Help: Bright line in the middle of the screen
Goto page Previous  1, 2, 3
yonexsp
Posted: Wed May 05, 2010 11:40 pm    Post subject:
Here is one:
http://www.curtpalme.com/images/XGimage009.jpg
Which cable is it?
Posted: Thu May 06, 2010 12:20 am    Post subject:
None. They are not on the neck board. I already looked at those pictures and there are not any pics of what you need to disconnect.
let me look in the service manual. Give me a few. Unless someone else has a pic.
Posted: Thu May 06, 2010 12:43 am    Post subject:
Here's the best image I could find. Disconnect the wires from the C and A drive and see if it affects the line.
 Filesize:  179.68 KB
 Viewed:  2566 Time(s)
yonexsp
Posted: Thu May 06, 2010 12:50 am    Post subject:
why am I feeling nervous now lol!!!
Posted: Thu May 06, 2010 1:06 am    Post subject:
Crap. I just realized I need to be specific with you. DONT disconnect all the wires to these 2 boards. Only the ones going to the deflection yolks (tubes). It probably wont run if you disconnect the other wires.
CR, CG, CB.......AR, AG, and AB.
yonexsp
Posted: Thu May 06, 2010 5:52 pm    Post subject:
Mark_A_W wrote:
yonexsp wrote:
no, only full white
Internal test pattern only?
Or external video/images?
Both
royuk
Posted: Fri May 07, 2010 11:08 pm    Post subject:
i have the save 'vertical line' with my 1209s and have never got rid of it until now.
It has bugged me since i got my pj and seen in any white/light colour areas of a movie. Very annoying!!!
Just got a lumagen hdp and hdfury3. When i run 1080p through this the line is gone. With 1080i it's still there.
The lumagen has not been set-up properly yet and the pj needs a reconvergence!
royuk
Posted: Fri May 07, 2010 11:15 pm    Post subject:
As for your horizontal line. Is it to simple to say that's the 'line of co-incidence'. I have that too depending on the set-up.
yonexsp
Posted: Wed May 12, 2010 4:01 pm    Post subject:
Seems to be. It is not there I guess with other signals.
Maybe the old girl is just showing here age
dvb1994
Posted: Thu May 13, 2010 7:38 pm    Post subject:
Hi, i had the same problem with my barco cine 6 and it turned out that the problem was the offset correction i the service menu.
i don't know if this is your problem or if there is an offset correction on your projector, so if i'm wrong please correct me
Posted: Fri May 14, 2010 12:27 am    Post subject:
yonexsp wrote:
macgyver655 wrote:
yonexsp wrote:
macgyver655 wrote:
If you disconnect the video to the neck boards how are you getting a raster on the screen? Are you turning up the brightness?
Yes
Ok, not to contradict Mark on this but without video connected I cant see it being a white balance issue since white balance comes through the video.
To add, tyhe vertical line does not appear with the video disconnected. But the faint horizontal line is still there
The vertical line is a white balance issue.
Usually a horizontal line is caused by over use of convergence/alignment. Other than that, I have no idea.
Page 3 of 3
