BG808: changing caps for better video signal ?
Corleone88
Posted: Mon Feb 02, 2009 3:34 pm    Post subject: BG808: changing caps for better video signal ?
I know that there are different topics talking about it, but I didn't read any definitive answer.
So I am looking to improve the PQ of my BG808 (especially sharpness) and I was wondering if changing caps (by Panasonic FC for example) on the following boards, can make a difference : R7621055 and R7617481 (used for port 3).
Has anybody done that?
Cheers
Posted: Mon Feb 02, 2009 4:06 pm    Post subject:
I haven't, but my understanding of the 808 (particularly the non-s) is that the tubes are more of a limiting factor for sharpness than the electronics - ie, the electronics can paint a sharper picture on the phosphor than the phosphor can resolve.
If the caps have deteriorated, I guess it could make a difference, but as far as I know with an 808s (with sony tubes) you're maxing out the tubes' resolving power by the time you get to the point where the electronics are an issue.
Corleone88
Posted: Mon Feb 02, 2009 4:20 pm    Post subject:
I am sure there is a possibility of improvement when you see all the mods available (Mike Parker, Greg Eisemann,...)
Posted: Mon Feb 02, 2009 4:49 pm    Post subject:
Yes, but Eisemann sells high-res tubes so you can see the difference the other mods provide. Smile
Corleone88
Posted: Wed Feb 04, 2009 8:41 am    Post subject:
Nobody tried changing caps on these boards Sad ?
Ile
Posted: Wed Feb 04, 2009 9:25 am    Post subject:
If input boards are high hour you might see some difference by chancing bipolar elcaps from input boards.
http://gallery.avsforum.com/showgallery.php/cat/500/ppuser/7428372
Chancing caps won't make picture sharper, there is needed to chance also transistors and modify peaking circuits etc. That is very time consuming and good test equipments is needed.
Modifying boards power lines filtering using bigger caps and inductors can make noise level lower. This is already done to 808s input board in factory.
Z-Photo
Posted: Fri Feb 06, 2009 11:04 am    Post subject:
I focused on the video amp boards and the SMPS.
Engineer by Day
Photographer by Night
My Portfolio
Corleone88
Posted: Fri Feb 06, 2009 7:45 pm    Post subject:
What did you change exactly in the video amp boards ? What were the results on the picture ?
Posted: Mon Feb 09, 2009 1:14 am    Post subject:
I changed a few hundred caps in my old BG800 that had about 24,000 hours on it at the time. Changing the bipolar's in the video input card did wonders for the colours. It was like a grey veil was lifted. The colours were considerably better. Didn't have a colorimeter at the time but it would have been interesting to measure the before & after primaries.
Changing the other caps (mostly the big SMPS ones) greatly improved convergence stability but it did nothing for the image quality/sharpness. In fact, caps won't help your sharpness.
Corleone88
Posted: Tue Jun 30, 2009 8:16 am    Post subject:
I update this topics because I recently calibrated my BG808. Colors are nice, sharpness is OK, but I see some noise in the picture (1080i/24 with Lumagen HDQ + BD35 + BJC + HDFury1). So I am planning to buy used R7621055 and R7617481 boards and change the caps (with Panasonic FC) in order to reduce the noise. Is this worth it Wink?
akajester
Posted: Tue Jun 30, 2009 12:25 pm    Post subject:
I screwed up one of my input boards doing that. I guess I'm just not good enough at changing caps. Only do a few at a time, and test test test!
I guess the results will depend on how bad your previous caps were. My unit has 5000+ hours on it, so not too bad. Kal had like 20k+ so it made a big difference for him.
WTS
Posted: Tue Jun 30, 2009 12:56 pm    Post subject:
Changing the input caps won't help the noise problem but changing the PS caps on the 2 boards might. DOn't worry about screwing up the caps, just remember to get them in polarity correct. You can go a little larger in value but try to stay close to the same voltage ratings.
Walter
Corleone88
Posted: Tue Jun 30, 2009 1:14 pm    Post subject:
What are the PS caps?
What is the use of the caps on the video input boards?
akajester
Posted: Tue Jun 30, 2009 1:32 pm    Post subject:
I had heard that when the caps get old on the video input board it can dull your colors. Not sure if it's true and never went back to try and repair the board to find out. Smile
Are the PS caps the power supply caps? You can find a service bulletin about that on Curts site.
Posted: Tue Jun 30, 2009 1:38 pm    Post subject:
PS = Power supply capacitors.
The FC caps are nice(i use those) but so are the Nichicon caps that Draganm uses on the marquee boards. He has info on them in the sale area for his Marquee mods.
Corleone88
Posted: Tue Jun 30, 2009 2:04 pm    Post subject:
Athanasios,
After changing the PS caps, have you seen less noise in the picture?
Posted: Tue Jun 30, 2009 2:08 pm    Post subject:
Yepp in my marquee i did.
Corleone88
Posted: Tue Jun 30, 2009 2:26 pm    Post subject:
How many hours on your Marquee?
My BG808 has around 12000 hours.
Posted: Tue Jun 30, 2009 2:36 pm    Post subject:
way way less, you should definitly change the PS caps. I personally think any PJ older than 10 years should have all the caps replaced, but thats just me Very Happy
1031
Posted: Wed Jul 01, 2009 8:35 am    Post subject:
Those bipolar caps that are series on rgb-lines usually are for blocking dc voltages between video stages. Ok, they work pretty good in theory. There are lines that are terminated to 75 ohm (or something else) and usually there is series resistor ( ie. 75 ohm ) and before/after there is cap (bipolar or normal ) Now caps impedance comes to play. Good cap has low impedance and that doesn't change much lines total impedance (75+ caps internal impedance) Old bipolar can have impedance near 10 Ohm at certain freq. And that cause poor impedance match between video stage´s. Good cap should have small impedance at wide freq.range, then it is good for circuits like that are used in barcos/sonys.
DVDO VP-50
New hobby, Rally
