| Posted: Sun Feb 01, 2009 3:54 pm Post subject: Software bluray decoding - what can do it? |
I'm on the verge of doing some computer swappery to upgrade my HTPC to a Core2Quad @ 2.6. Is there a way I can do straight-up software-rendered bluray playback on a system with those chops, so I can do post-processing? (mainly gamma, though if you know me from the forum, you know I'll try to do something else to it for fun)
The thing will probably be about 20x as fast as the Athlon X2 '5400' I've got now, but I'm still not sure that's enough!
My dream setup would be to basically do the equivalent of what I do with DVDs - rip straight to the HD (if I want to timeshift; if not, play straight off the drive), pick the folder/drive with Zoom Player (or whatever), off to the races. Realistic, or pipe dream?
greg_mitch
| Posted: Sun Feb 01, 2009 3:59 pm Post subject: |
Supposedly media player classic can do this. I have had limited success in reality.
You can also supposedly rip to ISO and mount it to play in PowerDVD. I don't have the new powerdvd so I haven't tried this yet either.
My laptop only has a Core2Duo 7350 so maybe I am limited by that.
| Posted: Sun Feb 01, 2009 4:24 pm Post subject: |
PowerDVD won't have ffdshow as an option, though, if I understand correctly. I'd also very much like to use AC3Filter for audio decode, since I like to send the LFE output to my two front speakers (Vegas that go down to 17hz or something idiotic, and are basically subwoofers that also do midrange and highs ).
| Posted: Sun Feb 01, 2009 5:24 pm Post subject: |
I do not know about Blu-ray, but I can say I have played back 720P p0rn using MPC with really good results. This is on a machine with modest components (2-core middle of the road).
| Posted: Sun Feb 01, 2009 5:33 pm Post subject: |
I played back 1080p HD WMV on a Pentium D at 2ghz, and even on a Pentium M at 2.0, but that's a different animal than bluray. Bandwidth is far different and the decoding is more difficult, I believe (?). My office machine is fairly similar, maybe I'll have to rip-n-transfer something to it and try. Or just wait until I get the HTPC going again.
jask
nuttall_chris
Joined: 08 Mar 2006 Posts: 832 Location: Ottawa, Ontario, Canada
| Posted: Sun Feb 01, 2009 6:05 pm Post subject: |
I have a Core2Quad at 2.4G and it has no problem software decoding Bluray in either Powerdvd or MPC or Zoomplayer. THis is only for playback, if you will be trying to manipulate the video in any way that requires re-encoding you basically need a supercomputer to do this in real time. I don't think there are any computers on the market right now that will do this in real time, even if you overclock it like crazy.
Chris.
| Posted: Sun Feb 01, 2009 6:06 pm Post subject: |
| jask wrote: | http://www.9down.com/KMPlayer-2-9-3-1284-Beta-10543/
FFDshow codecs,AC3,MKV files, and a whole lot more. |
Will it play bluray discs/images outright, or will I need to rip to mkv? I don't really fancy going through command line crap to rip and merge files, choose which things to rip, etc... Or has someone made a nice automagic mkv ripper?
nuttall_chris
| Posted: Sun Feb 01, 2009 6:31 pm Post subject: |
I play ISO images mounted with Slysoft Virtual CloneDrive. I use PowerDVD for playback. Playback can also be directly off disk.
Chris.
| Posted: Sun Feb 01, 2009 6:34 pm Post subject: |
| nuttall_chris wrote: | I play ISO images mounted with Slysoft Virtual CloneDrive. I use PowerDVD for playback. Playback can also be directly off disk.
Chris. |
That'd be perfect. All I'd need from there is a way to link double-clicking the ISO to an app which mounts it and fires up the player, and I'm golden!
| Posted: Mon Feb 02, 2009 1:47 am Post subject: |
| perisoft wrote: | | nuttall_chris wrote: | I play ISO images mounted with Slysoft Virtual CloneDrive. I use PowerDVD for playback. Playback can also be directly off disk.
Chris. |
That'd be perfect. All I'd need from there is a way to link double-clicking the ISO to an app which mounts it and fires up the player, and I'm golden! |
You may not get Gamma that way - it depends on video card and OS.
But your PC is EASILY fast enough to play BD.
My Q6600 at 3.0ghz can do ffdshow sharpening or denoise on BD....in fact if it could balance the cores better I could do HEAPS of ffdshow tweaking. Whether it's worth it is another matter...
| Posted: Mon Feb 02, 2009 3:38 am Post subject: |
Gotcha, Mark. Yeah, I should have said, "minus the powerDVD part" or some such - that was part of the question; whether I could, and how to, do software rendering of bd to give me good gamma control.
| Posted: Wed Feb 04, 2009 3:15 pm Post subject: |
Well, I've got the box back together again. Naturally, XP is complaining that I need to reactivate it, and preventing me from doing so... of course, if I had a hacked copy, I wouldn't HAVE this problem. But as a legitimate customer... :rolleyes:
Anyway, now the job is to try to get BD playback with gamma going.
I could potentially swap the HD4850 for a 9800GTX, if there's an issue with gamma, but I need to make sure that the box with the 9800GTX won't suffer too badly in 3D performance if I swap. The reason I originally put the ATI in there was so I could keep using powerstrip, so NOW... heh.
| Posted: Wed Feb 04, 2009 6:25 pm Post subject: |
So, I'm playing around with WALL-E now, both the bd itself and ripped. Playback of the bd disc is fine in powerDVD, but no gamma and it refuses to use software mode (without saying so or saying why).
I can drop the .m2ts into zplayer and mpclassic, and it plays - but not terribly smoothly, and then with a big stutter every once in a while, often accompanied by what look like compression errors - kind of like it didn't get any data for a while.
FFDShow is only reporting 22% CPU load whilst doing this, so I don't -think- it's CPU - but I'm new in town, so to speak.
Any advice? It'd be appreciated!
| Posted: Wed Feb 04, 2009 7:08 pm Post subject: |
| WanMan wrote: | I do not know about Blu-ray, but I can say I have played back 720P p0rn using MPC with really good results. This is on a machine with modest components (2-core middle of the road). |
Hi Def Adult fare?!?!?!?!?
How did that Happen?
_________________ Follow my blog
| Posted: Thu Feb 05, 2009 7:46 pm Post subject: |
I just got to trying kmplayer... god DAMN, jask, I owe you one! It's fantastic!
Seems to play BD sans stuttering, with gamma (only internal - haven't got ffdshow working with it yet, but obviously it can). The only thing it can't do (that I've found so far) is to play a bd complete with menus by opening the folder the structure is in, like it can with DVD. But I've only played with it for a few minutes.
Wonderful, wonderful, wonderful!
Elaine Benes
| Posted: Sat Feb 07, 2009 1:11 pm Post subject: |
| perisoft wrote: | | jask wrote: | http://www.9down.com/KMPlayer-2-9-3-1284-Beta-10543/
Wonderful, wonderful, wonderful! :thumbsup: |
If you EVER find a functioning application that will BOTH play a full BD, either from disc or ripped to .iso, AND gives you complete control over playback via software or hardware AND gamma control(that isn't Nvidia card based...) please post it here, 'cause currently, it does NOT exist...period.
There are dozens of applications which allow software playback of the file contained within the BD structure. Personally, I think Nero Showtime makes one of the absolute best images using the .m2ts file, but again, it is almost impossible to get Showtime to actually play back a BD disc(or, it is for me anyway, even though I actually PAID for the BD playback licence, stupid me...). And currently there are NO options to play back a full BD with gamma control, EXCEPT the rudimentary gamma control contained within the Nvidia control panel which thankfully they finally allow the user to apply to all applications. Another bonus of the Nvidia control panel is it allows you to choose computer or video black range. The drawback some see to Nvidia is it doesn't work very well with Powerstrip...
| Posted: Sat Feb 07, 2009 2:11 pm Post subject: |
I may have spoken somewhat too soon... it's 99% there: The only problem is that there's a tiny stutter every few seconds. You can only see it in smooth pans, but instead of bzzzzzzzzzzz, you get bzzz--zzzz--zzzz--zzzz... It's probably only a 10ms pause, but it's obviously No Good for watching anything.
I still haven't spent a huge amount of time with it, though.
One problem is that it only uses one core, so one core is sitting there at 80-90% while the other three are twiddling their thumbs...
Elaine Benes
| Posted: Sat Feb 07, 2009 2:32 pm Post subject: |
| perisoft wrote: | I may have spoken somewhat too soon... it's 99% there: The only problem is that there's a tiny stutter every few seconds. You can only see it in smooth pans, but instead of bzzzzzzzzzzz, you get bzzz--zzzz--zzzz--zzzz... It's probably only a 10ms pause, but it's obviously No Good for watching anything.
One problem is that it only uses one core, so one core is sitting there at 80-90% while the other three are twiddling their thumbs... :( |
Is this BD from disc or .iso, the full enchilada ? If so, please post HOW, it will be a first...
What you want is doable with the media files, easily, and if you convert to MKV, again, easy, but so far, it has been impossible to do what you want with NATIVE BD structure from disc or .iso...
| Posted: Sat Feb 07, 2009 3:52 pm Post subject: |
This is kmplayer opening the .m2ts file directly - it doesn't seem to load the whole bd structure with menus, etc. But it'll load the .m2ts right off the disc or out of the folder if I rip the disc to the HD (so presumably also would play off an .iso). This is with anydvdhd, of course.
It seems like the stutter thing goes away if I set KMplayer to "speed (1ghz)" - which is kind of funny to do with a quadcore at 2.4 but from doing some comparisons with powerDVD, it doesn't seem to be as smooth. Unfortunately I can't get any dropped frame / rendering stats out of kmplayer, so it's hard to tell exactly what's happening.
Oddly, gamma in the kmplayer menus works fine, but gamma in the ATI panel has no effect. So KMplayer is doing SOMETHING that makes its internal gamma work with an ATI card. Odd.
