What resolutions do people here use for 2.35:1 pictures?
Goto page 1, 2, 3, 4, 5  Next
Posted: Thu Jun 24, 2010 9:35 am    Post subject: What resolutions do people here use for 2.35:1 pictures?
Ive looked at a few Bluray disc cases, and they say they are in 1920x1080, but how can they be if that is a 1.78:1 ratio and the movie is in 2.35:1?
Wouldnt you be better off running 1920x about 820 or so?
Here is a shot from T2 on Bluray, shot on my computer using VLC media player, and in its original aspect ratio, which came out to 1920 pixels wide, by 817 pixels high.
Doesnt it seem pointless scanning the other 263 lines that are not in use?
benareeno
Posted: Thu Jun 24, 2010 3:17 pm    Post subject:
yes...it is pointless, and it's one of the only big advantages to running an htpc (custom resolutions). That...and low end gamma correction.
Posted: Thu Jun 24, 2010 9:39 pm    Post subject:
Only advantages to a computer? I can name a thousand more.
So you just go with what ever resolution is the average for these wider movies and create an entry for that?
Posted: Thu Jun 24, 2010 10:06 pm    Post subject:
I use no computer, Ben and his comments Wink I run 1020x800@72 hz. perfect for BD.
What you want to do is Called Active Area Scanning. here is a nice read.
http://archive2.avsforum.com/avs-vb/showthread.php?t=737385
Posted: Thu Jun 24, 2010 11:52 pm    Post subject:
Because the wider-aspect movie is letterboxed - just like on DVD. The source material BD is indeed 1920x1080. Your playback software is cropping the resulting image.
Yes, there are a lot of advantages. However, I can name just about as many disadvantages. For some, an HTPC just isn't worth the hassle. I'm in the "undecided" camp, as I have a love/hate relationship. I hate Windows, which doesn't help, and every time I try to use the HTPC, something about the experience pisses me off and I'm reminded that that in spite of the advantages, they're a giant time-suck.
Sparky015
Posted: Fri Jun 25, 2010 12:02 am    Post subject:
Good link Nash.
So to wrap my head around this, to get true 2.35:1, you should be running at a resolution of 1020 X 817, which is the native resolution of film. 1920 x 1080 is a 1.78:1 ratio, and is more for HD TV content, but if you have PC or VP, you could scale them all to 1020 x 817 at 72Hz and have 2.35 ratio for everything. Right? Ofcourse, if you have a VP, you can just set memories in it and the PJ and have the best of both worlds assuming you have a screen that can accomodate.
I hope I'm getting this. I'm trying to make sense of this in my head as I get to that point in my theatre build.
~Paul
Sparky015
Posted: Fri Jun 25, 2010 12:05 am    Post subject:
Ah, that makes perfect sense. 1920 x 1080p, but it has bars to make it fit 16:9 ratio TVs. To get true film aspect 2.35:1, you use 1020X817, which increases the bandwidth that you can go to 72Hz. and cuts off the bars, leaving you with just film.
Now I'm getting it! Laughing
~Paul
Posted: Fri Jun 25, 2010 12:07 am    Post subject:
Guys, most movies are actually 2.40:1, not 2:35. That's why Nashou suggested 1920x800... That's 2.40.
Sparky015
Posted: Fri Jun 25, 2010 12:10 am    Post subject:
Ok, so stupid question, what's the point of a Radiance then, if an older Lumagen can do this? 1.78:1 content at 72Hz?
~Paul
Posted: Fri Jun 25, 2010 2:47 am    Post subject:
That's a good point. Letterbox bars are wasted bandwidth. If you can eliminate them from the picture (pardon the pun) then you get a net gain in usable bandwidth.
But you need to have a custom vertical size setting for every different "barless" aspect ratio you set up.
This really makes perfect sense. Simply by not having the projector trace out the letterbox bars, you reduce the number of horizontal
scans per frame from 1080 to (example) 817 lines. That's a savings of 30 percent of your total video bandwidth.
However, this would apply only if there were truly no letterbox bars, seen or unseen. The frame sync data would have to start and stop immediately before and after the picture data. This would be really interesting because then the output signal would technically be a custom format instead of full standards-based HD. It would allow a lower horizontal scan rate and keep up with the frame rate.
CJ
benareeno
Posted: Fri Jun 25, 2010 3:23 am    Post subject:
I've said this a hundred times, and I'm sure you would all be too afraid to even try it...but you can even show 1.78 content in a 2.35 active scanning area. It only takes off a bit from top and bottom. Most movies look just fine like this...I think home theaters should be based around 2.35 or 2.4 as this should be what provides the best experience....you can then zoom 1.78 or do some sort of compromise where you go a little bigger than 2.4 but not as big as 1.78.
Uncle Buck looks great at 2.35...
Why a radiance you ask? Well..it's the latest and greatest so most people think they need to shell out and buy it. A lumagen DVI will do everything mentioned here...including gamma correction and 47.952 HZ.
Posted: Fri Jun 25, 2010 3:52 am    Post subject:
Wellt here are some movies on BD that still are 1.78 or 1.85 so if you still want 72hz then the XS+ is what you want as the vision HDP series will not over DVI. Also if you want true 422 all the way tot he PJ then the radiance will do this. the Vision series converts it to Digital RGB over DVI.
Also the radiance has true 3D CMS, the Vision is only 2D CMS and lacks Secondary control.
MikeEby
Posted: Fri Jun 25, 2010 4:10 am    Post subject:
All the buzz in the CIH forum on AVS is how 3D might push out scope. It will be interesting to see how it plays out.
I've ran 1080p72Hz on my 8"NEC and 1980X800p also. On my NEC it didn't look much better then 1080p, frankly I could hardly tell a difference.
Posted: Fri Jun 25, 2010 9:04 am    Post subject:
Thanks everyone for their replies Smile
Yep, when it is set to keep the correct aspect of the movie it is, if its set to full screen it leaves the bars there, unless i cut them off in the settings, and it stretches it down.
Depends how well you know windows i guess, not having a shot at your skills by the way cause i dont know you that well, but i certainly never have any issues getting a Windows based computer to do what it is designed to do. So easy. Double click what you want, and away it goes. Put in a movie disc, and it plays. Want to listen to music? Press the media button on the keyboard and it comes up with all your music. Leave it on 24hrs a day and never have an issue. Faultlessly reliable as all my computers have been. If the computer is powerful enough to do the tasks it is asked to do, and it is set up properly ( as in not by DeLL, HP, Compaq, or any other "brand name" computers ) for the tasks at hand, it will not miss a beat unless the user makes it do so. Setting up windows on a fresh install can take quite a few hours yes, for sure, but once its done you dont do it again unless you or someone else f***s it up. Windows has a worse reputation than it ever actually earned, cause it is VERY reliable and VERY capable in my experience, which spans well and truly long enough to be qualified to comment. The only downside to a computer is the total time to do initial setup, once that is done, there is nothing more to do, if you set it all all up right, it updates it's self and stays current.
All my opinions ofcourse, but coming from a fair amount of experience in the field.
Youre dead right, i wont be trying it cause i dont want to watch movies with the heads cut off everyone. My projector has a 4:3 aspect ratio, and i would prefer to stay as close to that as possible when i can, so pointlessly cutting the top and bottom off a picture seems to be a poor use of good phosphor.
Posted: Fri Jun 25, 2010 1:31 pm    Post subject:
Don't take this as a knock against your projector, but it takes a well tuned 9" PJ to get the most out of 1080p. 8" machines just don't have adequate MTF capacity to fully resolve 1080p from end to end. If the video chain is good enough, there's the CRT's limitations. If that's good enough, the lens can be a limiting factor. And even if every stage is 95 percent of
what you'd need to totally resolve 1920x1080, with at least three stages (Video bandwidth, CRT focus, optical focus) in
play, then you're losing over 15 percent of your total bandwidth capacity.
I have yet to see a "real world" 8" machine that actually can reap the benefits of 1080p. 720p is close to the sweet spot
for any 8" machine.
CJ
Posted: Fri Jun 25, 2010 2:45 pm    Post subject:
See my old thread here:
benareeno
Posted: Fri Jun 25, 2010 4:46 pm    Post subject:
my comment is for someone wanted a properly masked 2.4:1 screen...this person can try watching 1.85 movies in the 2.4 screen and will find out that they look fine. Likely better than making them smaller and more narrow. 2.4:1 movies look infinitely better masked off properly than they do if you watch them on a 16:9 screen...but, that's just my opinion.
Those of you who strive for 4:3 aspect ratio...I have no comment.
MikeEby
Posted: Fri Jun 25, 2010 8:52 pm    Post subject:
for any 8" machine.
CJ
I'll agree...with an XG is seems to have a bigger issue with horizontal resolution, vertical I could resolve fairly well. Here was a 1:1 screen shot @1080p@72Hz. Soft yes but the lines show some definition.
Horizontal 1:1 wasn't this good...I think that's why 1920X800 didn't look so good. 720p on an XG sucks ass...I can see scan lines at 2 screen width. I've settled in at 1600X900 and that's where I'll stay for the rest of the life of the projector.
Posted: Fri Jun 25, 2010 9:05 pm    Post subject:
cmjohnson wrote:
If the video chain is good enough, there's the CRT's limitations. If that's good enough, the lens can be a limiting factor. And even if every stage is 95 percent of what you'd need to totally resolve 1920x1080, with at least three stages (Video bandwidth, CRT focus, optical focus) in play, then you're losing over 15 percent of your total bandwidth capacity.
I have yet to see a "real world" 8" machine that actually can reap the benefits of 1080p. 720p is close to the sweet spot for any 8" machine.
So, let me understand CJ... Basically, you're suggesting that because the average well-setup 8" projector can only resolve say 75-85% of the 1080p signal because of lenses, video chain and CRTs, we should just go ahead and throw away about 55% of the original picture information from the Blu-ray so we can run "close to the sweet spot" for the projector?
Mike Parker and I have discussed this exact topic in other threads and both agreed... Why the hell would you do that?
I don't watch test patterns, I watch films. My G70 looks FAR superior running 1080p even though it's obviously not fully resolving the signal... Why? Because even though it's not fully resolving the 1080p source, there's a hell of a lot more real picture information than there is if I throw away more than half the original signal at the source just to run 720p and fully resolve!
Wouldn't you rather resolve 80% or even 70% percent of the original signal than resolve 100% of a signal that's only 55% of the source? Frankly, I just don't understand the logic.
But, hey - I'm all ears... Why would I want to run 720p over 1080p?
Posted: Fri Jun 25, 2010 9:49 pm    Post subject:
I think you're questioning a judgement I haven't actually made here.
The issue as I'm thinking of it is something that some of us have seen for ourselves: Attempt to push a projector beyond its bandwidth
limits and the picture can actually soften. Not just fail to fully resolve the picture, but actually get SOFTER as the MTF function goes to crap.
I've seen that for myself. Going full stupid, QXGA resolution (2048x1536) on a Marquee 8000 using a Sencore computer monitor analyzer,
with the refresh rate cranked up to 85 Hz if I remember right. The picture was mighty soft but it did lock right up. However, it was
equipped with a high res P19LNQ green CRT (for test purposes) and when I dropped the refresh rate down, the image got a great deal
sharper.
With regular tubes, the effect was even more pronounced. Go past the video bandwidth capacity and your picture essentially starts
to turn into a blur.
I AM saying, if your picture isn't better looking at 1080p than at 720p, then probably you're better off staying at 720p.
Of course, the optimal answer is to run at the resolution that is highest and still gives good definition, which means a reasonably good
MTF value. But particularly for those of us who can't run custom resolutions and have to choose from the standard resolution options given to us by our sources, we will have to choose from among a limited range of resolution options. In this case I'd say that a clear 720p beats a slightly soft 1080p. Maybe 1080i is best for that PJ.
The user has to make that decision for himself. I'm not saying to not use a higher resolution if it looks better but isn't perfect. I'm
saying, use what looks best to you. It may not be the highest resolution rate available to you.
CJ
Page 1 of 5
