What's with Marquee HVPS's ? Can they be fixed ??
Goto page Previous  1, 2, 3
Posted: Fri Aug 27, 2010 9:20 pm    Post subject:
Scott, you've been posting a lot this week so far....are you on vacation?
Smile
As Scott's agent, he was looking forward to taking the week off and traveling to see a Longbow blend. Unfortunately, he couldn't afford a plane ticket nor did he have a place to stay. Also, the availability of Greek food was somewhat limited.
Mr. Green Mr. Green Mr. Green Mr. Green
Posted: Sat Aug 28, 2010 12:24 am    Post subject:
Smile
Thumbs Up
tse
Posted: Sat Aug 28, 2010 12:45 am    Post subject:
Smile
No vacation until it cools off some. I hate this heat. My main computer is down with a virus I got while cruising the P2P sites downloading movies to watch on my fine Ampro (actually VDC) 3600. I'm getting it fixed this weekend so maybe not so much posting afterwards.
Scott
Thomas Jefferson
Posted: Sat Aug 28, 2010 12:50 am    Post subject:
Hey BTW, stop bitching about CRTs. Try fixing a ^&$%^&$* plasma. Got THREE 'Legend' 42" that are eating chips. $60 down the drain with the flash of the fuse. ;(
'Legend' has it that these damn things actually worked long ago. Made by Samsung. Pieces of &*%^*$^&#%&R*(&%(&^$^%#&^!!!!!!!!!
dvh99
Posted: Sat Aug 28, 2010 12:52 am    Post subject:
much safer to download from newsgroups and much faster too.
you are not dependent on seeders either which is a big plus because you will always get a complete movie and not one that is missing a few bytes.
Posted: Sat Aug 28, 2010 1:48 am    Post subject:
Viruses - the reason I use Ubuntu.
Elaine Benes
Posted: Sat Aug 28, 2010 12:20 pm    Post subject:
Thumbs Up Thumbs Up
And with well over 700 days retention, there are over 2 years worth of HD movies posted to choose from, thousands of movies and tv shows, all in HD, of course...
Check out the remake of Sherlock Holmes from GB if you get chance...
dvh99
Posted: Sat Aug 28, 2010 1:10 pm    Post subject:
mail me the nzb if you have it.
saw the entire dexter series in 1280*720 though but i had it in 1 day.
looks hot over there indeed Smile, temp here is about 15-16 degrees i like it to be 19-20.
Elaine Benes
Posted: Sat Aug 28, 2010 1:30 pm    Post subject:
Which nzb are you after ? (edit: DOH ! reread your post, PM'd you the nzb's)
If you use newsgroups, I'm sure you must know about the nzb indexing sites like nzb matrix. I use that one now, I used to use Merlins Portal till it disappeared. I also use binsearch if I need to. I get the heads up on HD material from abhdtv.net , then just use binsearch to find all the parts, very easy...
dvh99
Posted: Sat Aug 28, 2010 7:32 pm    Post subject:
i use the dutch forums mainly or just binsearch.
we have d4d.cc and twilightnzb, lots of hd content to be found and with subs.
i like the mkv files, great quality and max 15gig.
sabnzb is the program i use, its free and has a built in quickpar.
Elaine Benes
Posted: Mon Aug 30, 2010 11:32 pm    Post subject:
So I took my VIM to a local guy, an old Chinese guy, VERY good tech, but virtually impossible to get him to actually DO anything. He refused to do any of the updates or resolder anything, just cleaned the corrosion from that U35 chip, told me "that will fix it". Low and behold, it appears as if he's right. I haven't had time to run it for more than 10 minutes or so, but in that amount of time, there were no symptoms...
I'm buying a spare VIM anyway, there's one cheap, so I might as well...
Thanks very much to everyone who tried to help nail this down, I think we might have saved another projector from being parted out...(not that I know what I'll DO with it now...my collection is starting to build up again...).
Sparky015
Posted: Mon Aug 30, 2010 11:58 pm    Post subject:
Awesome! If you don't see any symptoms, then you don't need the tech bulletins. Enjoy that VIM. You just need a set of Scott's new high bandwidth neck boards and your in business!
~Paul
Posted: Tue Aug 31, 2010 12:01 am    Post subject:
Paul, i'd get the leaky bellows fixed first.
Shameless plug Wink
But Honestly if that glycol leak gets worse then you might as well dump that marquee now or sell it to someone who's willing to spend the money to fix her right.
Wink
Sparky015
Posted: Tue Aug 31, 2010 12:13 am    Post subject:
Wow! A plug and a between-the-lines proposal to buy all in one post! Laughing
~Paul
Elaine Benes
Posted: Tue Aug 31, 2010 1:27 am    Post subject:
The leak is at the top of the red*(colored) C element, between the C element and the ring that holds it in. Being the cheap ass I am, I'm going to try draining, disassembling and refilling first. See if I can simply re-seat the current bellows and get it to seal. I installed the green and red c elements myself originally, the green sealed perfectly, the red had the tiny leak in the top. Its small enough that it took over a year to notice it.
Page 3 of 3
