loribates
| Posted: Tue Apr 14, 2009 4:47 am Post subject: |
| AnalogRocks wrote: | | Not sure if it will make a difference but try changing your Bluray players color space settings. There should be options for 4:2:2/RGB 0-255 etc. See if that makes any difference. |
No such options. I've been through every option on the thing. I cannot find specs online or in the manual with regard to the colorspace. It's the Samsung BD-P1600.
_________________ Lori Bates
winduptoy
Joined: 25 Nov 2006 Posts: 187 Location: Lunenburg, Nova Scotia
| Posted: Tue Apr 14, 2009 9:49 am Post subject: |
Just a quick note before I head out; The gamma boost adjustment on these things takes as many as 18 turns to go thru the adj. range. Throughout most of that it looks like nothing is happening. Then for a few turns, it does. First you will see it in the shadows, then the whole image will get brighter. Before you attempt gamma adj., put up the pluge pattern from DVE or the THX logo from a disc that has the optimizer and set your brightness. Then the sweet spot where near blacks are boosted before the big jump in brightness will be easier to spot.
loribates
| Posted: Tue Apr 14, 2009 1:01 pm Post subject: |
I had already tried it on the internal greyscale patteren last night. Believe me when I say I took it from one end to the other and nothing. Yes its a lot of turns to get from one end of the adjustments to the other. I tried several different dvds. I will try a different test pattern tonight that has a greater number of bars than the internal test pattern but unless the range on this is minimal I would have expected to see at least some change on the internal test pattern and for the blackest bar to start to get grey at the top extreme of the adjustment but it just didn't. Thanks for all the replies. I will try a few more things.
loribates
| Posted: Tue Apr 14, 2009 5:45 pm Post subject: |
| Nashou66 wrote: | the internal grey bars wont be affected since they dont go through the moome box. you need to use a test disc.
Athanasios |
Oh DUH. Time to take a step back......
WTS
| Posted: Tue Apr 14, 2009 11:40 pm Post subject: |
don't forget that when you boost the gamma you'll also be increasing the video output level above the .7vpp, so you'll need to adjust the gain back to .7vpp. It's best to cycle back and forth gamma/gain. If your gain is too high it will appear washed out. Actually the best way to set it up is to have a scope. The gamma adjust actually kicks in fairly soon as you start to increase the gamma. Use a scope and a step pattern going from 0 to 100ire.
_________________ Thanks
Walter
drice1234
Joined: 07 Oct 2006 Posts: 1309 Location: Allen, Texas
| Posted: Wed Apr 15, 2009 1:17 am Post subject: |
| Quote: | | Use a scope and a step pattern going from 0 to 100ire |
Yea, everyone has a scope laying around and knows how to use it.
WTS
| Posted: Wed Apr 15, 2009 1:29 am Post subject: |
Ah yes, there is that problem.
Walter
loribates
| Posted: Wed Apr 15, 2009 2:08 am Post subject: |
You guys kill me. As soon as I get everything else under the sun done tonight I'm going down to work on it. I will report back.
Thanks to everyone!
loribates
| Posted: Wed Apr 15, 2009 2:17 am Post subject: |
| WTS wrote: | | , so you'll need to adjust the gain back to .7vpp. It's best to cycle back and forth gamma/gain. If your gain is too high it will appear washed out.. |
Oh hell you are making my brain hurt again. I went through this the last time I calibrated this thing. Its a Marquee. I don't have gain labeled as such. I've got G2 and Drive then brightness and contrast. Now you are going to make me have to remember which equals gain
I was assuming I wouldn't have to do a full color calibration again and not mess with my G2 and Drive. I assumed I'd just have to adjust my brightness and contrast to get the greyscale back in line.
WTS
| Posted: Wed Apr 15, 2009 2:52 am Post subject: |
Lori,
I was referring to the gain on the moome card not on the Marquee. Of course for the overall setup you'll be adjusting the gain/bias on the marquee.
Walter
loribates
| Posted: Wed Apr 15, 2009 3:05 am Post subject: |
At this point I'm afraid I must have one that's bad. I have my test pattern up and brightness down to where the second to last bar is barely distinguishable from the darkest black bar and I've cranked the gamma all they way and no change at all
loribates
| Posted: Wed Apr 15, 2009 3:11 am Post subject: |
And yes its the thx optimizer, not the internal pattern
| Posted: Wed Apr 15, 2009 3:28 am Post subject: |
Wo(w) man this sucks!
In all the theaters in all the world and the bad Moome has to walk into yours.
loribates
| Posted: Wed Apr 15, 2009 3:51 am Post subject: |
This is always my luck. Leave it to me to get stuck with something defective and have to wait for an exchange
I'm beginning to wonder if I should have bought the fury. I'm about ready to peek inside the case to see if something looks out of place.
loribates
| Posted: Wed Apr 15, 2009 5:35 am Post subject: |
I'm done. I'm tired of screwing around with this. I damn near have carpel tunnel from turning that litte pot a zillion turns both ways. Fwiw the contrast doesn't do anything either.
I've also found another glitch. The first time I thought it was a fluke but after the 4th time... It locks up when adjusting the picture position and the screen goes black. The only way to get it working again is to pull the plug.
Unless anyone can tell me if its worth opening up to check on anything in particular I'm going to have to make a decision. To exchange it and take a chance on another one, to live with it as is and spend another 100 and add the gammaX, or return it and go with the fury and gammaX.
I don't seem to be the only one according to all the posts I've read in the moome section of the forums. I'm disappointed because from my studies this was supposed to be superior to the fury and better quality.
Anyway, I thank you all for your patience and assistance in trying to solve this
1031
schmoe
| Posted: Wed Apr 15, 2009 6:56 am Post subject: |
What does that setting do anyway?
