| Posted: Tue Jun 08, 2010 1:22 pm Post subject: |
| km987654 wrote: | | r way 16:9 to 4:3 to max the phosphor usage? |
Not necessary. The Marquees (and probably every other CRT projector) are designed for 4:3. The Marquees just don't have enough range on the height adjustment to squeeze the raster down to 16:9. Change a few resistors and you change the height range, and then you can squeeze to 16:9.
| Posted: Tue Jun 08, 2010 5:44 pm Post subject: |
| km987654 wrote: | | cmjohnson wrote: | | km987654 wrote: | | Is there any reason that can't achieved electronically? |
We're doing it. It's called the anamorphic squeeze mod. It's very much a standard mod that practically every CRT
enthusiast puts into his PJ. It gives our projectors extended vertical size adjustment range
so the picture can be reduced in height enough to fit it into a 16:9 window with a little extra adjustment left over.
Usually it involves changing the values of three resistors. Simple.
CJ |
Can you go the other way 16:9 to 4:3 to max the phosphor usage? |
If you want 4:3, you just don't even do the vertical height mod. All CRT projectors are native 4:3 aspect ratio machines
with the except of a few made for simulation use that utilize round CRTs.
In this case, you can almost always select widescreen or fullscreen operation from the player, so if you really wanted to
watch a widescreen picture that uses the whole phosphor surface (4:3) and then use an anamorphic lens, you could do
that but you'd have to get the lens. The player will put the whole image on the CRT face, if you just have your projector
set up for the desired aspect ratio.
CJ
piratepowwow
| Posted: Tue Jun 08, 2010 11:47 pm Post subject: |
It can be done, and it can be done at home without huge capital expenditure.
The question is, are you up to the task, cause it's not going to be easy! But if you own a CRT projector, there is a higher than normal chance that you aren't a big fan of doing things the easy way ^_^
There are at least three design paths you can go down, each has strengths and weaknesses:
Prisms
Lenses
Mirrors
Both mirrors and lenses can be cylindrical/elliptical/parabolic/catenary and whatever else you want to call it.
I think CAVX's aussiemorphic lens has already proven that it can be done by the DIYer. But, again, I wouldn't say he found it particularly easy.
CAVX eventually abandoned the prism lens not because it didn't work well, but because each 'lens' had a "sweet spot" and was not as adjustable as the cylindrical lenses he is now using.
Going anamorphic will certainly exacerbate the edge focusing issues(and other issues as well) we have with CRT PJs, but there are things that can be done to help cope with it, such as curved or spherical screens. If you don't have lens flapping on your projector, you can pretty much forget going anamorphic.
Questions we must ask ourselves:
Why do I want to go anamorphic in the first place, what is to be gained?
I personally could care less about making the screen wider, I just want to use the most phosphor I can possibly use for the majority of the content I watch, which is 16:9.
I don't subscribe to either CIA, CIH, or CIW. I want my 2.35:1 content the same width as my 16:9 content, and I want my 4:3 content the same height as my 16:9 content. Fortunately, this is how HTPCs generally display their content by default.
Supposedly by using more phosphor, horizontal lines will resolve better, and less brightness will be needed so the tubes should last longer. If using zero-angle projection you also get a perfectly even wear pattern(only if 16:9 content is used exclusively).
What should my budget be?
For me, the cost should be less than the cost for a new set of tubes OR about half the cost of implementing blending, whichever is cheaper.
I don't doubt it for a second that someone CNC'd custom elements for their G70 - because I've done stuff like that before. In this day and age, advanced manufacturing techniques are becoming more and more available. Heck, there are clubs of makers these days that register what tools they have in there area and let others use them, much like a public tool library. Large, high precision CNC mills are going for less than $10k, and lathes(albeit small) are going for less than that. The average guy even has access to laser scanners to scan for surface imperfections, and 3D printers for rapid prototyping, or making mold reliefs.
| Posted: Wed Jun 09, 2010 3:57 am Post subject: |
Having CNC machining capacity does not mean you can make optics. Far from it. Any optics of high enough quality to be used on our projectors at HD resolutions would have to come out of an optician's shop and the lenses would have to be accurate to within a few millionths of an inch to meet the resolution specs that the application demands.
CNC machining capability is not equal to the skills and tolerances required of an optician. They are two completely different disciplines
and the optician must routinely work to a dimensional accuracy standard that would frighten most machinists and is beyond their capacity to achieve.
CJ
Kiev Savoie
| Posted: Wed Jun 09, 2010 1:01 pm Post subject: |
Great thread. There is a lot more involved than i thought. Now if only there were a cheap way to blend...
Kiev Savoie
| Posted: Wed Jun 09, 2010 1:03 pm Post subject: |
| cmjohnson wrote: | If you could find someone to make lenses like these in suitable sizes and tailored for the application at a reasonable price, you'd be
a thousandaire in a few months.
who makes these?
| Posted: Wed Jun 09, 2010 2:20 pm Post subject: |
Right click on the photo and you'll know.
But those lenses are TINY, maybe an inch square.
You will spend THOUSANDS of dollars per lens IF you can find someone to make them AND they will have to be custom engineered,
and that probably means sending your entire projector to their optical engineering department.
If it costs less than 15,000 dollars to get a set of lenses made, I will be very surprised. If you can afford it, then good for you!
CJ
piratepowwow
| Posted: Wed Jun 09, 2010 3:24 pm Post subject: |
The first thing that comes up when you search for DIY Anamorphic Lens is this: http://www.zuggsoft.com/theater/prism.htm
A man who acheived what I would call satisfactory results(chromatic aberration aside) using glass trophies as prisms. Not $15k custom lenses, not lenses ground to within a few millionths of an inch, but $29 glass trophies.
Folks have been grinding their own telescope mirrors for years...
| Posted: Wed Jun 09, 2010 3:53 pm Post subject: |
Interesting. But note he's doing that with a digital projector. "Tropies" big enough for CRT lenses would probably run you a LOT more than $29, and you'd need 6 of 'em...
| Posted: Wed Jun 09, 2010 5:08 pm Post subject: |
| Kiev Savoie wrote: |
Great thread. There is a lot more involved than i thought. Now if only there were a cheap way to blend...  |
What do you consider cheap? we all know the diVentix is about 12-16k. the Single Tv-one unit like the C2-7100 can be had for around 6k. the units i use the C2-2250 are about 2k each, maybe less, the deidcated C2-2450 I can get for about 1500 each if you get two, and the least expensive Tv-One stand alone units with DVI inputs/Outputs the 1T-C2-760 i can get for about 1k each if you get two. The latter units are the least expensive way to blend with a non PC based blend.
so with regards to the DiVentix and the upper end C2-7xxx series the latter models i think are fairly priced especially now with CRT prices lower the overall cost has gone down.
piratepowwow
| Posted: Wed Jun 09, 2010 7:02 pm Post subject: |
Cheapest blending I have heard of is using an Nvidia Quadro series video card that has edge blending capabilities designed specifically for blending projection displays. You can pick one up for less than a couple hundred bucks.
Then, of course you would need a projector that is capable of convergence on green. Probably just one of a two-projector setup would need convergence on green.
Kiev Savoie
| Posted: Thu Jun 10, 2010 1:37 am Post subject: |
Well Nash, the price of blending has definitely gone down, but until it's in the the hundreds of dollars range as opposed to the thousands of dollars range it will still be out of my league. It's killing me just trying to get a single Lumagen HDP scaler. they never seem to pop up when i actually have money!
POW, I'm not sure how it will all turn out but if you want to run some experiments, i just recently acquired access to an old TV repair shop that has room for a quick and dirty projection bay. We could use one of my spare G70's, that way our own setups don't have to be interrupted. I don't know how successful we'll be but, it could be fun and i'll bet we'll learn quite a bit about optics!
| Posted: Thu Jun 10, 2010 11:49 am Post subject: |
If anyone here has ever opened up a rear projection CRT television, they would have seen 2 things, the mirror is dead flat, and in better quality sets is made of surface reflective plastic instead of glass where the image has to go through the glass to get the the reflective level and then back through the glass, and also the tube faces are not using full raster, they have the same or simular width to the 4:3 version of the same or simular set, and have the vertical size reduced.
Dont know about every single set, but i have compared 2 Panasonic GAOO sets side by side, TX-51GF85-H 51 inch 4:3 and TX-47WG25-H 47 inch 16:9, both sets have the same 7 inch tubes, both sets have the same lenses, both are LC and colour corrected in red and green, the screen width is the exact same on both. The raster usage is about the only difference once you take the screen and lenses off and look through the c-elements.
Apart from all that, every other RPTV ive opened up has a simular mirror, and if its 16:9, its using a letterbox format on the tube face.
| Posted: Thu Jun 10, 2010 12:12 pm Post subject: |
Actually, the BEST RPTV sets, from an optical quality perspective, use a first (front) surfaced glass mirror of high quality.
The modern trend toward the use of tensioned Mylar film over a frame to make a mirror is done because it makes a mirror that doesn't
break and create a safety hazard when the set is scrapped, eliminates the use of more expensive glass mirrors, and it does a very good
job so long as the mirror is clean.
Drawbacks to the mylar mirror: Almost impossible to clean without damaging the silvering, susceptibility to vibration modes which
make optimal focus in some parts of the screen impossible, and second best reflection performance as compared to good first surface
glass mirrors. Though the surface is good, is not as perfectly planar as a good piece of glass.
CJ
| Posted: Thu Jun 10, 2010 12:24 pm Post subject: |
Thats true indeed, ive never opened one up with glass in it though, i think i remember reading somewhere that the Toshiba CRT RPTVs had glass in the 90s sets ( although the Toshiba i opened up was a 2003 model and had plastic ) , they were way out of my price range when i bought my first of the 2 Panasonics.
virusc
Joined: 11 Apr 2007 Posts: 358 Location: Massachusetts
| Posted: Thu Jun 10, 2010 3:41 pm Post subject: |
Most of the better RP TV's from the early 90's up had first surface mirrors. Mitsubishi's entire line used them as a selling feature early on and until the end. Pioneer, Panasonic, Toshiba and most likely others did as well. Pioneer would also list all glass lenses and corrected c-elements for the elite sets. I once had a Mitsubishi display at the store I worked at showing the difference and it was a huge difference.
| Posted: Thu Jun 10, 2010 9:10 pm Post subject: |
The mylar mirrors are a fairly recent introduction. Glass was the standard until the early 2000s when mylar started to get used.
It's also very cheap to make a mylar mirror.
CJ
Kiev Savoie
| Posted: Fri Jun 11, 2010 1:11 am Post subject: |
yeah, goodluck finding a big screen from that era though. Most of what comes in for repair and troubleshooting at the store i work at is only 4 or 5 years old at the most. I've been very disappointed at the pickings.
| Posted: Fri Jun 11, 2010 9:41 am Post subject: |
| cmjohnson wrote: | The mylar mirrors are a fairly recent introduction. Glass was the standard until the early 2000s when mylar started to get used.
CJ |
I dont know the technical name for the plastic meterial used, but the Panasonic GAOO range used suface reflective plastic mirrors in all 3 models, and i think they started in about 1995. I bought my first GAOO in 97, and the second in 99. As far as i know the TAU GIGA Panasonics also had the exact same mirror as the GAOOs. There is no question about it, that was indeed a surface reflective plastic mirror. I did a minor service on a General Electric RPTV that had a glass mirror, the 2 RCAs i looked in also had glass. Those 3 sets ( the General and the 2 RCAs ) were rather poor compared to almost anything else i ever saw or opened especially considering their age being quite late 90s models, picture quality was down, sharpness was poor, and neither had LC or colour correction either. The General Electric even had analog convergence, and the trim pots were on the side of it!!
