| Posted: Thu Aug 19, 2010 2:07 pm Post subject: Subwoofer freq response |
I've been working on calibrating my audio system, with the help of a Radio shack digital SPL meter, RoomEQ, and a soundcard oscilloscope thing.
I've got six subs, most completely different from each other, behind my couch. So what I've been trying to do is set each one to its maximum clean volume with the amp driving it (they're all driven separately). To do that, I've been using the o-scope with a sine wave output at a few different frequencies, and finding the level where I don't get any visible distortion from 30hz up to about 100.
Thing is, I'm seeing that even at 30hz, it's very hard to get much clean sound out of them; at 25, forget about it. Even the 12" Pioneers driven with a pretty beefy sub amp start to fall over anywhere under 30.
So, the questions:
1) Where's the majority of power used in theater LFE channels? Do they use a ton of 20-30hz stuff, or do they roll it off?
2) Does the LFE channel roll off above 80hz as mixed, since that's the expected roll off of the audio system? Or are there 150hz components of the LFE that ought to get rolled off by the audio system? These subs can hold cleanly up to 200hz...
3) What's reference SPL for the LFE channel? For that matter, what's reference for the fronts/center/surrounds? I can't find this information ANYWHERE; the best I can do is to find that 'your DTS decoder should be set to 7' ( ) and information about the X-Curve (see next question)
4) The X-Curve... it specified LFE roll-off at the low end, and some roll-off at the high end; supposedly this is why home theaters sound 'too bright' - because they don't tend to use the x-curve high end roll-off. So does this mean the mix might specify a 25hz sine wave (or whatever) at 70db, but they really WANT it to be 65 because at 25hz (random example) the x-curve says there's a 5db roll-off?
Oy vay! These specs are all stacked six ways from sunday... THX roll-offs, mix volume, an x-curve added on to that, expected room responses, whether the blurays are mixed with the x-curve 'burned' in (all I can find is 'no... maybe'). Aaaahhhh!
| Posted: Thu Aug 19, 2010 2:16 pm Post subject: |
I think your first problem is 6 different subs. A couple could be out of phase with each other, and you've ended up with a wall of mud. Get one or two matched ones, get rid of the rest.
| Posted: Thu Aug 19, 2010 2:59 pm Post subject: |
| Curt Palme wrote: | | I think your first problem is 6 different subs. A couple could be out of phase with each other, and you've ended up with a wall of mud. Get one or two matched ones, get rid of the rest. |
I don't think that's it. First off, this testing was with one sub at a time. So obviously it's not phase that's hurting the roll-off.
Second, with all of them running, subjectively they're absolutely MASSIVE. The 'going to warp' thumps in the new Star Trek feel like someone's hitting the back of the couch with a baseball bat. I'm going to do a test with the o-scope over lunch to see for sure, though.
At this point, my big thing is to try to find out WTF reference levels really are, and how stuff should be set up. If most material is 30-80hz anyway, then I should be golden. But if there's a lot from 20 to 30, then my setup will be missing some stuff as it stands.
Getting two 'better' subs is out of the question; I haven't got the money. I couldn't sell the ones I've got for much as they're all hacked together from bits and pieces - one of them is the sub part of a massive Logitech 5.1 speaker system, but it's the European version using a transformer I made myself, and is beaten up because it was in a mockup F1 chassis that came from Turkey. Not really gonna get much for that on Craigslist, even though it sounds just as good as a new one...
| Posted: Thu Aug 19, 2010 3:00 pm Post subject: |
I agree with Curt. Six completely different subs is going to be really difficult to try to make work right together. Unless you've got a really high-performance mains setup, 2-3 subs should be adequate for matching SPL to the rest of the system. This is definitely one of those cases where more isn't necessarily better. Try just turning 3 of the subs off and working with the best 3 and see if you don't end up with something that sounds just as good or better than all 6.
As for extension, yes - there are plenty of movies with content way below 30hz. Some action movies have effects in the LFE channel at 10-15hz, and a few even below that. Check out this really cool AVS thread, Perisoft... They have waterfall frequency plots in lots of cool movies with awesome LFE:
http://www.avsforum.com/avs-vb/showthread.php?t=755493
The problem is subs aren't like horsepower, in that no matter how many subs you have, if all the subs' have no- or unusable output below 30hz, the entire system won't have any usable output below 30hz.
However, subs are like horsepower in that it doesn't cost much to do something mild/average, but it does cost some bucks to get high performance. The practical reality is that any old 15 year old 12" sub is good to the low-30hz ballpark. But, to get good, usable, in-room extension to <15hz at nice SPL's is going to cost $300-500 even if you DIY, and no 15-year old sub is going to get you there.
| Posted: Thu Aug 19, 2010 3:01 pm Post subject: |
Hey, want another subwoofer? I've got this 220 volt powered Sony speaker that you can have..
| Posted: Thu Aug 19, 2010 3:03 pm Post subject: |
A bunch of this will be the room as well. Trying to get anything below say 40-50Hz an a typical HT room simply isn't going to happen. Why not get some Aura bass shakers from Parts Express? Cheap, and you'll get plenty of punch.
| Posted: Thu Aug 19, 2010 3:07 pm Post subject: |
| Curt Palme wrote: | | Trying to get anything below say 40-50Hz an a typical HT room simply isn't going to happen. |
Sorry, but this is a common misconception, Curt. With a really good sub, 10-15hz at >100db is easily attained. It's all about the money.
| Posted: Thu Aug 19, 2010 3:30 pm Post subject: |
| Curt Palme wrote: | | A bunch of this will be the room as well. Trying to get anything below say 40-50Hz an a typical HT room simply isn't going to happen. Why not get some Aura bass shakers from Parts Express? Cheap, and you'll get plenty of punch. |
The speakers are pushed against the back of the couch. Trust me, a bass shaker would be irrelevant. Like I said, the warp-thumps in Star Trek *literally* feel like you got punched in the back. 30hz sine waves fill the room like those shimmering heat waves you see over pavement.
The power is there, I just want to calibrate it correctly, and I want to find out whether roll-offs under 30hz are normal, and whether the content demands power under 30hz and at what db level.
It should also be noted that I can make stuff LOUD at 25hz, it's just not *clean*. Sine waves start to turn into triangle waves, or get some resonances in them.
I need to see what I get on the o-scope with all the speakers going.
How big is the Sony speaker? I've got more transformers where the first one came from...
| Posted: Thu Aug 19, 2010 3:31 pm Post subject: |
I posted a link to the unit in the buy.sell section...
| Posted: Thu Aug 19, 2010 3:40 pm Post subject: |
| Curt Palme wrote: | | I posted a link to the unit in the buy.sell section... |
*looks*
Probably not worth the shipping. If it was some monstrous thing, that'd be different...
I'm gonna go see if I'm getting interference with multiple subs running.
| Posted: Thu Aug 19, 2010 5:35 pm Post subject: |
OK, I did have a miswire on one of the subs that was doing some phase canceling. After fixing that and adding my final sub, which went in the corner rather than behind the couch...
Maximum output *while retaining clean output on each sub*. This was checked with the scope individually.
That's full scale, with correctly calibrated radio shack meter. So, that doesn't seem so bad. The question is, what's it SUPPOSED to be... Unfortunately I don't have EQ detailed enough to distinguish 50 from 40 from 30hz, which is really what I need.
| Posted: Fri Aug 20, 2010 3:56 am Post subject: |
That chart says you're down about 25dB at 10Hz -- but 15dB at **2** Hz!? Or is that greeen line the phase, not the SPL? The chart says it's both but there's only one line so I'm guessing it's phase.
greg_mitch
| ecrabb wrote: | | Curt Palme wrote: | | Trying to get anything below say 40-50Hz an a typical HT room simply isn't going to happen. |
SC |
If you want to build it yourself...it doesn't even cost that much...
Look at the sonotube subs...
| Posted: Fri Aug 20, 2010 4:17 am Post subject: |
| greg_mitch wrote: | If you want to build it yourself...it doesn't even cost that much...
Look at the sonotube subs... |
Yeah, but even a Sonotube (which can be an awesome value) still takes some money to make happen. Call it somewhere around $500 unless you happen to have a big amplifier just laying around, in which case it's probably more like $250-300. I was just pointing that out because Perisoft seems to be in the situation of not wanting to spend anything at all, which means even $250 is $250 too much.
But, yeah - DIY is definitely awesome. I'm pretty sure I'm going that route - just have to decide what I want to do. Waiting until it's nice and cool to work outside in the garage before I do anything at all.
1031
| Posted: Fri Aug 20, 2010 11:35 am Post subject: |
| perisoft wrote: | | Curt Palme wrote: | | A bunch of this will be the room as well. Trying to get anything below say 40-50Hz an a typical HT room simply isn't going to happen. Why not get some Aura bass shakers from Parts Express? Cheap, and you'll get plenty of punch. |
I need to see what I get on the o-scope with all the speakers going. |
Sounds that you got nasty standing wave or similar room related problems..
Has any there (that side of sea) tested this yet http://www.dspeaker.com/en/home.shtml
Here it has been wery succesfull "toy" to get subīs sound better.
_________________ Marquee 9500LC (Frankenyokes / Thomas electric tubes / HD-10L / +many modīs)
DVDO VP-50
New hobby, Rally
| Posted: Fri Aug 20, 2010 1:46 pm Post subject: |
Sounds like a too-good-to-be-true magic pill for perfect bass! I wouldn't believe claims like that ordinarily, but I assume The Absolute Sound wouldn't gush like that if it isn't true. Hmm, I'd been thinking of building a new sub, maybe this is a better idea...
Yow!! That is some serious hard-core snow driving!!
1031
| Posted: Fri Aug 20, 2010 2:00 pm Post subject: |
| garyfritz wrote: |
Sounds like a too-good-to-be-true magic pill for perfect bass! I wouldn't believe claims like that ordinarily, but I assume The Absolute Sound wouldn't gush like that if it isn't true. Hmm, I'd been thinking of building a new sub, maybe this is a better idea... |
That really depends.. if room is "good" then that does not much, but mostly room has serios modes and then that is helpfull.
I havent tested that yet, but i have heard how much that made difference (once i visited my frends ht.)
Yow!! That is some serious hard-core snow driving!![/quote]
Yep. iīm gonna sit to co-drivers seat at next month ( i hope that there are no skidd marks on my pants after that rally
DVDO VP-50
New hobby, Rally
greg_mitch
| Posted: Fri Aug 20, 2010 2:49 pm Post subject: |
| 1031 wrote: | | perisoft wrote: | | Curt Palme wrote: | | A bunch of this will be the room as well. Trying to get anything below say 40-50Hz an a typical HT room simply isn't going to happen. Why not get some Aura bass shakers from Parts Express? Cheap, and you'll get plenty of punch. |
Here it has been wery succesfull "toy" to get subīs sound better. |
The Anti-mode got quite a bit of buzz over at AVS when it came out...I kind of dropped from that discussion so I don't know how it was received by that community.
I think the key is having a terrible room and it will work wonders. For people with even adequately treated rooms the difference won't be that noticeable...but that isn't really a feature of the Anti-mode device...just a characteristic of squeezing the last bit out of a good room really.
greg_mitch
| Posted: Fri Aug 20, 2010 3:04 pm Post subject: |
| perisoft wrote: | OK, I did have a miswire on one of the subs that was doing some phase canceling. After fixing that and adding my final sub, which went in the corner rather than behind the couch...
That's full scale, with correctly calibrated radio shack meter. So, that doesn't seem so bad. The question is, what's it SUPPOSED to be... Unfortunately I don't have EQ detailed enough to distinguish 50 from 40 from 30hz, which is really what I need. |
Here is a "good" curve...
You are probably pretty close if you would plot the graph on typical subwoofer parameters.
| Posted: Fri Aug 20, 2010 5:11 pm Post subject: |
| ecrabb wrote: | | greg_mitch wrote: | If you want to build it yourself...it doesn't even cost that much...
SC |
Put it this way: My whole HT is less than $1k. I've got a son in a good daycare, a busted washing machine, school taxes, and a business fighting through a weak euro and the remnants of the great recession. Spending a couple hundred on a sub just ain't gonna happen. It'd be one thing if I had nothing right now, but to flatten my frequency response by a few db, it'd be an awful investment at this point.
Plus, trying to do this stuff for next-to-nothing is a fun intellectual challenge. If I'd just put ten grand into buying a nice HT, I'd have something 20% better but wouldn't know anywhere near as much as I know now.
