3D... It's working :)
Goto page Previous  1, 2, 3 ... 5, 6, 7 ... 16, 17, 18  Next
dokworm
Posted: Thu Oct 28, 2010 2:40 am    Post subject:
mhalsan wrote:
dokworm wrote:
I've been talking with Peter, and BD support for playback isn't far away.
I don't see a problem with Slysoft, the software only needs updating as new protection mechanisms come to light, even if support stopped tomorrow, it will still decode everything on the market today. That legislation would take an amazing amount of time to get through, and would be difficult to implement. I don't think you would have a problem in the near future, and once you have ripped your disc, the software is not required for playback at all. Plus there are plenty of other decryption solutions outside of Slysoft's offerings, including some free ones.
Anyway, just want to point out that I am watching the latest 3DBD movie releases right now on my CRT projector, in 3D and it works, but I wouldn't spend lots of money to get a turnkey solution, the CRT projectors just aren't up to it I'm afraid.
It is impressive that we can get them to work at all, most of them predate HDTV let alone HD 3D and Bluray, but their lack of brightness and green-phosphor lag and lack of high refresh rates at 1080P make this interesting only from a hobby point of view, a cheap 120Hz DLP actually gives a more enjoyable viewing experience.
I love my CRT projectors, but for 3D, they just don't give the quality that I want.
So....if I already have Peter Wimmer's payer, all I need is "SSIF Sucka?" I'm not familiar with that- does it take care of everything or do I still need AnyDVD HD? Googling that title doesn't bring up much.....I'm curious now....
Thanks, Mark
You will need SSIF sucka, (http://gl.tter.org/SSIFsucka/SSIFsucka_Beta2.7z) and if you don't have AnyDVD then use DVD Passkey (free whilst it is in beta)
http://www.dvdfab.com/passkey.htm
Then rip your 3DBD to the 3D format of choice and play back the resultant movie with Peter Wimmer's player, plug in yr glasses and you are good to go!
Posted: Fri Oct 29, 2010 1:03 am    Post subject:
What projector do you own?
Posted: Fri Oct 29, 2010 1:06 am    Post subject:
dokworm wrote:
A direct link to the DVI sync extraction circuit:
http://www.mtbs3d.com/gallery/displayimage.php?pos=-3651
That is a cool extractor. I wish I had seen that a month ago Smile
Posted: Fri Oct 29, 2010 1:18 am    Post subject:
dokworm wrote:
This is very impressive, but all sounds pricey and complicated.
I take it this is to be able to have a click and go solution for 3D blurays on CRT? That you just pop your 3DBD in the 3D capable player, plug all this stuff in and turn your glasses on and go?
The Lumagen aspect of this conversation, yes.
dokworm wrote:
As far as I can tell, most CRT owners will be stuck at 720P 96Hz at best, with only the few truly high-end CRTs capable of higher resolution and refresh rates.
Well, any projector that can run 1080p 60Hz should also be able to run 720p at 120Hz or 1080i at 120Hz. The Lumagne plus models will also be able to support 144Hz to avoid 3:2 pulldown issues. There is also going to be an 800x1920p option as well for 2.35 3D bluray.
dokworm wrote:
For that resolution you can purchase a 720P 3D capable digital for about $500, so the solution would have to be pretty cheap to be worthwhile.
All right, if you think so.
dokworm wrote:
Of course if you are running a PC you can watch 3D on your CRT now, there is free software (SSIF-Sucka) available to rip 3DBDs to any other 3D format (side by side, over/under, 2 separate streams etc.) and you can watch them in 3D using Peter Wimmer's Stereoscopic player software right now on your CRT.
I have looked at this and promise you that it does not look nearly as good as 3D bluray running on the Radiance. Wimmer's Stereoscopic player shows a ton of ghosting on my G90 that I don't get at all while running the Lumagen for 3D BD. I was surprised with how much better an actual BD player looks through the Radiance. I get no ghosting at all with the Lumagen.
dokworm wrote:
So for the PC owners, you can do this now for very little money, it is more hassle than just putting a disc in and pressing play, but you get the same quality end result.
I highly disagree with the quality at this point, but PC will get there. Timing and parallax (lack of screen size parameter) seem to be issues with PC at this point for BD playback. I did have a lot of fun playing with 3D videos on the computer for a while before the Luamgen project though.
Posted: Fri Oct 29, 2010 4:14 am    Post subject:
Hey Craig, wanna do some 3D on fresh tubes here before Cedia Indy? Mr. Green
If so, we'll take it to PM.
Cliff
dokworm
Posted: Sat Oct 30, 2010 2:06 am    Post subject:
I don't see how the radiance would be markedly better, I get about the same ghosting you get on samsung TVs. The tech is pretty basic, and I've been doing 3D on CRTs since the mid 90s, if you are getting a ton of ghosting, then either your glasses or your sync might have an issue.
I'm running an XGLC projector, not as nice a a G90, but the brightness on any CRT just isn't there to make the quality worth it IMHO. The DLP 3D projector I have is 2200 lumens, and it suffers in 3D because of brightness.
All shutter glasses cut an incredible amount of light, due to both the fact that they are not completely clear and that they are black for more than 50% of the time per eye. On my measurements, if you are getting 46lux off the screen, then with the Nvidia glasses (when they are clear) you get 40 lux through, but when they are active, you get only 12lux per eye, that is a massive drop in brightness, nearly 80% light loss. Activate your glasses in a lit room and look around and you will see just how much light they lose. CRTs are not that bright to start with, not many of us would be happy running at 20-30% brightness.
I'm not trying to pee on anyone's parade, I'm as keen to get 3D happening on CRTs as anyone, and if I had the cash, the lumagen solution sounds great. But I do think people need to look at the price/performance ratio, and understand that the image for all but the highest end CRTs will not be in 1080P resolution, and/or will be a bit flickery and will have some ghosting (it is unavoidable unless you have a fast green tube) If your existing CRT projector can only manage 720P @ 120Hz, then the lumagen solution would need to be a lot cheaper than a 720P 3D capable digital that will be many many times brighter.
But for the hobbyist, you can overlook a lot of the shortcomings as you can perhaps enjoy 3D on the cheap, and have the fun of tinkering with it, but it certainly (personally) would not be something I'd spend big bucks on, as the quality (for me) just isn't close to being there because of the brightness issue and the reduced resolution from the 1080P 3DBD.
It would be cool if people could test their projectors so we know which CRT models can do 144Hz and at what resolutions, as that is really the ideal refresh rate for most 3D Movies.
I'd also be keen to see how much light transmission the lumagen achieves per eye, I've tried every strobe sequence I can think of with the glasses, and would be keen to see if they are getting better light transmission than we are.
I find it very exciting that we can get some form of 3D on our existing rigs, however it is achieved.
speedyandre
Posted: Sat Oct 30, 2010 9:57 am    Post subject:
dokworm wrote:
If you are looking at a passive setup, then a HTPC with dual monitor outputs would probably be your best bet. Peter Wimmer's stereoscopic player (http://www.3dtv.at/Products/Player/Index_en.aspx) will feed the streams to the two projectors and you don't have to worry about glasses drivers, sync extraction or any of that stuff.
You will just need a passive glasses, a silver screen, polarising sheets for the front of each projector and effectively a 'stack' setup for the two projectors, and a HTPC that can drive the pair of them.
A lot of work, but the flight-sim nutters have been doing it for ages, plus you get full 1080P per eye.
Is a silver screen the only option?
I like to view both bd and 3D sources on the same screen and making a stack would be an advantage over using a single crt.
What effect do the polarised sheets have concerning the light output?
André
I'll be broke
dokworm
Posted: Sat Oct 30, 2010 1:18 pm    Post subject:
A silver screen is the only option if you want to use two projectors and passive glasses, as it is a method that uses polarised light, and normal screens mess up the polarisation and therefore destroy the 3D effect. You can use certain silver paint, certain silver fabric (monroe) or pay for a commercial silver screen.
In My experience the polarised systems don't block the light as much as the shutter glasses do, and you have two projectors pumping out light instead of one.
The hassle is, well, almost the same as doing a stack. You have two projectors to keep aligned and calibrated and the screen can hotspot.
mhalsan
Posted: Sun Oct 31, 2010 7:48 pm    Post subject:
What dokworm said above is right. There's a lot more to set up, adjust and tinker with- but if I didn't enjoy that I'd have gone digital to begin with. Polarized filters and glasses do reduce light, but this is still a LOT brighter than the Nvidia 3DVision setup (with a single 9500) I played with last February.
It looks like 3D Blu-ray is going to require a software solution. There are several products on the web that can do this. My preference would be a single product (like Peter's player) that handles the whole thing. There are only a couple 3DBD titles out right now, at astronomical prices, so I can wait..........
Thanks, Mark
Sigh. We are getting aggravated (yes, we are....)
dokworm
Posted: Sun Oct 31, 2010 11:18 pm    Post subject:
Absolutely, the polarised setup is way, way brighter, and is great as you can then afford as many glasses as you want, and there is no problem if kids wreck a pair. Polarising material big enough to sit in front of the CRTs can be tricky to find, (I always wondered if you could steal the film out of broken LCD monitors as a cheap alternative, but haven't tried it), but if you can get it right, it is pretty cool.
An awesome side affect for gamers is you can play two games on the same screen! Each player only sees their game in progress, which is fun for a night of 2 player HALO or Gran-turismo etc. if your friends bring a console over, you link them up and hook each console to its own projector. You make some glasses that just have 2 left eye lenses and some that have two right-eye lenses and it is great fun.
You could also show two movies at once if you had headphones I guess, it isn't really all that practical, but it is funny to swap glasses and see a different movie running.
BTW, a new beta of SSIFSucka is up for testing.
http://gl.tter.org/SSIFsucka/SSIFsucka_Beta3.exe
prover
Posted: Wed Nov 03, 2010 11:18 am    Post subject:
Polarizing materials are easy to get meanwhile. Newly I have seen in an internet shop
a polarizing foil (63cmx90cm) big enough even for a CRT under 200$.
http://www.bluray-disc.de/blulife/heimkino/prover
View user's photo album (19 photos)
Posted: Thu Nov 04, 2010 12:35 am    Post subject:
Hi guys,
Moome is now taking pre-orders for him HDMI 1.4 3D box. For complete details and manual, see: http://www.curtpalme.com/EXT-FULLHD.shtm
He's offering $50 off for pre-orders too!
nemmi69
Posted: Fri Dec 17, 2010 9:32 pm    Post subject:
Hi guys,
What has happened to the link? is this product still coming out?
What doesn't kill you is only biding it's time
bofr
Posted: Mon Dec 20, 2010 3:02 am    Post subject:
After spending a fruitful? weekend I too have now managed to get 3d on my crt.
Dug out a pair of old (ca -95) shutterglasses that came with a controller for the parallel port.
Knocked up a very quick interface so that the old controller now can be operated by vsync.
(Flip-flop and some resistors and you can do it in 10 min, I did not find a flip-flop so i made the converter
using a microcontroller instead...At least this way i can adjust timings in software)
It works quite well.
Compared to my normal crt-monitor there is more ghosting on green, the rest is pretty much the same.
Still...not any worse than what I've seen in electronics stores on lcd screens...
The amount of light coming trough the glasses are more than halved...probably less than 25%.
Meaning having to keep the room completely dark and crank the contrast up to 80..(but at this point..so what)
But it works...o man does it work!
Quality-wise i had to drop the resolution a "bit" to get up to the required refresh-rates right now I am running
100 hz 1256x706 but tomorrow i will give 120 hz 1048x589 a try since i think 50hz/eye is likely to result in a headache
after a few hours (BD 808s, only goes up to 75khz).
Luckily, the loss of resolution is somewhat compensated for by the fact that two slightly offset images are displayed so that
the brain takes in a lot more information.
Meaning things seem a lot sharper than they have a right to.
I've set it up so that the 3d-player automatically switches to the proper resolution and refresh when I play 3d-content in fullscreen.
That way normal movies aren't impacted.
Since this project has cost me nothing but some free time (that i probably would have wasted anyway) I have to say it's worthwhile.
If I had to shell out hard cash to do this I wouldn't. Not this way at least.
I think passive 3d is the way forward. Two inexpensive projectors, polarized screen and cheap glasses...
Getting light, quality and high refresh in an active setup seems very expensive at this point.
A small HMD-setup might be worth a try but that means only one person can watch it at a time..plus they are heavy and uncomfortable.
/bofr
Posted: Mon Dec 20, 2010 4:36 am    Post subject:
/bofr
Oh boy oh boy am I getting EXCITED! Smile
nemmi69
Posted: Wed Jan 19, 2011 10:02 pm    Post subject:
What is the best 3D glasses at a reasonable price? Whats the best way to get the glasses to work with the set up?
I have a Sony G70 and Moome ext-fullhd v3
bofr
Posted: Thu Jan 20, 2011 3:10 pm    Post subject:
Just a hint..
while the specifications for your projector might say one thing, the reality might be something different..
My BD808s has a max sync at either 69khz or 75 khz depending on who you believe. Apparently there is enough leeway
in this to allow 1280x720@100hz which works out to about 76kHz.
Your mileage might vary, experiment on your own risk etc...
/bofr
prover
Posted: Thu Jan 20, 2011 4:11 pm    Post subject:
I would recommend to use the Gen2-emitter with X- or U-Type glasses from www.3dmagic.com. They aren't so pricy and they are going to work out of the box with EXT V3. These glasses and emitter will work both with HTPC and PS3. I use at the moment the nvidia 3d vision kit. I can't recommend it because it doesn't work out of the box, especially over HDMI I had to try a lot and do some DIY stuff (like VESA plug...). Although the result is awesome it works only together with a HTPC.
dvh99
Posted: Thu Jan 20, 2011 4:33 pm    Post subject:
whats all this fuss with shutter glasses, i prefer the polarised any day.
KrisRoberts
Posted: Thu Jan 20, 2011 6:53 pm    Post subject:
I agree, and of the 3D displays I saw at CES the LG CF3D LCoS 1080p projector with passive glasses was easily the best.
For me the biggest obstacle for a passive system in my theater is the requirement of a silver screen to retain the polarization. With a CRT that would also probably result in severe hot spotting. But so far I've been using digitals for 3D anyway.
Passive flat panel displays typically only show half the resolution to each eye. Passive projection systems require a silver screen and either a single projector capable of oscillating its polarization each frame or two projectors stacked (not easy to align perfectly).
Active shutter glasses are attractive because its pretty easy to do 100-120hz these days and you can show a full resolution image to each eye.
I recently bit the bullet for the Moome EXT V3 and got the Gen2 emitter from these guys which should be compatible with the nVidia 3D-Vision glasses I already have (as well as supporting lots of other glasses):
http://www.3dmagic.com/catalog/Gen2hometransmitter.html
The neatest universal glasses I've seen are the Volfoni ACTIVEYES. They put the IR receiver, battery and other electronics in a little dongle you clip to your shirt and that allows the glasses themselves to be as light and comfortable as passive ones:
http://volfoni.com/article.php3?id_article=238
Page 6 of 18
