I now say that UPSs are mandatory on some 9" sets
Goto page 1, 2, 3  Next
Posted: Wed Jun 02, 2010 2:46 am    Post subject: I now say that UPSs are mandatory on some 9" sets
So I managed to nuke a Barco 909 all by myself, and it wasn't intentional, or due to stupidity.
I was working on an HDM (8 hours, and I finally nailed it!), and was testing the HDM without one of the MOSFETS that was blown, so all I wanted to do is power the set up for about 10 seconds, and since the remote is slow to react, I had my finger on the main power button, pushed in slightly to release it as soon as the set powered up for 5 seconds.
The dog brushed against my leg, and my finger slipped, turning the set off. Instinctively, I pushed the button back in, so the main AC power was disconnected literally for 1/4 second or so. Poof! Blew the AC input board, which on the 909 is full of components.
Also, I sold a retubed G90 to Hong Kong a month ago, and about 30 hours in, the customer had a power failure, which spot burned all three tubes. He's since run the set for 100 hours, and the chassis is fine.
So I implore all of you, GET A 1000 watt UPS for your high end CRTs. This doesn't seem to apply to the Marquees and BArco 1209s, but this 909 failure really pissed me off, after spending 8 hours on the HDM, finding a cracked SMT solder joint due to 'someone' here doing a piss poor job of packing the board in a shoebox.
(no, it wasn't any of the usual suspects that you'd expect would be sending me a 909 board.. Mr. Green Mr. Green
Rant off. Thumbs Up
Posted: Wed Jun 02, 2010 2:57 am    Post subject:
Exclude the dog from your work zone.
CJ
Posted: Wed Jun 02, 2010 2:58 am    Post subject:
It still should not have happened. Power brownouts happen here a lot more than complete blackouts.
tse
Posted: Wed Jun 02, 2010 3:06 am    Post subject:
I think Thomas Edison said it: bringing a product to completion is 10% inspiration and 90% perspiration. Barco should have spent the time (perspiration) testing reaction to brownouts and power dropouts. That is what makes a good product.
Scott
Thomas Jefferson
Posted: Wed Jun 02, 2010 5:24 am    Post subject: Re: I now say that UPSs are mandatory on some 9" sets
Rant off. Thumbs Up
Sony "engineering" (and I use the term very loosely) strikes again. Sad
Posted: Wed Jun 02, 2010 6:43 am    Post subject:
Dragan making snide remarks about Sony?!?!? That's weird! Rolling Eyes
So, if the spot burned G90 was caused by Sony "engineering", then what was this:
That must have been some Barco "engineering", eh?
Oh... And what's with the P14 filament voltage problem on the Marquees? How many perfectly pristine tubes has THAT issue killed? Was that Electrohome "engineering"?
Rolling Eyes
papalek
Posted: Wed Jun 02, 2010 11:16 am    Post subject:
Sounds like you need to buy an Ampro.
I do love my AmPro's
dochlywd
Posted: Wed Jun 02, 2010 12:13 pm    Post subject:
Can someone provide a few links to affordable UPSs that meet the requirements?
THanks!
Doc
Sparky015
Posted: Wed Jun 02, 2010 12:38 pm    Post subject:
Oh, that sucks. Those are the days you just put down the soldering iron and do something else for the rest of the day!
~Paul
Posted: Wed Jun 02, 2010 12:39 pm    Post subject:
Rolling Eyes
Steve this might be one of the few times i have to disagree with you Wink Even TSE who is an engineer in an above post blames the Barco engineers for not thorough testing.
Scott
now with the Marquee filament issue that was a part not designed by
Electrohome. Yes you ultimately have to blame Electrohome but even Apple gets bum parts that caused the famous Power supply issues in the iMac G5's that was not fully under their control.
Sony on the other hand Designed the Chip that is failing. they used a proprietary part where you can get no where else. Also its standard practice to keep parts for any major appliance or product in stock for repair or replacement for up to 10 years. the G90 last production date i believe was 2003. No parts are available, SOL.
dvh99
Posted: Wed Jun 02, 2010 12:43 pm    Post subject:
paco de lucia used that phrase too 10% inspiration 90% perspiration.
he did turn out pretty well.
Posted: Wed Jun 02, 2010 2:50 pm    Post subject:
Curt, are you talking about a UPS to help just in the case of brown outs, or for total power failures as well?
I ask because on my G90 test chassis with shot tubes I have literally shut the projector down hundreds of times with the hard off switch at the back. This is the same as ripping the plug out of the wall with the projector running. I have done it hundreds of times and have never had any damage to the tubes.
Granted, I never turn a good projector off this way because I am always fearful that something might happen. But I have never seen a problem with the Sony projectors when power is fully cut. On the other hand, I have never experienced a brown out when a G90 was running...
Also, on the Marquee chassis I have hung out with Mike Parker a lot when he works on them. Mike will literally pull out boards while the projector is running resulting in a shutdown with errors. I asked Mike if he has ever damaged a tube that way and he says no.
Posted: Wed Jun 02, 2010 3:05 pm    Post subject:
Look, EVERY projector has issues. Every car has issues. Heck, any DSP product (digital signal processing) audio device I've used save for one brand has had massive issues that I've had to deal with.
I'm not saying that EVERY time you turn a projector off/on quickly or if you have a brownout, that sets or tubes will die. I was recently questioning Terry's claim that a brownout snaps G90 tube necks, and of course 2 weeks after that, my G90 spot burned all three tubes.
I'm just saying that someone that doesn't have access to tubes or is a tech _MIGHT_ save their set if they put in on a UPS.
You should get a 'true RMS sine wave' UPS in my opinion, rated at 1000 VA. Don't use the UPS to finish the movie in a power outage, just use it to turn off the set via the remote if your power fails.
Posted: Wed Jun 02, 2010 6:47 pm    Post subject:
Rolling Eyes
Scott
I am confused. I think Crabb was implying that Barco has issues as well. From his whole post, I think he was saying that all of the brands have issues (except Ampro:wink:). Honestly, I think Crabb is just tired of hearing Dragan bash Sony at every turn.
I do have to laugh sometimes when you guys talk about how great the Marquee is. With all of the mods/updates/repairs, one has to wonder if it was ever a good pj. Also, what do you guys think of Scott's work if it it needs all of these mods/updates/repairs?
Posted: Wed Jun 02, 2010 6:49 pm    Post subject:
THanks!
Doc
I almost forgot the point of the thread. Very Happy I use to know of some decent ones. I will have to do some searching. From Scott's post, I would guess that the Marquees and Ampros are fine without one.
Posted: Wed Jun 02, 2010 7:18 pm    Post subject:
Rolling Eyes
The Marquee lvps was not our proudest moment, but Electrohome did not design it.
Posted: Wed Jun 02, 2010 7:22 pm    Post subject:
Rolling Eyes
ok i'll bite Very Happy The filament voltage came with the designed and built by Spellman power supply. It wasn't an Engineering (design) issue either but rather a defective part , the Trim pot (adjustable resistor). Even with this bad part, only one tube would normally get damaged. I've never seen a Marquee spot burn all 3 tubes EVER.
90% of the mod's are for increased performance, there's nothing wrong with the machines basic design.
Also, the base machine was Engineered in Canada in 1993 and re-designed in 95. It's basically still the same machine today. AFAIK, Scott came on much later with VDC and worked on some boards and technical bulletins. I know he designed a new neck-board for one.
Considering a new set of LUG's is $3600., to me installing them in a G90 is little better than putting $3600. into slot machines. Wink
Posted: Wed Jun 02, 2010 7:24 pm    Post subject:
BTW, despite my reputation as a Sony hater, I just sent a bunch of free boards to a guy in Canada and helped him fix a G70 he was battling for 6 months or more. the emtpy chassis is going to recycling. So I do have sympathy (not hatred) for folks who own sony products. Razz
Posted: Wed Jun 02, 2010 7:56 pm    Post subject:
Man, with all these funny posts I could have a field day here....... but I'll keep my mouth shut..... Laughing Laughing Twisted Evil Twisted Evil
Posted: Wed Jun 02, 2010 8:04 pm    Post subject:
Yeah I guess your right Spanky. Very Happy And I am not a sony or Ampro hater, i now own both Wink
To be fair i think i'll set up the 3600 before the G90 since i got that first.
And besides the LVPS which Tim says is not Ehomes proudest moment. Scott also knows about the Astig board noise and would love to re design it but the bean counters at VDC won't let him or fix many other issues he would like to.
Now i need a Barco and NEC and what the hell maybe a Seleco too ! Wink
Page 1 of 3
