Got Tubes !!??!!
Posted: Thu Dec 25, 2008 4:02 am    Post subject:
ShockedShockedShocked
Mr. Green Mr. Green Mr. Green
Posted: Thu Dec 25, 2008 4:21 am    Post subject:
Wink Wink Wink
Posted: Thu Dec 25, 2008 12:18 pm    Post subject:
stefuel wrote:
And the whack job of the year award goes to....(drum roll)....Atha....Oh $hit, you already new what I was going to say.
When your ready to go to the grey side i'll take your Ampro's and fit the girls with a set of these. Very Happy
and do a hybrid MarPro Quad blend Very Happy
Confused no what were you going to say? Wink
Athansios
Some day I'd like to try a LUG (same pin-out as AmPro) or one of those type tubes. My idea for mixing tubes is to produce adapter plugs that go between the existing tube and neckboard. I think it can be done adding less then a inch to the overall length. I saved some old tubes to smash and steal the plugs off the end for half the adapter and somewhere around here I have some old neck sockets for the other half.
Posted: Thu Dec 25, 2008 3:09 pm    Post subject:
Chip I was going to do the same thing, make a small pcb(2 piece) as an adapter for the marquee neck board but after looking at it all t was actually easier to just modify the original VNB. I bought pins and connectors for the pins i wont need. i can send you a set to try for one tube. He still has used tubes left and the two i got with the 16 new are just as good, no wear that I can see. I need to go down there and move all those boxes and organize them into sets, and look for the used and new and separate those also.
Posted: Thu Dec 25, 2008 3:40 pm    Post subject:
I don't know how the neck is keyed on the Sony tubes you have in relation to the original P19's that are in a Quee but one of the 9 inch quee couplings that I have came with a tube (red) installed. When I tried to slip on a AmPro neck board, it was upside down. So not only would I have to redo the pin-out but adjust the key position or remount the tube in the coupling 180 degrees.
Posted: Thu Dec 25, 2008 3:43 pm    Post subject:
the key is mounted as for any marquee tube, so you'd have to flip the tube in the housing which would be no big deal since your going to have to mount them from scratch anyhow.
And lets call them Thomas tubes as that will cause less confusion.
Posted: Thu Dec 25, 2008 7:23 pm    Post subject:
Hello
The early 9000s used Thomson tubes and 40kv on the anode; what is a "Thomas" tube?
Posted: Thu Dec 25, 2008 8:01 pm    Post subject:
These hybrid custom tubes.
http://www.curtpalme.com/forum/viewtopic.php?p=155166#155166
http://www.curtpalme.com/forum/viewtopic.php?p=141289#141289
Posted: Mon Dec 29, 2008 11:00 pm    Post subject:
I would say your crazy, but I think insane is better.Laughing Aren't these the same ones you have been pushing for the last couple of months?
Posted: Mon Dec 29, 2008 11:07 pm    Post subject:
Yes I am And yes they are ! Very Happy
Posted: Mon Dec 29, 2008 11:12 pm    Post subject:
Impress the ladies, 243" 's of tubes
Posted: Mon Dec 29, 2008 11:13 pm    Post subject:
Do you realize there is a company on ebay pushing your mods for the Sony tubes as an option?
Posted: Mon Dec 29, 2008 11:17 pm    Post subject:
yeah Niktec i bet. I mentioned to the one guy i buy parts from that it can be done, but i dont think he realizes that the 09MEX03 tube has a different bell housing and I am not sure if the marquee's deflection coil will be able to fit over it or just work the way it is, someone would have to try it to find out. if someoen sends me a 09mex03 tube i can test it since i have a modded VNB already.
speedyandre
Posted: Mon Dec 29, 2008 11:19 pm    Post subject:
Wow that's a great Xmas tree picture Thumbs Up
I still wonder if they can be mounted in a 1292 incl. the LC hardware, that would boost the light output here a lot Mr. Green
However, I've built in the 'new' blue Sony tube and all is fine without any streaking because I don't need a high gain anymore Smile
Finally the blue colour is ok and the whites too, now I can play all my BD's on the PS3 the way they should Wink
Happy days Thumbs Up
André
I'll be broke
CRT_Ben
Posted: Tue Dec 30, 2008 2:29 am    Post subject:
Wow I've never dealt with this Niktec guy but he seems to stretch the truth a little bit?? "These tubes can be used with the Electrohome 9500lc with some minor modification." I wouldn't call the modification "minor", and secondly we don't even know if the true sony tubes with the different shaped bell can be used with Marquee magnetics. Then he rates the tubes as "USED Excellent condition" but says that the red tube is spot burned... Rolling Eyes
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370125784682
