goodshucken
jkruger
| Posted: Sat Apr 03, 2010 3:00 am Post subject: |
You have to use the memory block that matches the input frequency that you are using. Each memory block must be converged and aligned for the input that matches it.
I'm not going to tell you to read the manual again, you are either too lazy or you can't read. This hobby might be too much for you. Sorry, I'm done.
goodshucken
| Posted: Sat Apr 03, 2010 3:12 am Post subject: |
i don get it i tryed each block i evan used the text key to adjust it and it still looks like a wavey pos i give up tonight
| Posted: Sat Apr 03, 2010 4:22 am Post subject: |
| goodshucken wrote: | | i don get it i tryed each block i evan used the text key to adjust it and it still looks like a wavey pos i give up tonight |
That's a fine picture you got there.
Any of the Barco guys know if there's a sync that you can set like the other projectors. This looks like the sync maybe set wrong.
| Posted: Sat Apr 03, 2010 5:00 am Post subject: |
Tom, 1024x768 is negative sync by default on most PC's
| Posted: Sat Apr 03, 2010 5:03 am Post subject: |
But is the signal from a PC ? This guy is all over the place in multiple threads.
| Posted: Sat Apr 03, 2010 5:07 am Post subject: |
| Tom.W wrote: | But is the signal from a PC ? This guy is all over the place in multiple threads.  |
That's my understanding from all the ping pong'ing. What else put's out 1024x768?
dturco
| Posted: Sat Apr 03, 2010 1:29 pm Post subject: |
Goodshucken,
Here is a new tool from Goggle that might help you with your Queries.
Once you read and comprehend the instructions everything will be clear as to the operation of you BACO 800.
http://www.google.com/mentalplex/MP_faq.html
http://www.hulu.com/firefly
| Posted: Sat Apr 10, 2010 12:08 am Post subject: |
Hey Goodshucken, how's it going over there? Please answer in this thread
