trying to breathe easy...G70, error code 39
benareeno
Posted: Tue Jan 19, 2010 5:40 am    Post subject: trying to breathe easy...G70, error code 39
G70 error 39 appears to suggest too much voltage to one of the crts. In this case, I can clearly see that it's the red crt...but it's not instant. I turn on the projector and withing about 5 or 10 seconds I can see the red becoming too high in voltage, the retrace lines appear and then the set shuts off.
Should I tweak down the G2 or something? That's what it appears to be...too high of a G2 value.
Any other thoughts or suggestions?
It happens with or without anything plugged into the projectors input.
benareeno
Posted: Tue Jan 19, 2010 5:47 am    Post subject:
it simply looks like the red G2 is too high...how can I lower it?
I thought I had been through enough with this adventure! I just took a week to de-house a PGXtra green and mount it in this G70...and that appears to have went fine as the green tube looks just fine.
I could have bet there would be at least one more hurdle...if not more than one.
Elaine Benes
Posted: Tue Jan 19, 2010 4:11 pm    Post subject:
For cautions sake, why not carefully remove the neck board and reseat it, checking the pins and such on the tube neck, JUST TO BE SURE there is no damage to that tube too...
I have a red you can have if you need it...
benareeno
Posted: Tue Jan 19, 2010 5:39 pm    Post subject:
I'm thinking I'll need a neck board...but I'll reseat it tonight and see.
benareeno
Posted: Tue Jan 19, 2010 6:14 pm    Post subject:
Paul can now be considered a G70 expert as well...reseated the red neck board, projector runs fine now! Now for a longer term test...
Posted: Thu Jan 21, 2010 5:27 am    Post subject:
You mean....you actually have a working projector?
Are you going to stick with it for more than a month? Wink
benareeno
Posted: Thu Jan 21, 2010 6:14 am    Post subject:
I think it needs some G2...and I don't think I can get it because of the software version it's running.
I can easily see the LC advantage though...but the low end is really lacking. Perhaps I will hook up a PC and raise the gamma.
I'm telling you...that 6PG is my favourite projector I've had in a long while...I am going to really look at what I would need to do to get the LC hardware from the G70 into the NEC.
Bradad did it...although he might have used LC housings from an XGLC, but they should be a similar size. I think the LC hardware from a G70 would be even better...the flapping is totally tweakable.
Posted: Thu Jan 21, 2010 8:21 am    Post subject:
You will need to make a new chassis.
Just fix the damn G70, you are so close.
Posted: Thu Jan 21, 2010 3:01 pm    Post subject:
Go into the service menu on the G70. Next navigate to the "Set Setting" menu. Select the ABG Mode and turn it on. Let the G70 run for about 20 minutes. This will automatically set the G2 levels for all your tubes including the new one. After 20 minutes turn ABG back off.
cinema mad
Posted: Thu Jan 21, 2010 3:25 pm    Post subject:
Graig I am interested to know When you calibrate A G70 do you leave ABG on or off inc post calibration ?,
As I alway's obtain better results with ABG running all the time inc when performing Gamma/ Grayscale calibration with my low hour G70...
Cheers...
Posted: Thu Jan 21, 2010 4:28 pm    Post subject:
I don't know how Craig does it, but I can't run ABG... I had to turn it off to get rid of the obnoxious line.
So, in my case, I ran the machine for an hour with ABG on, watched some material while it warmed up, turned ABG off, then set about calibrating.
Posted: Thu Jan 21, 2010 4:50 pm    Post subject:
Cheers...
Whenever I calibrate a G90 or G70 I always turn on the ABG for 20 minutes upon my arrival. I do this because over time the G2 voltages at the tubes will have dropped, and the ABG circuit redoes the G2's to the correct levels before the calibration. When I calibrate I usually give the client the option of me leaving the ABG on or off.
Here is the run down...
With ABG on, the G2's are reset every time the projector is turned on. What this means is that over hundreds of hours the gray scale and brightness should stay relatively close to the calibrated levels. As a lot of time goes by, the color calibration will shift, but it will take longer than with ABG off. The downside to leaving ABG turned on is that the G2 is never going to be at quite the correct levels because they change slightly after each power cycle. This translates to differences in the color calibration and black levels every time the projector is turned on. So the ABG keeps the gray scale and brightness closer over a longer period of time, but the gray scale and black level are never spot on with ABG left enabled.
With ABG turned off after the calibration the G2's never reset themselves. What this means is that the gray scale and black level will stay perfect after power cycling the projector. Over hundreds of hours though the G2's will drop in voltage and the gray scale will drift more than with ABG on. Also, the black level will slowly get darker over time.
So for perfect gray and black levels the ABG must be left off. For longer term gray stability and black stability the ABG should be left on. The third alternative is to keep ABG off after a calibration, but then after a year or about 500+ hours you can cycle the ABG to on for 20 minutes. What this does is let the gray scale be close to perfect with ABG in the off postilion, but to later recalibrate the G2's by using the ABG again. It kinda gives the best of both worlds.
Posted: Thu Jan 21, 2010 4:55 pm    Post subject:
There is the ABG line issues as well... depending on things, this can wind up on the screen and that is not acceptable as you've noticed Wink The ABG line is always a problem when running a true 2.35 scan rate (such as 817x1920) on a 1.78 screen because the ABG line is right there and very bright at the top of the screen.
cinema mad
Posted: Thu Jan 21, 2010 11:12 pm    Post subject:
Thanks for the informed reply Craig & ecrabb...
I run 1920x800 but streched A little larger veticaly to use more Raster than the Correct 2:40:1 Aspect ratio,
the ABG lines on my G70 with image centered on raster is'nt noticeable on the 16:9 screen Running contrast at 65 on A
small 92" Stewart Lux, studio tek130 of course if I look into the Tubes I can see the lines thouugh..
Cheers...
benareeno
Posted: Fri Jan 22, 2010 12:16 am    Post subject:
as soon as I turn off agb, it goes back to looking horrible again...perhaps I can't have it in serice mode?
At any rate, I don't see the akb line as I run 2.35:1 or thereabouts...It seems that with it on, the G2 is too high...with it off, it's too low. Damn these f'ing things!
Posted: Fri Jan 22, 2010 1:28 am    Post subject:
Yes, there is certainly a problem with the projector Sad When you turn ABG off, nothing at all should happen. Do all three tubes shift when you turn off ABG or just one?
Posted: Fri Jan 22, 2010 2:19 am    Post subject:
Craig,
On my machine, when I turn ABG off, G2 goes sky high and I get bright blacks. I have to cut bias way back to get blacks back. If I go back to ABG on, then I get über-crushed blacks and have to crank G2 back up. Or, maybe it's the other way around...
Either way, when I switch from ABG one way or the other, I have to re-adjust bias to compensate. Could that be Ben's problem... Ben, have you done anything with bias?
Think there's something wrong with MY machine, Craig? Or, jut a firmware quirk?
Elaine Benes
Posted: Fri Jan 22, 2010 4:41 am    Post subject:
Craig,
I've only had two or three Sony's, but they've all behaved like this...looked great with ABG on, terrible with it off...
Posted: Fri Jan 22, 2010 5:29 am    Post subject:
I believe issues with the pix with the ABG off are issues with the tubes aging, which makes sense to me. As the tubes age (differently), tubes end up with different gains, causing the white balance to go haywire. The ABG senses these differing gains, and brings them back in line with each other, resulting in a proper white balance.
benareeno
Posted: Fri Jan 22, 2010 7:36 am    Post subject:
Curt,
you might be right...the blue and red are fairly low hour and mint tubes...I swapped in an older green, and perhaps that's the culprit.
Anyhow, it looks pretty great with the abg on...I just have to lower the brightness and all of a sudden the pic becomes 3d. The abg line is a non-factor for me as I run 2.20:1 and use black velvet above the screen....overall, a very pleasing picture for sure!
Now...will I get this beast onto the ceiling before the snow is gone? If not...it will not get done!
