| Posted: Sun Dec 06, 2009 11:07 pm Post subject: |
Also i should mention, in the pics you only see the brightest lines in the middle of the tube, they go all the way across edge to edge of the internal pattern, but are brightest in the center. it does sound like the jail bar tech bulliten but that was for the 8000-9000 PJ's way back in the 90's this is a 2004 build.
This is starting to sound like the Gozer thread
| Posted: Mon Dec 07, 2009 12:58 am Post subject: |
Ok new discovery, on the vertical lines in the horizontal bands caused from the Astig board. If i disconnect one astig coil connector, doesn't matter which one the squiggles go away , well they are are barely visible and will not show up on screen as soon as I plug in the not connected coil connector they come back.
| Posted: Mon Dec 07, 2009 1:12 am Post subject: |
Try altering your porch settings.
_________________ Chip
| Posted: Mon Dec 07, 2009 1:16 am Post subject: |
| Nashou66 wrote: | Chip, this is with internal patters and its on all internal frequencies. But thanks.
Athanasios |
Sorry, I must have this confused with another fudged up Marquee thread
| Posted: Mon Dec 07, 2009 1:24 am Post subject: |
| Nashou66 wrote: | yeah, maybe i'll look for another ampro and put those into the blend
Athanasios |
What would be the fun in that?...... mount them, align them and watch them.......
| Posted: Mon Dec 07, 2009 1:30 am Post subject: |
| macgyver655 wrote: | | Nashou66 wrote: | yeah, maybe i'll look for another ampro and put those into the blend
Athanasios |
What would be the fun in that?...... mount them, align them and watch them.......  |
Its sick isn't it? I love problems. Id probably break something on the Ampro just so i could post crap
here.
Ok now back to the problems. What to try next?
Weird thing is it's on Both 8503's I need to find out if its inherent with this PJ model and VDC missed it?. I wonder if Bruce has his set up or if he sold them?
| Posted: Mon Dec 07, 2009 1:32 am Post subject: |
Did you try a different neck board yet?
| Posted: Mon Dec 07, 2009 1:39 am Post subject: |
Ya know. Normally I wouldn't even think this would be a neck board issue since its on all 3 tubes but since this is a new device you have to account for build anomalies.
| Posted: Mon Dec 07, 2009 1:43 am Post subject: |
Alright, I just thought of some thing. If the neck board doesn't yield any results. Do the lines show up at low resolution? Like 480p?
| Posted: Mon Dec 07, 2009 1:57 am Post subject: |
Hi Ron, ok same with new VNB on Red. I tried all internal resolutions and the lowest one in the marquee has to be close to that.
Now remember i have all external sources disconnected while testing.
Since i first hooked these up I thought it was a Tv-one issue, so i never pursued investigating till i started to look more in depth to the blend zone lines I had.
I always thought those jail bars were part of the Tv-ones. So i started this thread once i took the tv-ones off the video chain and went to my Lumagen and now No sources.
Wish I would have noticed it was a PJ issue and not the Tv-ones earlier as I would have not mounted them to ceiling yet, servicing these above your head sucks !!!
Ok I feel better after the rant.
All thats left is the VDM, but i have no Ultra VDM/CVA rear panel. I know I can modify a non ultra to become one. i have one loose I could do that to, or will I be able to just use the stock board for now while testing? i wont need all the extra convergence and keystone crap for now.
| Posted: Mon Dec 07, 2009 2:14 am Post subject: |
Well my next thought was that since you also have an issue with your astig then maybe thats whats causing this. Believe me I'm going out on a limb here but I think we are already out there. If you can run the resolution down to 480p then you should be able to run a tube without the astig coil. Maybe the coil is causing the problem. It should still focus well without the coil. Remember, astig was never used on early, low res devices. It wasn't until higher res with mass amounts of electron flow that astis was required.
If your not comfortable with that then try a different coil.
| Posted: Mon Dec 07, 2009 2:23 am Post subject: |
I dont need to run the astig as I can get the dots nice and round with the CPC magnets, and the astig coils are built into the focus coils. The squiggles don't bother me as much, its the jail bars that are very noticeable on screen. And that has not gone away with any testing and swapping and changing. I could try the LVPS and HVPS but I don't see how it could be those. Only other thing is the way they route the wires? On theses there all tucked nicely away between everything On all other PJ's there just everywhere. But even that might not be it, I have a different HDM and those wires are just hanging.
| Posted: Mon Dec 07, 2009 3:34 am Post subject: |
| Nashou66 wrote: | Ok I tried a new Recall and cleared it out and left it as is , no convergence or anything else touched.
The lines were still there.
So i went to my other Long bow and pulled the vim since i only have the Moome card and not any RGBHV's as the other PJ does, easier to dismantle . I put in another 02P vim with no peaking circuit and its still there.
Also Scott if you read this remember i told you about those horizontal bands of vertical distortion lines and I could not capture it? well this other vim shows it better, But i made it less noticeable by pushing on the slot 2 side of the vim connector against the back plane. It was reduced but still there. Pics of vertical bars with different Vim and
the horizontal bands of vertical distortion
Bars and distortion if you look closely
Close up of distortions, these have always been here since I got the longbows.
Scott do you think it could be the Longbow mods? And could I try a non Ultra HDM here to see if its that?
So now I have two issue with the PJ's and one with the Tv_ones.
Athanasios |
Ok, In these images here, if you adjust horz phase, the image moves back and forth, how about the lines?
| Posted: Mon Dec 07, 2009 3:45 am Post subject: |
Ok your on to something here, when I used the SIZE control the bars move, they either expand or contact.
Now using phase they stay in the same location, so seems that Phase does not affect them but SIZE does.
Also i changed the internal resolutions and the higher i go the other lines in the blown up pic become larger in vertical size and more defined.
At the lowest frequency its barely noticeable.
I need to read the service manual to see what H phase comes from and to what board, most likely the convergence board.
| Posted: Mon Dec 07, 2009 4:26 am Post subject: |
Maybe you should try swapping the power supplies.
| Posted: Mon Dec 07, 2009 6:03 pm Post subject: |
| Nashou66 wrote: | I dont need to run the astig as I can get the dots nice and round with the CPC magnets, and the astig coils are built into the focus coils. The squiggles don't bother me as much, its the jail bars that are very noticeable on screen. And that has not gone away with any testing and swapping and changing. I could try the LVPS and HVPS but I don't see how it could be those. Only other thing is the way they route the wires? On theses there all tucked nicely away between everything On all other PJ's there just everywhere. But even that might not be it, I have a different HDM and those wires are just hanging.
Athanasios |
You may be onto something here with the wire routing. I have seen this exact same looking distortion on Mits RPCRT's and it is caused by the position of the mini-coax cables... On the Mits sets, moving wires around can make the issue worse or better.
| Posted: Mon Dec 07, 2009 6:04 pm Post subject: |
Do these Marquee's still use those mini RCA connectors for the coax?
