sony 1272Q
chrissky
Posted: Tue Nov 24, 2009 4:33 pm    Post subject:
Hi everyone,
blue image appear and when push the DC-10 4 wires pin (2 red and 2 yellow) the blue ghost image disappear, what can i do to permanently fix this blue ghost image. was it loose? should i remove the PCU to check for solder weld problem.
thanks
As regards to the HDfury 3, the special edition is that all i need to have to get to 1080i, thanks
Chris
Posted: Tue Nov 24, 2009 5:10 pm    Post subject:
I'll let somebody else chime in on the problem, but I'd guess it's a dry solder joint, will just need to be re-flowed.
You don't even need the HD Fury 3 if you don't want to spend the money. As AnalogRocks pointed out a couple of posts ago, all you really need is the HD Fury 1, green cable (RGBHV), power supply, and a HDMI-to-DVI cable.
So, this:
http://www.curtpalme.com/HDFury.shtm
Advanced kit with GREEN cable and power supply.
And this cable (or one like it):
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10231&cs_id=1023104&p_id=2404
Posted: Tue Nov 24, 2009 5:11 pm    Post subject:
chrissky wrote:
Hi everyone,
thanks
Chris
No you don't need the HDFury3. You can use the HDFury1. Click on this link:
HDFury1
Order the advanced kit with power supply. You will need the power supply. DO NOT buy the gamer unless you have a PS3 to do bluray. You will need the HDFury1 Advanced, green edition, with power supply.
Don't forget a DVI to HDMI cable like this:
http://www.amazon.com/Cables-Unlimited-PCM-2296-06-Single-Cable/dp/B0007MWE1E/ref=sr_1_4?ie=UTF8&s=electronics&qid=1259082758&sr=8-4&tag=curtpalmecrtp-20
chrissky
Posted: Wed Nov 25, 2009 5:00 pm    Post subject:
thanks everyone
Chris
