JorisS
Joined: 18 Jun 2007 Posts: 160 Location: Uppsala, Sweden
| Posted: Sun Mar 08, 2009 1:13 am Post subject: NEC XG110LC - Problem with focus on green tube |
Hi all!
Having owned my XG110LC for about 2 years now, this evening I finally managed to get it to produce an image somewhat approximating it's capacities Reason for this was that I came in touch with a guy living very closeby, who has the same projector and much more experience and knowledge as to its ways. He came over this evening and went through the setup/convergence process with me, in a summarized fashion.
One problem we were left with was the focus on the green tube - a problem I've had from the start but didn't know how to fix or whether it was my own shortcomings, or something amiss.
The problem is that the green tube is blooming, which shows clearly in for example the point pattern. Enclosed two images, one of the green and one of the red pattern:
(click for larger image)
These pictures were taken immediately after eachother, with all settings the same for both. So if it were contrast or brightness, the problem should show for the red tube as well? (Both are at about 60% by the way) In the pictures it clearly shows how the green image blooms, and also the intense spot isn't centered in the blooming area.
The guy helping me out mentioned that he had a similar problem on a PG before, and that was caused by a faulty chip of this type:
We've taken a look inside and there are five of these in the XG, albeit they end with 220 instead of 020. Then there's another one ending in 240 or 420, I don't recall exactly.
Any spontaneous reactions? Are there any settings that may be off, or could this indeed be caused by faulty electronics? We still managed to get a pretty good image overall, but this is definately something I'd like to dig into and hopefully sort out; it's partially what's been keeping me from trying more and harder on my setup previously: I simply had a feeling I couldn't get proper focus on green and couldn't figure out why, had nothing to compare to.
Hoping that somebody can give me some advice here!
Best regards,
Joris
Uppsala, Sweden
| Posted: Sun Mar 08, 2009 4:42 am Post subject: |
I'll assume the lens focus was checked and is not the problem. Then I would ask if the green focus changes with the electronic focus, meaning if you run up and down the scale does the focus on the green get worse and then thats the best you can get it or it doesn't change at all when you run up or down the scale?
JorisS
| Posted: Sun Mar 08, 2009 1:14 pm Post subject: |
| macgyver655 wrote: | | I'll assume the lens focus was checked and is not the problem. Then I would ask if the green focus changes with the electronic focus, meaning if you run up and down the scale does the focus on the green get worse and then thats the best you can get it or it doesn't change at all when you run up or down the scale? |
Lens focus was one of the first things we did and is as good as it gets. I just tested the electronic focus and it does indeed change clearly when sliding the scale - the current focus was the best I could get. There seems to be some kind of problem causing blooming of the green tube/image, and it's there all over the screen.
| Posted: Sun Mar 08, 2009 2:10 pm Post subject: |
Does the focus get better if you turn contrast (or green gain) down?
Do the green dots change shape / move when you ramp the focus?
JorisS
| Posted: Sun Mar 08, 2009 2:17 pm Post subject: |
| perisoft wrote: | | Does the focus get better if you turn contrast (or green gain) down? |
We tested the gain last night, but couldn't really see much difference. Didn't adjust contrast, can give it a shot in a bit - too light still, but will get darker in an hour or 2.
| perisoft wrote: | | Do the green dots change shape / move when you ramp the focus? |
With ramp you mean if I adjust the focus by sliding across the scale? If so then yes they do, although I tested that just a bit earlier prior to my previous reply, and it's not quite dark in the room. Still the dots changed to more blurry larger round dots with focus lowered (to the left on the scale), and they became more oval (with a south-west/north-east orientation, if you know what I mean) with focus adjusted to the right.
| Posted: Sun Mar 08, 2009 2:54 pm Post subject: |
Well I can see from the pictures that the astigmation is off. See how it looks like a comet going to the right. You need a better mechanical set up. Also, even with the stig and flare being off, you should be able to get better electrical focus than that. You have other problems to be sorted out.
_________________ Chip
JorisS
| Posted: Sun Mar 08, 2009 3:21 pm Post subject: |
| stefuel wrote: | | Well I can see from the pictures that the astigmation is off. See how it looks like a comet going to the right. You need a better mechanical set up. |
I won't argue you there, the setup we did last night was after all a 'quick and dirty' one as the projector currently isn't in a permanent placement. However, the problem I'm trying to adress here is the fact that the focus on the green tube seems to be impossible to get sharp, and I don't know why. Surely if I get a pretty-near razorsharp line with the red image and tube, I should be able to get the same or comparable (better?) with green?
Do keep in mind that the images are photographs, and by themselves cause some blur.
| Quote: |
Also, even with the stig and flare being off, you should be able to get better electrical focus than that. You have other problems to be sorted out. |
Are you referring to the green or red, or both? Any specific other problems I should look into? As said, the images are clouded by the fact these are photographs taken at dark - I'm pretty satisfied with the focus on the red tube. But why does the green one bloom, regardless of what I try changing through the menu?
I'll be testing the contrast and green gain some more shortly to see what that does. But please bear with me, I'm relatively new to all this and well aware that my setup and knowledge have major shortcomings. However, after last nights session it seems that my suspicions of something being amiss with the green tube/focus were confirmed by a more experienced NEC XG user.
Please keep in mind that I'm trying to learn how this beauty works, so remarks stating what problems I have are appreciated, but difficult to 'work with' as I in many cases don't know how to adress or try and solve the problems. Please include some hint/description of how to proceed too
| Posted: Sun Mar 08, 2009 3:35 pm Post subject: |
If your focus setting is not at the end of one side to get it to its best then I'm leaning towards a bad tube.
JorisS
| Posted: Sun Mar 08, 2009 3:45 pm Post subject: |
| macgyver655 wrote: | If your focus setting is not at the end of one side to get it to its best then I'm leaning towards a bad tube.  |
You are talking about the FOCUS through the remote right? To be honest I've resetted everything to 'zero' before the guy came to help out, and we haven't touched it during setup (except for me testing it somewhat in response to your previous post) - we adjusted focus on the lenses, didn't look at FOCUS or astig. I've done that myself before though, and didn't get any better results then. But when I tested earlier on, focus only got worse when sliding it far towards the sides in the focus menu.
A bad tube, do you mean wear or some other problem? Here are the tubes, unfortunately taken with flash:
To make things simple, how would you guys recommend me to proceed to get a good picture from the green tube? Step by step, what should I do? I myself have never done anything with any of the trim pots or the magnetic rings around the tube neck, the only thing I recall I did was adjust the yoke for getting the cross hair leveled, if I remember correctly. That said, I'm obviously not the first owner of the pj so I can't really tell what it's history has been.
I'd be grateful if somebody could give me a step-by-step to figure this one out. I can look up and post more settings if that's of any help.
| Posted: Sun Mar 08, 2009 3:51 pm Post subject: |
Take the green lens off or look into the lens with a pair of sunglasses on. Put up a grid pattern and adjust your electronic focus looking mostly at the center, to get it at its best. Is it focused? If not , where on the focus scale are you? Full left, middle, full right or in between?
| Posted: Sun Mar 08, 2009 4:26 pm Post subject: |
Do what MacGuyver said. Look into the lenses at high contrast (90 or so) to adjust the electronic focus and astig. Your astig is off for sure, but it also looks like the dot is defocused. Do you know about the focus trimpots that have a slot cut into the card cage? Those are the coarse focus adjustments.
IN all of the NECs I've had here, I've always been able to focus the middle of the screen, assuming the astig adjustments on the necks of the tubes are done correctly. A bad focus board in an XG almost always (from what I've seen) affects the left and right edges only, not the middle. If the middle is out of focus, I'd put my money on an adjustment, either electronic or mechanical) that is not set right.
JorisS
| Posted: Sun Mar 08, 2009 4:50 pm Post subject: |
Working on it.... here's some pictures, dang hard to get those to be of any use though. Didn't have contrast at 90, guess I'll try again. Sunglasses are necessary though
In words: I definately see a clear difference in focus when sliding from left to right across the bar, with the best focus somewhere between -5 and +20 or so. Further out to either side and it get's worse. I'm having a hard time determining exactly where the best focus is, differences are small in the 0 to +20 range. On the tube I cannot really see the blooming effect, might be due to the small size though?
On the photo's it appears that green is not nearly as sharp as the red, that's an artifact of the photographing (and higher light output of the green tube?) though. In reality both are about equally sharp from what I can judge.
| Posted: Sun Mar 08, 2009 4:55 pm Post subject: |
I would now try those focus trimpots in the card cage like Curt said. The middle one should be for the green.
Here's a pic of them: http://www.curtpalme.com/NECXG_Layout1.shtm
JorisS
| Posted: Sun Mar 08, 2009 5:01 pm Post subject: |
Should I try that on the tube, or with the lens back on? On the tube it's hard to even see any of the blooming effect I was having on the screen
Out of sheer interest: how do those trimpots differ from what I'm doing with the remote? Do they control the range over which I can adjust focus with the remote, or do they actually affect the focus in another manner?
| Posted: Sun Mar 08, 2009 5:04 pm Post subject: |
I put the lens on, as it acts as a magnifying glass so you can see the tube face better.
| Posted: Sun Mar 08, 2009 5:25 pm Post subject: |
Lets try it this way......with the lens on, contrast at 90 like Curt said, looking into the lens with sun glasses on and at the middle of the grid, set electronic focus at mid range......then adjust the green trim pot until you get the best possible focus. Then adjust the electronic focus until you get the best possible focus. Then turn and look at the screen.....and adjust the lens...loosening the wing nut closest to the projector and turning the whole barrel and again looking mostly at the middle of the screen....for the best possible focus. Then snap a pic of the screen with the grid and dot patterns and post it here.
JorisS
| Posted: Sun Mar 08, 2009 5:46 pm Post subject: |
Allright, will give it a go. Had to take a break and get myself showered
JorisS
| Posted: Sun Mar 08, 2009 7:03 pm Post subject: |
Ok here goes...
The trim pot didn't require much adjustment, only a minor couple of degrees twisted. After this I still found that the best focus was obtained with electronic focus around 0. Lens didn't require much adjustment, just a little. The edge focus seems to have gotten well worse though.
Anyway, here another bunch of images - taken from different distances, but always red and green with exact same focus on the camera, timer and at the same stationary spot:
The green is still not nearly as good in focus as the red, particularly visible with the dot pattern. The last image was an attempt with both R and G on, but didn't really work out well. In reality they are more distinguishable. That said I do think it's improved over the pictures from last night though.
On a sidenote, lowering contrast makes the blooming less visible, but it's still there nonetheless. Meaning it's probably not blooming really, but indeed a focus problem? Sliding the green gain across the entire scale hardly gives a noticeable effect - should it? I think when it's on the lowest setting the green loses in intensity vs the red and blue, judging by the dots - when sliding it up to max the dots seem to be somewhat more green dominated. But it's not a very obvious effect.
| Posted: Sun Mar 08, 2009 7:43 pm Post subject: |
I dont know. I'm having a tough time looking at those pics. The green still looks defocused but to me the red looks defocused too. We are only concerned with the center area for now. The outer area is done later with different adjustments. The CPC is definitely off but it should still focus fairly well. I'm sure it wont hurt to go through the CPC and astig setup and see how it ends up. The focus magnet should be checked as well. I just hate looking at pics. I cant really see whats going on. Maybe its my eyes.......
| Posted: Sun Mar 08, 2009 7:55 pm Post subject: |
Here is the adjustment procedure. Section 12-3, pages 10-15 thru 18. Maybe you and your buddy can work through this. Read it about 10 times....then read it again about 10 times. Its difficult for 1st timers but easy once you know how.....but i guess thats like anything else..
| Description: |
 Download |
| Filename: |
10 Adjustment Method(2).pdf |
| Filesize: |
1.47 MB |
| Downloaded: |
725 Time(s) |
