Marquee Banding Fix
Posted: Wed Mar 24, 2010 3:55 pm    Post subject:
I removed it. I Just wanted to see if this was Mikes own fix or the one who has an intellectual intreats in it(The one who came up with it).
Yes the chip in my Pic is a specially programed chip that alters the wave forms. I am not 100% sure on what it involves but I have the schematics and the pics on how to do it. I will try to find time and do one of my longbows with this as I do have banding on the one.
nashou
dvh99
Posted: Wed Mar 24, 2010 6:07 pm    Post subject:
nashou will you post youre results when done im really curious.
btw what do yuo use to remove chips, i still have those 3 lme opamps for the focus board but without the proper tool i wont risk replacing them.
dvh99
Posted: Wed Mar 24, 2010 6:12 pm    Post subject:
? 1 more thing you have banding on 1 but not on the other.
i thought you had 2 of the same longbows for your blend.
Posted: Wed Mar 24, 2010 6:40 pm    Post subject:
Yes i do have two of the same PJ's. The one on the right has the banding. I think I might be able to get it worked out . I spent more time on the Left PJ as that one had a cold solder joint on one of the CLM buffering caps and would initialize on its own. So i really worked on set up with that one and then used the Video processors controls more to move the image around compared to using the PJ controls. That helps out some as well. And I think I did a better job centering the green, red, and blue Focus coil and CPC magnets where i am using very little convergence to line them up. I can do a convergence reset and need only a few clicks to move the center for red and blue to line up with green.
There are many methods to remove the chips, one good one is to load on the solder to cover all pins and then just lift the chip off. the use soldering braid to wick the excess solder off. do a search on the web and you should find some other tips.
Posted: Wed Mar 24, 2010 7:02 pm    Post subject:
For DIP packaged IC removal I like to use a small cutting wheel and cut the chip body away from the legs, then each leg can be heated and extracted by needlenose pliers, one at a time.
Posted: Wed Mar 24, 2010 7:20 pm    Post subject:
This is how I take ships off. You can get rework stations for less than $100 now.
http://www.youtube.com/watch?v=Z-6vPyG8MGA
http://www.youtube.com/watch?v=MOEHstgaVLM&NR=1
Posted: Wed Mar 24, 2010 7:30 pm    Post subject:
This is pretty much exactly how I put them back as well.
http://www.youtube.com/watch?v=wQXhny3R7lk&NR=1
Posted: Wed Mar 24, 2010 7:31 pm    Post subject:
I have an Aoyue work station similar to the one in the video. I assume you do not have one but i paid 159 bucks for mine and it gets lots of use.
Athansios
dvh99
Posted: Wed Mar 24, 2010 11:24 pm    Post subject:
wow i really need that device.
with that thing you can save hours.
tx for the replies.
Sparky015
Posted: Thu Mar 25, 2010 12:05 am    Post subject:
cool, Craig's 3rd link shows a guy that uses the same machine I do. The Pace MBT-250. It really does save hours. Not a cheap setup though.
~Paul
Posted: Thu Mar 25, 2010 12:15 am    Post subject:
I have this one the 968
http://store.sra-solder.com/product.php/6267/26
Sparky015
Posted: Thu Mar 25, 2010 12:27 am    Post subject:
very nice price. You can't go wrong with that. I got mine thru work, so I paid a similar price. Here is the link to mine.
http://www.amazon.com/gp/product/B000PDUQMO/ref=pd_lpo_k2_dp_sr_2?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000PDQMKY&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0SJ2CSRH97EDTMJW4MF3
Paul
Posted: Thu Mar 25, 2010 12:31 am    Post subject:
Damn!!!! I want to up grade mine to the hotter 70 watt iron for some other non delicate jobs. The added De Soldering gun will be a big heal also.
http://store.sra-solder.com/product.php/6268/0
Sparky015
Posted: Thu Mar 25, 2010 12:35 am    Post subject:
Wow, $250 is an incredible price for that!
~Paul
dvh99
Posted: Thu Mar 25, 2010 9:06 am    Post subject:
think i will go for this 1
http://www.eleshop.nl/aoyue-2702-4in1-station-p-186.html
Posted: Thu Mar 25, 2010 9:41 am    Post subject:
Edit
Posted: Thu Mar 25, 2010 12:16 pm    Post subject:
If you buy an Aoyue, look on eBay first. I have purchased a few of them from authorized sellers and the price on eBay is less than that of other sources. There is even a portable hot air rework gun that is only $44.
Posted: Sun Mar 28, 2010 10:21 pm    Post subject: Update!!
I've installed this mod on two different CLMs so far. It works extremely well!
I first needed a few days to play with it and become familiar with it.
Sometime next week I'll ship the second CLM to Tim Martin or one of the other Electrohome experts for further evaluation.
My initial observation: Thumbs Up Thumbs Up
Posted: Sun Mar 28, 2010 11:23 pm    Post subject:
Hmmmmm,................wait a minute..............................it's coming to me...........................I'm having a thought...........
It's almost here.........................My head is starting to pound...................................Mike Parker has..........................
has......................................has.........................invented
BANDAIDS Laughing
