What causes lens focus to shift with heat?
RVonse
Posted: Sun Jul 04, 2010 4:35 am    Post subject: What causes lens focus to shift with heat?
I have noticed that focus of my green tube changes very slightly from when I first power up to after a couple of hours of viewing. It is not an elctrical but a mechanical focus change, and its not a lot. I'm stumped about what would causes this. Could it be the c element distorting or shifting? Would it help to remove some of the fluid even though there is no sign of fluid leaking? The lense and c element were originally taken from an Ampro 4200.
Posted: Sun Jul 04, 2010 4:44 am    Post subject:
I doubt the c element or glycol has anything to do with what your seeing...
Try swapping lenses and see what happens.
r.bauer
Posted: Sun Jul 04, 2010 8:10 am    Post subject:
This is temperature related. I have experienced this with a 1209 setup I did for someone else. There was no temperature control in the room, and the temepersture in the room increased more than 8 degrees centigrade in the room, and the green lens was warm to the touch! The projector was ceiling mount, which makes it even worse. I had to re-focus green optically because of the increase in temperature.
CRT projectors 'behave' a lot better when the room is temperature controlled, unfortunetaley this is not the case in many Home Theaters.
CZ Eddie
Posted: Sun Jul 04, 2010 9:11 am    Post subject:
Mechanical focus doesn't change in normal environments. It's set & forget.
If focus changes as temperatures rise, then you need to look at magnetics or electronics. If the problem is on all three tubes, then I'd start with magnetics. Try setting G2 to 100 and ramp focus up & down. If dots move around a lot, then you've got a magnetics issue.
If it's only on one tube, then I'd look to electronics.
Posted: Mon Jul 05, 2010 12:03 am    Post subject:
You guys are forgetting your basic high school physics classes.
EVERYTHING changes size as it gets warmer. Everything gets bigger as it gets warmer. Lenses included. As the lenses grow slightly larger, it slightly changes their focal point.
Why do you think that all the calibration specialists say to let the display or projector warm up for at least half an hour before calibration?
It's not to allow yourself a coffee and bathroom break. It's so the projector can stabilize at operating temperature, and that includes lens stabilization.
Anyone who ever spent any time at all in amateur astronomy knows just how far focus can drift on a telescope with a change in the weather. The difference is sometimes quite dramatic.
CJ
zGman
Posted: Mon Jul 05, 2010 3:48 am    Post subject:
Yes - the entire pj chassis will shift a bit during warmup - but -
one thing to be aware of is that overtightening the lens base screws,
and especially tightening unevenly, can cause more shifting than
normal - also, there is no need to overtorque the focus knobs - just
snug is fine - not good to create unresolved stress in the system.
G
RVonse
Posted: Mon Jul 05, 2010 4:29 am    Post subject:
G
I never thought of that.
Posted: Mon Jul 05, 2010 4:39 am    Post subject:
A customer complained bitterly on avs about this a few years ago with a G70 I sold to Sweden I think. all new tubes, etc. He finally came back saying it was optical shift, but his pictures were so poor that we could never tell anything from the\m. Over weeks of playing with it, he wore his green tube due to 50 hours of all white on the tubes (!!!) and then of course blamed me for that too. Smile
We never figured out what did it, but based on the above responses, I'd say that mechanical shift is indeed possible due to temperature changes. I don't think most people would notice it though.
RVonse
Posted: Mon Jul 05, 2010 4:44 am    Post subject:
Here's how I know it is mechanical. When the set is first turned on everything looks perfect. After a couple hour movie the green will look very very slightly out of focus in the middle. And I can make it look perfect again just by a quick re-adjust the mechanical focus on the green. If I do this however when I start it up again from cold (next time) green will be off exactly the same amount out of mechanical focus.
Mind you, this is not a big issue and a very small amount of movement. But it has always kind of bothered me. And honestly, I don't know for sure if it is only green considering that the other colors are not focus sensitive like green.
I've pondered about building some kind of home made motorized focus that would control focus by lens temperature. But before I did that, I thought it best to post here and see if I have overlooked any other simpler solutions.
It helps a lot to know its got nothing to do with the C element.
zGman
Posted: Mon Jul 05, 2010 5:11 am    Post subject:
I had the thought back when I had my nice 9500LC mounted, that it would be nice
to have some temp controlled chassis heaters attached to the LC housing mounting
plate, as i was similarly bothered by slight focus shift during operation - never
followed thru on it though...Did find the issue with lens base screws, and switched
to stainless steel screws - which have a more compatible thermal coefficient of
expansion to the aluminum housings...
G
Posted: Mon Jul 05, 2010 5:40 am    Post subject:
Have you tried swapping the green and blue lenses? If not, try swapping them and see if the focus problem goes away (actually, moves to the blue where it won't be very visible, if at all). It could be that you're only seeing the problem on the green because it's so visible, but given that you're looking for it, I wouldn't be surprised if that lens has a loose element or something. If you move it to the blue, you probably won't even notice it.
Sparky015
Posted: Mon Jul 05, 2010 12:36 pm    Post subject:
Is this why the Marquee has temperature thermistor in the focus coil? Sony and Barcos don't have this, so not sure if focus is temperature compensated like in a Marquee?
~Paul
Posted: Mon Jul 05, 2010 5:44 pm    Post subject:
It could be a loose lens element...Did you try swapping lenses ?
CZ Eddie
Posted: Mon Jul 05, 2010 6:25 pm    Post subject:
Well, there is no sense in speculating on what the cause is, until you find out if the problem is only on the green or with all three tubes. Blue will likely be impossible to figure out, but Red should be just as easy as the green.
But first things first. Warm up the projector for 30 minutes and then set focus as tight as possible on all three tubes.
Then the next time you turn the set on, wait for 30 minutes before you start watching the behavior of the focus. If after 30 mintues goes by, you start seeing a difference in focus again, then there is definitely a problem. Especially if you are in a normal environment where temps are between 70-80 degrees at all times.
What happens in the first 30 minutes should be disregarded for the most part. Unless there is something obviously wrong of course. Very Happy
deronmoped
Posted: Mon Jul 05, 2010 6:36 pm    Post subject:
Heck
It's even normal for your eyes focus to vary. Wake up first thing in the morning and you should be able to notice you can not focus as good. From day to day you will notice your eyes ability to focus will change. How your body is treating you, weather conditions... will change everything, even your PJ can be effected by the weather.
Set the PJ for best overall focus, trying to get it perfect will have you on the quest for adaptive optics.
Deron.
Posted: Mon Jul 05, 2010 7:42 pm    Post subject:
Guys
The first Electrohome ECPs (1000 and 2000) had lens elements mounted on bi-metal strips like those found in thermostats. When the lens elements warmed up, the strips would shift the lens position a few thousandths of an inch, effectively tracking the temperature shift.
Posted: Mon Jul 05, 2010 8:00 pm    Post subject:
I think that has a lot to do with what you drank the night before!! Laughing
Posted: Mon Jul 05, 2010 9:21 pm    Post subject:
...And even more to do with how much of whatever you drank the night before!!!
Wink
deronmoped
Posted: Tue Jul 06, 2010 4:22 am    Post subject:
I almost forgot about those days. Have not had a drop in ten years. The parties were always fun, but the next day was payback Sad
Deron.
Posted: Tue Jul 06, 2010 7:46 am    Post subject:
I've never noticed the focus change with temperature on my various NECs.
I've never really looked for it either.
