kylemm
Joined: 10 Feb 2010 Posts: 4 Location: East Central Indiana
| Posted: Tue Mar 23, 2010 8:47 pm Post subject: Parts for the oh so wonderful ctc195 |
Hey all,
I have a 1999 RCA P61940. It is chassis PTK195E2T, the main board is chassis ctc195E. My HOT and flyback went bad and I replaced them. While adjusting convergence, I accidently cycled the power quickly a couple times because I had the front button pcb in hand. My HOT shorted again and the chirping started. I decided to inspect things more closely and found no ring cracks or cold solder joints. I did find 4 resistors that are discolored from overheating: R14110, R14159, R14512, and R14703. Some of the color bands are cooked beyond recognition. My service manual only covers chassis ctc195A-D. I really don't do enough repairs to buy another service manual, especially since none of the downloadable manuals specify the chassis variations covered. The color bands that I can read don't all match the parts lists for the previous chassis variations.
If someone can give me the correct values or even better an E chassis parts list and/or schematics, I would greatly appreciate it.
I know that once the factory deficiencies are corrected these are great projectors. I may convert it to a home theater projector just for S&G's since I have another rear projection tv.
Thanks.
_________________ Just a hobbyist looking for ways to spend the time I don't have!
| Posted: Fri Mar 26, 2010 3:15 pm Post subject: |
Are you still looking for this info?
kylemm
| Posted: Sat Mar 27, 2010 5:17 am Post subject: |
I sure am. I haven't had any luck anywhere.
I love your animated gif lettin' the smoke out! Did you make that?
| Posted: Sat Mar 27, 2010 5:25 pm Post subject: |
I'm working on the info. Give me a little time. this one is a little difficult.
The avatar is one that I found somewhere.
kylemm
| Posted: Sat Mar 27, 2010 7:42 pm Post subject: |
OK, I have few resources and the slowest dial-up internet imaginable, and NO high speed availability, so you can imagine my difficulty.
I really appreciate the help.
| Posted: Sat Mar 27, 2010 7:44 pm Post subject: |
Don't feel bad, in high school I worked on CTC 38s. THe oldest one I worked on was a CTC 20.
| Posted: Sat Mar 27, 2010 11:13 pm Post subject: |
Alright, I called in a favor and got the info. Since you only have dial up forget sending it to you. If you need a schematic or print section just post here what you need and I'll post an image here. Here's you info.
R14110= 20K/3w
R14159= 12K/3w
R14512= 150 ohm/2w
R14703= .56 ohm/2w
Now 110 and 159 are source B+ and source +33v so they would be critical in value.
512 is +13v source off deflection and 703 is filament.
Let me know if you need anything else.
| Posted: Sun Mar 28, 2010 2:38 am Post subject: |
| Curt Palme wrote: | | Don't feel bad, in high school I worked on CTC 38s. THe oldest one I worked on was a CTC 20. |
dturco
| Posted: Sun Mar 28, 2010 4:22 am Post subject: |
| macgyver655 wrote: | | Curt Palme wrote: | | Don't feel bad, in high school I worked on CTC 38s. THe oldest one I worked on was a CTC 20. |
Ahh, the old, where's the pliers, so I can change the channel deal
http://www.hulu.com/firefly
kylemm
| Posted: Sun Mar 28, 2010 6:42 am Post subject: |
macgyver,
Thanks for the info, The values seem to match the colors I can make out. I suppose 703 could be a dark blue, not black as I thought. Maybe I can return the favor some time. I go to the public library, 20 minutes away, for high speed access. High speed is available from telco 2 miles away and wireless 1/2 mile. They ran fiber through our town but not to it.
Curt,
Sounds like fun! I think we had one like that next to our Vic-20 computer growing up. Thanks a lot for having this forum. I am a firm believer in sharing information and trying to help other people learn.
The resistors read within tolerance (just barely)at room temp but you can see why I questioned them and will replace them.
| Description: |
| Filesize: |
78.88 KB |
| Viewed: |
104 Time(s) |
harrypotter_r2
| Posted: Wed Jan 19, 2011 11:06 pm Post subject: |
Hi Macgyver:
I need the schematics for the ctc195E,can you share it please? Thanks in advance..best regards
| Posted: Wed Jan 19, 2011 11:41 pm Post subject: |
| harrypotter_r2 wrote: | Hi Macgyver:
I need the schematics for the ctc195E,can you share it please? Thanks in advance..best regards  |
I believe I have the E2 and the 195 training manual. Would these suffice? I would have to dig around to see if I have just the E.
| Posted: Thu Jan 20, 2011 12:28 am Post subject: |
Whazza matter Potter, magic wand broken?
(sorry, couldn't resist!)
| Posted: Thu Jan 20, 2011 12:31 am Post subject: |
| Curt Palme wrote: | Whazza matter Potter, magic wand broken?
(sorry, couldn't resist!) |
Hahahaha
I pulled out my RCA discs. As you know there are a lot of versions of the 195. And I should have them all. Is this a direct view or RP? Give me the full model number.
harrypotter_r2
| Posted: Thu Jan 20, 2011 10:05 pm Post subject: |
Hi:
The main board is chassis ctc195E..I already have the raining manual..Thanks in advance..Best Regards
Harry
| Posted: Thu Jan 20, 2011 10:17 pm Post subject: |
| harrypotter_r2 wrote: | Hi:
Harry
Well, there's the problem right there.
(sorry, I'm being a goof. I worked on some CTC195s back in the day, but I've forgotten most of it, otherwise I'd actually post something useful...)[/b]
| Posted: Thu Jan 20, 2011 11:10 pm Post subject: |
| Curt Palme wrote: | | harrypotter_r2 wrote: | Hi:
Harry
(sorry, I'm being a goof. I worked on some CTC195s back in the day, but I've forgotten most of it, otherwise I'd actually post something useful...)[/b] |
Well aren't you just a regular comedian lately......
| Posted: Thu Jan 20, 2011 11:13 pm Post subject: |
Harry
Well Harry. The manuals I have are on disk which are actual RCA disks and as such require RCA software to open. They are not PDF's. SO. If you need schematics I can probably post screenshots of such. What schematics do you need?
harrypotter_r2
| Posted: Fri Jan 21, 2011 5:18 pm Post subject: |
Macgyver655 & Curt Palme: Thanks a lot for your support...
-- Model :P56930BL
This TV set dont turn on..but before I start with the troubleshooting I wish have all the info i can achieve and tools..if you can supply the screenshoot schematics from the main board and the supply p[ower supply first ..i will appreciate it... Thanks in advance and Best Regards..
Harry Potter
| Posted: Fri Jan 21, 2011 5:56 pm Post subject: |
| harrypotter_r2 wrote: | Macgyver655 & Curt Palme: Thanks a lot for your support...
-- Model :P56930BL
Harry Potter |
I'm curious Harry, how did you stumble on our little site here?
