MikeEby
| Posted: Wed Jan 19, 2011 6:23 am Post subject: |
| CIR Engineering wrote: | So right now in theory you will not need the Lumagen sync dongle if you have a Moome board with the correct 3D output.
craigr |
Smart!
dochlywd
Joined: 25 Apr 2006 Posts: 346 Location: Saint Louis, Missouri
| Posted: Wed Jan 19, 2011 1:56 pm Post subject: |
Craig,
Is there any kind of upgrade program for those of us that had just purchased a MOOME right before the 3D protocol??
Doc
| Posted: Wed Jan 19, 2011 1:57 pm Post subject: |
Just an FYI.
Right now we are having a compatibility issue between the Moome EXT and the RadianceMINI. It seems there is noise on the HDMI signal when the two are combined. The RadianceXS and RadianceXE work fine with the Moome EXT. The RadianceMINI also works fine with everything else that has been tested.
I will keep you guys updated as we are hoping this will be solvable.
wildchild22
| Posted: Wed Jan 19, 2011 4:16 pm Post subject: |
Can you try a hdfury3 and see if that has noise on it?
| Posted: Thu Jan 20, 2011 1:48 pm Post subject: |
| wildchild22 wrote: | | Can you try a hdfury3 and see if that has noise on it? |
That is a good idea.
I don't think Lumagen has an HDF3, but I have an HDF3 and HDF1 in my shop and also several Moome IFB cards. I am sure I will have a MINI in at some point for a client, but so far every order this month has been for XS and XE models. If I get a MINI I will do some testing.
I also will ask Lumagen to send me a MINI sample, but Jim is out for two weeks so it certainly will not be authorized until he returns. I may just send Lumagen my HDF3 and HDF1 to test there.
noos@xp37+
Joined: 17 Jun 2008 Posts: 464 Location: Berlin/Munich
| Posted: Fri Jan 21, 2011 9:16 am Post subject: |
[quote="Alan Head"]I have spent a considerable amount of time experimenting 3D over the years with different shutter glasses. The following may be of interest :-
Setup :-
G90 CRT Projector with P19LUG tubes, HTPC based on ASUS P7P55D motherboard, Blackmagic Intensity Pro 1080i capture card. Radiance XE+ 3D Video processor.
Glasses :
Nvidia 3DVision
Edimensional wired via VGA dongle
Edimensional IR via VGA dongle
Samsung SSG 1000 modified to run from Edimensional VGA dongle.
Conclusions :
NVidia customer support non existent when you are using CRT technology despite their own spec saying system supports CRT monitors with high refresh rate capability. NVidia glasses look good from an aesthetic point of view but suffer from severe ghosting (on IIyama CRT monitor as well as G90)
Edimensional glasses work well with virtually no ghosting but image rather dark.
Samsung glasses offer best compromise, much more light coming through than Edimensional and virtually no ghosting.
I have improved the ghosting on Nvidia glasses by running a much higher vertical resolution than I need and then overscanning the picture to get it where I want on screen. This improves the ghosting at the expense of bandwidth. So the big problem with NVidia is a lack of sync adjustment for the glasses.
Other Info :
I have just bought the Radiance XE+ 3D and as it develops with full CRT 3D Support I hope to settle on one type of glasses. I suspect with the Radiance 3D, Sync will end up really good (Lumagen customer support is in a different league to NVidia) and I am sure P19LUG tubes will be fine. Watching Avatar in 3D via the Samsung Glasses the image is pretty impressive with decent 3D depth and no ghosting marring the experience. Once I have greyscale/colour calibrated the 3D input through whatever set of glasses I decide to go for I know it will look even better.
I look forward to the day my NVidia 3DVision kit can be removed from my system.
Alan Head[/quote
Alan,
do you use these Samsung glasses with the PC? Via the ED Dongle plus the 3d Vision emitter plugged in? Sothat you use the 3d vision software? Or is my understanding wrong, and you use them on a different path/system or the ED software to genrate 3D content. I also used old shutter glasses via their VGA dongle with the 3d vision emitter plugged in. This works with my 8800Ultra card from EVGA. Later generations did not provide a sync signal anymore. But as you wrote, these glasses are very dark. Please provide more details on these Samsung glasses.
Best regards from Munich
Marc
1031
Alan Head
| Posted: Fri Jan 21, 2011 4:08 pm Post subject: |
| noos@xp37+ wrote: |
Alan,
Yes, I run 3d games on the PC, watch Sky3D TV and play 3D BluRays in this way. You have to be careful about keeping the emitters placed in a way that they don't interfere with each other. The Samsung emitter will soon be replaced with a gen 2 universal emitter from 3DTVcorp. This is Nvidias last chance before their glasses are moved on! At the same time I will get a pair of type N glasses as well.
| noos@xp37+ wrote: |
Marc
The Samsung glasses were bought from Digiland in the UK last summer, they were a discontinued model at that time so I am not sure if its even possible to still get them. They have a slightly yellow tint and the timing is slightly different from Edimensional giving a small out of sync band at the top of my screen. From an aesthetic and comfort point of view they are not as good as Nvidia. From a sync point of view they are better.
When I get the sync from my Radiance 3d I should get the sync perfect with all my glasses (although not necessarily at the same time). At that point I will decide which I prefer and colour/greyscale calibrate my system to suit them.
Alan
| Posted: Fri Jan 28, 2011 2:58 pm Post subject: |
| Quote: |
Glasses :
Nvidia 3DVision
Conclusions :
Other Info :
I have just bought the Radiance XE+ 3D and as it develops with full CRT 3D Support I hope to settle on one type of glasses. I suspect with the Radiance 3D, Sync will end up really good (Lumagen customer support is in a different league to NVidia) and I am sure P19LUG tubes will be fine. Watching Avatar in 3D via the Samsung Glasses the image is pretty impressive with decent 3D depth and no ghosting marring the experience. Once I have greyscale/colour calibrated the 3D input through whatever set of glasses I decide to go for I know it will look even better. |
I just posted over here...
http://www.curtpalme.com/forum/viewtopic.php?p=290161#290161
After reading above, I want to get a set of the Edimensionals to try out as well as the XPand 103's.
| Posted: Fri Jan 28, 2011 4:35 pm Post subject: |
craigr |
So after looking up the Edimensional glasses I realize I already had them here and sold them. I found them pretty good as well, but not better than the Samsung glasses, and also darker. I wish I still had a pair here, but I don't think they would prove anything anyway for me at this time.
I am about to go pick up the XPand 103 glasses from Sears and will test them later today sometime.
Regards,
MIK100262
Joined: 27 Apr 2012 Posts: 5 Location: Lexington Kentucky
| Posted: Fri Apr 27, 2012 10:17 pm Post subject: P19LUG |
Is it possible that the projection tube is ghosting from lens or the halation of the electron beam?
_________________ TubeMan
MIK100262
| Posted: Fri Apr 27, 2012 10:25 pm Post subject: |
Is anyone still using CRT projectors?
MIK100262
| Posted: Fri Apr 27, 2012 10:27 pm Post subject: |
Any CRT use at all?
MIK100262
| Posted: Fri Apr 27, 2012 10:29 pm Post subject: |
Are there any uses for CRT projection tubes or would anyone like info for CRT's?
MIK100262
| Posted: Fri Apr 27, 2012 10:30 pm Post subject: |
If anyone needs help with CRT issues I am a CRT engineer and can offer some info.
| Posted: Sat Apr 28, 2012 10:08 am Post subject: |
I have been using the nVIDIA 3D shutter glasses for abit over a week now, and i get zero ghosting on my Runco DTV 991 at 72 or 75 Hz, and using my CRT monitor at any resolution itll do, there is no ghosting on that either. The monitor is an LG F700P.
Testing with 3D bluray movies has been abit light on, due to numerous bluray playing programs having an issue with nVIDIA and reseting the computer... I can occationally make them run a few minutes and the effect on the NEC is perfect, no ghosts.
My InFocus DLP on the other hand.... Ratsh**... Ghosts at any refresh in certain parts of the screen, and the picture is so weak on the 120 inch screen id say it must need a new bulb...
Im yet to try my Epson EMP-S5... Dont have much hope for it, but it is ALOT brighter than the InFocus...
Not sure why youre getting ghosts on the CRTs youre using, wonder if it has anything to do with your computer being up to the task?? Mine is reasonably powerful, but my video card is only a 9800GT, so its certainly nothing to rave about...
| Posted: Sat Apr 28, 2012 10:22 am Post subject: |
I should also add ive got the really old Sega-Scope 3D shutter glasses, and they are perfect too. They run at either 50 or 60 Hz depending on the region of the console ( or the position of the switch after you mod... ) and there is no flickering on my NEC PG...
| Posted: Sat Apr 28, 2012 5:11 pm Post subject: |
You will get less ghosting on lower refresh rates but more flicker. 72/75 Hz has a good bit of flicker and is not good for movies from 3D BD or 60Hz sources. The dimmer the image the less you will notice the flicker as well.
More ghosting occurs with higher refresh rates, but flicker is reduced. On the G90 the flicker/ghosting is about perfect at 96Hz. 96Hz is good for 3D BD, but not good for games or TV. TV and games requires 120Hz which has more ghosting, but no judder...
48Hz has no perceivable ghosting, but will induce seizures because the flicker is so bad.
It's always a toss up. Every projector has some ghosting, you just want to hide it the best you can
| Posted: Sun Apr 29, 2012 3:29 am Post subject: |
It must be just me then, cause i cant see one bit of flicker at 72Hz or above!! Been a while since i used the Sega glasses, but i remember being VERY supprised at how there was no noticeable flicker on that either, on the NEC 9PG with a 125 inch screen
