Nec XG Retro
odskaggs2
Posted: Mon Feb 09, 2009 6:32 pm    Post subject:
Is it pics of of the tube faces you want? Or just general pic to see the style of tube? I only ask because trying to get detailed pics like reading the labels on the tubes didn't work so well. Without flash I got a dark pic and with flash it washed out all the writing. But I'll try some different settings and a few more pics tonight after work
Posted: Mon Feb 09, 2009 6:58 pm    Post subject:
Put your finger over the flash to limit how much comes out. That may give you an OK picture of the tube numbers.
Tube faces, with no flash.
Posted: Mon Feb 09, 2009 7:43 pm    Post subject:
Tube faces are the more important pictures. If you can't get a good picture of the label don't worry, just post the tube type off the label, it should be a P16 type tube.
Erik
odskaggs2
Posted: Tue Feb 10, 2009 1:34 am    Post subject:
Okay got some pics. Yes the tubes are P16 tubes by the way. The green has some wear. I couldn't see it in the lens but it does have some. Ihad to shine a light bulb on it to see it but I saw a little.
 Filesize:  13.69 KB
 Viewed:  2227 Time(s)
 Filesize:  22.15 KB
 Filesize:  21.8 KB
 Filesize:  20.81 KB
Posted: Wed Feb 11, 2009 4:19 am    Post subject:
odds,
I think your best bet is to part it out and discard the box. The lenses aren't going to be worth much unfortunately. If Zeb is willing to drive down and pick up the tubes, then I would go that route even for less money. Shipping tubes can be a pain. I am guessing that the boards are all the same as in a standard 135. You could take them all out and box them up for anyone looking for working back ups. I did that once and it seems like I was able to pack everything into a two foot square box. Zeb could probably help you with it.
