roland@b4
| Posted: Wed Jul 08, 2009 10:43 am Post subject: |
SHE LIVES !!!
Decided to get brave an make up a lead
Connects pins 1+2, 3+4, 5+6
This plgs into J5 on the RGB Driver board R762705 after the semu is removed
I must assume that these are in and out for the SEMU. and that whilst the active part of the circuit is disabled the video is still going through a torturous route and about 6 connectors to and from the SEMU Card which can't be good.
All I have to do now is soak test the projector because don't forget I only think it is the SEMU unit that is loosing me a color.
Guys thanks so much for your help
roland@b4
| Posted: Wed Jul 08, 2009 3:31 pm Post subject: |
Ran for about 2hrs then went into EHT failure.
I doubt it is related just a failed quad.
| Posted: Wed Jul 08, 2009 4:16 pm Post subject: |
I wonder if it might be the splitter in this case because of the Green only failure prior to the EHT shutdown.
roland@b4
| Posted: Wed Jul 08, 2009 4:41 pm Post subject: |
Ah I like your thinking.
I've only ever had about two splitter failures EVER so tend not to consider them.
Out with the soldering iron !
