The BIG 9 Inch CRT's
Mr. Green
Posted: Tue Feb 10, 2009 1:25 am    Post subject: The BIG 9 Inch CRT's
Hello,
As opposed to hijacking another thread, I'll start a new one. Wink
I have my 9PG+ and have been very happy with it, but like most people in this hobby there's the upgrade bug and I'm always thinking about eventually getting into one of the top 9 inch sets.
I happened across the thread about a discontinued chip for G90's that is really important and would like to know more. Is this something that could easily happen to the other 9" sets or were there that many more 9" sets made of other brands that parts aren't an issue, or unlike the G90, do other machines not have a "one-off" chip (or other part) that isn't used in another machine making parts scarce?
A large portion of people call the G90 the pinnacle of CRT, but I would like to know if it's true or just really proud owners (as they should be). Everyone bashes Marquees because the are "ugly" to look at and bash AmPro's for fun, even though a 4600 should be able to hold its own against a G90. It's very confusing.
Having gone through all that... Just how much better is the G90 compared to a 9500 Ultra or a 1209/ Cine9, or even an AmPro 4600? Is it really that much better?
Is it simply because they are hard to find, making it a coveted machine? Is it mostly bragging rights having the rare big daddy machine?
If you set up a G90, Marquee 9500LC ultra, Barco 1209s, Cine9, Ampro 4600 (assuming all were in mint condition and set up by a pro and calibrated) would you really see a difference? Has anybody ever used more than one of these sets in the same place?
If it's the lenses that make the difference, could a mod be made so you could hook them up to a Marquee like the NEC lenses?
If my budget would allow it, I'd personally like to get a 9" LC machine (probably a 9500 ultra), but I've never been able to tell by reading all the documentation and posts just how close the best 9" machines are. On paper they all look very similar. One would also assume since Marquee 9500's and Barco 909's are/ were in production more recently that the G90, they would have made some technological steps up over the last 4 years, leaving the G90 with 2004 tech, yes/no?
I love reading about Cliff's G90 stack and seeing the pictures, but I wonder, if you swapped the G90's out with a stack of any of the other top 9" CRT's, would his setup be any less impressive?
I'd really appreciate anybody's input. Thumbs Up
Cheers,
Chris
Posted: Tue Feb 10, 2009 1:38 am    Post subject:
I think most of the newer 9" machines will all be close in preformance. The 4600 may have a disadvantage in corner focus due to the lens mounting but other than that they should all be close with the same C-elements and lenses. I am no expert on this having never used a 9" machine but I can't imagine that there would be a real visible difference when they are all using about equivilant lenses and tubes.
As an aside if i ever upgrade I'd look at two MP modded 8500LC Ultra's in a blend.
Mr. Green
Posted: Tue Feb 10, 2009 1:46 am    Post subject:
I'm hoping to do a single 9" unit versus, stacking 1080p capable 8"s, but it crossed my mind.
Posted: Tue Feb 10, 2009 1:51 am    Post subject: Re: The BIG 9 Inch CRT's
Mr. Green wrote:
Hello,
Cheers,
Chris
Hello
A stock G90 is hardly perfect. Sony traded color accuracy for lumens; green is only mildly color filtered and the result is that what should be deep green is more like pastel green. Tune in a golf tournament and the grass looks yellowish. A few G90 owners have swapped in Marquee tinted C elements to get green right. The G90 is several years out of production, Sony has no concern for support, and at least one failure-prone IC is proprietary and constructed of Unobtainium. VDC builds the Marquee today in Florida, so parts and support should be available for years. Those who consider the Marquee "ugly" are just whiners. The Marquee has been rebadged as the Vidikron Vision, Madrigal MP, Reference 8 and 9, Taw 800, Accurate 8 and 9, and one or two others, some with rather sleek fiberglass lids. Those not agreeing can buy something else, but any Marquee throws a nice image, is easily set up, easily supported, and lends itself to performance mods at reasonable prices.
Gary M.
Posted: Tue Feb 10, 2009 2:43 am    Post subject:
if they all had the relevant correct filtered c-elements and LUGs with at minimum GT17 lenses then things should be pretty close, but don't throw the 909/Cine 9 in there, that beast is at another level over any other 9", super bandwidth and ultimate tube focusing control
also consider that 2 makes, the Barco and Marquee, can be heavily modified by various folks like Greg, Mike and Tim
if you want really close to 9" performance as Cliff has said, but don't want to spring for the whole deal, get a NEC 1352LC Wink
-Gary
Posted: Tue Feb 10, 2009 2:45 am    Post subject:
Yepp What Tim said ! Thumbs Up Thumbs Up Thumbs Up Very Happy
Posted: Tue Feb 10, 2009 3:32 am    Post subject:
I've never seen the marquee or the ampro.
The sony is remarkable. I dont wanna dispute with Tim but i dont recall the color issue w/ the 90 stack we used to run @ the shop. One of my first jaw drop moments with a big screen was watching "the Masters" in hd w/ a 90 stack. It was so good you could smell the grass....almost.
The barco (runco dtv1200) was almost as good. Its really close.
just an opinion.
jkruger
Posted: Tue Feb 10, 2009 3:37 am    Post subject:
I have seen a very nice G90 setup and I think the Runcos look just as good as the G90 because they have colored c-elements. The Barco 1209s does not come stock with them and does not have colors that look as good.
zGman
Posted: Tue Feb 10, 2009 6:20 am    Post subject:
Well, I have seen all but the ampro, and worked quite a bit with (and owned) Barco/Runco 1101 (1209)
and 1200 (909) and 2002/3 Marquee Ultra...They all have some issues stock - and specs do not not tell
the whole story. But, to answer your question - the only way you could tell them apart if setup professionally
would be to run a few test patterns such as vertical line and streaking and know what to look for. On normal
material I think it would be difficult to just walk in and say 'Oh, that's a ........' , without a lot of experience.
The much vaunted bandwidth figures for the 909 are not realized in real life testing, although it is
better than the 1209S series (which had the same video chain as a BG808S) - That being said,
the picture quality is great. All the extra focus and astig and conv. zones do not add a lot or get
around the need for perfect mechanical set-up including cpc magnetics. Parts and support will
be interesting in the next few years, as the all digital chassis has a high level of complexity.
Later model Barco 1209S series have a nice picture and are easy to set-up, but have some limitations
in bandwidth and as mentioned earller, don't come stock with color filtered c-elements. Parts and
servce availability are very good though, and prices are reasonable - certainly worth considering.
G90 is definitely the best looking chassis, but also big, heavy & noisy, with issues of its own, including
a tendency to streak. But a great picture with lots of "pop", nice set-up features, and great lenses.
Lack of support is the worst issue here. I don't know if anyone has correlated the failures to any
particular issue, but using a very good UPS and providing very good cooling would be great ideas
to implement for current G90 owners/operators.
The late model Marquee Ultra with no mods except for high res LUG tubes and 1292 focus coils is
certainly a match with the G90 or 909, given that equivilent lenses are used. Tim's point about service
and parts availability is very true and certainly was a factor in deciding to stay with the Marquee.
But that's just me - it is a hotly contested point I am sure, just like Porsche vs Ferrari.....
At this point, anyone who is sticking with CRT is OK by me, take your pick and light up
those tubes, and enjoy the wonderful lack of motion artifacts and the film-like image....
G
Posted: Wed Feb 11, 2009 4:40 am    Post subject:
I remember asking Scott about this once and his reply was that there would be only minor differences between pjs that have the same tube/lens combo. This is probably more like Indycar racing than F1. In Indy, everyone is using the same engine and chassis(at least the winners:)). Lap times are close because of this. If it was like F1, then the each pj would have their own special tube. Each F1 team using their own chassis and for the most part engine gives a big discrepency in lap times.
Honestly, the part situation makes the Marquee the only safe choice. With the G90 chip problem, I think someone would have to be adventurous to say the least to buy a G90. If I was a G90 owner with good tubes and wanted to stick with CRT, then I might get a trashed tube Marquee for back up. The Ampros and Barcos probably aren't to bad. Scott could answer the question of if there are any unavailable parts for the Ampro. There should be enough used parts floating around for the next couple of years to take care of the Barcos. For Marquees, Scott has mentioned that VDC will be supplying parts into the middle of the next decade. That should be sufficient for the last five CRT users still around.Smile
Mr. Green
Posted: Wed Feb 11, 2009 4:53 am    Post subject:
What are these parts? 1292 focus coil... as in a Sony 1292? What is a LUG tube? Is that the GT17's Gary mentioned?
Thanks ZGMan, that's the kind of reply I was looking for. It seems a lot of people see one or two of the big machines, but often not at the same location. A rare few have owned a couple brands of them.
I personlly was never particularly interested in a G90, but I really waned to know why it is more coveted than the others. I'd guess that it is really great, but quite rare. I watch Curt's for sale list quite often. I think he's had more 909's in even compared to the few G90's he's listed in the last year or so. I guess since a Marquee isn't as hard to get so it's like "oh that's a nice unit...", not "wow, you got a G90? Score!" No offence to the G90 owners. I REALLY hope your chip problem gets solved. Thumbs Up
Now I'm 99% sure I'd go with a late model Marquee 9500LC Ultra. Now, I need some $$$$ <sigh>
CURSE YOU UPGRADE BUG!!! Wink
Posted: Wed Feb 11, 2009 4:56 am    Post subject:
If you really want the best image and only watch movies, then a blend is the best. An 8" blend for 2.35 will beat a 9" single every time.Smile
Clarence
Posted: Wed Feb 11, 2009 5:03 am    Post subject:
every single time?! Shocked Confused
Which blend processor was used in the 8" setup that you preferred?
I haven't seen a blend yet that I prefer over a single G90. Or more literally, since I did see the blend(s), I prefer my single G90.
Mr. Green
Posted: Wed Feb 11, 2009 5:10 am    Post subject:
Uh, a Blend is where half of the image (left side) is done by one projector, magically merged in the middle and the 2nd half of the image is done by projector #2? Yes?
I take it you can really maximize the raster that way? Probably almost do a 4:3 raster on each projector. Wow that could be a big bright image... I love my Blu-Ray... Maybe an 8" blend is worthwhile.
How hard is it to blend the 2 units? I'm just looking for the short answer, I know there are threads that cover it in detail.
HA! I knew we'd finally get a G90 guy in here eventually.
I guess the big benefit of using 2 x 8" units is they wouldn't have to be as far back to make a decent sized 2.35:1 image.
Posted: Wed Feb 11, 2009 5:42 am    Post subject:
Well, you got me Clarence. I haven't seen an 8" blend yet. Just going on specs and what it should do, an 8" blend should be better than a 9". It has been a while since I have seen a blend anyway. I was assuming that the TVone and Blendzilla were much better than what I have seen in the past. Of course, you have seen the Blendzilla up close, so maybe it isn't all that.
Mr. Green
Posted: Wed Feb 11, 2009 6:16 am    Post subject:
Ok,
So, what is better? A single 9" lc unit or 2 x 8" lc units. In a 2.35:1 aspect ratio, you really aren't using a lot of tube face, which seems like a bit of a waste on a 9" tube. You also could have the projector a lot closer with a blend... what didn't you like about a blend Clarence?
I'm sure a 9" blend would be unreal though.
Posted: Wed Feb 11, 2009 6:45 am    Post subject:
IMHO Its unlikely that you will get an consensus here because these machines are all top of their game so what your seeing are personal preferences surfacing.
Mr. Green
Posted: Wed Feb 11, 2009 6:51 am    Post subject:
I know, it's always hard to get a unbiased opinion here. Razz
I'm trying to get people to put ego's aside and just say, "you know I love my G90, but I've seen a 9500lc and it looks just as good" or something to that effect. I'm pretty satisfied with the replies I've received. it sounds like a very small difference in performance, especially if you get any projector that has already got a few upgrades on it.
Now I'm toying with this 2 x 8" sets in a blend or a single 9" lc unit. I want to know what the downside to a blend would be. I can already imagine the pro's, just waiting for the cons...
rabies_70
TV/Projector: Sony G70Q
Posted: Wed Feb 11, 2009 8:01 am    Post subject: Re: The BIG 9 Inch CRT's
[quote="Tim in Phoenix"]
That made me giggle out loud dude, Thanks...it's been one of those days.
I've only seen one 9" unit and it was jkrugers. Twisted Evil He took me up to his bedroom and showed me his 1209s.
Yep, it pretty much kicked some serious ass. And you can't beat the price he got it for. Like 400.00 delivered
Ray
I am an iconoclast
Clarence
Posted: Wed Feb 11, 2009 1:14 pm    Post subject:
You're taking the worst part of 2 different projectors... the outside edges... where focus drops off and uniformity decreases 15%. Then you're taking these worst case edges and making them the dead center of a huge image.
Then you're fighting against color shift if you have any gain at all on your screen material... the left projector is shifting in one direction, the right projector is shifting in the opposite direction.
It's not a question of IF you'll see the blend, it's a question of WHEN you'll see the blend. And it's usually during large solid fields (sky, fields, snow, etc) and when something pans throught the blend zone and during fades to black.
And yes, the split throw distance means your projectors are closer to the screen. So instead of having one projector slightly behind your seat, you're now staring at the ass end of 2 projectors between you and the screen with 10 RGBHV wires running everywhere. Plus, since the throw distance is effectively reduced, your keystone geometry is more extreme, so you also have to take that into effect (and double it)when you're trying to align the blendzone.
Oh, yeah. You also have to throw a blending proce$$or into the middle of all of this. As if HDMI/HDCP wasn't enough of a PITA with a straight shot between the source and the projector.
It's just a personal preference and one man's opinion, but I like stacks 10x more than blends.
