WayneB
Joined: 24 Dec 2008 Posts: 113 Location: Victoria, BC
TV/Projector: Marquee 9500LC Ultra
| Posted: Tue Jun 30, 2009 6:46 pm Post subject: Strange Prism-Like Image Below the Screen Image |
I have a newly installed ceiling mounted Marquee 9500LC Ultra and a 16x9 72inch wide screen.
I just noticed a prism-like (multi-colored) light about 24 inches below the screen.
It may have been there for the last month (since I installed the projector), but I just noticed it yesterday.
What the heck is it?
It is definitely coming from the lenses. I can hold a piece of white paper in the light path and follow it back up to the lenses. It happens on all signal sources (1080i satellite, 1080p DVD, and all test images from the Marquee).
I took the following pictures in a totally dark room, using "night scenery" and the count-down timer, then modified them in Photoshop Elements to brighten the image so it is easier to see. I also taped some white paper as a background for the colored lights.
Marquee white-screen test pattern with prism-like image below
This picture is a blow-up of the prism-like image
Enhanced closeup of the Prism-like image
Has anyone else seen this before?
What is causing it
Am I "overdriving" the Marquee in some way?
Thanks for your help
....Wayne
jkruger
| Posted: Tue Jun 30, 2009 6:49 pm Post subject: |
Bubbles in the glycol?
Heywood Jablome
| Posted: Tue Jun 30, 2009 7:04 pm Post subject: |
| jkruger wrote: | | Bubbles in the glycol? |
Yep. Mine does the same thing... Filled the tubes a little short and this (exactly) was the result. Also on a 9500.
_________________ "Those countries which lag behind in industry, in the application of mechanics and technical chemistry, in the careful selection and utilization of natural products, where the respect for such activities does not permeate all classes of society, will unfailingly decline in prosperity. They will sink faster when neighbor states, with an energetic exchange between science and industry, go forward with renewed vitality."
WayneB
| Posted: Tue Jun 30, 2009 7:07 pm Post subject: |
| Quote: | | Bubbles in the glycol? |
That sounds serious!
What would it take to fix that? A quick sharp rap on the side to float the bubbles?
...Wayne
jkruger
| Posted: Tue Jun 30, 2009 7:16 pm Post subject: |
You just need to put a little more glycol in them. The bubbles are at the top of the chamber, rapping on the tubes won't do any good.
WayneB
| Posted: Tue Jun 30, 2009 7:19 pm Post subject: |
| Heywood Jablome wrote: | | jkruger wrote: | | Bubbles in the glycol? |
Yep. Mine does the same thing... Filled the tubes a little short and this (exactly) was the result. Also on a 9500. |
So what did you do?
Are you just living with it?
...Wayne
You might need to add some of this....
http://www.mcmelectronics.com/product/20-4275
Turn down the contrast and brightness for the sake of your eyes and look through the lenses. You should see the source of the relection on one or all CRT tubes.
| Posted: Tue Jun 30, 2009 7:21 pm Post subject: |
I bet you could put some masking tape or other blocking material over the top of each tube face -- which you're not using anyway -- and keep that stray light from leaking out. Some people say masking the top & bottom "unused" areas with black material will help your contrast ratios.
That works with an AC projector. I don't know if you can do that with an LC. Maybe on the back of the lenses?
jkruger
| Posted: Tue Jun 30, 2009 7:28 pm Post subject: |
How high is your brightness?
Heywood Jablome
| Posted: Tue Jun 30, 2009 7:32 pm Post subject: |
| WayneB wrote: | | Heywood Jablome wrote: | | jkruger wrote: | | Bubbles in the glycol? |
So what did you do?
...Wayne |
Living with it, until I take the PJ down again. My color scheme is damn near black on the screen end of the room, so its' not too noticeable.
jkruger
| Posted: Tue Jun 30, 2009 7:39 pm Post subject: |
I wouldn't try to mask an LC pj. Black stuff between the lens and c-element might get too hot and make a mess.
| Posted: Tue Jun 30, 2009 7:55 pm Post subject: |
The image inverts when it leaves the lens. Look in while it's running with sunglasses on. You will see one large bubble at the top, inside the coupling of each color you see projected on the wall. You could blank it with some black tape or paper rolled in to match the curve of the c-element. The fluid does not get that hot. I have seen factory installed blanking panels on other LC projectors.
_________________ Chip
| Posted: Tue Jun 30, 2009 8:33 pm Post subject: |
Yeah, I probably wouldn't use tape on the lenses, as it would be a mess, but a plastic or perhaps flocking tape stuck to itself to seal the adhesive or something might work.
Some later XG LC's had factory-installed masking panels - I've seen them in pictures. I bet if you searched here or at AVS long enough, you might even find them in a photo. I've thought about making a set for my G70 to try, but it's LOW on the priority list.
WayneB
| Posted: Tue Jun 30, 2009 8:51 pm Post subject: |
| jkruger wrote: | | How high is your brightness? |
Currently brightness is 60 (but I usually run it as low as 50), contrast is 40.
| stefuel wrote: | | The image inverts when it leaves the lens. Look in while it's running with sunglasses on. You will see one large bubble at the top, inside the coupling of each color you see projected on the wall. |
I did not see any bubbles anywhere, until I tapped the side of the projector and saw the liquid line move. It is not much of a bubble, but I guess if I see it at all, it is too much, right?
I think I will have to live with it as well, at least for a while.
Since it must have been there all along, and I did not notice it for a month, I can "condition" my mind not to notice it again.
What is the process of "topping up the glycol"?
...Wayne
dturco
| Posted: Tue Jun 30, 2009 9:07 pm Post subject: |
| WayneB wrote: | | jkruger wrote: | | How high is your brightness? |
...Wayne |
I'm certainly not an expert but I believe you have to take the Marquee down from the ceiling and then top off the glycol through the Fill holes
see here : you only need to look at 5-b
http://www.curtpalme.com/Marquee_LC_tube_replacement2.shtm
This is what I am doing now with the new bellows I just Installed. As for the purpose, topping off the Glycol is to insure that no part of the tube face is not submersed allowing it to over heat and implode.
If I'm wrong I'll beat myself with a wet noodle.
http://www.hulu.com/firefly
dturco
| Posted: Tue Jun 30, 2009 9:22 pm Post subject: |
Also a more important question is where did the Glycol go? Are your bellows leaking?
I misread your process, as purpose. Sorry about that. This is what you need for the process
http://www.etechvideo.com/techtip8.htm
Kiev Savoie
| Posted: Tue Jun 30, 2009 9:38 pm Post subject: |
Even if you don't have a leak i would imagine that those bubbles are scattering light to other places on the image and may be affecting your black detail a little. the surface of an air bubble suspended in a liquid is usually shiny, even mirrored. it could be like having a tiny disco ball hanging out at the source of your image! At least they aren't spinning! But then again maybe not.
WayneB
| Posted: Tue Jun 30, 2009 10:05 pm Post subject: |
| dturco wrote: | | Also a more important question is where did the Glycol go? Are your bellows leaking? |
Dave, don't even hint at that! I have been following your adventure replacing your bellows.
Thanks Tom. I will put that on my things to buy list.
| GaryFritz wrote: | | I bet you could put some masking tape or other blocking material over the top of each tube face -- which you're not using anyway -- and keep that stray light from leaking out. |
Thanks Gary, my previous projector was a Runco 980 Ultra air coupled, so this whole Liquid Coupled is new to me.
....Wayne
dturco
| Posted: Tue Jun 30, 2009 11:03 pm Post subject: |
| WayneB wrote: | | dturco wrote: | | Also a more important question is where did the Glycol go? Are your bellows leaking? |
....Wayne |
Sorry I "upset" you with that leak comment.
To put in more glycol the machine has to be on the floor I think, Gravity and all that nonsense. I sincerely hope you don't have a leak. The bellows are easy though.
Magnetics and shiempflug [flapping] however, are hard for me.
| Posted: Tue Jun 30, 2009 11:25 pm Post subject: |
I, like Chip, have seen a soft flocking material adhered to the top and bottom of the C-elements. I believe this is done to block any reflections of the image off the screen or any surrounding reflective material to be focused back into the LC chamber and then possibly back out of the lens onto the screen therfore contaminating the original picture. To demonstrate this i bet you could shine a very bright flashlight onto the screen while the PJ is off and then move it around and you will see another light source moving with it. That would be the light being reflected off the screen into the PJ lens then back out. Now this is just a theory but it makes sense to me.
