| Posted: Thu May 20, 2010 3:15 pm Post subject: Electronic Masking: DIY and very easy :) |
So I wasn't sure where to post this, but figured people would see it here. I know there is a lot of interest in electronic masking and the other day I built a system for myself. The building of the project only took the better part of a day. I thought about the project for weeks, but the building went smoothly.
Here are photos of the screen open at 178 and closed at 235. There is also a linked video showing the screen masking motion in real time.
VIDEO Download
http://www.cir-engineering.com/bin/masking/masking.wmv
I got most of the parts from www.av-outlet.com Here is a parts list of what I got from them.
Somfy LT30 IR Round Head 1.25" 12VDC Roller Shade Motor.
Somfy LT30 - IR1 - Single Channel IR Remote Control (Required for programming stops).
Three Rollease RB360 Shade Brackets.
Two Rollease REP03 End Plug for 1.25" Tubes.
AVO 12VD100W - 12VDC 1A White Wall Plug Power Supply.
Rollease SAPE03-RIGHT Pin End Spring Assist - 1.25" - RIGHT.
From HomeDepot I got a couple 2x4's, some aluminum "U" channel, Velcro, pulleys, screws, Gorilla tape, drywall anchors, and other odds and ends.
I went to a metal shop near me and got 1.25" round tubes for the rollers and 0.5"x1" rectangular metal tubes for the masking bars. Please note: You CAN NOT use a ferrous tube for the motor tube. This motor uses magnets to know where it is, and to memorize the stops positions. If you use a steel tube, your motor will not work correctly at all. You must use an aluminum tube for the motor tube.
I went to a craft store and got some black fabric for the masking.
Here are more photos.
Top Right 178
Bottom Right 178
Top Right 235
Bottom Right 235
Top Left 235 (see wound up cables)
Bottom Left 235
Cable to Masking Bar
Stabilizer Pulley
I got many original ideas from this thread on AVS http://www.avsforum.com/avs-vb/showthread.php?t=1219694.
Here is a quick explanation...
The motor goes inside the roller tube at the top right. The tension spring goes in the roller tube at the bottom right. The top and bottom round tubes are attached with the brackets and plastic bearings from av-outlet to a 2x4.
The fabric is taped to the round tubes with Gorilla tape. The fabric is wrapped twice around the masking bars and is again taped to the bars with Gorilla tape.
The top mask falls by gravity as it unwinds. The bottom mask is pulled up by coated metal cables attached to the bottom masking bar. The cables wind up around the top round tube. The cables are held to the top round tube with hose clamps and are held to the bottom mask bar by wire fasteners (available in the electronic section of HD).
The spring in the bottom right round tube pulls the mask back down when the mask is opened. The motor pulls the top mask up when the mask is opened.
The "U" channel holds the masking bars at the sides. I wrapped the ends of the masking bars with Velcro so there would be a smoother motion of the moving parts.
A 2x4 is anchored into the drywall about 2.5" from the boarder of the screen. These 2x4's hold the roller tubes and all hardware.
I would estimate that the entire project cost around $400.
Questions?
Last edited by CIR Engineering on Thu May 20, 2010 5:07 pm; edited 2 times in total
dochlywd
Joined: 25 Apr 2006 Posts: 346 Location: Saint Louis, Missouri
| Posted: Thu May 20, 2010 4:54 pm Post subject: |
He ain't lyin', man!!! I've seen it in person and it works flawlessly. I was amazed at the increased perceived contrast with masking in place. It really does make a difference and appears to be a pretty simple project.
Great job!
Doc
| Posted: Fri May 21, 2010 12:26 am Post subject: |
What are you using to control it?
I have started a project just like that (or close)
Mine uses rollers and cloth just like yours.
For motors and control I use two HiTec brand (HS-785HB) high torque multi-turn sail winch servos and a Pololu serial servo controller. I've programmed my Crestron system to send the correct code to the Popolu controller to make the servo's stop at the correct position. The speed at whitch the servos turn is also programmable.
One button push on my touch panel sends the screen to a pre-set aspect ratio and it stops exactly where it's supposed to every time.
_________________ Chip
| Posted: Fri May 21, 2010 12:55 am Post subject: |
| dochlywd wrote: | He ain't lyin', man!!! I've seen it in person and it works flawlessly. I was amazed at the increased perceived contrast with masking in place. It really does make a difference and appears to be a pretty simple project.
Great job!
Doc |
Amen.
Masking is the biggest tweak of all.
I simply cannot understand why most CRT users somehow think they don't need it, when CRTs have crappy ANSI Contrast.
Masking makes a staggering difference to the quality of the image.
My masking system is similar. Except I just use a pull string at the side, it works plenty well enough.
CZ Eddie
| Posted: Fri May 21, 2010 2:33 am Post subject: |
Looks great!
How well do you think that setup would work for a constant-height screen?
_________________ Back after a digital sabatical.
| Posted: Fri May 21, 2010 2:43 am Post subject: |
| CZ Eddie wrote: | Looks great!
How well do you think that setup would work for a constant-height screen? |
Um......WTF?
Think that one through Eddie....
Or, do you mean: Can the motor be adapted to move a curtain sideways?
| Posted: Fri May 21, 2010 2:44 am Post subject: |
Totally awesome, Craig. Beautiful. I so want to do masking... Subs and masking are my two high-priority projects. The subs are easy... The masking... Not so much. Gotta kinda tear my screen wall apart.
Anyway, big kudos - looks perfect... Pretty much exactly what I was going to do, too. I'm glad to see pics and hear how the design works. Thanks for posting!!!
CZ Eddie
| Posted: Fri May 21, 2010 2:46 am Post subject: |
| Mark_A_W wrote: | | CZ Eddie wrote: | Looks great!
Um......WTF?
Think that one through Eddie.... |
I'd rather not. Why don't you just point out the flaw in my question.
| Posted: Fri May 21, 2010 2:57 am Post subject: |
Well...constant height doesn't need a moving vertical mask. The height is constant.
You need moving side curtains.
Maybe you could use the same motor setup to drive the pull strings on standard curtains.
But mechanically, this is a totally different situation.
CZ Eddie
| Posted: Fri May 21, 2010 3:21 am Post subject: |
| Mark_A_W wrote: |
Well, hence my question.
But I'm not interested in curtains so much as I am the material he's using.
| Mark_A_W wrote: |
But mechanically, this is a totally different situation. |
Not sure why it can't be adopted to CIH. But then, that's why I asked.
| Posted: Fri May 21, 2010 3:45 am Post subject: |
CZ,
I think Seymour screens has a link to a good DIY fabric.
| Posted: Fri May 21, 2010 1:01 pm Post subject: |
Great job!
Doc |
Thanks man And so far you are the only one from the forums who has actually seen it in person.
| Posted: Fri May 21, 2010 1:13 pm Post subject: |
| stefuel wrote: | What are you using to control it?
One button push on my touch panel sends the screen to a pre-set aspect ratio and it stops exactly where it's supposed to every time.  |
The title of this thread is "Electronic Masking: DIY and very easy "
The motor is designed for electronic shades applications and fits inside the roller tube that the mask winds up around. Below is a photo of the motor.
The motor costs $135 from AV-Outlet and it has all the control system integrated on a small board that is encased inside the motor housing. You set the end limits with the IR (or RF) remote that you buy with the motor. You must use the original remote to set the limits (you can't use a universal). Once the limits are set, the screen masks its self to the exact same position every time and it does so perfectly.
Here is the section from the LT30IR manual on setting the limits. It takes 15 seconds to do.
So on mine, the OEM remote up button masks to 235, and the down button opens up the screen to 178. I have a button on my universal remote that closes the screen and at the same time switches my Lumagen to 818x1920 72Hz output mode I have another macro that opens the screen and switches the Lumagen output to 1080p 72Hz.
Last edited by CIR Engineering on Fri May 28, 2010 1:16 pm; edited 1 time in total
| Posted: Fri May 21, 2010 1:14 pm Post subject: |
| Mark_A_W wrote: | | dochlywd wrote: | He ain't lyin', man!!! I've seen it in person and it works flawlessly. I was amazed at the increased perceived contrast with masking in place. It really does make a difference and appears to be a pretty simple project.
Great job!
Doc |
Amen.
My masking system is similar. Except I just use a pull string at the side, it works plenty well enough. |
Totally. My wife is amazed at the image quality improvement as well which is always nice.
I thought about using a manual system as well Mark, but I really wanted electric
| Posted: Fri May 21, 2010 1:17 pm Post subject: |
I had a client ask me that the other day. Constant height is a totally different problem and will require quite a bit of tweaking. I would consider a semi rigid masking fabric, or some kind of tension system.
I think constant width is easier to design.
| Posted: Fri May 21, 2010 1:19 pm Post subject: |
| Spanky Ham wrote: | CZ,
I think Seymour screens has a link to a good DIY fabric. |
I am just using felt right now for the masking material. I want to get something better before I trim in the system. Where is this link? Or does anyone know a good fabric that I could use instead of the felt I have now?
| Posted: Fri May 21, 2010 1:21 pm Post subject: |
This is the spring I used inside the bottom right roller tube.
This is what pulls the mask at the bottom down when I open up the screen to 178. It also keeps the fabric taught when I close the screen to 235.
| Posted: Fri May 21, 2010 1:41 pm Post subject: |
| ecrabb wrote: | Totally awesome, Craig. Beautiful. I so want to do masking... Subs and masking are my two high-priority projects. The subs are easy... The masking... Not so much. Gotta kinda tear my screen wall apart.
SC |
Thanks for the kudos
This project was totally easy compared to how difficult I thought it would be. I mean, I thought about my design for at least three of four weeks. I ordered the parts and they sat here for another week or two. But when I finally started building it only took me about five or six hours to have the entire thing almost complete.
I had two complications. The first was that I originally used a round steel tube for the top mask with the motor inside it. The motor would not memorize the stops, and when I would do a factory reset on the motor it would freak out and unwind my entire system and everything would fall all over the place (lots of very loud cursing would follow). After this happened at least six times I was annoyed.
This was a Friday evening so I had to wait until the following Monday to talk to AV-Outlet about what I thought was a defective motor. When I talked to Ken at AVO he discovered that I had used steel and told me that was the problem. A few days later I got an aluminum tube and the motor worked perfectly.
Unfortunately, when I took the bearing out of the old steel tube it broke, so I had to wait four more days to receive a new $3 bearing that cost $6 to ship However, after that I was good to go.
The hardest part is getting everything wound up. Remember, the bottom is on a spring and is always under tension.
Winding up everything is easier with two people. I first did the bottom mask and started by attaching the fabric to the rectangular masking bar with the parts on the carpet laying in front of the screen. I then slid the bottom masking bar (and fabric) in between the channels on either end. I held the bottom masking bar well above the 235 position and then attached the green steel cables to the bar. I pulled the cabled (one at a time) up to the top roller tube and wound them around it five turns (I had calculated four would be enough 2*pi*R). Make sure you wind the right way or you will obviously have serious problems. With the cables in position I clamped them down with the hose clamps.
I then pretensioned the bottom sprig by rolling it up about twenty turns. I attached the fabric to the bottom roller tube with the Gorilla tape. Once the tape is on and the cables are fastened the system is under tension and will hold its self together...
...level the bottom masking bar by adjusting the cable lengths, and then move onto the top...
| Posted: Fri May 21, 2010 7:17 pm Post subject: |
| Spanky Ham wrote: | http://www.syfabrics.com/View.aspx/Plush-Triple-Velvet/Black-Plush-Velvet/681/264
This is the stuff that Seymour recommends. I haven't kept up with this stuff, as I know there are other places to get good fabric. Chris is a good guy (like all people from Iowa ), so I am sure this is one of the best fabrics at a reasonable price. |
Cool thanks. I just ordered a swatch of it.
