docadillac
| Posted: Sun May 10, 2009 4:47 pm Post subject: Anamorphic squeeze mod? |
OK, I know this is probably a dumb question but what is this anamorphic squeeze mod. I know 2:35 movies are really wide screen and that there are those annoying bars at the top and bottom. Does this mod eliminate them or what do you need to make them go away?
| Posted: Sun May 10, 2009 4:49 pm Post subject: |
The Anamorphic squeeze mod is to give you enough vertical compression so the stuff on screen isn't tall and thin.
docadillac
| Posted: Sun May 10, 2009 4:52 pm Post subject: |
Thanks for the answer.
...because basically the Marquee projectors were really only designed to project 4:3 images. The "vertical size" adjustment doesn't go small enough to display even an HDTV (16:9) image. The squeeze mod changes the range on the "vertical size" adjustment so you can squeeze the raster into a 16:9 screen, which is what most people do.
I'm not sure if the standard squeeze mod will let you squeeze your raster down to a 2.35:1 aspect ratio. Unless you expect to watch **only** scope movies with your projector, running at 16:9 gives you a lot more flexibility.
docadillac
| Posted: Sun May 10, 2009 7:22 pm Post subject: |
Thanks, I'm not planning to watch only movies there will be a lot of digital tv. I was trying to determine whether or not I could maintain a constant image height with all material. I'm sure that any picture size changes have to be done by an external device. The question then becomes which unit will do the best job for the majority of stuff that I watch. Picture quality in terms of detail and resolution as well as color etc. are all important considerations.
| Posted: Sun May 10, 2009 8:45 pm Post subject: |
CIH requires you to set your raster to the height of the "shortest" aspect ratio, then other ARs use that same height but less of the width. So if you really wanted to do CIH you'd have to set the raster to 2.35:1, then fit all other ARs into that raster. You'd have a better picture (better resolution) for your 2.35:1 material, because all 720 or 1080 lines of the raster would be displaying picture content -- as opposed to the letterbox format which wastes some of the lines for the top/bottom black areas. (That assumes you have a source that displays 2.35:1 material on the full raster, with no letterboxing.) Meanwhile for 16:9 content you'd be using a small piece of the center of the tubes, resulting in less resolution and much less brightness for HDTV. (16:9 is 1.77:1. A 2.35:1 raster with the same width is 1.77/2.35 = 0.75 as high as the 16:9. Now put a 16:9 raster in the center of that 2.35:1 area, and it will be 0.75x as high and 0.75x as wide as if you used the full width of the raster. 0.75*0.75 = 0.57 -- so your HDTV material will use over 40% less tube-face area, and at the same contrast settings will be be over 40% dimmer, than if you used the full 16:9 raster area. You might make up for that with a smaller screen size for HDTV, but there will be 40% fewer photons [assuming equal contrast settings] than if you maximized the 16:9 raster.)
Really the only "right" way to do CIH is with a digital projector and an anamorphic lens. That way 16:9 content can fill the 16:9 image area of the projector chip, and 2.35:1 content can *also* fill the 16:9 image area but it gets stretched in width (with the anamorphic lens) to the proper AR. There's really no way to do that with a CRT unless you have a helluva big budget for the anamorphic lens(es). CIH in CRTs necessarily means you use a subset of your tube faces. A blend can do it pretty darn well, especially for 2.35:1, but you still use only a subset of both tubes when you display 16:9 with a blend.
docadillac
| Posted: Mon May 11, 2009 12:20 am Post subject: |
Thanks. Wow that was quite a lot of info to digest. As a relative newbie to the world of projection it certainly is a lot of info to think about when doing a setup. This is why it takes me a long time to figure what I'm going to do and how I'm going to do it. The challenge is always getting the most bang for the buck. Everything is always a series of trade-offs. I will have to decide what I can live with and what I can't. Poor detail and contrast are always a deal breaker. Some color tweaking I can live with as long as I can perform my own amateur setup with the help of a disk like AVIA 2.
docadillac
| Posted: Mon May 11, 2009 3:42 am Post subject: |
Thanks. Yes 4x3 is getting to be more rare. I know June is the cutoff for the transition to digital in the U.S. but we won't have it here in Canada until 2011 I believe. The constant width makes sense as does showing all material in a 16x9 format. I guess I really don"t like the loss of screen real estate in a 2:35 movie. It seems really small. I'll probably be investing in a box of some type and for movies I think I'll go with a Denon. I'm not really all that interested in Blu-Ray and I'd like to keep the video chain as simple as possible.
| Posted: Mon May 11, 2009 4:15 am Post subject: |
| docadillac wrote: | | The constant width makes sense as does showing all material in a 16x9 format. I guess I really don"t like the loss of screen real estate in a 2:35 movie. It seems really small. |
I'll throw another perspective out... If you get your viewing distance (viewing angle, actually) right, then 2:35 really feels about right, and 16:9 actually seems too big (vertically speaking). That's the situation I have with my 40+ degree viewing angle.
Usually, when people complain about 2:35 bars on a 16:9 display, they're coming from smaller 16:9 displays like LCD/plasmas or even RPTV's, which rarely ever have decent viewing angles. In that case, yes - 2:35 seems small. But, if you get a good viewing angle around 35 or 40 degrees, 2:35 looks awesome - even on a 16:9 screen.
| docadillac wrote: | | I'm not really all that interested in Blu-Ray and I'd like to keep the video chain as simple as possible. |
OK, don't take this the wrong way, but this I have to take serious issue with. To me, this is a little like saying you want to build your own sports car because you're really into autocross, then saying you're just going to put a 1.0L 4-cylinder in the car because "you're not all that interested in horsepower". Presumably, you want your own home theater because you want to recreate the cinema experience as closely as possible. HD (which is Blu-ray now) is the best way to make that happen.
I'm not exaggerating when I saw watching a movie on Blu-ray on a good display has literally redefined home theater as we knew it. The picture and sound quality is incredible. By watching on DVD at home, you can get a comparable (yet, compromised) experience to a commercial theater. With Blu-ray as your source, a good display, and a good sound system, you can have a SUPERIOR experience in your own home theater to that of many commercial cinemas.
I'll just put it this way... If you don't have Blu-ray in your HT, you'll be missing out in a big way. I wouldn't consider putting together even a modest-budget theater for anybody at this point and NOT include a BD player. Once you see BD on a good display, you'll realize just how great it is, and just how crappy SD DVD is by comparison. Don't deprive yourself of the ultimate experience. Otherwise, what's the point of it all?
docadillac
| Posted: Mon May 11, 2009 5:59 pm Post subject: |
| ecrabb wrote: | | docadillac wrote: | | The constant width makes sense as does showing all material in a 16x9 format. I guess I really don"t like the loss of screen real estate in a 2:35 movie. It seems really small. |
SC |
Thanks for your input. The last display I had was a 65" RPTV. It actually had a good picture and a good viewing angle. Perhaps it was too small for 2:35. I certainly think on a large enough screen 2:35 would look awesome. I also expect that if I sit too close to the screen then 16x9 will be too much. I have certain constraints to work with. The room is 15 x20. I plan to use a 100" screen. My optimal viewing distance will be around 10 ft. The placement of the screen height will involve whatever I find most comfortable without having to crane my neck around either to the left or the right or up and down.
On the second part of your answer. I take no offense as everyone is entitled their own opinion. I am glad that you have found your optimal experience in your HT. My remark on keeping it simple was about minimizing the amount of hardware in the video chain. Blu-ray is very nice but I can't really see much difference between 720p and 1080p. I'm not sure that Blu-ray will survive as a medium as it will depend upon sales of that material to keep it alive. There has been some noise about it going away but I'm not sure about that. The other consideration here is that the maximum ability of an HD broadcast is 720p. 1080p is only being used for HD movies. So for the fact that I watch a lot of prime time 1080p for me isn't the best option. Yes there are limitations in this system. For example; I cannot make the room completely dark as the walls and carpets etc. are a light color. I don't own the house so I can't actually build anything. I can black out the windows in the daytime but that's about it. I may well be missing out by not having Blu -ray but I can live with it.
The audio section will be made up of a pair of Carver Amazing speakers, a Sunfire 2 channel amp and a Theater Grand processor. I'll probably still stick with California Audio Labs for playing CD's but the sound is really very good from that player and it is a well built unit with good quality parts. I listen to a lot of music and as someone who has played an instrument in live venues as well as sat in many concerts etc. 2 channel is as good as it gets for me.
What's the point? That's a good question. For me the point is to enjoy an entertaining experience and put together a system that I'm happy with. As you know there are people out there who would say that I'm missing out by not going with a digital setup and that CRT is a waste of time. If they are happy with their systems, then great; shouldn't that be what it's about? I believe it is and that all that matters at least to me. I realize people are trying to be helpful with their input and suggestions and I always listen because you never know when you'll come across a good idea. I'm also amenable to change because life is not static it's always in motion, just like a movie.
| Posted: Mon May 11, 2009 6:17 pm Post subject: |
I understand you point but honestly i do not watch any SD DVD'd anymore. Blu ray will not complicate your hardware it will still play your SD dvd's so you can ditch your dvd player, and it is not dyeing. It will only go away when they come up with something better and for that we need new tv's, new players, new media etc and that is years away. Why miss out on it now?
| Posted: Mon May 11, 2009 7:46 pm Post subject: |
I'll throw my 1.7cents in with these guys.
Bluray is here, it's a viable media, it will scale DVD's to HD for you and the players are fairly well made if you go with a brand name.
Also just to correct what you said there docadillac: | docadillac wrote: | | the maximum ability of an HD broadcast is 720p, |
Over the air will do 1080i, it's still 1920x1080 just 30 fields per second. Also there is satelite that is broadcasting 1080p so it's available. 720p isn't the highest.
docadillac
| Posted: Mon May 11, 2009 11:31 pm Post subject: |
| AnalogRocks wrote: | I'll throw my 1.7cents in with these guys.
Over the air will do 1080i, it's still 1920x1080 just 30 fields per second. Also there is satelite that is broadcasting 1080p so it's available. 720p isn't the highest. |
Thanks AR. Bluray is here for now, but there has been some question over whether it will last. The same thing happened with Beta vs. VHS. Beta was better but VHS won out. I've heard good things about the Denon 5910 and that was the way I was planning to go as far as players are concerned. It does a good job of upscaling and is well built. Parts are still available too.
docadillac
| Posted: Mon May 11, 2009 11:35 pm Post subject: |
| Nashou66 wrote: | I understand you point but honestly i do not watch any SD DVD'd anymore. Blu ray will not complicate your hardware it will still play your SD dvd's so you can ditch your dvd player, and it is not dyeing. It will only go away when they come up with something better and for that we need new tv's, new players, new media etc and that is years away. Why miss out on it now?
Athanasios |
Thanks. I don't have a DVD player yet, so my choices are pretty open. I do like the Denon 5910 though from everything I've seen. You make a very good point when you say I could ditch my DVD player and go Bluray as Bluray will play 'em all.
docadillac
| Posted: Mon May 11, 2009 11:39 pm Post subject: |
Over the air will do 1080i, quite right A/R. It's news to me that there is a satellite that will broadcast at 1080p. I'd like to know which one just to update my info. Quite true about upscaling DVD players too. I wasn't interested in just a standard DVD player.
dturco
| Posted: Mon May 11, 2009 11:42 pm Post subject: |
| docadillac wrote: | | AnalogRocks wrote: | I'll throw my 1.7cents in with these guys.
Thanks AR. Bluray is here for now, but there has been some question over whether it will last. The same thing happened with Beta vs. VHS. Beta was better but VHS won out. I've heard good things about the Denon 5910 and that was the way I was planning to go as far as players are concerned. It does a good job of upscaling and is well built. Parts are still available too. |
Any dvd player upscaling will not look as good as a blu-ray. I have an upscaling dvd player [Integra 10.5] it can not upscale 1080p only 1080i. But my Sony bd550 down rezzing blu- ray to 1080i looks a whole lot better than the upscaled images the integra puts out by a large margin. Also the sony players upscaling of regular DVD's is better too. So unless your inheriting a DVD player I would buy a blu-ray.They are just that damn good.
http://www.hulu.com/firefly
docadillac
| Posted: Mon May 11, 2009 11:45 pm Post subject: |
Thanks for all the input guys. I really appreciate the effort. Its all good info as it helps me to think about what I'm doing. I didn't mean I was going with standard DVD and I realize I must have conveyed that idea. I apologize for that. I'm always open to listen to others and learn or try something new. That's what makes it interesting for me. I engage in discussions because that helps me to think and refine my ideas and knowledge. I don't know if anyone can relate to this but when I was 15 or so I knew everything in the universe. Now that I'm mid 50's I know nothing and question everything.
| Posted: Tue May 12, 2009 12:24 am Post subject: |
Yep, I remember knowing it all at age 19. Now in my mid 30's I know much less. By the time I'm ready to retire I'll have to go back to school to learn it all over again.
dturco
| Posted: Tue May 12, 2009 12:54 am Post subject: |
| AnalogRocks wrote: | | Yep, I remember knowing it all at age 19. Now in my mid 30's I know much less. By the time I'm ready to retire I'll have to go back to school to learn it all over again. |
When I was 20 something I would yell at people, I forgot more than you'll ever know. As I was sure I knew it all. It's simple being me . Or at least I'm simple.
