XG's and 1080p question.
VideoGrabber
Posted: Sun Apr 18, 2010 5:05 pm    Post subject:
Craig wrote:
> The other option on the NEC and Radiance is to run something just below 1080p's 1080x1920. You could crop say 10~15 pixels off the vertical and say 15~30 off the horizontal image area. Then match that on the input using the sizing to maintain perfect 1:1 mapping without scaling to the custom resolutions. <
If I understand what you're saying, this sounds like you're talking about cropping active content. At least, if you're maintaining 1:1 as you indicated.
> This is a similar technique to running 818x1920 for 2.35 movies <
No, with AAS (active-area scanning) you're not cropping any actual content. Here, you would be. But I agree that you could probably get away with it, and the end results of being able to run with proper cadence would outweigh any losses. 30 pixels on the horizontal would be <1% on each side. Probably never noticable. If that's all it took to let you fit your clocks into the bit bandwidth, it would be a good tradeoff.
- Tim
Posted: Sun Apr 18, 2010 5:27 pm    Post subject:
Correct on every count.
Posted: Sun Apr 18, 2010 5:31 pm    Post subject:
...but I did say "This is a similar technique..." and not identically the same thing. The concept is similar in setting up the VP; be sure to maintain 1:1. However in this case, you are indeed cropping active pixels, so you lose a small amount of content.
VideoGrabber
Posted: Sun Apr 18, 2010 5:57 pm    Post subject:
Thanks, Craig. One other option, assuming you have a quality scaler, sacrifices the 1:1 mapping (which you don't really need on CRT anyway, right?) is to keep all the pixels in the full width and height, so no content is lost, but scale the horizontal area down from 1920 to something more modest.
If your source material is ATSC, you never actually have 1920 anyway. In that case, it's limited to ~1770, based on comprehensive testing that was performed during the evaluation phase. Blu-ray may come closer to 1920, but even there they employ both horizontal and vertical filtering... just not as aggressively as they used to on DVD. HDCam material (which they use on the HDNet series) is limited to 1440 as well. So preserving the full 1920, in many cases buys you nothing.
Thus by dropping the 1920 down to 1800 horizontal (6% lower), you can fit 1080p at 72 Hz into the bit-rate constraints, and in most (all?) cases with no visually perceivable differences (maybe with a test pattern). This was something I suggested to Clarence back a year or more ago, when he was first trying to get 72p to work on his G90. But I never heard if he tried it or not.
The bottom line is that if you've got a good scaler, there are a number of options available to you that you wouldn't have otherwise.
- Tim
dvh99
Posted: Sun Apr 18, 2010 6:01 pm    Post subject:
quick question does the radiance use front porch settings.
and is this needed on a crt.
it says 2200 total so does this simply mean a back porch of 2200-1920.
craig i have looked at the excel file and it says its for no raster ringing on the g90.
does this count for lcp and lugs or is this general for all 9inch crt pjs.
i looked at my powerstrip settings and it gives me a pixel clock of 188mhz so there must be something there to be gained.
dennis
Posted: Sun Apr 18, 2010 6:47 pm    Post subject:
Can you provide reference to this? While I never went looking, this is the first that I have head of it. And what evaluation phase are you referring to? I've got to ask since the adoption of ATSC was in 1995-1996, and there were some 18 standards afford. Are you talking about a specific broadcaster's case?
To suggest that it buys you nothing is misleading, IMO. Even if all 1920x material were based on 1440x original source capturing and pixel interpolation to simply chop off a sliver of left and right side suggesting its ALL made up on those ends is not assumed.
And do not get me wrong. I am fully aware of the eye's less than sensitive nature when it comes to horizontal resolution. But I am not about to conclude my eyes only care about the in the middle pixels. If this were the case then the hell with corner focusing, convergence, etc.
Posted: Sun Apr 18, 2010 9:08 pm    Post subject:
No. The question is not 1:1 on the CRT. What happens when you lose 1:1 in the VP is that the image must be scaled and this should be avoided.
1:1 in the VP maintains the exact pixel information, for each pixel, without any molestation of the image. As soon as you scale, you have scaling artifacts, noise, and loss of resolution.
Setting up 1:1 for a custom resolution requires the use of test patterns that show horizontal and vertical lines, one pixel wide, alternating back and white. In other words the patterns must show the max resolution on the screen.
With the patterns up, you adjust your input size so that you can see exactly the 1:1 pixel pattern without banding horizontally or vertically. At that point you know you hit it.
I will point out, that on the Radiance it is very easy to setup 1:1. Just lower the active pixels on the output resolution, and then turn off "scale bias" in the input menu. Done.
Posted: Sun Apr 18, 2010 9:10 pm    Post subject:
Yeah, this is a cool trick and I have used it before to get 1080p 16x9 72Hz Thumbs Up ...almost Wink
VideoGrabber
Posted: Mon Apr 19, 2010 11:09 pm    Post subject:
There was considerable discussion over on the A forum, but it was a number of years ago. If you can't locate it, let me know and I'll see if I can dig it up.
I'm talking about 1920x1080i.
At no time in that discussion did I ever suggest chopping anything off either side. This was an alternative that avoided any chopping at all, by scaling the full 1920 input down to, say, 1800.
Glad to hear it. That would be silly. And not in any way, shape, or form what was being suggested.
- Tim
Jesse S
Posted: Tue Apr 20, 2010 2:32 am    Post subject:
Mark_A_W wrote:
Just remember, if you try an interlaced res with Powerstrip, you HAVE to put the card into "interlaced mode" first, using the ATi CCC or Windows Display settings.
If you don't you will only get the top half of the screen.
I really dunno what is wrong with your setup Jesse, 1080i 96hz is superb on an 8" LC projector. Detailed, no flicker, and smooth pans.
60hz is the work of the devil. There is no reason to run 60hz for movies - even my plasma and bluray run 24p.
This is my problem with 1080i
I have a little astigmatism (in my eyes) and I can still see the lines clearly at 10'.
MikeEby
Posted: Tue Apr 20, 2010 2:40 am    Post subject:
yep me too, I saw the same noise...really bad on white images...I did actually run 1080p/72 for a while. It was pretty soft until the projector warmed up, it really looked very good but a 2 hours warm up was crazy. I ended up running 1600x900p/72 and quit tweaking and started enjoying my theater.
Posted: Tue Apr 20, 2010 3:16 am    Post subject:
That's really weird.
I tried 1920x804p at 72 hz (active area scanning) and the scanlines in a white area were identical to the fieldlines in 1080i 96hz.
I couldn't tell them apart.
Posted: Tue Apr 20, 2010 4:01 am    Post subject:
Mike,
I know someone else who did this with their 135LC and enjoyed it. When he side graded to a G90, he thought the image at that res was as good as 1080p on his G90.
Jesse S
Posted: Tue Apr 20, 2010 4:57 am    Post subject:
Is the theory that with a higher refresh, the fields are drawn often enough that there isn't enough time for phosphor decay to show the blank areas?
120hz should look different from 96 if so.
With 96hz it just looked like regular 1080i60 from a cable box.
Maybe each of us perceive phosphor decay differently. I can't watch 48hz (progressive) but some have no problem with it
VideoGrabber
Posted: Tue Apr 20, 2010 5:26 pm    Post subject:
One problem there is you don't say what the camera settings were (though you did indicate that's what you were perceiving with your eyes). Too short an exposure has the potential to exaggerate interlace visibility.
Mark_A_W wrote:
I tried 1920x804p at 72 hz (active area scanning) and the scanlines in a white area were identical to the fieldlines in 1080i 96hz. I couldn't tell them apart.
Easy enough. Just put your hand in front of the screen, and take a shot of 1080i like Jesse did. It would be very interesting to see the differences.
- Tim
Jesse S
Posted: Tue Apr 20, 2010 8:57 pm    Post subject:
My shot accurately depicts what I see standing at the screen. Everyone running 1080i96hz should post a shot so we can see how/if it varies with different projectors.
It's too bad that 1080p72hz has so many problems. It's not fully resolved like a G90/marquee 9500, but the increase in pixel density is very apparent. Running at 1280x720 is much less "fine". Maybe I'll try 1440x900 again.
mcintoshman
Posted: Thu May 20, 2010 2:53 am    Post subject:
CIR Engineering wrote:
Jesse S wrote:
I've tried setting up 1080p 72hz and it's always a mess. There is either raster wrap or bright/dark bands with streaking horizontally. Larger porches make no difference.
Perhaps someone has timings that work?
As to 1080i 96hz, sucks. We've visited this idea already Smile
I would never even try 1080p 72Hz on any NEC. That to me is just really pushing it and I would be worried about burning up the projector. Frankly, 1080p 60Hz is already pushing things.
I sure am happy I found this thread.
I am still a newbie compared to all the brain power
flowing around here. I bought a Runco 991 and was
wanting to use my computer (Mac) and I chose
the resolution of 1600 and 1420@ 72hz.
My FH 85 and Fv 75. Is this too high
for my projector to operate safely? I am
feedind the computer to a Leeza, then
to my projector using rgb passthrough.
Thus no processing. When feeding HD
Direct TV with the res. Set at 1080p @
50 Hz, the FH is only 59 fv 49. I'm trying
to understand what determines the FH.
Also, would it be better to use way lower
resolution with my computer than
1600 x 1420 and then because the image
would be way bigger on my screen,
simply down size the image with the
position? I hope this was not too long.
Mcintoshman
Jesse S
Posted: Thu May 20, 2010 5:15 pm    Post subject:
1600x1420 is an odd resolution. It's also too high for an XG unless it's a 4:3 res and you use all of the raster.
Is there any reason you want that res rather than something 16:9 like 1280x720?
mcintoshman
Posted: Thu May 20, 2010 5:27 pm    Post subject:
Sorry my mistake, it is actually 1600 x 1040.
I will try 1200 x 720. Thank you,
Jesse S.
