Blorton
Joined: 27 Jan 2009 Posts: 105 Location: Hotlanta, GA
| Posted: Sat Feb 07, 2009 6:03 am Post subject: |
Well we just sat through Top Gun on BRD.
Awesome! I was surprised I didn't have to refocus the projector, but I do need to fix the aspect ratio. The displayed picture was a little too tall. Any pointers there if all we have is a standard dvd test pattern disc?
We did have a nervous moment about halfway through the movie when it looked like the sync was going away - the screen got real sideways jaggy, but that stopped after a few minutes. I'll reseat what cables and connectors I can get to inide the pj tomorrow, but attribute that to it not being used for a good while. I was using the short cable from the hdfury into the pj. (Also got lucky and had a cell phone charger with the right plug that I reversed the wiring on and used to power the hdfury.)
Thanks again everyone for the pointers - this is easily the best image quality we've seen on this system. We'll be tweaking focus and aspect this weekend and best of all - firing up the popcorn machine!
Cheers!
Dan
| Posted: Sat Feb 07, 2009 6:57 am Post subject: |
Pop the test pattern DVD into the player and use it to adjust the aspect ratio. The PS3 will upscale it to 1080i for you.
Blorton
| Posted: Sat Feb 07, 2009 3:35 pm Post subject: |
| AnalogRocks wrote: | | Pop the test pattern DVD into the player and use it to adjust the aspect ratio. The PS3 will upscale it to 1080i for you. |
Excellent! Thanks.
Now I just need to take another look at the IFB12's switches. When things got wavy last night, I pulled both h/v and the picture stayed up. (it got darker, but stayed in sync. hmmm.)
Edit: Dang. the video essentials dvd we have is the fullscreen version. time to buy the brd one.
| Posted: Sat Feb 07, 2009 4:54 pm Post subject: |
Ahh sounds like the IFB 12 is set wrong. Do you have the manual? Is it the IFB 12 or IFB12A?
Blorton
| Posted: Sat Feb 07, 2009 6:53 pm Post subject: |
It's the IFB-12A and was set for RGB. I actually bought this card new from Sony when I first got the HTPC going.
Should I set this to Y/Pr/Pb for best quality? (making the H/V bnc cables pointless?)
ralpharch
| Posted: Sat Feb 07, 2009 10:03 pm Post subject: |
Idon't know about your input card (I use a Moome Exd-HD into the projector using vga to rgbhs cable); but I will say that the output from my PS3 to the projector was essentially identical on screen whether out at component or HDMI into the Moome box (both 1080i)
| Posted: Sun Feb 08, 2009 1:15 am Post subject: |
No don't use it for compoenent. Anything over 576P makes it turn green.
I have had a couple IFB-12 cards here ( I think one was a 12A ) and they are the only card that will work in a Sony1271 switcher when paired with the HDFury1 because the buffer their output. IFB-10, and IFB-11 didn't cut it.
HDFury1 doens't support component just RGBHV
Blorton
| Posted: Sun Feb 08, 2009 4:26 pm Post subject: |
Thanks, I was able to confirm that rgbhv was the only way it works yesterday while adjusting the set. I'd get no sync with either h or v disconnected. No telling what went on that squiggly time, but we sat through the horrible Miami Vice movie last night without any problems surfacing.
