Having problem with ext-Full HDv2 and Onkyo905
sulley
Posted: Tue Jan 26, 2010 5:38 am    Post subject: Having problem with ext-Full HDv2 and Onkyo905
I've got my ext-FullHD v2 1week ago. Finally, I had time to hook it with my Barco 1209s last night. My connection was as follows: Panasonic BD30 and PS3 (1080p/60) HDMI-> Onkyo 905 HDMI (Through) -> ext box -> 1209s. Then I connected the power supply to the box. I noted the LED lights of two HDMI input is kept flashing (seemed like to search for for input). Of course, there was no picture at all.
Then I tried to connect BD30 directly to the box. I got a stunning 1080p picture once the box detected the input. PS3 also showed a fantastic picture when I connected directly to the box. I reconnected the BD30 with Onkyo 905, there was no picture and kept searching the input again.
Does it related to the handshake problem between the box and the Onkyo 905? I've spent whole night in connecting and disconnecting the machines but still can't figure it out. Rolling Eyes
What can I do ?
Please help. Thanks.
Rolls-Royce
Posted: Tue Jan 26, 2010 7:25 am    Post subject:
Page 52 of the manual states you have to go into the receiver's setup and set HDMI Monitor to HDMI MAIN OUT or HDMI SUB OUT as well as having the box connected to the output you selected. You also need to have the correct output resolution selected. Both of these must be done in order to get an HDMI link and picture.
....Royce....
sulley
Posted: Tue Jan 26, 2010 1:35 pm    Post subject:
Thank you Royce,
I definite connected the right HDMI output since I can see the image when I connected the same cable to the TV. Interestingly, I can see image when I entered the setup menu (probably 480p) of Onkyo905. But the picture disappeared once I exit the setup, no matter what resolution I choose ( 480p/ 720p/ 1080i/1080p). any idea?
sulley
Posted: Tue Jan 26, 2010 2:18 pm    Post subject:
there are three LEDs at the back (from left to right), let me show you the condition of the LED when I connect the cable to the HDMI 0:
1. before Onkyo905 on: 'red', no light, 'red'
2. Onkyo905 is on: alternate between 'orange' , no light, no light / 'green', no light, 'red' : no picture
3. when I enter the setup of Onkyo905: 'orange', 'green', no light: setup menu can be seen
Rolls-Royce
Posted: Tue Jan 26, 2010 4:58 pm    Post subject:
OK, Sulley. The fact that you can see the setup menu tells me that the 905 is "talking" to the EXT-FULLHD. There's one other thing to check. If the 905 works like my 705 (and I'll bet it does), you also have to tell the 905 which of its HDMI inputs you are using for the mode you have selected. In other words, if you want to select your BD30 when you hit the Onkyo remote's 'DVD' key, you have to go into setup for the DVD input and tell it which HDMI input the BD30 is on.
EDIT: The procedure is on page 54 of the manual, where it also says that none of the HDMI inputs are assigned by default. It has to be done manually.
The lights on my box are working exactly the same way as yours, Sulley, and it works as advertised, so I suspect yours is too. I get your condition #2 (flashing back and forth) only when I select an input with no signal, if I select 'DVD' and my player is off, for instance. I'm pretty sure that the 905's HDMI inputs just need to be assigned and you'll be up and running.
....Royce....
sulley
Posted: Wed Jan 27, 2010 7:04 am    Post subject:
I think I have no problem in assigning the HDMI output since there is output when I connect the cable to the TV.
Rolls-Royce
Posted: Wed Jan 27, 2010 4:30 pm    Post subject:
Sulley, I think you might have misunderstood a little. It does look like you have assigned the HDMI output just fine. But with HDMI, you need to tell the 905 two things: which of its HDMI inputs you're going to send the signal in to, and which of its HDMI outputs you are going to send the signal out of. You also have to turn on the HDMI outputs. OK so far? You are able to see the 905's setup menu through the EXT-FULLHD for two reasons. First, you have successfully turned on the 905's HDMI outputs and told it which one to use. Second, that menu is coming from inside the receiver itself and not from an external source that hasn't been set up yet. I believe that you still need to assign the 905's HDMI inputs, and that is why you aren't getting a picture from the BD30 or PS3.
In short, it appears that you have a good HDMI connection between the 905 and EXT-FULLHD, but not between the BD30 or PS3 and the 905. Sad
....Royce....
sulley
Posted: Thu Jan 28, 2010 2:55 am    Post subject:
Thanks Royce,
Let me make it more clear. I can see the movie from BD30 on TV , it means I have made the right input and output connection. But when I disconnect the cable from TV and reconnect the same HDMI cable to the box, there is no more picture. Therefore, I think it does not relate to the HDMI input/ output assignment. I also tried to turn off and on everything, but still doesn't work.
Posted: Thu Jan 28, 2010 3:21 am    Post subject:
sulley wrote:
Thanks Royce,
That's HDCP poping in on you.
Try powering the Moome box first then the BD30.
Rolls-Royce
Posted: Thu Jan 28, 2010 7:46 am    Post subject:
sulley wrote:
Thanks Royce,
Thanks for the clarification, Sulley. I'm curious, though. If you can connect direct to your TV via HDMI, why are you then using an EXT-FULLHD? Or is it that you are using the EXT-FULLHD with another display entirely?
I agree with Analog Rocks. I power my EXT-FULLHD from the switched outlet on the back of my 705, so it comes on with the receiver. Then I start up my BD35. The BD35 can then see a "display" (the EXT-FULLHD) that's already powered up and make an HDMI connection with it.
....Royce....
sulley
Posted: Mon Feb 01, 2010 2:58 am    Post subject:
I tried the way you advised but it didn't work. In fact I've tried to switch on the boxes with different sequence but the result was just the same!
Rolls-Royce
Posted: Mon Feb 01, 2010 5:17 pm    Post subject:
Another thought, Sulley. Your 905 may need a firmware update. Many of the x05 series receivers (including my 705) needed DSP updates for sound dropouts, long HDMI sync delays, and the infamous DTS "pop". In the "Amps, Receivers, and Processors" area of the AVS Forum, there's a long thread on Onkyo firmware updates for that series. The first post lists latest firmware versions and how to check the firmware on your receiver.
I also found a thread on 1080p input timings for your 1209s on another site: http://www.pixelmagicforum.com/forum/archive/index.php/t-1427.html
Although you mentioned that you do get a good 1080p picture when bypassing the 905, more info is always nice to have.
Hope you get everything straightened out! Very Happy
....Royce....
betel
Posted: Mon Feb 01, 2010 5:56 pm    Post subject:
This sounds a lot like the issue I am having with my Onkyo TX-NR906 except my Moome IFB card accepts the 1080p signal but my 1080p Dell LCD display won't. I purchased the Dell display to use as a secondary monitor for my HT and primary PC monitor. Interestingly, I have an old Samsung 105BW LCD display that will accept the signal just fine through the DVI input and it’s only a 1680 x 1050 display. If the signal is routed directly from my PS3 to the Dell, no problems. I have not been able to find a reason it's doing this but am convinced it’s a HDCP issue. BTW, the 906 has the latest firmware installed.
PS3 --> TX-NR906 (HDMI I/O) --> Moome IFB Full HD V2 --> G90 (GOOD)
PS3 --> TX-NR906 (HDMI I/O) --> Dell ST2410 monitor. (NO GOOD)
Rolls-Royce
Posted: Mon Feb 01, 2010 7:16 pm    Post subject:
I believe your Dell is looking for computer monitor timing, while the PS3 sends video timing when it's connected to your 906 (these receivers have their own EDIDs, and I'm pretty sure they list video timings). As you probably know, these timings are slightly different, and some displays can't/won't lock onto both. When the PS3 is connected directly to the Dell, it sees only that EDID and adjusts its timing and colorspace to that for computer monitors, which is why it works OK in that arrangement. There is a "Game" selection in these receivers, and although I've never used that mode on my 705, it might be worth trying to see if it'll allow the 906 to work with the Dell.
....Royce....
sulley
Posted: Tue Feb 02, 2010 3:21 pm    Post subject:
Rolls-Royce wrote:
Another thought, Sulley. Your 905 may need a firmware update....
I am using the latest firmware 1.09 but it doesn't work!
When I switch on BD30 and Onkyo905 without plugging HDMI to the ext v2 box, the display of 905 will show connection. However, the display will show no signal when I plug the HDMI to the ext v2 box. If I connect 905 with the box first (both are on) and followed with switching on BD30, there will be no signal at all. It seems like that the problem is between 905 and the box!
Rolls-Royce wrote:
......Although you mentioned that you do get a good 1080p picture when bypassing the 905, more info is always nice to have....
If I bypass 905, then I can only use the Toslink without the latest audio format ( Dolby True-HD or DTSHD master audio) Crying or Very sad
Rolls-Royce
Posted: Tue Feb 02, 2010 5:06 pm    Post subject:
Sulley, what happens when you turn on the box, then the 905, then the BD30, in that order, with everything already connected?
I'm not sure if the HDMI spec includes hot-plugging components, so you might not be able to get a good reliable connection by inserting the cable(s) with everything already powered up. I've never had much luck trying it.
It's weird that you can see the 905's setup menu through the box. This shows that you have a good HDMI connection from the 905 to the EXT-FULLHD, at least when the menu is being displayed. IIRC, the setup menu is only shown at 480i or 480p, so there's a resolution change. But the resolution being sent by the BD30 shouldn't cause a no-signal condition. Everything would indicate normally on the player, receiver, and box, and you'd have sound. You just wouldn't have a picture. I see this on my BD35 with every firmware update-it goes to AUTO resolution and puts up 1080p, which the box supports but my display doesn't-so I'm familiar with the symptoms. I'll bet that the receiver isn't using HDCP to send its setup menu over HDMI, and that's why you can see it. It's looking like you have an HDCP issue between the 905 and box.
....Royce....
sulley
Posted: Tue Feb 02, 2010 5:28 pm    Post subject:
Tonight, I connected my old DV camera (non-HDCP source) to Onkyo905 with S-video and then HDMI out to the ext v2 box. You guess what happened, I can see the video on my 1209s. Therefore, the problem is definitely related to the HDCP issue . How can I solve it?
Rolls-Royce
Posted: Tue Feb 02, 2010 5:49 pm    Post subject:
Well, you could try unplugging (not just turning off) the 905 for about 30 minutes or so. That's been known to sometimes correct things on these units that suddenly get a little wacky, like HDMI issues. There's also a full hard reset that can be done, but this will wipe ALL settings, custom labels, etc. and return the receiver to just-out-of-the-box settings. This would be the last resort.
....Royce....
sulley
Posted: Thu Feb 04, 2010 2:55 am    Post subject:
Rolls-Royce wrote:
Well, you could try unplugging (not just turning off) the 905 for about 30 minutes or so....
I tried it last night. The V2 box can detect the input finally from Onkyo905 with BD30 but did not have any picture , no matter what the resolution I chose or changed the H-phase by pushing the select button on the V2 box (with SW1#5 at K side).
I felt exhausted with the box. Crying or Very sad Anyway, do you think the HDMI 4x2 matrix switch can help? One input to the V2 box for the video and another input to Onkyo905 for audio decoding since the switch can output both HDMI simultaneous. Or is there something in the market called HDMI remover?
cinema mad
Posted: Thu Feb 04, 2010 3:21 am    Post subject:
The problem with Splitters when connected to the BD30 Blu-players HDMI output sending one to Display and the other to the
905 is that your Audio will be downgraded to standard dolby or DTS you wont get the HD codec's Due to the EDID being reported by
the Moome... Onkyo 905 asks Display device what do you support Moome V2 external reports standard Dolby/DTS..
Without using A PC There are 2 ways around this,
1, use A Gefen HDMI Detective plus with EDID programing, to trick the Onkyo due to the Moome HDMI Detective combo now reporting HD audio complient thus it will allow HD Codecs..
http://www.gefen.com/kvm/dproduct.jsp?prod_id=8005
2, (The Best way) Moome updates the EDID in the Moome V2 thus report's that it supports HD codecs..
Also Pass through in Devices such as Sound processors does'nt mean untouched as is clearly Evident with Onkyo
its always better to go straight to the Display Device avoiding any Video pass through where possible using A, IE: HDMI 1.3b 1x2 splitter for example ...
Cheers...
