dvh99
| Posted: Wed Sep 22, 2010 3:52 pm Post subject: |
i have to get other paper for the exposure when i expose say 10 or 15 seconds too long all small traces are gone.
the transparancies, even 2 on top do not block uv light enough.
dvh99
| Posted: Thu Sep 23, 2010 12:29 pm Post subject: |
unmirrored
dvh99
| Posted: Fri Sep 24, 2010 1:04 am Post subject: |
all vias done with a simple copper wire.
HK-Steve
| Posted: Fri Sep 24, 2010 6:04 am Post subject: |
Looks good for a home made board. Well done.
Now get that thing all soldered up and tested.
Cheers
Steve
tse
| Posted: Fri Sep 24, 2010 12:26 pm Post subject: |
Sometimes, when you are working with prototypes, it makes alot of sense to stuff only one channel and test.
Scott
Thomas Jefferson
dvh99
| Posted: Fri Sep 24, 2010 1:23 pm Post subject: |
wise advice, should have thought about that but i am over excited .
everything is almost on the board.
spent 15 minutes looking for a 10ohm resistor just to find out it wasnt in stock and it would be delivered later.
this delivery was 4 weeks ago and i still dont have the resistor.
for now i will settle with 2*20ohm.
dvh99
| Posted: Fri Sep 24, 2010 3:47 pm Post subject: |
everything on the board accept the ad834s and the smb sockets.
not using the beads yet instead of the 4.7ohm but i do have them.
decoupling= 1nf-10nf-100nf-1uf-6.8uf-tant all cogs.
dvh99
| Posted: Sun Oct 03, 2010 7:40 pm Post subject: |
pic
dvh99
| Posted: Sun Oct 03, 2010 8:19 pm Post subject: |
here it is.
dvh99
| Posted: Sun Oct 03, 2010 8:22 pm Post subject: |
im afraid that is too small.
are you sure that is an smb.
the inside diameter is 5 to 6mm.
yours is 3.75mm
dvh99
| Posted: Sun Oct 03, 2010 8:26 pm Post subject: |
my connector has to go 5mm over the socket.
dvh99
dvh99
| Posted: Sun Oct 03, 2010 8:57 pm Post subject: |
http://www.amphenolconnex.com/catalog/smb_and_smc.pdf
i should have had this one but what i do not understand is that my connector isnt right, it is a smb.
dvh99
