SONY VPH-1292Q STREAKING PROBLEM SOLVED
Goto page Previous  1, 2, 3 ... 6, 7, 8, 9, 10, 11  Next
Interested in purchasing upgrade?
Yes
79%
 79%  [ 39 ]
No
20%
 20%  [ 10 ]
Total Votes : 49
RogueChili
Posted: Mon Oct 12, 2009 1:15 pm    Post subject:
A small price to pay for 10,000 lumen output! Looking back I should have snagged one of those from the R&D department.
VideoGrabber
Posted: Mon Oct 12, 2009 3:43 pm    Post subject:
~6 weeks ago, azzkicker wrote:
> in a few days i have the kit
then i bring the mod on my neckboards, and hope ich dont see the f*cking streaking
Any reports on progress in that area? Or are there problems there as well? Thanks.
- Tim
RogueChili
Posted: Mon Oct 12, 2009 5:49 pm    Post subject:
The second set of boards shipped last week. Because of the reported problem I felt it necessary to burn in the boards for a long period of time in my machine before shipping them. The boards preformed as expected in my machine and no failures after 40 hours of burn in time.
Installation of the second set of boards should start this week. It will take some time being the first field installed kit. The installation instructions have not been verified and are sure to need editing.
speedyandre
Posted: Mon Oct 12, 2009 10:11 pm    Post subject:
I think that I have some troubles with blue here Sad
After swapping the blue neck board and placing the fans blue was gone.
With my own blue neck board blue is very dim, I can't get it as bright as the other colours.
Earlier I had a bad blue tube but I can't imagine that it gets this bad in one day ....
When the ABL jumper is removed green stops working, even when the extra cooling fans are in place.
I hope I can find out why blue fails, I don't have equipment for measuring HV.
André
I'll be broke
Posted: Mon Oct 12, 2009 10:56 pm    Post subject:
If one tube is working, you don't have a HV problem. HV is all or nothing.
RogueChili
Posted: Mon Oct 12, 2009 11:28 pm    Post subject:
I agree with Mark, the HV is not the problem.
During development I noticed a few things that can cause problems.
First, verify the neck board is pushed securely on the tube neck and seated properly.
Second, remove the flat ribbon type cable from the CA board and re-insert it straight and centered into the connector. Compare the position with the other connectors, it should look straight and be seated at a similar depth.
Another point, when you enable or disable the ABL you must reset the bias levels accordingly.
Just to be clear, when you enable the ABL you must put the jumper back to the original location; it must be installed on one of the two boards.
speedyandre wrote:
I think that I have some troubles with blue here :(
André
speedyandre
Posted: Tue Oct 13, 2009 4:38 pm    Post subject:
The HV is not the problem, when I disconnected the blue wire from the neck board I got a lot of light output (I put the 1292 off immediately after that).
Replacing the ribbon cable with a better one didn't help.
The video coax connector doesn't fit very well, it gets loose easily.
With or without ABL, both connected properly makes no difference.
It seems that the video signal is muted or there is almost no gain in it.
When I pump up the blue video signal with my scaler I can see a faint picture with the standard neck board, so at least some thing comes trough.
This can be a cable problem, but wich one is it?
Connecting the green video coax to the blue neck board also gives a faint pictue on blue.
André
I'll be broke
RogueChili
Posted: Tue Oct 13, 2009 4:56 pm    Post subject:
What board is the ABL jumper installed on ?
Enter the service mode; record the values for RGB bias and RGB gain parameters and post the values.
speedyandre
Posted: Tue Oct 13, 2009 5:10 pm    Post subject:
When it worked well with the red and green modded neck boards and having disabled ABL I had these values:
Bias
R 193
G 238
B 219
(my own settings).
Gain
R 100
G 165
B 200
Blue is a bit lower because the tube has been replaced with a 'new' one (800h).
The other tubes have about 3000h.
The problem with blue persists with the jumper on either board.
André
I'll be broke
RogueChili
Posted: Tue Oct 13, 2009 5:41 pm    Post subject:
OK, those values look good.
Sorry to be redundant, I just want to be sure I understand correctly.
What board is the ABL jumper currently on?
Are the Red and Green tubes working properly?
Verify the pins on the crt are not bent or broken.
The CAB and CBB boards are connected electrically via two headers. It is possible the connection was disrupted by the removal of the wire located between the boards during the swap. Verify they are connected properly.
The black wire that connects to the CAB board on the top left, that is the video input signal, make sure it is completely engaged.
Bias
R 193
G 238
B 219
(my own settings).
Gain
R 100
G 165
B 200
André
speedyandre
Posted: Tue Oct 13, 2009 5:56 pm    Post subject:
I think the black cable (video) could be a problem here, it doesn't fit well on both blue neckboards and it gets loose easily.
Maybe the central pin is misaligned or not exactly round anymore ....
That would at least explain the weak video signal.
André
I'll be broke
RogueChili
Posted: Tue Oct 13, 2009 6:35 pm    Post subject:
Send Curt an email and see if you can get a replacement cable.
I will investigate the possibility of repairing it.
André
speedyandre
Posted: Tue Oct 13, 2009 7:23 pm    Post subject:
I got the video cable fit a bit better, it's more like the neck board where the 'loose' grip comes from.
When showing a test pattern blue is visible and steady but faint with contrast and brightness set to maximum.
As before also the green video cable on the blue neck board shows the same faint picture.
The blue cable on the green neckboard shows a normal picture so the video channel and the cable seem ok.
I suppose something is wrong with the blue neckboard, it came after swapping it with the modded one.
Maybe one of the pcb's connected to the neckboard is bad, can I exchange it with green or are they different?
André
[edit] The modded blue neck board now works at least with a video cable that fits better.
Blue is still very dim but comparable with the normal neck board.
I'll let it play for some hours to see if the blue modded neck board doesn't get muted when ABL is switched off Wink
I'll be broke
b52_freakshow
Posted: Tue Oct 13, 2009 9:33 pm    Post subject:
I am certainly in line to buy this mod...the streaking was driving me nuts. On a side note, can you point me to a thread about a jittery picture? My picture bounces like someone is shaking the projector, even though it is mounted rock solid.
speedyandre
Posted: Tue Oct 13, 2009 9:56 pm    Post subject:
I've checked the service manual, the EBB board is connected to the neck board, it has some power lines going to the neck board, maybe one of them failed ....
I can place a spare EBB board if that makes sense ....
André
I'll be broke
RogueChili
Posted: Tue Oct 13, 2009 10:28 pm    Post subject:
Andre, remove the neck board assembly and give all the connections on the CAB and CBB boards a careful methodical inspection. Then carefully inspect all the cables that attach to the neck board assembly- both ends. Look for bad crimp on contacts, damaged or cut wire, bent male contacts or female contacts pulled out from the connector housings. This has to be something simple.
André
azzkicker
Posted: Wed Oct 14, 2009 5:14 pm    Post subject:
hi
well i wait for the parts, then i can you tell more
regards
1292 without streaking
speedyandre
Posted: Wed Oct 14, 2009 7:10 pm    Post subject:
Whoohooo!!!! blue is finally normal here !!! Very Happy Laughing Thumbs Up Mr. Green
It seems that the thin ribbon cable was the problem, when I placed it reversed (neck board side in EBB board) blue had full gain Razz
I hate the yellow and very dim picture I had Evil or Very Mad Mad
The problem with green and blue muting after half an hour when using ABL still exists, even when the corner fans are working.
André
I'll be broke
RogueChili
Posted: Wed Oct 14, 2009 7:41 pm    Post subject:
I'm glad you solved it, good job!
For now, run with ABL disabled. When azzkicker is up and running we can compare results.
FoLLgoTT
Posted: Fri Oct 16, 2009 3:50 pm    Post subject:
RogueChili wrote:
I have the schematics for each of these and neck boards for all but G90.
Here you can download the complete service manual of the G90.
My G90 streaks as well. Not as much as the 1292, but it is still annoying in darker scenes. It would be great if your modification will work on this projector! Smile
Nils
Page 7 of 11
