dturco
| Posted: Mon Feb 23, 2009 10:01 pm Post subject: |
HI,how do you get the hour menu to display? I am trying to tell someone else how to do this so is their a different menu for machine hours>standby >and tubes on? Marqueee 9500lc and 8500.Yes 2 different ones.
http://www.hulu.com/firefly
| Posted: Tue Feb 24, 2009 1:43 am Post subject: |
Hello
Same access for any Marquee, UTIL, 9, 0901, 6, 3
dturco
| Posted: Tue Feb 24, 2009 2:13 am Post subject: |
Tim, thank you very much.
| Posted: Tue Feb 24, 2009 5:42 am Post subject: |
Crt PJ are great. Expect to do all thats been suggested above and other maintenance along the way though. CRTs do require attention so perhaps you should decide if you are willing to put the time and effort in before buying one.
dturco
| Posted: Thu Feb 26, 2009 7:09 pm Post subject: |
Hi again, If you can see the wear through a L/C lense in a picture is this bad? Only slight wear as per tube rating on this site. Only pictures not viewed in person and I cannot post them it came in a 15MB file. 6900 hours ontubes and 7015 on machine.
secstate
| Posted: Thu Feb 26, 2009 9:05 pm Post subject: |
| dturco wrote: | | Hi again, If you can see the wear through a L/C lense in a picture is this bad? Only slight wear as per tube rating on this site. Only pictures not viewed in person and I cannot post them it came in a 15MB file. 6900 hours ontubes and 7015 on machine. |
If the wear is broad and even it is probably ok as you can stay in the wear area but that will be hard to tell from a photo with the c element on. Also, assuming this is a marquee the green c element will hide wear and make it look less and green is likely to show the most wear. Flash and lighting can also impact perception of wear. At the end of the day it can be hard to tell from a photo and more so with LC tubes.
dturco
| Posted: Thu Feb 26, 2009 9:16 pm Post subject: |
Well it's a gamble then , but only $1000.So if it works on arrival theres room for tube [hopefully only one] replacement.
Bruce 09
Joined: 08 Mar 2006 Posts: 747 Location: Kamloops BC, Canada
| Posted: Thu Feb 26, 2009 9:30 pm Post subject: |
| dturco wrote: | | Well it's a gamble then , but only $1000.So if it works on arrival theres room for tube [hopefully only one] replacement. |
Text wear will be your main concern, it will be on all tubes and virtually impossible to see with the lenses on. Is there anyway to get him to take one of the lenses off ?
Can you get him to turn it on and put up a full 100ire image on a white wall even ?
Bruce
dturco
| Posted: Thu Feb 26, 2009 9:35 pm Post subject: |
Theres the rub I the noob am trying to explain how to do something I've never done to a projectorI've never seen in person I just figured out how to seperate the photos.
dturco
| Posted: Thu Feb 26, 2009 10:14 pm Post subject: |
Yeah, the seller said "I think your just being picky I didn't even see it until you pointed it out".So 16x9 screen 106" moome card and good to go?Of course assuming it works once shipped.After all the shipper could drop it 3 feet.
secstate
| Posted: Fri Feb 27, 2009 1:22 am Post subject: |
| dturco wrote: | Yeah, the seller said "I think your just being picky I didn't even see it until you pointed it out".So 16x9 screen 106" moome card and good to go?Of course assuming it works once shipped.After all the shipper could drop it 3 feet.  |
Or you might get the projector with a couple of quarts of oil in/on it (happened to a friend of mine). The tube looks good if the pictures are an accurate depiction of the phosphor, it is broad and light wear. You should be able to stay with the wear area easily. That of course assumes no text or sport burn issues.
secstate
| Posted: Fri Feb 27, 2009 1:24 am Post subject: |
| Nashou66 wrote: | | dturco wrote: | | Well it's a gamble then , but only $1000.So if it works on arrival theres room for tube [hopefully only one] replacement. |
This Guy is selling his pimped out PJ.
http://www.avsforum.com/avs-vb/showthread.php?t=1124562
Give him a PM and make an offer.
Athanasios |
I am guessing he wants more that dturco is willing to pay still it never hurts to offer. On the other hand that seller is located in Virginia Beach which is close enough to the dturco's location to avoid shipping.
dturco
| Posted: Fri Feb 27, 2009 1:50 am Post subject: |
Good point, I like to try to keep my word on offers I've made until the deal closes or falls apart. I thank you for pointing this out to me and I did look at the link but could not find a way to contact. It is still an option though. Thanks again. Or Curt might PM me with a deal I cant refuse?
secstate
| Posted: Fri Feb 27, 2009 1:59 am Post subject: |
If you are a member of AVS you can login and PM other members through the site (same as on Curt's). I clicked on his name and it took me to his profile and there was an option to send him a PM.
dturco
| Posted: Fri Feb 27, 2009 2:09 am Post subject: |
Yeah I just signed up. Good thing I have freetime to keep looking.
Thanks again you guys are great
donaldk
| Posted: Fri Feb 27, 2009 3:04 am Post subject: |
Dturco you posted a public message on the forum, not sure if you also sent him a private message. In case you haven't it's simple, click on his name, and click on the second item in the pop-up menu. Many posters (not me) have enabled notification emails for private messages, so he will see it before visiting the forum. Always ask about condition and features first before talking price.
dturco
| Posted: Fri Feb 27, 2009 3:18 am Post subject: |
Thank you donaldk. I did indeed send a PM after I realized my mistake. Advice will be heeded as well.
