Sharp Quattron Technology
skippyar
Posted: Sat May 29, 2010 6:10 pm    Post subject: Sharp Quattron Technology
Has anyone seen the advertisment for Sharp's new innovation and what are your thoughts.
SharpEurope Video Explanation: http://www.youtube.com/watch?v=eiKNzFTTsHo
SharpElectronicsUSA Commercial: http://www.youtube.com/watch?v=4hSnAxvRdmY
Paul.
Barco 500 Data Owner.
View user's photo album (45 photos)
dturco
Posted: Sat May 29, 2010 7:35 pm    Post subject: Re: Sharp Quattron Technology
Paul.
Oh my. Been there already Wink
https://www.curtpalme.com/forum_archived/viewtopic.php@t=20928.html
http://www.hulu.com/firefly
skippyar
Posted: Sat May 29, 2010 7:56 pm    Post subject:
Ah right, I did use the forum search option parameters before posting but found nothing under Quattron.
Posted: Sat May 29, 2010 9:04 pm    Post subject:
I can see some merit to the concept. It gives a wider color gamut BUT in order to fully exploit it, that wider color gamut has to be used in the production of the signal to be displayed. A matching four-color camera system would be required in order to fully exploit the fourth color.
I think that there is certainly some room for the idea of extending the color gamut. Look at anything which is a fluorescent or day-glow color. Photograph it, record it with a video camera. Print it out or display it on any display device. The result is nothing like what
you see with your own eyes when looking at the original item.
If the color gamut of the record-reproduce system was wide enough, fluorescent colors WOULD be seen with their fluorescent effect intact.
CJ
skippyar
Posted: Sun May 30, 2010 9:36 am    Post subject:
I did read this http://www.rgby.org/ though it doesn't really go into great detail.
I wondered what use it would be when source content is derived from RGB colorspace.
Some queries to my questions were reflected here: http://answers.yahoo.com/question/index?qid=20100426223651AAzX2XT
What I do find odd is how Sharp refer to the individual R G B Y diode elements as quad pixels. I thought pixels were collectively derived from the elements, seems an erroneous use of terminology.
Paul.
winduptoy
Posted: Sun May 30, 2010 9:45 pm    Post subject:
If the red and green were accurate, the yellow wouldn't be needed.
Posted: Sun May 30, 2010 9:52 pm    Post subject:
It can also be a matter of efficient use of the colors on hand.
If you filter out yellow as its own separate channel, it allows you to make more efficient use of red and green individually.
You wouldn't have to mix red and green to get yellow, so the red and green channels would not have to work hard when the signal
calls for just yellow.
You could easily extend the concept to a six color system, red, green, blue, cyan, magenta, yellow. Now complete the visual spectrum
with two more colors: A deep violet bordering on long UV, and a super deep red bordering on near IR. With that setup you should be
able to reproduce every color the eye can perceive.
It's probably been done, in a laboratory.
CJ
skippyar
Posted: Sun May 30, 2010 10:42 pm    Post subject:
I wondered at first if the introduction of this Yellow concept was geared towards including the CMYK colour model.
Perhap extending to Yellow (Z axis) is part of an initative to move towards creating a three-dimensional representation of a color space X, Y, Z for 3D TV. Just a thought, but then what do I know. I'm just a bush kangaroo.
Skippy.
Posted: Sun May 30, 2010 10:48 pm    Post subject:
What ever happened to Mitsubishi and the 6 color system?
Posted: Mon May 31, 2010 12:36 am    Post subject:
The entire RGB concept is based on how our eyes work, which are RGB devices. But the specific responses of our eyes in the R, G, and B ranges are due to the specific differences between how the cone pigments in our retinas absorb light. Retinal is the prosthetic group for each pigment. Differences in the amino acid sequence of their opsins accounts for the differences in absorption.
So, each specific type of opsin (retinal pigment) has a specific chromatic response characteristic. In order for our TVs and film to give
"perfect" color response, allowing us to see the full range of colors on the screen that we see in real life, the cameras, films, and display
devices would have to use sensors that have matching response characteristics. We don't have that. What we see as red, green, and
blue in our displays is an approximation of the pure red, green, and blue that the eye actually detects but it's not exact. It's reasonably close, though.
Here's a chart showing the actual response curves of the pigments in the eye of someone with normal vision.
Note that the red pigment actually has a very broad response curve and its peak sensitivity is closer to yellow than red.
[img]http://www.ncbi.nlm.nih.gov/bookshelf/picrender.fcgi?book=mcb&part=A6255&blobname=ch21f49.jpg[/img]
You might have to click or copy and paste to see this chart.
CJ
HogPilot
Posted: Mon May 31, 2010 1:18 am    Post subject:
I've always wondered why the lowest frequency opsin is referred to as the "red" pigment when it's clearly most sensitive at the yellow wavelength.
Posted: Mon May 31, 2010 4:27 am    Post subject:
Because the lowest frequency it has significant response at is in the red area of the spectrum.
The blue pigment is called blue because it has significant response in the blue area of the spectrum.
Both those colors represent the extremes of our vision's color range. Green falls in the middle, but is most sensitive in the yellow-green range.
The RGB we use in video is a good compromise as there are only so many easily engineered color response curves available for film,
video cameras, and display devices, but it's far from an accurate representation of our vision system and there are some things you can see that our video systems simply can't reproduce, like fluorescent colors. I think that would require extended blue and red range.
CJ
HogPilot
Posted: Mon May 31, 2010 8:58 pm    Post subject:
CJ
What I was getting at was the fact that the three receptors for our eyes peak at the frequencies for indigo (detects between violet and green), green (detects between blue and orange/red), and yellow (detects between blue/green and red); however they're often mistakenly referred to as blue, green, and red receptors, respectively. The "red" receptor actually has a low sensitivity to red, thus the moniker is a misnomer.
What would be really interesting is to know why red, green, and blue were chosen as the three primary NTSC colors way back when - was it a technological limitation of the time, was it based on our understanding of the eye at the time, or some combination of both?
Posted: Mon May 31, 2010 10:23 pm    Post subject:
It'd be primarily because you can't create colors that are outside of your color gamut.
With red being the lowest range of frequencies that the eye has substantial sensitivity to, and blue being the highest, it makes sense
to choose red and blue as your lower and upper range colors. This allows all colors between red and blue to be created by mixing
them (along with green) in appropriate ratios.
If you were to choose the strongest response colors of the eye, then our TV red would be closer to yellow and it's not possible to create red with yellow, green, and blue light in any combination. This would be a very limited color gamut with no reds.
But, our eyes have a wider color acuity range than the gamut covered by television as we've known it. A truly accurate color
system would have equal or wider total spectral response than our eyes do.
It would be very interesting to obtain a deep violet/near UV camera and mate it up with a CRT or digital projection device outputting similar spectra, and do the same for deep red/near IR and converge the images along with a standard projector. This should be
able to accurately portray every color your eyes can see, including day-glow fluorescent colors.
CJ
HogPilot
Posted: Mon May 31, 2010 11:16 pm    Post subject:
Actually this isn't the case - in fact, how do you think our displays fool us into seeing violet when that's a higher wavelength than blue? The S, M, and L cones (improperly referred to as blue, green, and red cones respectively) in our eyes don't report wavelength data to our brains, only stimulation level. The S cone, for example, can't tell the difference between violet and green light; it only can report the level to which a given wavelength stimulates it. This is why you need at least two types of cones to see any color - each cone is variably sensitive across a range of wavelengths, and the brain interprets the color we're seeing based on the different level of stimulus from each of the (in the case of humans) three cones. Turquoise is the result of mild stimulation from both the S, M, and L cones; mild stimulation of the M and L cones only is red; orange is the result of mild stimulation of the M cones and moderate stimulation of the S cones. Every color is the result of a certain combination of stimulation levels for each cone, so as long as you stimulate each cone to the proper level, it doesn't matter what the wavelength of light is used. This is why the basis for the RGB (or any additive) color system. An indigo/green/yellow system would work just as well as RGB from the standpoint of the human visual system.
True enough - there is the xvYCC gamut, but that simply hasn't caught on in commercial use (outside of some HD camcorders) yet. Maybe we'll see it in the next optical format that supersedes Blu-ray (if such a format ever comes to fruition).
Posted: Mon May 31, 2010 11:54 pm    Post subject:
But..violet isn't indigo, or near-UV.
Look at a Compact Disc (or better yet, if you have one, a LaserDisk) in sunlight. Look at the rainbows you can see in it.
The purple you'll see outside of the blue zone is NOT the same purple you get by mixing red and blue light! Though it's good enough
for television purposes, real spectral purple (Better termed Indigo) is a color that can not be ACCURATELY displayed or simulated with
an RGB system.
Neither does the purple you see by mixing red and blue (typo corrected) actually occur within a contiguous spectrum. But it's not the only color that
isn't in the spectrum. This particular "purple" is really a dark Magenta. Magenta does not occur in a natural spectrum.
CJ
HogPilot
Posted: Tue Jun 01, 2010 1:38 am    Post subject:
an RGB system.
Neither does the purple you see by mixing red and green actually occur within a contiguous spectrum. But it's not the only color that
CJ
We've already agreed that what's reproducible by the REC709 gamut isn't the whole range of colors detectable by the human eye, so it's definitely possible to see colors with our eyes that our displays can't reproduce with their native or calibrated gamuts.
However, the use of red and blue (not red and green as you said, which actually causes us to see yellow) does not create a "fake" shade of violet (which has a shorter wavelength than indigo). Interestingly, violet light does indeed stimulate the L and S cones, however it does not stimulate the M cone, which is how the brain differentiates between violet and say turquoise. This is why using R and B to create a color that our brain interprets as violet absolutely works, and that violet is no more fake than any other color that we see that's reproduced by the RGB system that all of our displays use.
skippyar
Posted: Sun Jun 06, 2010 9:44 am    Post subject:
Thanks for the sharing your views and the informative feedback.
Paul.
Posted: Sun Jun 06, 2010 2:29 pm    Post subject:
If I had some friends over and we were watching a movie and one of them said, "hey, that violet doesn't look right"....I'd throw him out with a do not return kick...... Laughing
HogPilot
Posted: Sun Jun 06, 2010 4:15 pm    Post subject:
an RGB system.
CJ
Where are you getting your info from? Not a single thing you've posted above - even in your corrected post - agrees with color theory or our understanding of the human visual system. You've even managed to throw in some bass-ackwards stuff which I also address below. No offense, but it seems like you're just pulling all of this out of your ass as you go along.
1. Violet is a higher wavelength of color than indigo. It is closer to UV than indigo, and in fact indigo is a color that was used by Newton to describe the range of color between blue and violet. So yes, violet is near-UV - it is the closest of any perceivable color to the UV portion of the spectrum. Although indigo not officially recognized as a color, it can most definitely be reproduced by our displays within the limit of accepted gamuts.
2. Yes, the color of purple that our displays show is the same color of purple that we see in real life. Just as with all the other colors in the SMPTE-C or REC709 gamut, its max saturation isn't the max saturation that we're capable of perceiving, but violet is "real" violet in the sense that our eyes and brains perceive it the same. Of course, if you have a poor display with a native gamut that is significantly undersaturated, its ability to reproduce any color will be stunted, but that's another issue entirely.
3. I have no idea what you mean by "not occurring in the natural spectrum." If you mean that magenta cannot be reproduced using a single wavelength of light, you're correct. HOWEVER, back to discussing how the human visual system works, our displays trick us into seeing an entire gamut of colors that they don't reproduce. Once again, because of how the eye and brain interprets color - measuring the stimulation differential of our S, M, and L cones - it doesn't matter whether a display uses actual violet light or tricks us into seeing violet by using red and blue, because on a physiological level our eyes can't tell the difference. As long as the proper stimulation level of the proper combination of cones is achieved, it doesn't matter if you use one wavelength or five, you'll see the exact same color.
