JustGreg
| Posted: Fri Jul 16, 2010 9:21 am Post subject: Can one bad magnet ruin it for everyone? |
Sorry...sad play on words but I worked a long shift.
I'm still battling compressed image ouput across all three tubes on the left sides. I've changed out EVERYTHING except the backplane, motherboard, and magnetics.
I won't resurrect the original thread but for those just tuning in, the internal grid pattern on my Marquee 8500 is compressed slightly on the left side of the tube faces (looking at them with lenses removed). It isn't much and can be adjusted out but I'd rather not.
Looking at the grid on the screen the left side dips up at the bottom left and down at the top left beginning from about 2/3's of the way across from right to left. Not a lot as I said, but enough to trip my OCD trigger.
It looks like what you'd see if you held a playing card flat on to your sight about a foot away and then rotating the left side away, while maintaining a vertical center pivot. I had a Sony HS10 that had adjustments for this but they called it Keystone. Marquee keystone is different in that it flips the 'playing card' from a midpoint side horizontal point.
Now the question...I haven't swapped in magnetics from deflection on back yet (on any tube) because I just got all three new tubes from two different people. They never complained of this 'phenomenon' and are standup people who would have told me if they did.
The red tube has never been used, the green and red have ~ 20 hours on them. Could one bad convergence coil 'backfeed' to cause the problem in all three tubes? And if not the convergence coil could the focus or H deflection do it?
I know...I'm grasping at straws - but in the Land of Deaf People the Man Who Can Hear is King. Can anybody hear me?
_________________ Greg
tse
| Posted: Fri Jul 16, 2010 12:35 pm Post subject: |
The three horizontal deflection windings are connected in parallel (by the HDM) so if one is bad it can induce problems in the other two.
I haven't read the other thread so I don't know what you have done. Have you tried disconnecting the convergence coils from the convergence amplifiers to see if the problem is coming from there?
Scott
Thomas Jefferson
virusc
Joined: 11 Apr 2007 Posts: 358 Location: Massachusetts
| Posted: Fri Jul 16, 2010 12:44 pm Post subject: |
What about the horizontal linearity adjustment? Does this have any effect?
| Posted: Fri Jul 16, 2010 2:11 pm Post subject: |
Can you link to the other thread please?
| Posted: Fri Jul 16, 2010 3:16 pm Post subject: |
I remember the thread, and the plethora of suggestions to solve the problem. I started to chime in then, but when it got on the magnetized strut and magnetic fields, it got a little too spookie for me.
The problem is the CLM (control board) - but the CLM IS NOT defective...
I'm going from memory here, but have seen this problem before, and in most cases simply tweaked around it.
There's a history involved here if my memory is correct. Over the years the Marquee before having the VDC label on it, went through a series of chip changes. In the pursuit of making things better, they came out with various chip upgrades. Some of these chips were very short lived because they created some other problems. And during this process, I'm sure not all of the CLM's had the chips removed that were failed beta or they later found to be a problem.
The main chip for this was U35, which had about four versions of it for version 4 or 4.2 It was something like, 4.2a, 4.2b, 4.2c etc.
Anyway, the problem could be two fold. You'll either need to check the entire chip version starting from the CLM and DPB to that of the HDM and Focus or even VERT modules being used.
On the CLM you'll need to make sure the deflection processor board has the right version chip for the Focus module, HDM and that it also lines up with U35, which is the main determining chip for the ULTRAS, therefore was very necessary for it to work properly with the Ultra DPB, VERT, HDM and FOCUS boards.
I don't remember a lot on this, but if there's a difference in some of the chip versions, it could cause some unusual problems.
OR
You could do what I've done and simply work around the problem.
That problem is not magnetic, coils, strut or caused from a demonic force. It's generated from the CLM, and most likely caused from having the wrong version chips on one of the boards.
JustGreg
| Posted: Sun Jul 18, 2010 5:12 am Post subject: |
| Curt Palme wrote: | | Can you link to the other thread please? |
Sorry for the delay...work keeps getting in the way of my hobby.
http://www.curtpalme.com/forum/viewtopic.php?p=257182&highlight=#257182
Scott I swapped in another CLM with the same results and also disconnected the convergence; also same results.
Mike, for not thinking you remembered 'exactly' your reply was very detailed. I got a chuckle out of the voodoo comment. I warned you I was in uncharted waters with this 'problem'.
I have two sets of boards (doesn't everyone?). I've numbered them on the trace side with a Sharpie #1 or #2. I run the #1 ones and keep the #2's for spares. I've tried what I think is every conceivable variation and combination with the same results. I should have made an Excel for this but too tired so here's the board versions and chips.
CLM #1: 50-2036-03P U35-v4.1
CLM #2: 50-2036-03P U35-v4.1
DPB #1: 50-2106-05P Note:U1,U12,U7,U15,U11 are all socketed
DPB #2: 50-2106-05P Only 3 chips are socketed
FCM #1: 50-2034-02P No issue sticker
FCM #2: 50-2004-03P Issue 7 - Has sticker with hand written: 4787Z
HDM #1: 50-2003-07P U525 and U528 - v2.0
HDM #2: 50-2003-08P U525 and U528 - v2.0
Vert #1: 50-2330-02P
Vert #2: 50-2230-01P
Is there a chart or post somewhere that lists which boards play nice with each other and which ones are better/newer than others?
Mike, you're right...I can adjust out the anomaly and just 'fahgetaboutit'. I just wanted it to be as perfect a setup as I could get it this time around.
Thanks for the replies guys.
CZ Eddie
| Posted: Sun Jul 18, 2010 5:37 am Post subject: |
I think you're right about wanting everything as good as possible "out of the box". If you have this problem, then who knows how it could affect long term stability or what other problems there may be that you won't know about until you fully set up the projector and run it for awhile.
I know there are some non-Ultra boards that won't work well with Ultra boards. But I don't know of any other issues.
Have you tried running just one tube at a time, with the other two completely disconnected from the chassis electronics? That should rule out one set of magnets causing problems for the others.
_________________ Back after a digital sabatical.
| Posted: Sun Jul 18, 2010 8:55 am Post subject: |
| JustGreg wrote: |
I'll see if i have a v4.1 chip around somewhere and try it. I do know that there was something about the version 4 chips, but don't recall what the issues were and why they produced so many different variations of version 4.
I'll check my data on this and get back...
| Posted: Sun Jul 18, 2010 5:47 pm Post subject: |
I have more to find on that version U35 chip, but for now this is what I've found:
MODULE DESCRIPTION Marquee 8110/8500/9500 series Software.
CLB U35 (version 4.1 Main)
CHANGES SINCE 4.0E SOFTWARE
1. Changes to support Marquee 9500HS model.
2. Binary RS232 commands added to provide support for color temperature setup.
• SCT (0X0E) select/request current color temperature
• CTM (0X52) set/get color temperature values
• CNM (0X2E) set/get contrast modulation (zone contrast) values.
COMPATABILITY ISSUES FOR 4.1 SOFTWARE.
U16 on the CLB (02-263336-03P) must be at version 3.1 (IOP).
U7 on the DPB (02-250306-08P) must be at version 5.3 or higher.
SOFTWARE KIT NUMBERS
03-900000-02P Includes U35 (V4.1), U16 (I3.1) and Marquee Librarian and Languages (V4.1).
03-900001-02P Includes U35 (V4.1), U16 (I3.1).
03-900015-01P U7 (5.4)
| Posted: Sun Jul 18, 2010 5:51 pm Post subject: |
MODULE DESCRIPTION Marquee 8110/8500/9500 DPB software U7 (version 5.4)
CHANGES SINCE 5.3 SOFTWARE
1. Correct the vertical sync measurement above 291us. This solves the problem discussed in ISA 97-20a.
2. Focus start pulse defaults have been changed to 65% of the original value.
NOTE: Due to the change in start pulse defaults, the dynamic focus will need to be readjusted when U7 is replaced.
COMPATABILITY ISSUES FOR 5.4 SOFTWARE.
Needs 02-263336-03P control board and a 02-250306-08P deflection processor board.
03-900015-01P D5.4 for the 8110/8500/9500.
MODULE DESCRIPTION CLM [8110/8500/9500/9500 DM]
MODULE PART# 02-270336-03P Control board with DPB
02-280336-03P Control board with DPB\STIG
02-280356-01P Control board with DOME DPB\STIG
SERVICE PART# 03-263336-03P Service Control board only
ISSUE LEVEL UPGRADE Not Applicable
FAULT DESCRIPTION 1. Corrects the operation of standby off when using programmable events.
2. Reduced source change blanking time from 3 sec. to 1.8 sec.
3. Fixed ASR problem, if you switch to a unused input then connected the input the ASR was not triggered to select a input.
COMPATABLITY No effect on the compatibility with other modules
PARTS REQUIRED
PART NUMBER QUANTITY DESCRIPTION LOCATION
14-P33635-25P
1
V4.0c
U35
UPGRADE PROCEDURE
1. Replace U35 with a the 4.0c version software .
2. Check that U16 has V3.0 software.
3. Use Marquee Librarian V1.8 or later to load the languages V4.0a
| Posted: Sun Jul 18, 2010 6:10 pm Post subject: |
The one I'm looking for I did not find. I'll keep looking later when I have more time.
It'll show what chip versions you'll need to have depending on the version of U35. As you can see from the previous stuff posted, version 4.1 is the tricky one.
Let me stop here, because I'm going from memory. I'll post back later when I find more on this.
JustGreg
| Posted: Mon Jul 19, 2010 5:35 am Post subject: |
| CZ Eddie wrote: | I think you're right about wanting everything as good as possible "out of the box". If you have this problem, then who knows how it could affect long term stability or what other problems there may be that you won't know about until you fully set up the projector and run it for awhile.
Have you tried running just one tube at a time, with the other two completely disconnected from the chassis electronics? That should rule out one set of magnets causing problems for the others. |
Hmmmmm. No actually I haven't. huh. It never occured to me.
I'll have to give it a shot Tuesday when I"m off work. Can I disconnect the HV leads too? And for general knowledge...will it do any harm to the tube if I disconnect everything else but the HV? I've often wondered about that when troubleshooting.
Thanks Eddie.
JustGreg
| Posted: Mon Jul 19, 2010 5:46 am Post subject: |
That's excellent stuff Mike! I appreciate the time you've put into this. I didn't write down the board number formats that are referenced...just the silkscreen'd ones. Going on memory here too I 'think' I have a hodgepodge of boards and chips going on. That would explain a lot but I'll have to dig into it more Tuesday to be sure.
The big question is...if I need to order the chip-up kit(s) is the price going to have me pissing blood? (If they're even available any more).
Thanks again Mike. I'm sure alot of people will be interested in this info.
| Posted: Mon Jul 19, 2010 9:33 am Post subject: |
| JustGreg wrote: |
Go into the SERVICE MENU (0901) > 6 Diagnostics > 1 Hardware ID
Post here what you see on the screen..
antorsae
| Posted: Mon Jul 19, 2010 11:27 am Post subject: |
Greg,
I had a similar problem a while ago and it was a defective green deflection coil which was partially shorted. The projector worked but I had the raster severely compressed horizontally. I changed the deflection coil and voila! I understand the deflection coil has multiple windings so you can have a "working" projector even with a defective deflection coil.
In my case it was obvious it was the green one.
Hope it helped!
Andres
| Posted: Mon Jul 19, 2010 11:50 am Post subject: |
| antorsae wrote: | Greg,
Hope it helped!
Andres |
Yes, this is a possibility. One I thought was already ruled out in the other thread.
Greg, did you check this problem out at both HIGH and LOW deflection bands...
bring up internal test pattern UTIL 1 > 6 then select 3 then also look at 5. 3 is low band and 5 is high band.
I've seen the defective yoke problem before, but that pattern was too linear. What I remember was a distorted pattern.
JustGreg
| Posted: Thu Jul 22, 2010 9:56 am Post subject: |
| mp20748 wrote: | | antorsae wrote: | Greg,
Hope it helped!
Andres |
I've seen the defective yoke problem before, but that pattern was too linear. What I remember was a distorted pattern. |
Hey Guys,
Thanks Andres. Read on and your question will be answered.
Mike...I didn't check Hi or Lo bands. Here's what I DID do. And what I found blew me away, and still has me baffled...questions at the end.
As you all know I've tried swapping everything while attempting to find out why the rasters were compressed equally at the top and bottom beginning ~2/3 across from left to right at the tube faces. Nothing but the motherboard and backplane were left unswapped.
Last night I lowered the pj down and put it on a rolling copy machine cart to give my neck and back a break. I accepted the inevitable fact I just couldn't move on with the setup until I had conquered this.
What I first discovered is that the red tube is FINE....no compression of the raster. I have no idea what I was seeing at the red tube when it was ceiling mounted but I was incorrect stating the 'problem' was at all three tubes. I apologize to all who tried to help when I'd given them bogus information to work with.
Once cart mounted I decided to remove the mags from the blue tube and install a known working set from an old red tube. Powered it up and it still had the problem! I tried another set of mags..same thing. I then swapped out the nb's, HDM, FCM, all the heatsink boards, the PS's, and the CLM. All done one at a time powering up and checking each time. The 'problem' was still there! I even changed the mini coax and ribbon cables to the heatsink with the same results.
NOTE: I didn't think of it until now but I should swap the mags from the new installed red tube into the installed 'new' blue and try again...but I really don't want to mess with the red when it's sharp enough to shave with!
At this point I have no alternative but to deduce the problem lies in the green and blue tubes. I'm cool with adjusting it out now that I know the problem isn't electronic in nature and going to cause a problem later on.
I've sent a PM to the seller to help me track down the history of these tubes. They only have <100 hours on them so they must be NOS as they don't have VDC markings? (Panasonic)
Now the inevitable questions.
1) Obviously the electron gun is somehow firing the beam at a weird oblique angle for me to see what I'm seeing. Are tubes made this way on purpose for unconventional applications like domes or cuved screens, or????
These two tubes display the same funky image down to the mm! It appears to me I'm seeing a manufactured 'problem'.
2) Can storage next to a strong magnetic source cause this? I don't seriously think they were both dropped off a truck and suffered identical damages.
All the hours I could have saved if I had just done the mag swaps early on as part of overall troubleshooting... but who woulda thunk it when there isn't one but TWO tubes with identical 'issues'?!
dvh99
| Posted: Thu Jul 22, 2010 11:50 am Post subject: |
have you tried swapping the vim as well.
or try the 8 different ways to connect the rca connector on the vim
rgb
rbg
grb
gbr
brg
bgr
if you look at the underside of the vim you will see that the connector for the minirca cable has its signal and ground connections very close together on the underside of the vim.
i noticed this when i did the faint line tb fix and just went ahead and bend them a bit with a small screwdriver.
i wont be of much help but since you have tried almost anything i really do not know where to look for.
dennis
