dvh99
| Posted: Sun Aug 15, 2010 11:29 pm Post subject: |
with room for the cog on pin6.
tse
| Posted: Sun Aug 15, 2010 11:32 pm Post subject: |
It won't hurt to leave it there. The only downside is the board will cost a little more than if you put a regular tant or electrolytic in it's place.
Scott
Thomas Jefferson
dvh99
| Posted: Mon Aug 16, 2010 4:47 pm Post subject: |
still awaiting the price for the pcb.
scott i ordered the cogs for all decoupling purposes plus a tant on the ths3201 or el5166s
pretty big order 567 euro but its enough for 3 boards and i still will have components left because of a minimum order of 50 for some components.
the smb plugs werent cheap either, 10 euro a piece i need 6 of course but ordered 12 for a 2nd board and then i still need the smb sockets for on the addon board and vnb`s and the ad834s (approx 30dollars a piece)
turns out to be an expensive hobby, not that it is really needed cause the picture already is amazing despite the blooming with high contrast.
dvh99
| Posted: Mon Aug 16, 2010 4:51 pm Post subject: |
if all goes well i would like to know if people are interested in an addon board so i can get some of my money back, you then can have it for cost price of course plus shipping.
dvh99
| Posted: Mon Aug 16, 2010 4:59 pm Post subject: |
my 03p wont be noisy................................
i hope .
| Posted: Mon Aug 16, 2010 5:08 pm Post subject: |
| dvh99 wrote: | my 03p wont be noisy................................
i hope . |
You might be right looks like your new output stage has enough filtering that it would clean up the noise to the video signal pretty well. How many De coupling cap pads are there. I really can't tell exactly how the components are going in some spots on your layout, wish you had them all labeled;) But that cost's more
dvh99
| Posted: Mon Aug 16, 2010 6:16 pm Post subject: |
5 * 2 per opamp
dvh99
| Posted: Mon Aug 16, 2010 6:24 pm Post subject: |
yep keen eye.
i followed scotts suggestion and ordered cogs for all decoupling plus 1 tant so 4 plus tant.
1nf-10nf-100nf-1uf-6,8uf tant.
i still have some higher value tants from a previous order if i need some more but they will then be stacked upon the 6,8uf.
dvh99
| Posted: Mon Aug 16, 2010 6:28 pm Post subject: |
Hoeveelheid Fabrikantnaam & -nummer Productomschrijving RoHS Catalogusprijs Regelprijs
1 1653087 25 VISHAY DRALORIC
CRCW12061R00FKEA THICK FILM CHIP RESISTOR; Resistance:1ohm; Resistance Tolerance:± 1%; Power Rating:250mW; Voltage Rating:200V dc; Series:CRCW; Temperature Coefficient:± 100ppm; Resistor Element Type:Thick Film; Resistor Case Style:1206;
Y-Ex € 0,074 € 1,85
2 1738986 25 VISHAY DRALORIC
CRCW120610R0FKEAHP RESISTOR, 1206, 1%, 10R0; Resistance:10ohm; Resistance Tolerance:± 1%; Power Rating:500mW; Voltage Rating:200V; Series:CRCW HP; Temperature Coefficient:± 100ppm/K; Resistor Element Type:Thick Film; Resistor Case Style:12
Y-Ex € 0,118 € 2,95
3 1414709 50 KEMET
C1206C102J5GACTU CAPACITOR, 1206, 1NF, 50V, NP0; Dielectric Characteristic:C0G / NP0; Capacitance:1000pF; Capacitance Tolerance:± 5%; Voltage Rating:50V; Temperature Coefficient:± 30ppm/°C; Series:C1206; Capacitor Case Style:1206; No. of
Yes € 0,139 € 6,95
4 1653081 25 VISHAY DRALORIC
CRCW12061K50FKEA THICK FILM CHIP RESISTOR; Resistance:1.5kohm; Resistance Tolerance:± 1%; Power Rating:250mW; Voltage Rating:200V dc; Series:CRCW; Temperature Coefficient:± 100ppm; Resistor Element Type:Thick Film; Resistor Case Style:12
Y-Ex € 0,074 € 1,85
5 1502089 20 TYCO ELECTRONICS / HOLSWORTHY
RP73D2A169RBTG RESISTOR, 0805, 169R 0.1% 15PPM; Resistance:169ohm; Resistance Tolerance:± 0.1%; Power Rating:0.125W; Voltage Rating:150V; Series:RP73; Temperature Coefficient:± 15ppm/°C; Resistor Element Type:Thin Film; Resistor Case S
Yes € 0,54 € 10,80
6 1773538 5 DIODES INC.
MMBD7000-7-F DIODE, SW ARRAY, 75V, 0.35W SOT23; Diode Type:Switching; Av Current If:150mA; Voltage Vrrm:75V; Max Voltage Vf:1.25V; Operating Temperature Range:-65°C to +150°C; Diode Case Style:SOT-23; No. of Pins:3; Case Style:SOT-23
Yes € 0,31 € 1,55
7 8453063 10 TEXAS INSTRUMENTS
THS3201D OP AMP, 1.8GHZ CFB, 3201, SOIC8; Op Amp Type:Low Distortion; No. of Amplifiers:1; Bandwidth:1.8GHz; Slew Rate:10500V/µs; Amplifier Case Type:SOIC; No. of Pins:8; Operating Temperature Range:-40°C to +85°C; SVHC:No SVHC (
Yes € 4,20 € 42,00
8 1100213 50 WELWYN
WCR1206-6K2FI RESISTOR, 1206 6K2; Resistance:6.2kohm; Resistance Tolerance:± 1%; Power Rating:0.25W; Voltage Rating:100V dc; Series:WCR; Temperature Coefficient:± 200ppm/°C; Resistor Element Type:Thick Film; Resistor Case Style:1206;
€ 0,03 € 1,50
9 9188703 15 SANYO
30SC1M CAPACITOR, 1UF, 30V; Capacitor Dielectric Type:Aluminium Electrolytic; Capacitance:1µF; Capacitance Tolerance:± 20%; Voltage Rating:30V dc; Effective Series Resistance:350mohm; Series:SC; Height:6.8mm; Outside Diameter:4
Yes € 1,04 € 15,60
10 1653096 25 VISHAY DRALORIC
CRCW1206240RFKEA THICK FILM CHIP RESISTOR; Resistance:240ohm; Resistance Tolerance:± 1%; Power Rating:250mW; Voltage Rating:200V; Series:CRCW; Temperature Coefficient:± 100ppm; Resistor Element Type:Thick Film; Resistor Case Style:1206;
Y-Ex € 0,074 € 1,85
11 8820210 30 MURATA
GRM31C5C1E104JA01L CAPACITOR, 1206, 100NF, 25V; Dielectric Characteristic:C0G / NP0; Capacitance:100000pF; Capacitance Tolerance:± 5%; Voltage Rating:25V dc; Temperature Coefficient:± 30ppm/°C; Series:GRM31; Capacitor Case Style:1206; No.
Yes € 0,94 € 28,20
12 1510761 5 NXP
2N7002 MOSFET, N, SOT-23; Transistor Polarity:N; Max Current Id:300mA; Max Voltage Vds:60V; On State Resistance:2.8ohm; Rds Measurement Voltage:10V; Max Voltage Vgs:30V; Power Dissipation:0.83W; Transistor Case Style:SOT-23; No
Yes € 0,168 € 0,84
13 1501590 15 TYCO ELECTRONICS / HOLSWORTHY
RP73D2B768RBTG RESISTOR, 1206, 768R 0.1% 15PPM; Resistance:768ohm; Resistance Tolerance:± 0.1%; Power Rating:0.25W; Voltage Rating:200V; Series:RP73; Temperature Coefficient:± 15ppm/°C; Resistor Element Type:Thin Film; Resistor Case St
Yes € 1,24 € 18,60
14 1218576 8 NEXANS
RG179BU 100M CABLE, COAX, RG179BU, PER M; Reel Length (Imperial):328ft; Reel Length (Metric):100m; Cable Type:Coaxial; Coaxial Cable RG/U Type:RG179B/U; Outer Insulation Colour:Brown; Outer Insulation Material:FEP; No. of Strands x
Yes € 5,68 € 45,44
15 1470008 50 VISHAY DRALORIC
CRCW1206330RFKEA RESISTOR, 1206, 330R , 1%; Resistance:330ohm; Resistance Tolerance:± 1%; Power Rating:0.25W; Voltage Rating:200V dc; Series:CRCW; Temperature Coefficient:± 100ppm/°C; Resistor Element Type:Thick Film; Resistor Case Style
Y-Ex € 0,04 € 2,00
16 1739012 25 VISHAY DRALORIC
CRCW12061K00FKEAHP RESISTOR, 1206, 1%, 1K00; Resistance:1kohm; Resistance Tolerance:± 1%; Power Rating:500mW; Voltage Rating:200V; Series:CRCW HP; Temperature Coefficient:± 100ppm/K; Resistor Element Type:Thick Film; Resistor Case Style:12
Y-Ex € 0,117 € 2,93
17 1470018 50 VISHAY DRALORIC
CRCW1206475RFKEA RESISTOR, 1206, 475R , 1%; Resistance:475ohm; Resistance Tolerance:± 1%; Power Rating:0.25W; Voltage Rating:200V dc; Series:CRCW; Temperature Coefficient:± 100ppm/°C; Resistor Element Type:Thick Film; Resistor Case Style
Y-Ex € 0,04 € 2,00
18 1097184 20 NXP
BFT93 RF TRANSISTOR, PNP, SOT-23; Transistor Polarity:NPN; Collector-to-Emitter Breakdown Voltage:12V; Typ Gain Bandwidth ft:5GHz; Power Dissipation Pd:300mW; DC Collector Current:-35mA; DC Current Gain hFE:50; Operating Tempe
Yes € 0,45 € 9,00
19 1501482 5 TYCO ELECTRONICS / HOLSWORTHY
RP73D2B75RBTG RESISTOR, 1206, 75R 0.1% 15PPM; Resistance:75ohm; Resistance Tolerance:± 0.1%; Power Rating:0.25W; Voltage Rating:200V; Series:RP73; Temperature Coefficient:± 15ppm/°C; Resistor Element Type:Thin Film; Resistor Case Styl
Yes € 1,24 € 6,20
20 9489380 3 NATIONAL SEMICONDUCTOR
LM317AT V REG ADJ +1.2/37V, TO-220-3, 317; Dropout voltage:2V; No. of Outputs:1; No. of Pins:3; Voltage Regulator IC Case Style:TO-220; Operating Temperature Range:-40°C to +125°C; SVHC:No SVHC (18-Jun-2010); Case Style:TO-220;
Yes € 1,98 € 5,94
21 1658552 20 AVX
TPSB685K020R1000 CAPACITOR, CASE B, 6.8 UF, 20V; Capacitance:6.8µF; Capacitance Tolerance:± 10%; Voltage Rating:20V; Effective Series Resistance:1ohm; Series:TPS; Capacitor Case Style:B; No. of Pins:2; Operating Temperature Range:-55°C t
Yes € 0,67 € 13,40
22 1717861 20 PANASONIC
ERJ8RQF4R7V RESISTOR, 1206, 0.25W, 1%, 4R7; Resistance:4.7ohm; Resistance Tolerance:± 1%; Power Rating:250mW; Series:ERJ; Temperature Coefficient:± 200ppm/°C; Resistor Element Type:Thick Film; Resistor Case Style:1206; No. of Pins:2
Yes € 0,29 € 5,80
23 1658883 50 AVX
12063A103JAT2A CAPACITOR, 10 NF, 25V, 1206, C0G; Dielectric Characteristic:C0G / NP0; Capacitance:10000pF; Capacitance Tolerance:± 5%; Voltage Rating:25V; Temperature Coefficient:± 30ppm/°C; Series:MLCC; Capacitor Case Style:1206; No.
Yes € 0,57 € 28,50
24 1469658 50 VISHAY DRALORIC
CRCW120620R0FKEA RESISTOR, 1206, 20R, 1%; Resistance:20ohm; Resistance Tolerance:± 1%; Power Rating:0.25W; Voltage Rating:200V dc; Series:CRCW; Temperature Coefficient:± 100ppm/°C; Resistor Element Type:Thick Film; Resistor Case Style:12
Y-Ex € 0,04 € 2,00
25 1501566 10 TYCO ELECTRONICS / HOLSWORTHY
RP73D2B453RBTG RESISTOR, 1206, 453R 0.1% 15PPM; Resistance:453ohm; Resistance Tolerance:± 0.1%; Power Rating:0.25W; Voltage Rating:200V; Series:RP73; Temperature Coefficient:± 15ppm/°C; Resistor Element Type:Thin Film; Resistor Case St
Yes € 1,24 € 12,40
26 1653127 25 VISHAY DRALORIC
CRCW12063K90FKEA THICK FILM CHIP RESISTOR; Resistance:3.9kohm; Resistance Tolerance:± 1%; Power Rating:250mW; Voltage Rating:200V dc; Series:CRCW; Temperature Coefficient:± 100ppm; Resistor Element Type:Thick Film; Resistor Case Style:12
Y-Ex € 0,074 € 1,85
27 1100152 50 WELWYN
WCR1206-36RFI RESISTOR, 1206 36R; Resistance:36ohm; Resistance Tolerance:± 1%; Power Rating:0.25W; Voltage Rating:100V dc; Series:WCR; Temperature Coefficient:± 200ppm/°C; Resistor Element Type:Thick Film; Resistor Case Style:1206; No
Yes € 0,055 € 2,75
28 1469977 50 VISHAY DRALORIC
CRCW1206100RFKEA RESISTOR, 1206, 100R , 1%; Resistance:100ohm; Resistance Tolerance:± 1%; Power Rating:0.25W; Voltage Rating:200V dc; Series:CRCW; Temperature Coefficient:± 100ppm/°C; Resistor Element Type:Thick Film; Resistor Case Style
Y-Ex € 0,04 € 2,00
29 1501589 10 TYCO ELECTRONICS / HOLSWORTHY
RP73D2B750RBTG RESISTOR, 1206, 750R 0.1% 15PPM; Resistance:750ohm; Resistance Tolerance:± 0.1%; Power Rating:0.25W; Voltage Rating:200V; Series:RP73; Temperature Coefficient:± 15ppm/°C; Resistor Element Type:Thin Film; Resistor Case St
Yes € 1,24 € 12,40
30 1562028 10 INTERSIL
EL5166ISZ IC OP AMP, CURRENT FEEDBACK, 1.4GHZ; Op Amp Type:Current Feedback; No. of Amplifiers:1; Bandwidth:1.4GHz; Slew Rate:6000V/µs; Supply Voltage Range:5V to 12V; Amplifier Case Type:SOIC; No. of Pins:8; Operating Temperature
Yes € 2,73 € 27,30
31 1501546 10 TYCO ELECTRONICS / HOLSWORTHY
RP73D2B301RBTG RESISTOR, 1206, 301R 0.1% 15PPM; Resistance:301ohm; Resistance Tolerance:± 0.1%; Power Rating:0.25W; Voltage Rating:200V; Series:RP73; Temperature Coefficient:± 15ppm/°C; Resistor Element Type:Thin Film; Resistor Case St
Yes € 1,24 € 12,40
32 1111345 12 AMPHENOL
SMZ6112A6-3GT30G-6-75 PLUG, SMB, RIGHT ANGLE, 75R; Connector Type:SMZ, Coaxial; Series:SMB; Body Style:Right Angle; RF Coax Termination:Crimp; Impedance:75ohm; Coaxial Cable RG/U Type:RG-179/U, RG-187A/U; Contact Material:Beryllium Copper; Co
Yes € 8,75 € 105,00
33 1081201 10 NXP
BAT74 DIODE, SCHOTTKY, DUAL; Diode Type:Schottky; Av Current If:0.2A; Voltage Vrrm:30V; Max Voltage Vf:400mV; Max Reverse RecoveryTime, trr:5ns; Max Current Ifs:0.6A; Diode Case Style:SOT-143B; No. of Pins:4; Case Style:SOT-14
Yes € 0,178 € 1,78
34 1501998 15 TYCO ELECTRONICS / HOLSWORTHY
RP73D2A24R3BTG RESISTOR, 0805, 24R3 0.1% 15PPM; Resistance:24.3ohm; Resistance Tolerance:± 0.1%; Power Rating:0.125W; Voltage Rating:75V; Series:RP73; Temperature Coefficient:± 15ppm/°C; Resistor Element Type:Thin Film; Resistor Case S
Yes € 0,82 € 12,30
35 1574372 25 MULTICOMP
2N3906 TRANSISTOR, PNP, TO-92; Transistor Polarity:PNP; Collector-to-Emitter Breakdown Voltage:40V; Typ Gain Bandwidth ft:250MHz; Power Dissipation Pd:625mW; DC Collector Current:0.2A; DC Current Gain hFE:100; Operating Tempera
Yes € 0,138 € 3,45
36 1653169 25 VISHAY DRALORIC
CRCW120675R0FKEA THICK FILM CHIP RESISTOR; Resistance:75ohm; Resistance Tolerance:± 1%; Power Rating:250mW; Voltage Rating:200V dc; Series:CRCW; Temperature Coefficient:± 100ppm; Resistor Element Type:Thick Film; Resistor Case Style:1206
Y-Ex € 0,074 € 1,85
37 1653119 25 VISHAY DRALORIC
CRCW120639R2FKEA THICK FILM CHIP RESISTOR; Resistance:39.2ohm; Resistance Tolerance:± 1%; Power Rating:250mW; Voltage Rating:200V dc; Series:CRCW; Temperature Coefficient:± 100ppm; Resistor Element Type:Thick Film; Resistor Case Style:12
Y-Ex € 0,074 € 1,85
38 1327717 20 AVX
12063C105KAT2A CAPACITOR, 1206, 1000NF, 25V, X7R; Dielectric Characteristic:X7R; Capacitance:1000nF; Capacitance Tolerance:± 10%; Voltage Rating:25V dc; Temperature Coefficient:±15%; Capacitor Case Style:1206; No. of Pins:2; Mounting T
Yes € 0,35 € 7,00
39 9526854 20 MURATA
BLM31AF700SN1L INDUCTOR, SMD, 70Z; Max DC Resistance:0.15ohm; DC Current Rating:200mA; Case Style:1206; External Depth:3.2mm; External Length / Height:1.1mm; External Width:1.6mm; Impedance:70ohm; No. of Pins:2; Resistance:0.5ohm; Term
Yes € 0,27 € 5,40
40 1515415 6 MURATA
LQH31HNR14K03L INDUCTOR, 1206 CASE, 145NH, 10%; Inductance:145nH; Inductance Tolerance:± 10%; Max DC Resistance:0.061ohm; DC Current Rating:700mA; Self Resonant Frequency:500MHz; Q Factor @ Frequency:60 @ 100MHz; Series:LGH31; Core Mat
Yes € 0,73 € 4,38
41 1515414 6 MURATA
LQH31HN95NK03L INDUCTOR, 1206 CASE, 95NH, 10%; Inductance:95nH; Inductance Tolerance:± 10%; Max DC Resistance:0.047ohm; DC Current Rating:790mA; Self Resonant Frequency:650MHz; Q Factor @ Frequency:60 @ 100MHz; Series:LGH31; Core Mater
Yes € 0,79 € 4,74
Subtotaal: € 476,60
BTW: € 90,55
Totaal: € 567,15
dvh99
| Posted: Mon Aug 16, 2010 8:02 pm Post subject: |
scott dont you have any ad834s laying around at vdc, the 03p vim project was terminated and perhaps there are some left.
jantje112
| Posted: Mon Aug 16, 2010 8:44 pm Post subject: |
| dvh99 wrote: | still awaiting the price for the pcb.
turns out to be an expensive hobby, not that it is really needed cause the picture already is amazing despite the blooming with high contrast. |
I have 20 of these 5166 around here. A while back it was suggested to use these on the neckboards (I believe mine have the cl449)
Is this still a good "tweak" or has it been proven wrong/not working.
@dvh99 nice work, but if you rebuild the 03p output stage, why not buy one?
| Posted: Mon Aug 16, 2010 9:00 pm Post subject: |
| jantje112 wrote: | | dvh99 wrote: | still awaiting the price for the pcb.
@dvh99 nice work, but if you rebuild the 03p output stage, why not buy one? |
The El5166 works fine there.
He is making an 03-P output stage to replace the 02-P's that uses the lower bandwidth Ad835. So he is basically turning an 02-P vim to a 03-P vim.
dvh99
| Posted: Mon Aug 16, 2010 9:06 pm Post subject: |
this is much more fun.
the circuit can be build with better components as well.
in the parts list from vdc they point out where to use 1% resistors but nowadays you can only buy 1% tolerance resistors or better, i havent seen 1 smd resistor with a tolerance higher then 1%.
yes, put them on the vnb`s.
change them on the vim as well.
use chipquick for removing soic chips.
http://www.youtube.com/watch?v=FTQqjggeklo
jantje112
| Posted: Mon Aug 16, 2010 9:27 pm Post subject: |
| dvh99 wrote: | this is much more fun.
http://www.youtube.com/watch?v=FTQqjggeklo |
If I have my second 03p working again I will look at a shootout between a tweaked and an untweaked version.
Plenty of neckboard, I will try that soon
dvh99
| Posted: Tue Aug 17, 2010 9:52 pm Post subject: |
i have made some traces wider and made the traces between the components wider too.
smallest trace is now 1.2mm
5v lines are 2mm.
i still cannot reach the guy who has to make the boards maybe he is on a holiday but i will be patient.
here is my final design.
dvh99
| Posted: Wed Aug 18, 2010 2:04 pm Post subject: |
question about the groundplane, do i have to connect a ground plane from the addon pcb to a ground point from the vim or can i use ground from the chassis.
thanks
dennis
dvh99
| Posted: Wed Aug 18, 2010 3:13 pm Post subject: |
i think i am going to make the pcb`s myself.
i can buy a photosensitive pcb 151cm*51cm (double sided)
i can make 36 pcb`s this way.
all i need are some chemicals uv tube lights transparent printer paper and a finishing spray.
