3D Blu-Ray standard is set. Will any CRT PJs ever have it?
Posted: Mon Dec 21, 2009 1:39 am    Post subject: 3D Blu-Ray standard is set. Will any CRT PJs ever have it?
Now that the Blu-Ray 3D standard has been set, the question has to be asked:
What CRT projectors will have the bandwidth to work at 1080P at the full spec frame rate with shutter glasses?
What additional equipment (if any) will be required to make it happen?
I can't find the details on the Blu-Ray 3D spec. What is the total required refresh rate that will have to be supported by
the PJ in order for it to be a contender?
My guess is that a healthy Marquee 8500 or 9500 will be able to handle it, along with most other top tier projectors,
but I think that a lot of low to mid range PJs will be out of the running.
CJ
Posted: Mon Dec 21, 2009 2:00 am    Post subject:
Guys!
One cannot expect smooth stereo below 96hz refresh, so think 105khz horizontal.
Posted: Mon Dec 21, 2009 4:15 am    Post subject:
So what is the spec'ed frame rate (total and per channel) in the Blu-Ray 3D spec, if you know it?
I have looked but have not found that information.
Will new HDMI input cards have to be designed and built for our projectors?
CJ
Posted: Mon Dec 21, 2009 4:51 am    Post subject:
CJ,
The BDA has only announced that they've finalized the spec, not actually released the spec. Until they do, there aren't really any details on how exactly it's going to work. All we know is that it'll use the MVC (Multiview Video Coding) extension to the AVC codec, and will be backwards-compatible with 2D equipment. Unless you're reading somebody that has first-hand info from somebody on the 3-D working group at the BDA, it's all a bunch of speculation at this point. We'll all have to keep our panties on until the BDA releases the spec.
Tim is right, though... 96khz overall refresh yields a 48hz refresh per eye. That's going to make the LCD shutter glasses flicker a bit. I'll be surprised if it's 96khz, though... How many displays will work with that. Some people are speculating it will somehow make use of 120hz displays, but I question that supposition, because it would yield 60hz per eye, which may not work well with film-source material - the overwhelming majority of what we'll be watching. They could use 240hz displays, which would be 120hz per eye, which would work well for both video- and film-source material, but would be a non-starter for CRT. The BDA press release said this:
Moreover, the specification is display agnostic, meaning that Blu-ray 3D products will deliver the 3D image to any compatible 3D display, regardless of whether that display uses LCD, Plasma or other technology and regardless of what 3D technology the display uses to deliver the image to the viewer's eyes.
It's interesting that they go out of their way to point out that it is display agnostic, but if you read it closely, it's only display agnostic on any compatible 3D display. Nobody knows what "compatible" is at this point.
I'll be very interested to see the details on the spec when it's released.
See the other thread about this, too:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=19299.html
MikeEby
Posted: Mon Dec 21, 2009 4:59 am    Post subject:
I don't see the point of a 50-60" Plasma or LCD screen at 10-12 feet away. IMO don't you need big screen immersion to really make 3D effect pay off?
bbfarmht
Posted: Mon Dec 21, 2009 5:22 am    Post subject:
MikeEby wrote:
I don't see the point of a 50-60" Plasma or LCD screen at 10-12 feet away. IMO you need big screen immersion to really make 3D effect pay off?
I agree with that. It wasn't till my daughter wanted to watch "Coraline" in 3D on as she likes to put it "Daddy's Big Screen", that I was impressed with the 3d experience. I think that 3D on anything smaller than an 80" screen is pointless. The whole idea is feeling immersion, to feel like what you're seeing is actually in front of you. You can't do that if the display is not large enough to "Lose yourself in it".
As far as what the standards will be I can't see why they would go with 240hz unless the display manufacturers have pushed this. If they can have exceptable results with 120hz why would they set it higher. Sure you would have a better experience with 240 but most displays are 120. Then again I have been wondering why they are raising the displays up to the 240 range. There is a point that its just numbers and no advantage to the viewing experience.
Adam
Benjamin Franklin
Axatax
Posted: Mon Dec 21, 2009 7:18 am    Post subject:
Doable - if you're willing to sacrifice some resolution, so long as you have a competent VP (or the next generation of BDPs offer more flexible output options).
If you absolutely *must* have exactly 1080p at all costs, you need to look at a digital, but I bet most here aren't running at 1080p72 for film to begin with, so I wonder why this is even an issue?
Jeff
Posted: Mon Dec 21, 2009 7:23 am    Post subject:
Just think.. it's the next excuse to tell everyone that their current 1080p displays are obsolete, and that they need to upgrade.
TheVerge
Posted: Mon Dec 21, 2009 2:52 pm    Post subject:
I was thinking the same thing the other day... This 3d stuff is out of control with consumer sets, and there is nothing to watch on them.
Not to mention, the only 3d glasses i can find are 500 bones.... OUCH !
Posted: Mon Dec 21, 2009 2:58 pm    Post subject:
For $600 you can have the whole TV....
Posted: Mon Dec 21, 2009 3:31 pm    Post subject:
I saw the 2 Toy stories in 3d.... I'm not impressed... It distracts from the film.
Posted: Mon Dec 21, 2009 4:17 pm    Post subject:
I was digging a year ago for information, and it seemed at that time that pretty much any display device could be made 3D compatible with an external 3D processor... sorta like a VP that we run now. So I am hoping that if 3D ever winds up being worth doing, that we will be able to do it... if the projectors can handle the BW. If not, the only alternative for 3D CRT is with a blend.
I worked for a guy four years ago who was doing 3D rendering for the military without the use of ANY 3D glasses. They were using CRT projectors because CRT was the ONLY technology that would actually make an image that looked 3D at that time. He said that digitals just didn't work.
BTW my brother saw Avatar 3D last night a a really good theater in Philly. He phoned me as soon as he got out and said that it was the coolest fing thing he ever saw. It was quite an endorsement. He said the 3D looked perfect and realistic like no other he had seen yet. Now I just will have to go to a theater and check out Avatar as well and I don't ever go to theaters anymore.
Posted: Mon Dec 21, 2009 4:36 pm    Post subject:
What theater???
Posted: Mon Dec 21, 2009 4:41 pm    Post subject:
Glad I'm not the only one. The only recent 3D film I've seen was Monsters vs. Aliens. The 3D was at best a dopey gimmick, and at worst a serious distraction from enjoying the film. I just don't get the attraction.
Posted: Mon Dec 21, 2009 5:13 pm    Post subject:
What theater???
Regal Cinema in Warington... I just phoned him for you Smile
Posted: Mon Dec 21, 2009 5:14 pm    Post subject:
What theater???
Laughing
Thanks I know it well.... in fact, i saw Toy Story 3d there!!!
TheVerge
Posted: Mon Dec 21, 2009 6:37 pm    Post subject:
Not sure how that is possible without 500hz refresh rate or so.
Posted: Mon Dec 21, 2009 6:55 pm    Post subject:
I do not know and I have been wondering ever since... It was a military secret and he was not allowed to explain the function to me at all Confused
MikeEby
Posted: Mon Dec 21, 2009 7:09 pm    Post subject:
Lets hope Avatar doesn't have a Yo-yo in it...Every 3D movie I've seen to date seems to have one.
The opening shot with the WB logo in most of the Harry Potter Movies look very 3D on a CRT.
Oddly enough a simular shot in The Dark Night does too...Something about smoke.
Posted: Mon Dec 21, 2009 7:14 pm    Post subject:
Refresh rate has nothing to do with it, TheVerge.
There is a technique for passive stereo viewing, but they it requires two projectors and passive glasses (cheap polarizers). There were also some newer direct-view LCD displays with a built-in grating to show discrete images for each eye, but it only worked for a single viewer in the sweet spot.
I doubt the display technique was a military secret, but rather the project itself was classified. Practically all of the military's technical hardware like this comes out of the commercial or ed/research sectors first.
Page 1 of 6
