dvh99
| Posted: Sun Oct 03, 2010 10:39 pm Post subject: |
i compared my rg179 cable to the stock cabel and they seem to have exactly the same thickness.
tse
| Posted: Sun Oct 03, 2010 10:52 pm Post subject: |
The small connector type is SMB. That is what I was going to use for the Marquee. We found a source for the original mini-RCA connectors so didn't switch over.
Scott
Thomas Jefferson
| Posted: Sun Oct 03, 2010 10:55 pm Post subject: |
| tse wrote: | The small connector type is SMB. That is what I was going to use for the Marquee. We found a source for the original mini-RCA connectors so didn't switch over.
Scott |
Right Scott but there are s many sizes of SMB, were getting confused. I think we have the right socket. the one i have is about 3 mm in outer diameter. can you check yours when your at work tomorrow?
dvh99
| Posted: Sun Oct 03, 2010 11:03 pm Post subject: |
well it must fit because it says it is compatible with rg179 which is the cable i have right here.
tse
| Posted: Sun Oct 03, 2010 11:07 pm Post subject: |
I'm pretty sure that SMBs are SMBs. There are SMA and apparently SMZ types but they are different sizes. SMB being the smaller size connector. There may be types for different cable sizes but the jack and plugs will all fit together. AFAIK.
Scott
Thomas Jefferson
dvh99
| Posted: Mon Oct 04, 2010 12:35 pm Post subject: |
scott the conducting area of the original cable is that 0.7mm, 7*0.1mm.
dvh99
dvh99
| Posted: Mon Oct 04, 2010 1:15 pm Post subject: |
if i click on that link i do not get the same screen.
1: € 3,36
10: € 3,07
25: € 2,83
100: € 2,63
500: € 2,38
1.000: € 2,26
this is what i see.
edit its euros and dollars conversion is done when approaching the site within the eu.
dvh99
| Posted: Mon Oct 04, 2010 1:18 pm Post subject: |
are you going to order these?
| dvh99 wrote: | if i click on that link i do not get the same screen.
1: € 3,36
10: € 3,07
25: € 2,83
100: € 2,63
500: € 2,38
1.000: € 2,26
this is what i see. |
Switch Country to USA, then enter the manufactures part number not the mouser part number. The Mouser number is region specific. Once on the USA site you'll see the USA flag . enter the Amphenol number and you'll see the 3.98 price for one, 10 are 3.64. etc.
| Posted: Mon Oct 04, 2010 1:24 pm Post subject: |
| dvh99 wrote: | | are you going to order these? |
I might order a few for myself to test. I want to see if i can use a much thicker cable i have here that is 99% copper with silver plating. the RG 179 cables i looked at are mostly copper plated Steel, i dont like the sound of steel carrying a video signal. And I think that is what the original cable is. I made one cable out of very thick double shielded Audio Quest Silver cable and that was much better than stock. but it was so thick it broke the Socket off the VIM.
The belden cable i have is silver plated and thinner. So it should be easier to feed through the chassis. Hopefully it will
not be so rigid as to break off the original Mini Rca . The new SMB's with the screw should hold up better if i try that. I should have ordered a few for testing.
jantje112
| Posted: Tue Oct 05, 2010 10:54 am Post subject: |
@dvh99 I was on the so called "radio market" a week back. Plenty of SMA SMB wires plugs connectors for sale. The connectors were about 75 cent to 1 euro a piece. Bought some ready made coax with smb for 2,50 each (thats including 2 connectors)
dvh99
| Posted: Fri Oct 08, 2010 3:48 pm Post subject: |
i looked at the schematic from the 02p vim and want to know what the edge blending switching is for.
edit: 74hc4053 is the responsible chip
dvh99
| Posted: Fri Oct 08, 2010 4:41 pm Post subject: |
progress:
connector is temporary
| Posted: Fri Oct 08, 2010 4:42 pm Post subject: |
| dvh99 wrote: | i looked at the schematic from the 02p vim and want to know what the edge blending switching is for.
edit: 74hc4053 is the responsible chip |
It was originally designed for an edge blending board that did not happen. The design was a separate board that attached on top of the VIM (P3 / P4), it was to be mounted right behind the second input slot on the VIM.
U21 was how they were going to insert the signal into the video chain thru AD835's
