| Posted: Fri Feb 25, 2011 5:47 pm Post subject: |
| Nashou66 wrote: | | 35c seams ok to me. I am sure those chips will handle much more heat, the rear heat sink I think gets hotter than that. | that's only 94 degrees, i know the FET's on the convergence board run at least that hot.
So steve what have you from the time it blew the 34.9 supply's to now? Just replaced the neck-boards?
HK-Steve
| Posted: Sat Feb 26, 2011 1:35 pm Post subject: |
No parts changed, except the splitter,
I don't think it is the splitter because there are no burn marks, holes or spots to short to the chassis. Unless you think otherwise.
Projector has run for 5hrs no issues, will run it again today.
Cheers
Steve
Sparky015
| Posted: Sat Feb 26, 2011 1:49 pm Post subject: |
Steve, is it possible the 34KV supply is a low enough voltage that the issue does not arise? I'm wondering if there isn't something internal to one of the tubes, or the neckboard attachments on the tube pins that are OK at a lower HV, but not at the 34.9KV.
_________________ ~Paul
HK-Steve
| Posted: Sat Feb 26, 2011 3:33 pm Post subject: |
Appreciate your comments, but I don't think an extra 900volts would make much difference.
if there is an issue with the HV section of the tube, I would expect it to be shorted from say 2kV and up
at the current 34kV, I would think the tube wouldn't know the differece to 34.9kV
I may be proven wrong yet,
Cheers
HK-Steve
| Posted: Sun Feb 27, 2011 8:18 pm Post subject: |
some more feedback,
34.9kV HVPS installed,
Pressed the power button,
all running fine, no POP or BANG
So, now leads me down a path or what was the original problem.
Now confused.
Cheers
Steve
| Posted: Sun Feb 27, 2011 8:22 pm Post subject: |
Steve, that is strange.
Now we have to ask, was Scott's original theory of incoming current rush the issue?
Did anything Change in his home? new HVAC system, new dishwasher, etc and or was there any new power authority work in his area? Like new transformer etc. Its just a wild theory but could it have been nothing wrong with the PJ to begin with but more an issue with the AC power from the power company?
Just a wild thought...
nidi
| Posted: Sun Feb 27, 2011 8:40 pm Post subject: HVAC |
we do not have HVAC systems in our hones here in Switzerland
nothing changed.
Michael
HK-Steve
| Posted: Mon Feb 28, 2011 3:30 pm Post subject: |
Athanasios, Just a wild thought...
Hmmm, Now where have I heard that before, Ha Ha, just joking.
Wild thoughts are good, but unfortunately, nothing has changed as Michael, nidi, said.
I have been running the projector for 3 days now, no issues.
This is just frustrating now, we still don't know the answer.
GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
Cheers
Steve
HK-Steve
| Posted: Mon Feb 28, 2011 3:38 pm Post subject: |
the incomming rush current, is not an issue as far as I am concerned,
because, nothing had changed in the projector after running for the last 9+ months with no power up issues.
One day, the HVPS fues exploded, Michael ordered a HVPS from Curt,
put it in, fuse exploded, (no blame or flames to Curt)
I repaired the HVPS, fuse exploded.
After comments about better protection on the 34kV HVPS, got my hands on one, thanks to the anonimous person,
fired up the projector, and well what do you know it runs no issues. Dam.
So put in the 34.9kV HVPS, and it runs like nothing had happened.
I am going to get Michael's projector back to him to run it as much as possible, on thursday fingerscrosed.
Big question, where to point the finger????????
Cheers
Steve
HK-Steve
| Posted: Mon Feb 28, 2011 8:04 pm Post subject: |
All 3 failed at Michael's house.
Power point, (outlet), was checked, is all good, so not suspected as an issue.
My power voltage is a little higher than Michael's, he has 231volt output, I have 235volts.
Ground in both Michael's house outlet and mine are good, 0.01 Ohms projector power to any ground point.
Should we send over a witch doctor??
Cheers
Steve
| Posted: Mon Feb 28, 2011 8:09 pm Post subject: |
| HK-Steve wrote: | All 3 failed at Michael's house.
Cheers
Steve |
No thats not it Steve, lol I was thinking something might have shifted in transport from Michael's to your place.
One small Aluminum shaving from removing screws etc could have gotten into a connector and caused a short.
Moving it to your place may have moved its location so the short went away.
Happened to one of my PJ's, After i tore it down to the bare chassis is was a screw lodged in a mother board to back plane connector. But my unit just wouldn't turn on, no blown parts.
nidi
| Posted: Mon Feb 28, 2011 8:20 pm Post subject: projetor transportation |
Steve disassembled the whole thing and moved it in parts.
the projector ran for 4 months straight before I suddenly had the fuse explosion
and ironically after I told Steve how well the projcetor worked.
Michael
HK-Steve
| Posted: Mon Feb 28, 2011 8:20 pm Post subject: |
After taking the projector down from Michael's ceiling,
I broke the projector down to every circuit board removed, mother and daughter board removed, wiring loom removed.
Found no issues at all, no extra screws, no parts fell out.
Place the projector on a table in my workshop, put it all back together, with the screws in the same spots, anal like that I am
Then reinstalled the tubes and put in the 34kV HVPS. You know the rest.
Appreciate the comments, keep them comming, like your thinking.
Cheers
Steve
HK-Steve
| Posted: Mon Feb 28, 2011 8:24 pm Post subject: |
Hey Michael.
Projector is still running with the 34.9kV HVPS, so Thursday looks good.
Cheers
Steve
| Posted: Mon Feb 28, 2011 8:25 pm Post subject: |
| HK-Steve wrote: | After taking the projector down from Michael's ceiling,
Cheers
Steve |
Right, but it might have been there and moved during the move. One small shaving so small you can easily over look it can cause havoc . I'm glad its working at your place and since you tore it down I am sure its clean and there is nothing
that will cause a short.
HK-Steve
| Posted: Tue Mar 01, 2011 10:02 am Post subject: |
Hey All,
Just something I found, the HVPS cable is rated for 50kV and also has the clear plastic sleeve over the cable.
Each of the 3 tubes has 40kV cables with no sleeve, think this is an issue????
Cheers
Steve
HK-Steve
| Posted: Thu Mar 03, 2011 7:00 am Post subject: |
Any comments on the cables ratings??
Cheers
Steve
| Posted: Thu Mar 03, 2011 7:55 am Post subject: |
I don't think it would be a problem
My 7500 and 9000 have the same cable setup, and no problem with them. there is "only" ~35kV coming from HVPS so a 40kV cable is enough.
Anyway a simple HV arcing usually don't cause the fuse blowing.
