Decibel
Joined: 31 May 2007 Posts: 904 Location: Roma - Italia
| Posted: Thu Apr 30, 2009 1:02 pm Post subject: Barco Graphics 808 AC ---> LC |
I've purchase a set of P16 LC tubes from Curt and the tubes are here now
A question for scheimpflug system, see this photo.
Green tube have four springs (understand?), two upper and two down.
Blue and red tubes have two down only.
Why?
I want to change glycol for all tubes because into green tube there is a little impurity in suspension.
Suggestions?
I hope that you understood
_________________ Domenico (Barco fan!)
Decibel
| Posted: Tue May 19, 2009 12:12 pm Post subject: |
However the conversion is continuing.
Today I have changed the c-element
The new P16 tubes with new c-element (from G70)
Go out the old incompatible
Install new
Ok!!! color corrected
| Posted: Tue May 19, 2009 1:40 pm Post subject: |
I'm glad you did that.
Now you can use lenses designed for forward projection, as well as filtered for better colours.
Decibel
| Posted: Tue May 19, 2009 1:50 pm Post subject: |
| Mark_A_W wrote: |
Now you can use lenses designed for forward projection |
Yes yes
I' have a set of nice HD18
A my dear friend making the adapters for tubes and lenses
Decibel
| Posted: Tue May 26, 2009 10:16 am Post subject: |
My dear friend "effecci" has prepared for me the tube and chassis adapters
Thank you effecci
Drew Packard
Joined: 12 Mar 2006 Posts: 43 Location: Monroe, Washington
| Posted: Wed May 27, 2009 6:53 am Post subject: |
WOW! What a great friend you have there....
That is gorgeous workmanship!!
Drew
Decibel
| Posted: Fri May 29, 2009 8:31 am Post subject: |
New adapter and lens.
The new adapters are in place!!!
Adapter+tube+lens
Drew Packard
| Posted: Fri May 29, 2009 2:48 pm Post subject: |
That is awesome work!!
Ile
| Posted: Fri May 29, 2009 6:48 pm Post subject: |
Good looking adapters!
Is there going to be enough center focus adjustment range with adapters?
zGman
| Posted: Fri May 29, 2009 6:50 pm Post subject: |
Possibly, if he uses a small screen...
G
Decibel
| Posted: Sat May 30, 2009 12:02 am Post subject: |
| Ile wrote: |
Is there going to be enough center focus adjustment range with adapters? |
I think yes ... unfortunately I haven't plate of the G70
Decibel
| Posted: Sat May 30, 2009 12:11 am Post subject: |
| zGman wrote: | Possibly, if he uses a small screen...
Why?
zGman
| Posted: Sat May 30, 2009 1:45 am Post subject: HD-18 lens conversion |
Good Question!
The base of the HD-18 lens needs to be on the same plane as the recess
in the original lens mounting plate that was on the Barco LC housing.
Looks like you will be about 5mm further out, and since the focus point
moves inward as the screen width increases - you will likely be limited
in screen width.
Your friend did a beautiful job on the machine work, no doubt - I love to see it!
G
Decibel
| Posted: Tue Jun 02, 2009 2:28 pm Post subject: |
Go out old 180dvb22
Replace with P16 LC
coooooooooolllllll
Thank you Curt
Thank you effecci
zGman
| Posted: Tue Jun 02, 2009 3:20 pm Post subject: |
Looks Great!
You are really going to love the new tubes with HD-18 lenses.
G
Decibel
| Posted: Wed Jun 03, 2009 3:22 pm Post subject: |
I have a problem with electric focus
In according with service manual I have set at 57 focus of all tubes.
I do not succeed to having a good focus because I do not have more margin than movement in ahead.
Focus yokes are in contact with deflection yokes, I don't have more margin!
Suggestions?
Ile
| Posted: Wed Jun 03, 2009 5:38 pm Post subject: |
Usually electronic focus is needed to tweak after yokes mechanic adjustment.
Do you get good focus with electronic mid point adjustment?
If no, you might need to cut those deflection yoke plastic clamps off and use rtv to lock yokes to level. Two small blob between yoke and tube bell should be enough.
| Posted: Wed Jun 03, 2009 8:30 pm Post subject: |
or cut the focus coils screw threads on the deflection coil side off, this way you still have one clam on the neck side of the tube to lok focus coil into place.
Also you might get better focus away from tube face so remove the cpc mags and move coll up and down tube face to find best location, if you can do this with no electronic focus connected first , then do it that way. Its how i find best static focus of the coil before any electronic focus is going through it.
zGman
| Posted: Thu Jun 04, 2009 12:03 am Post subject: |
I have done several of these conversions on BG808S - you should be able
to pull in perfect electronic focus. Look in the lens (with reduced contrast &
on an off angle) and have a look at the grid lines while ramping the focus
control. Also bear in mind you can't really make serious progress on focus
until astig (cpc magnets) is dialed in very accurately. Also - it is a lot easier
to work on focus (and astig) with external patterns, IMHO...
G
Decibel
| Posted: Thu Jun 04, 2009 12:17 am Post subject: |
| zGman wrote: | | I have done several of these conversions on BG808S |
The vpr is a BG808 non "s" I'have swapped 180dvb22 AC to P16 LC.
However I must to setup flare and astigmatism .... ok, thank you
