Problem with Marquee WIDTH and FOCUS
antorsae
Posted: Fri May 15, 2009 7:33 am    Post subject: Problem with Marquee WIDTH and FOCUS
I had an HPVS failure with one of my Ultras. I replaced the HPVS as well as a neckboard (since initially I suspected the problem was due to a VNB) and and now I have the following:
The image is compressed horizontally and the image is completely out of focus. The R & B can be more or less focused but the G can only be focused in the center. I've already swapped:
- CLM
- VIM
- LVPS
- HDM
- FGM
..and I am always getting the same behavior.
Ideas?
Posted: Fri May 15, 2009 10:51 am    Post subject:
hmmm i wonder if the HVPS failure took out the deflection coil and or focus coils. was there and arc at all? An I assume this is only on the green or all tubes?
if all tubes then rule out the deflection coil unless it was a bad arc and took them all out but i doubt it, looks like the only thing left is the CVA and VDM since you changed all others.
antorsae
Posted: Fri May 15, 2009 11:02 am    Post subject:
Athanasios,
It's in all tubes.... so I don't think it is in the coils... I will change the whole rear panel (CVA, etc.) and see.
There was no ark... when the HPVS failed.... but definitively there was an smell of fried electronics, that's why I first thought it was a VNB which in fact looked bad, which I changed.
I will change the whole rear of the PJ and see.... Good thing I have a lot of spares.
Posted: Fri May 15, 2009 11:04 am    Post subject:
I wonder if the HV splitter went bad? try that also it might not have been the HVPS at all.
Posted: Fri May 15, 2009 11:20 am    Post subject:
Yep. I would also start here for this problem. And again, you got something mysterious going on in that Marquee.
Posted: Fri May 15, 2009 11:34 am    Post subject:
I was firts thinking too high HV, but if that is case, then picture should be smaller vertical also???
Antorsae can you check if +85v is OK (from vnb or connector under blue tube)
DVDO VP-50
New hobby, Rally
antorsae
Posted: Fri May 15, 2009 11:58 am    Post subject:
Good point about the HV splitter. Will check it out tonight!
antorsae
1031... where in the VNB can I test 85V?
Is is VDC or VAC?
Posted: Fri May 15, 2009 12:05 pm    Post subject:
Is is VDC or VAC?
Multipin connector P1 at VNB, another extreme pin is -85 and another is +85V and those are VDC. That same +85v is feedet to HDM.
Another note, does picture size/focus change if you ramp contrast up/down.. If it does, then it sounds more to HV issue.
Spiltter should read 3300ohms between in -> outīs
DVDO VP-50
New hobby, Rally
Posted: Fri May 15, 2009 12:23 pm    Post subject:
When a splitter is suspect to this degree - replace it, even if it's not the real problem.
antorsae
Posted: Fri May 15, 2009 3:38 pm    Post subject:
Splitter changed, problem remains. Will change rear panel tonight.
1031: moving contrast up down does not affect picture size, but affects focus heavily.
Posted: Fri May 15, 2009 3:49 pm    Post subject:
Ok next unplug focusyoke connectors from FCM and test is there still same effect to focus if you ramp contrast up/down.
I want just make sure where that focus "movement" is happening (FCM, HV-section or something Question )
DVDO VP-50
New hobby, Rally
Posted: Fri May 15, 2009 3:55 pm    Post subject:
The HVPS mainly operates from the 390 volt primary DC supply inside the LVPS. The HDM mainly operates from the +85 DC supply from the LVPS.
The internal +85 DC supply inside the LVPS is switched from the main 390 DC supply inside the LVPS.
Since both width and focus suffered in that shot, and both operate from the same 390 supply, I would suggest that you replace the LVPS.
antorsae
Posted: Fri May 15, 2009 4:00 pm    Post subject:
Mike: I replaced the LVPS too. Same problem.
Posted: Fri May 15, 2009 6:10 pm    Post subject:
How are another functions like convergence etc.. does those work like they should work? Iīm asking this because i once had vim that had dataline short and that messed all functions, like focus adjust changed convergence etc.
DVDO VP-50
New hobby, Rally
Posted: Fri May 15, 2009 8:23 pm    Post subject:
looks like he changed all boards except the back heat sink ones. if those dont show any issue i wonder if its the the mother board of the main chip on the back plane, not sure if that controls any function but isnt it where the super secret service menu code is in and some other factory set functions? didn't you have a glycol leak on that PJ once , that could have done something to that chip? Tim where are you!!!!????
Posted: Fri May 15, 2009 8:34 pm    Post subject:
How do you know the replacement HVPS is ok?
Posted: Fri May 15, 2009 9:02 pm    Post subject:
Ya know, I have to ask, when you changed the CLM did you also use a different DPB or do you use the original and put it on the different CLM?
Posted: Fri May 15, 2009 11:27 pm    Post subject:
Guys!
Weird problem, have not seen this before.......Andres, was there ever any traces of a glycol leak in that machine?
antorsae
Posted: Sat May 16, 2009 7:58 am    Post subject:
I just tested with a different one and same issue.
