Marquee 9500 ultra: geometry issue... SOLVED
Goto page 1, 2, 3  Next
karmat63
Posted: Sat Dec 12, 2009 7:56 pm    Post subject: Marquee 9500 ultra: geometry issue... SOLVED
I'm setting a Marquee 9500 Ultra; under Geometry menu, going to top pincushion and bottom pincushion, I can't make any regulation; if I hit top pincushion, the bars for regulation are normally showed (top pin and top keystone), but changing values from 0 to 100 makes no difference; same with bottom pincushion...
The only way to have straight bottom and top lines is by green convergence.
Any idea?
Posted: Sat Dec 12, 2009 7:59 pm    Post subject:
Make sure all connectors are clean on the CVA, and VDM. Then if thats not it clean all the socketed chips on the CLM and the DPB and the connectors to the two boards.
karmat63
Posted: Sat Dec 12, 2009 8:12 pm    Post subject:
Thanks, I will try..
Posted: Sun Dec 13, 2009 12:22 am    Post subject:
Hello
You may have a faulty GEOM/FOCUS board, or an older type board without geometry circuits.
Posted: Sun Dec 13, 2009 12:52 am    Post subject:
If you have a non ultra DPB you wont have certain functions also.
karmat63
Posted: Sun Dec 13, 2009 11:06 am    Post subject:
I've cleaned all board contacts (not the socketed chips as I have no chip pullers) with no results: I have no possibility to correct bottom and top pinchusion and keystone, other than by green convergence. All the other geom regulation works properly...
The focus board is labeled as: 03 270354 02P
The DPB is: 03 280335 03P
Meybe one of this 2 board (or both) are older types (non Ultra)?
Thanks for your answers
Posted: Sun Dec 13, 2009 11:57 am    Post subject:
Check ICU7 (square chip) on the deflection processor board (on control module).
If your Marquee is a true Ultra, U7 would have to be version 5.5 or higher.
menec
Posted: Sun Dec 13, 2009 1:08 pm    Post subject:
This is just quessing, since I'm not really familiar with 9500 Ultra, but I had exactly the same symptoms when I replaced boards with older revisions in my PJ. The older revision boards were missing some fly wires. You could check if on the DPB and on the VDM those wires are in place.
antorsae
Posted: Sun Dec 13, 2009 1:34 pm    Post subject:
I also had this issue and the fly wire in one of my DPB board was missing. Make sure you have that fly wire.
karmat63
Posted: Sun Dec 13, 2009 2:59 pm    Post subject:
The DPB looks like it is an Ultra board; the chip U7 is v. 5,5
and it has green fly wire:
This is a pic of VDM:
All the other geom corrections are OK; only I have no possibility to correct Top and Bottom pin
menec
Posted: Sun Dec 13, 2009 3:11 pm    Post subject:
Ok, so the VDM does not have the flywire (+resistor) and the additional cap... What about the convergence board? does it have fly wires?
Maybe one of the 8/9500 Ultra owners around here can post a pic of their boards, but my guess would be, that the VDM is missing these additional parts...
Posted: Sun Dec 13, 2009 7:08 pm    Post subject:
here's a pic of the Ultra VDM , but I also had a customers Ultra boards board here with no top/bottm pin and it was the FGM. After I re-conditioned the board and did a small repair to the Focus section it I simply sent it to Curt for repair on the Geometry circuit.
Posted: Sun Dec 13, 2009 7:22 pm    Post subject:
I didn't think there was an ultra VDM. There are different versions of the VDM but not one that is specific to the ultra and required for the ultra. Yes,No?
Posted: Sun Dec 13, 2009 7:26 pm    Post subject:
The CVA also has fly wires, you can convert the non ultra rear heat sink boards to ultras with the addition of these parts and wires . A comparison of the non ultra to ultra schematics is all that is needed.
karmat63
Posted: Sun Dec 13, 2009 8:07 pm    Post subject:
Many thanks to everyone for your suggestions...
I have a working 8500 (non ultra) and so I was able to compare rear heatsink boards: they are the same, so I assume, rear heatsink boards in 9500 are non Ultra boards and that explain why i can't adjust top and bottom pin... am I correct?
If so, where could I find Ultra boards schematics to make changes needed?
Or do you think could be better first trying to swap focus board (in case is this one defective)?
dturco
Posted: Sun Dec 13, 2009 8:15 pm    Post subject:
I'm pretty sure all Marquee 8500/9500 have the ability to adjust top and bottom pin. Be they Ultra or not.
Let's see if others agree.
http://www.hulu.com/firefly
Posted: Sun Dec 13, 2009 8:21 pm    Post subject:
DAve, along with top and bottom pin they have top and bottom keystone on the same menu selection. I think the software change puts them together.
Karmat, make sure you also have an ultra FGM, NOT FCM. On the Ultra FGM Focus and Geometry Module the electronics cover the entire board, on the FCM Focus Control Module the back 1/3 of the board is blank, nothing there at all.
karmat63
Posted: Sun Dec 13, 2009 8:37 pm    Post subject:
I think it is FGM:
menec
Posted: Sun Dec 13, 2009 9:44 pm    Post subject:
Yes, this is an FGM.
I'd try soldering in the missing components on the VDM and then try it again.
Nashou has the schematics in his signature
karmat63
Posted: Sun Dec 13, 2009 10:16 pm    Post subject:
I looked at schematics in Nashou's page Shocked
But I need something easier and with some pics Embarassed : as put this resistor in this position, solder the fly wire from here to there...
I'm not skilled at board level... nor I have any skills in soldering, but a friend of mine has and he offered to help me if I can show him exactly what to do....
I hope someone has the right instructions
Thanks to all of you
Page 1 of 3
