Marquee Banding Fix
Posted: Tue Mar 23, 2010 2:40 am    Post subject: Marquee Banding Fix
Of the most recent mods I'll be offering around the first of April, the following one I'm most excited about..Very Happy
Finally there's a fix to make that dreaded BANDING on a marquee completely go away. The mod is not a simple one. It would require quite a bit work to include a special. that's all I'll be sharing on it for now, but the pictures (below) should clearly show how well it works.
More will be mentioned about it and the Super VIM only mod real soon.
Posted: Tue Mar 23, 2010 2:47 am    Post subject:
Damn, that's REALLY impressive!!!
Posted: Tue Mar 23, 2010 2:10 pm    Post subject:
cool
Sparky015
Posted: Tue Mar 23, 2010 2:30 pm    Post subject:
Cool. Nice mod work. Is this banding only on the newer machines? I don't believe mine has it, or is there a setup that shows it the best?
~Paul
Posted: Tue Mar 23, 2010 2:35 pm    Post subject:
Banding can be avoided by a very careful and methodic set up. There is a great wright up on Tim's web site on a procedure that helps eliminate it.
But for those who do not have the patients the pictured Mod is a must have. I Have the pre programed chip here but have not done the mod yet.
But was told its impossible to get banding with it.
dturco
If you don't see it do not go looking for it. Just be happy. Very Happy
http://www.hulu.com/firefly
Posted: Tue Mar 23, 2010 2:36 pm    Post subject:
Words of wisdom Wink
Sparky015
Posted: Tue Mar 23, 2010 2:38 pm    Post subject:
Ahhh, got it. I do remember reading that article on Tim's site now that you mention it. I will keep this in mind as I'm redoing mine after the upgrade to 9" LC. Hopefully it will continue to be not needed!
~Paul
Posted: Tue Mar 23, 2010 3:29 pm    Post subject:
Once you pop those 9" in that projector, and when/if you're able to dial it in at 1920x1080P 60 or 72 hz, you're going to get some banding. To what degree it varies. And that's even if you have an Ultra.
The lower the scan rate the less you'll notice it. the higher the rate, the more it'll show up. the banding is the horizontal lines touching together. And the more lines there are the more likely they will touch together, and that explains why the problem is more obvious at higher scan rates.
And then this, once you zero out your grid, there's no banding, but once you apply geometry adjustments- how likely would you be able to maintain good geometry and not have those lines touching at higher scan rates?
Now when you get those 9" tubes in your setup, try 1920x1080P native or 72hz and then get back to me. If you're able to make the banding go away at the higher scan rates, then you don't have the projector fully optimized for that rate.
keep in mind that you'll have to display a perfect geometry pattern at a higher scan rate without any banding. And the setup must be fully optimized to show the full line structure (bandwidth).
Remember this: Whenever you put a marquee at 1920x1080P 60 or higher, you bring out 3 of the flaws in it that was never corrected either at Electrohome or VDC in a production model..Mr. Green
Sparky015
Posted: Tue Mar 23, 2010 3:43 pm    Post subject:
Thanks Mike. To sum it up, by doing these upgrades in order to fully resolve 1920X1080p 60Hz or better, I'm basically hitting the edge of performance where this banding occurs. To even have a shot at not having it, I need to have a perfect setup, but probably still run the risk of still having the issue.
When the upgrades are complete, I will report back. If I can't fully resolve 1920X1080p 60Hz or better after all of these mods and upgrades, I will be a very unhappy camper! About the only thing this pj doesn't have is frankenyokes at this point!
Paul
~Paul
Posted: Tue Mar 23, 2010 4:06 pm    Post subject:
Paul
Yep, you got it!
Your goal would be to get your setup fully optimized. And if you plan to do that at 1920x1080P 60/72hz, it'll require some work. And once that's done, you're also going to see some of the flaws in the projector. much like how my left-side ringing shows up in my screen shots.
Think for a minute about the SMPTE test pattern and the two top vertical/horizontal patterns. You have two pattern with both "ONE" pixel lines representing both vertical and horizontal resolutions -- that should be your goal, and that would be to get both line structures properly dialed in on the screen. Then from there you move out to see how well you'll be able to make the same happen in other places on the screen.
When those lines 9both groups are being displayed, you have respected the line structure, meaning that you have achieved both focus and bandwidth optimization.
You can however, tweak the projector to make the banding appear to be gone, but try and make that happen in respect to maintaining the line structure!
Now you should understand why I don't have my geometry to perfection in my screenshots....if I tweak the geometry to perfection I'll loose line structure..Wink
Sparky015
Posted: Tue Mar 23, 2010 4:21 pm    Post subject:
Ah, ok I'm following. I love this stuff! I can't wait to complete the work and start tweaking, although I'm not sure I will be able to fully mazimize the tubes with stock yokes. We'll see. It's going to be a busy spring!
~Paul
Posted: Tue Mar 23, 2010 4:34 pm    Post subject:
Hopefully Paul I'll Have a complete set of Custom Barkenstein Yokes made up. I am awaiting one more set to come in so I can use the ones I have now for experimenting and the ones I have coming( hopefully) will get the best wind combination.
This also depends on my personal time to get them apart, rewind them, put them back together and test .
But when that happens i'll drive down to bring them and help you do a set up. Your only a few hours away.
Sparky015
Posted: Tue Mar 23, 2010 4:54 pm    Post subject:
Thanks Nash, I would love to be apart of your testing. IF you'd like my help with the winding, let me know. We have a winder here at work we use to make some of our sensors. I could probably snag it's use for a few prototypes on the weekends.
~Paul
Posted: Tue Mar 23, 2010 7:05 pm    Post subject:
Ditto that!!! Mike that is AWESOME!!!
Posted: Wed Mar 24, 2010 10:28 am    Post subject:
There is another way to totally eliminate banding and produce better colors,.................................................................................................................................................................................................................................................................................................................................................................................................................................. buy a AmPro Razz
dvh99
Posted: Wed Mar 24, 2010 1:10 pm    Post subject:
where can i obtain the chips to do this mod.
i thought i saw a picture of the mod but now its gone??
think this mod will take me 2 hrs, not nearly as long as the tants.
David_Web
Posted: Wed Mar 24, 2010 2:18 pm    Post subject:
Wow. Geometry engine of the marquee is really lousy. As I set up mine I noticed the digital bits and groups that makes up the "curved" correction.
No wonder it bands as the "group of lines" are pulled apart and pushed together with no interpolation between groups at all.
The problem is digital.
For some reason, even when returning geometry to 50 I still seem to get banding. Although faint.
To avoid some of the problems, mainly the band at the center of the screen one could use exactly mirrored amount of top/bottom bow.
How bad would using convergence instead of geometry be?
Posted: Wed Mar 24, 2010 2:23 pm    Post subject:
I usually adjust bow until I find the sweet spot that has the least banding. Sometimes linearity can affect the banding as well. Find the setting with the least banding with the geometry controls.
After that, use interpolated zone to fine tune the shape. Follow that by random access zone. It will work, but there is always some banding even if it is very very faint.
Mike's mod seems to eliminate all the banding thous so it will be a much better fix with less stress on the point system.
Sparky015
Posted: Wed Mar 24, 2010 2:27 pm    Post subject:
I take it someone is going to sell this mod, and that's why the pic of it was removed? If this chip has to be programmed, it's kind of hard to copy.
