Weak bass -- do I need a new receiver?
Posted: Sat Nov 07, 2009 12:50 am    Post subject:
I skimmed through this quick so if I'm repeating someone, sorry. But if this is a down firing sub and your floor is carpeted then try placing the sub on a piece of plywood or flat board and see if that increases your punch.
rabies_70
TV/Projector: Sony G70Q
Posted: Sat Nov 07, 2009 4:07 am    Post subject:
I believe it is difficult and expensive to attempt visceral bass without an infinite baffle.
http://ibsubwoofers.com/
I have 4 of these 15"
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-455
Powered by a Mackie fri1400 bridged
Positioned in front more or less center of the screen/room
EQ'd with a Behringer 1124 feedback destroyer
and room EQ wizard
http://www.hometheatershack.com/roomeq/
Bass traps in all the corners and acoustic treatment panels on walls.
Bass so low it shakes you in your gut. Hell it can actually shake the whole house. Distortion free. It's a very musical sub when it needs to be and a ass thumping movie sub all the rest of the time. Speakers barely moving at all too.
You can mount them so they are invisible to the room as well through a manifold no bigger than an air intake for a furnace. I just wanted to see mine.
On the cults website there are some really nice finish quality builds.
Go inifinite Twisted Evil
Ray
I am an iconoclast
Posted: Sat Nov 07, 2009 4:49 am    Post subject:
Ray, so you have what, about a grand or so into your IB setup? That's about what I'm looking at with the eD sub, and should have usable response down in the 10hz ballpark, and at or above 100db. Where does your usable response stop, i.e. where you down 3db, and what kind of SPL are you getting at, say 20hz? Just curious.
I'll also just point out (again), that most of us do not have houses conducive to an IB setup (Gary included, I think)... Or, even if we do, if isolation is a concern, then an IB setup is a non-starter. In my case, IB would run completely counter to my goal of being able to watch at a reasonable volume at night with the kids in bed.
Posted: Sat Nov 07, 2009 5:19 am    Post subject:
greg_mitch wrote:
I have heard great things about their dual designs. My only hang up is the fit and finish. How would you finish it? I saw someone get some gloss black formica and make it look like a piano finish. That was neat.
I don't think paint takes to EFS (similar to MDF) too well without first putting some sort of thick base down (bodyputty?).
I am partial to the shear grunt of ported designs but I think that the amount of power available here would probably blow my mind.
It does look pretty sleek though without ports...
I know what you mean about ported... Cliffy's two SVS' feel like you could shake the freakin' house down with them. Standing in the kitchen above his theater when it's rockin', it feels like somebody is standing next to you slamming their foot on the floor... Seriously (if he has a meet again next spring, you need to ride over there with me). Anyway, in the case of the sealed eD, I'm just going by what Ben told me, and he said I'd be flat down to probably 15hz at 105dB, and would have nice usable output close to 10Hz in-room.
Yes - It would take a little work to finish... That's why I said "a couple of weekends." I could probably build the thing in a single day, but priming and painting would probably take another two. Basically, I think filling and smoothing the seams and corners are the hard part. You put a soft filler on (like Bondo), then sand smooth. Shoot a coat of primer, and sand lightly. Fill/smooth any more high or low spots, and shoot the primer again. Once it's good and smooth, you shoot 2 or 3 coats of paint. The laminate is a cool idea, but I've had bad luck with the router and laminate trimmer bit... All it takes is one tiny wrong move, and you 'eff' the whole thing. Plus, I like the rounded edges. I don't think the finish would be ultra-critical in my room - everything is black.
The other option would be to see if they'd sell me an A5-350 as a kit... It's $800 complete, so maybe it could be had for in the $600 ballpark as a kit. I could start with one, and go from there. I don't know... One thing I do know: I have a bad case of champagne taste on a Milwaukee's Best budget.
Oh... Gary... Sorry to highjack your thread, but I think it's actually relevant, in that I want big buck performance and don't want to spend much for it, either.
Posted: Sat Nov 07, 2009 3:11 pm    Post subject:
Oh yeah, totally relevant. You're looking to spend more than I would, and I think you're more willing to take on finishing/etc jobs than I would be. (I don't have any kind of usable spray setup so I have to buy, & learn to use properly, some kind of sprayer in addition to the rest of the job.)
And I agree completely about Ray's IB comments. IBs are very cool but there is NFW I could use one. I have concrete on 2 sides & floor of my HT, and un-breachable spaces on 1 side & ceiling. The only conceivable way I could put an IB in my HT would be to use the equipment closet as the baffle space. But that means the rest of the house would get about as much bass as the HT, and as you say that's NOT a viable solution when there are other people in the house. If it was just you & your wife, AND your wife always watched movies with you in the HT, then who cares if the rest of the house is shaking? But that's not my situation.
Mac, I'll try slipping a board under the sub, but I would be VERY surprised if that made any difference. There's just carpet and pad on top of the concrete floor, and the carpet is going to be 99% transparent at subwoofer freqs. As far as the sub can tell, it's firing directly onto concrete.
dturco
Posted: Sat Nov 07, 2009 5:31 pm    Post subject:
Just dig a hole like this Guy did. Mr. Green
http://blog.makezine.com/archive/2008/07/worlds_largest_subwoofer.html
http://www.hulu.com/firefly
Posted: Sat Nov 07, 2009 5:53 pm    Post subject:
Even if I was that crazy, and even if my wife wouldn't have me committed if I tried it, that sort of thing works a whole lot better BEFORE you build the HT on top of it...!! Laughing
dturco
Posted: Sat Nov 07, 2009 6:11 pm    Post subject:
Why not Gary? Econmic stimulus. You'd have a shovel ready project. Embarassed Laughing
Oh and also found the whole article.
http://www.royaldevice.com/custom.htm#THE%20REAL%20TOTAL%20HORN
