donaldk
| Posted: Fri Apr 24, 2009 3:45 pm Post subject: |
It depends how you are feeding the machines, if via PCs, just have one pc flip the image.
RogueChili
Joined: 31 Mar 2008 Posts: 162 Location: Westfield, MA
| Posted: Fri Apr 24, 2009 8:45 pm Post subject: |
| donaldk wrote: | | It depends how you are feeding the machines, if via PCs, just have one pc flip the image. |
Good suggestion, at some point that may be viable however at this point I can not pipe all the sources through the PC. I built it specifically for driving dual projectors in mind complete with ArcSoft, dual dvi graphics card, blu-ray player and digital tv tuner. One problem to solve, I have no method to input external HD sources. Work in progress..
| Posted: Fri Apr 24, 2009 9:11 pm Post subject: |
| RogueChili wrote: | | Yes! I found it it the sony supplemental manual in the section "Proper Mechanical Setup When Stacking 1292's", however it is recommended to rotate the deflection coils 90 degrees and mount the projectors vertically and juxtaposed?? |
Holy crap, I never thought of running the damn things on their sides. That's crazy. Wouldn't be much good for a ceiling mount setup, but it would certainly require a lot less geometry correction than a side-by-side stack would.
You don't need to do anything funky with a PC. You'd just rotate the magnetics 90-degrees to the right in the right machine, and 90-degrees left in the left machine. Voila!
Interesting. Never though of running the machines standing on edge. I suppose you'd have to weld something up to hold them in that position, and they'd take the best seat in the house... and then some.
