to adjust the CRT 3D dongle HDMI bias to remove some sparkles on the displayed 3D image (G90's HDMI cable runs for 7m lenght).
This can always be a problem with HDMI Sad But don't forget, you can use the CRT 3D dongle on either output of the Radiance. You can use it with a video output, with video off, or even with just audio. So either HDMI output on the Radiance will always work to drive the 3D dongle even if it is only for audio.
JohnHWman wrote:
I do have two pairs of 3D Glasses : One SSG2100AB (lithium bat) and one SSG2200AR (Li-ion rechargeable). The GEN2 IR emitter was set in orange led blinking mode (SAMSUNG) and I've got the SSG2100AB glasses working fine but failed to get the SSG2200AR to sync. Alan, did you tried these Samsung glasses and get them working with GEN2 ? I really don't understand why 2200 can't sync as 2100 does : they both share the same IR protocol Evil or Very Mad Maybe the frame rate of 96Hz rather than 120Hz ?
Yeah this is strange. I think the Gen2 is not really all that fantastic unfortunately. When it works fine, but the emitter from 3dflightsim is much better. Buy this one if you don't already have a solution: http://www.3dflightsim.com/product/product_02.htm
The reasons the 3dflightsim emitter is better are as follows in part of an email I sent to Alan earlier today:
After testing your emitter I am very pleased. Your product is much better than the 3DTVCorp emitter because the emission is much cleaner and does not interfere with other IR AV equipment. With the Gen2 I have to be very careful about placement (read nearly impossible situation) of the emitter because my Blu-ray player and other hardware will not respond to remote commands while the Gen2 is running; with your emitter no problems Wink Also, I like the way your LED only comes on when a 3D signal is being emitted by your emitter. It is actually a useful indicator this way. This is unlike the Gen2 because the Gen2 LED is always lit so it only indicates that the Gen2 is getting power.
JohnHWman wrote:
I hadn't enough time last evening to carrefully adjust the G90 convergences in the corners of the image, neither MG focus (I should do this, for sure) but the image already looks very good with strong 3D effect.
[EDIT] Conv. and MG focus adjustments done : image looks superb now !
SWEET!
JohnHWman wrote:
I just found that my 3m wide 16/9 screen looks quite dim through the glasses and been forced to rize the contrast to 80 (versus 70 in 2D mode). I've also noticed that some of the black levels get losted in 3D. I should redo the greyscale 'by eyes', through the glasses, for this 3D mode (is there's a 3D grayscale test pattern blu-ray available ? or should I use radiance test pattern ?).
Yes, you need to completely redo black, white, gamma, grayscale, and everything in between to get 3D looking right. I even have found that running the Radiance with gamma at 0.95 on the G90 can be of some benefit to give some more punch. On a Marquee I would consider dropping the gamma to 0.85 or maybe even 0.80 as Marquee has an even higher gamma tahn the G90.
JohnHWman wrote:
P.S. does the BDP-93 '3D screen size' setup parameter does something on the displayed 3D image ?
As Alan said, this adjusts the Z-axis (dimension coming out of the screen). It is similar to the "3D affect" on a HTPC.
Posted: Wed Apr 27, 2011 5:48 pm    Post subject:
Also thanks to John, Cliff, Mike, atomiccow, and everyone else for their kind remarks and kudos. I really appreciate the kind words so thank you all Smile
Posted: Wed Apr 27, 2011 6:00 pm    Post subject:
During my CRT open house a couple months back one pair of Samsung glasses got sat on and the lenses were crushed. Right before I went to California I opened them up, turned them on, and hooked up the O-Scope to examine the wave forms. I was surprised at what I found!
Here is the right eye wave form:
Here are the left and right eye wave forms on top of each other:
I find it interesting that the lenses go +10volts > zero > -10volts > zero > +10volts > zero > -10volts... I was expecting to see +10volts > zero > +10volts > zero +10volts > zero... I think Samsung must have done this because I suspect that this actually may allow the glasses to be more transparent when they are open at zero volts. I suspect that if the LCD crystals are aligned the same direction with the same voltage polarity on each cycle that they may not go back to clear as quickly each time. I bet that by changing polarity each cycle the lenses can get clearer and respond with less latency.
I also find it surprising that the open and closed period is the same. I thought that the voltage would be sent back to zero earlier than an exact fraction of 1/2 the period.
Anyone else have thoughts after seeing the photos of the scope?
bofr
Posted: Wed Apr 27, 2011 9:49 pm    Post subject:
What exactly are you measuring? If it is the signal directly to the crystal shutter then an AC waveform is perfectly normal.
LCD shutters do not like dc....as in they get destroyed after a while.
The period seems a bit strange though, AC @ 500 hz or so is more normal for shutters.
Voltage on -> they are black, voltage off- transparent (for a fraction of a second).
/bofr
Posted: Thu Apr 28, 2011 11:59 am    Post subject:
Yeah, that is voltage to the crystals and the timing is correct because I am running 96Hz video.
I just don't really know much about LCD shutters so I was surprised by the +/- voltages. With my lack of knowledge in this particular area I was expecting always + or always -. I was surprised, but it makes sense...
Learn something new every day Smile
JohnHWman
TV/Projector: Sony VPH-G90U (one unit for me, four others units repaired and sold)
Posted: Thu Apr 28, 2011 12:52 pm    Post subject:
Hello Craig,
As per your recommandations, I've ordered the new version of the 3D IR Transmitter (A3D_589) from "Ultimate 3D heaven source" :
http://www.ultimate3dheaven.com/3dtrformisa3.html
This one is cheap and I'll see...
I've also tested my SSG2200AR glasses on a 'regular' Samsung 3D LCD TV (120Hz) and they're working nice (you never know with Ebay sellers !). So I assume that this is either the GEN2 IR emiter issue or the 96Hz versus 120Hz issue. Like others, I've also discovered that GEN2 IR emitter action is corrupting all other IR transmission (HT remotes) while playing 3D content (you can't even pause a movie !) So I assume that either the TX power or the IR spectrum of the LEDs used on GEN2 may be too high/large for small HT rooms !
John
Home theater enthusiast for over 20 years !
My dedicated HT room !
Posted: Thu Apr 28, 2011 1:12 pm    Post subject:
JohnHWman wrote:
Hello Craig,
John
I actually have the Gen2 working really well here, but it took a lot of tweaking...
I covered all but three of the IR transmitters with electric tape to cut down on the IR emission level. I placed the Gen2 on the "inside" side of my ceiling support beam, and pointing Gen2 towards the seats and away from my equipment rack and screen. I placed my IR receiver for my theater on the "outside" of my ceiling beam and pointing at the screen.
This is just enough so that I can use the Gen2 without interference with my other hardware. But I don't think this is going to work in many theater installs and it took a lot of trial, error, and planning.
I am curious to see how the tiny emitter you just ordered works out John. Can't wait to hear your results!
bofr
Posted: Thu Apr 28, 2011 2:50 pm    Post subject:
Don't exactly claim to understand it myself Wink
Long and extremely tedious explanation here http://en.wikipedia.org/wiki/Liquid_Crystals
It is not really obvious, if you put on a dc voltage to the shutters they will seem to operate correctly. And when turning off the power they go back to normal.
After a while though they will inevitably get destroyed.
This could take quite some time....I accidentally left a pair of shutters hooked up to straight dc 12 v for at least an hour and they worked fine after..
Simplest driver for standalone shutters is a quad xor and a clock source. Or if you are really lazy, make an xor gate self-oscillate.
Most of the wired glasses used AC@ about 500 hz.
These new ones though...maybe shuttering for the complete interval at the same voltage is ok as long as the voltage is reversed for the next period.
/bofr
Posted: Mon May 02, 2011 11:59 pm    Post subject:
I have been waiting for "Sanctum" to come out and now I see that the pre-order is up and posted on Amazon Smile For those who don't know, this is another James Cameron film and from what I recall reading he used all the same camera equipment that he used on AVATAR. And man, AVATAR sure was eye candy in 3D. I am pre-ordering now by hopping through Curt's web page so that he gets his kickback Wink
Posted: Wed May 11, 2011 11:30 pm    Post subject:
What happened with this? I really want to know because if emitter is better than the 3dtvcorp one I will pursue getting one here for testing. Please let me know!
My emitter finally arrived today after its little holiday with UK customs.
First impressions are very good. It has a very strong signal which means a wide range of effective seating positions. At last I have an emitter that syncs with my Samsung SSG-2100AB glasses.
I tried my old Samsung SSG-1000 glasses but could not get it to sync properly. I tried the 3dtvcorp type N universal glasses and got exactly the same results. In my setup at least it would appear that the Gen2 emitter and type N glasses respond to the old Samsung format. I don't understand how Craig is getting them to work but I'm glad it does so great.
For me the 3DFlightsim Samsung emitter is a far better proposition than the Gen2 one. I wonder how JohnHWMan is getting on with his Gen2 emitter ?
I only got a chance to try BluRay 3D tonight and found that with a delay of -2.1ms and running about 470 lines of vporches I get a completely ghost free image.
This is very encouraging
regards
Alan
Well, I figured out what to look for to determine if an SSG-2100 will work with the GEN2 or not... it's not the suffix of the model number or anything obvious. If you remove the battery cover and take out the battery you will see one of two things silk screened on the PCB to indicate battery polarity. One possibility is that the text "(Minus: -)" will be printed, either that or a large "-" will be printed.
Only the "-" printed glasses will work with the GEN2. If your glasses actually say "minus," they will not work with the GEN2 at all. I discovered this when I started going through an order of 45 random Samsung glasses that I got in today. I was horrified at first to discover that only about 1/3 of the glasses worked... then I realized that ALL the glasses work with the 3DFlightsim emitter!
The 3DFlightsim emitter works with both types of Samsung glasses just fine.
So it seems that 3dtvcorp really has a mess on there hands and that their emitter is only compatible with one of two types of current Samsung glasses. I love how they blamed the Lumagen dongle for this defect straight away when I was quite sure it had nothing to do with Lumagen... and it didn't.
So again, go for the 3DFlightsim IR emitter over the GEN2.
I guess Samsung has at least two manufacturers, or designs, or whatever, because the type of PCB was not related to the model number. In other words, an SSG-2100xx could be either type and it is simply luck of the draw...
JohnHWman
Posted: Thu May 12, 2011 8:06 am    Post subject:
Thanks for pointing this Craig !
I'm still waiting for my new version of the 3D IR Transmitter (A3D_589) from "Ultimate 3D heaven source" : (http://www.ultimate3dheaven.com/3dtrformisa3.html). They said that it has been shipped last week. This should arrive soon now.
Today I have one pair of SSG2100AB (working with GEN2), three pairs of SSG2200AR (non working with GEN2) and one pair of 3D Heaven Ultra-Clear HD Wireless 3-D Glasses that is comming with the new tiny IR emitter.
I hope the new IR emitter will solve all my issues with the glasses...
John
Posted: Thu May 12, 2011 10:05 am    Post subject:
John
Hey,
Could you check your non-working Samsung glasses and see if they correlate to the non-working ones I have discovered - and minus?
I am curious about your new emitter as well. It only seems to have two IR transmitters so I am not sure how the range will be, but if strategically placed, you will probably do well Wink I am also curious about those ultra clear glasses... let me know if you think they have identical lenses to the Samsung glasses. I think almost all the newest gen glasses are using the same generic lens...
Posted: Thu May 12, 2011 2:03 pm    Post subject:
Well here is a strange twist... out of the 30+ pair of Samsung glasses I just got in, one of the pair labeled "(Minus: -)" actully does work with the GEN2, but the other 30+ pair do not. All of the pair labeled with just "-" work with the GEN2.
So I guess some of the "(Minus: -)" pair may work with the GEN2, but what I have here is less than 1/30.
JohnHWman
Posted: Thu May 12, 2011 6:20 pm    Post subject:
Craig, I've checked my own pair of SSG2100AB battery inner PCB and it is written a large "-". This one is working with the GEN2.
John
JohnHWman
Posted: Sat May 14, 2011 2:08 pm    Post subject:
Well,
I finally received my new version of the 3D IR Transmitter (A3D_589) from "Ultimate 3D heaven source" : (http://www.ultimate3dheaven.com/3dtrformisa3.html) with one pair of 3D Heaven Ultra-Clear HD Wireless 3-D Glasses.
The small A3D_589 IR transmitter is working really nice with Samsung glasses ! I just had to revert the 3D polarity from "+" with gen2 to "-" in Lumagen menu with this A3D_589. There is no IR power issue versus GEN2 : its two IR leds are providing enough IR for direct vision with glasses. Even reflecting those two IR leds to the display screen is still providing enough IR to the audience seated at 5m distance from the screen !
The pair of 3D Heaven Ultra-Clear HD Wireless 3-D Glasses is working also nice at 1280x720p96. However, I've think that these Samsung SSG2100AB copy is slightly slower than original because I've noticed that they exhibit some yellowish lines at the top of the 3D image that SSG2100 do not show. I tried to change the 3D signal delay on the lumagen without improvement.
I tested my three pairs of SSG2200AR (non working with GEN2) and they still don't work at all with A3D_589 IR emiter. I'm suspecting that they only work at 120Hz, not at 96...
You can go for the A3D_589 IR transmitter : it's a cheap but effective solution to work with Samsung glasses !!
John
PS : Craig, maybe the "MINUS" written SSG2100AB battery compartiment PCB may be unable to work at 96Hz (but work at 120Hz) while "-" version does Wink
Posted: Sat May 14, 2011 5:10 pm    Post subject:
Guys
I expect that P43 green phosphor will become a requirement at 120hz refresh and continue to be helpful at 96hz based on my experience with stereo back twelve to fifteen years ago, or the prospect of lag problems will be an issue.
JohnHWman
Posted: Sat May 14, 2011 6:03 pm    Post subject:
I agree Tim,
P43 fast green phosphor with proper C element filter is my next step for 3D. However, 120Hz full HD 3D would also require to improve the G90 VBW to 180MHz or more.
John
Posted: Sat May 14, 2011 6:28 pm    Post subject:
Yeah but doesn't the P43 put out less light output?
Page 15 of 18
