1031
| Posted: Fri Dec 19, 2008 5:53 am Post subject: |
| Person99 wrote: | | 1031 wrote: | | I´m not sure but i think that those warm up modes are to prevent cathode contamination. Friend here in Finland complained that his barco 808(over 7000 hours on tubes) had elevated black level on one tube, i recommended to use that "run in cycles" funtion that Barco´s has. That helped to get blacks back. Also on picturetube testers/rejuvenators that "cleaning" function has cycles with/without filament voltage, so that there is small mechanical movement(heat expansion) between tube elements (G1/cathode) that allows "crap" to fall out between elements. Those are just my thougts, |
You are 100% correct. However, these PJs where never expected to be be fired up, run for 2 hours (a movie), then shut down. In that kind of scenario, running the warm up every time is way overkill and just wears the tubes. It needs to be run like once a year or so. |
I tryed to edit that post yesterday, but had internet failure..
Yes its good to use that warm up / Run in cycles function few times at year.
_________________ Marquee 9500LC (Frankenyokes / Thomas electric tubes / HD-10L / +many mod´s)
DVDO VP-50
New hobby, Rally
VideoGrabber
| Posted: Fri Dec 19, 2008 10:58 am Post subject: |
Dave,
> It needs to be run like once a year or so. <
1031
> its good to use that warm up / Run in cycles function few times at year. <
I'd recommend once every 4-6 months (2-3 times/year), which is compatible with the above comments. Every time you power up makes no sense at all, and will definitely shorten the life, as Dave previously mentioned. Twice a year works for me, and I've never had any problems with cathode contamination, or accelerated wear.
Another option, along the lines of 1031's friend, is to not do it at all, until you eventually notice evidence of a problem. However, by letting it go that long, you run the risk of needing more "aggressive" treatment (plus progressively deteriorating PQ leading up to that point).
_________________ - Tim
VideoGrabber
| Posted: Fri Dec 19, 2008 12:23 pm Post subject: 1024-point Individual RGB Gamma Correction for DVDO VP50 |
1024-point Individual R/G/B Gamma Correction for DVDO VP50
Discussion is now found here.
VideoGrabber
| Posted: Fri Dec 19, 2008 12:56 pm Post subject: |
Dave,
> Yes, this only happens with analog solutions. Though per our other conversations, I know how to reshape the curve (if you will) with a Lumagen and an HTPC, I thought it was impractical on the VP50? <
Bizarre. With all the "warm up" discussion, I missed this response of yours completely. Sorry.
Well, you have your answer to that now, at least. It basically will be very similar to the HTPC method, that you're used to.
[Further discussions will be found here].
dropzone7
Joined: 12 Jun 2007 Posts: 1069 Location: Charlotte, NC
| Posted: Fri Jan 30, 2009 2:09 pm Post subject: |
I know that this thread took a very different direction late last year but I need to revisit this and ask for some help again. I started this thread when I added a VP50 scaler to my setup along with the Moome FullXG card. I have been enjoying both for a while now and I'm learning more about the scaler each time I use it. My question is somewhat related to the scaler but perhaps more about the projector. Basically, I'm seeing an effect at the far left side of my screen that I can only describe as a wavy vertical band. It's easier to see on an all white image or an image of sky. If I put up the geometry pattern from the VP50 everything on screen looks pretty straight aside from that area at the far left. The horizontal arrow looks like a snake near the edge of the screen. The grid patterns show the same problem with a waviness at the left edge. Now just to give you a bit more background, this was not happening until I set up a 72hz output through the scaler. At 60hz I would say it might still be there but nowhere near as noticeable as at 72hz. Most people probably don't even notice this but it's starting to drive me nuts. Anyway, I played around the the VP50 a bit last night just to see if I could make this go away. I don't really know what I'm doing but with a combination of projector "position" and "image size" adjustments along with "horizontal sync" in the scaler I was able to smooth out that wavy edge a good bit. So, am I on the right track in trying to remedy the problem this way? Do I need to create a new signal entry in the projector and experiment a bit?
_________________ "Coffee is for Closers."
MikeEby
| Posted: Fri Jan 30, 2009 2:16 pm Post subject: |
Are you using any blanking on the projector? If not try to apply some and see if it goes away.
dropzone7
| Posted: Fri Jan 30, 2009 2:20 pm Post subject: |
| MikeEby wrote: | Are you using any blanking on the projector? If not try to apply some and see if it goes away.
Mike |
Hi Mike. I'm using just enough blanking to take the picture to the edge of my screen. I can't remember now if blanking more of that edge made it go away or not. I know if I shift the image to the right about 6 or 8 inches it goes away but then of course I'm not centered on the screen. When I look at the tube faces I'm not anywhere near what I would call close to the edge so I'm not sure where the distortion is coming from.
MikeEby
| Posted: Fri Jan 30, 2009 2:36 pm Post subject: |
| dropzone7 wrote: | | MikeEby wrote: | Are you using any blanking on the projector? If not try to apply some and see if it goes away.
Mike |
Hi Mike. I'm using just enough blanking to take the picture to the edge of my screen. I can't remember now if blanking more of that edge made it go away or not. I know if I shift the image to the right about 6 or 8 inches it goes away but then of course I'm not centered on the screen. When I look at the tube faces I'm not anywhere near what I would call close to the edge so I'm not sure where the distortion is coming from. |
If the blanking doesn’t fix it, what I did, with the high refresh rate I use was move the image over till the line goes away, in my case it was actually foldover. Then using the 3151 pass code move the rasters over so the image is back on the screen using the reference raster centering for each tube. You want to be sure your raster is NOT going past the edges of the tubes and you will have to touch up the convergence. You also might wait for a second opinion before doing this; although mine has been running for over a year using this type of setup so I’m not sure it will do any harm as long as the image does not go past the edges. If you using any other signal inputs they will need to be touched up also.
dropzone7
| Posted: Fri Jan 30, 2009 2:42 pm Post subject: |
I'm so desperate to fix it that I was considering going to a smaller screen size. I would rather not do that at this point. I suppose moving the rasters to a position that is not centered on the tube face is an option since I will likely be the last owner of this projector. It kind of goes against everything we are told regarding centering the rasters and maximizing the phosphur. Raster centering is a global adjustment right? So if I change where they are right now then it's going to affect all of my signal entries right? Duh, I guess that's what you said in your last statement. I suppose I could just right down my current settings and go back to them if I foul it all up.
Oh, speaking of high refresh rates, I tried to use 96hz and could not get it to work. Is this a limitation of my XG (852)? I went into the VP50 using a 1080i/60hz format and then went to "framerate" and hit "60hz unlocked". Then I cranked that number up trying to get to 96hz. Somewhere around 86 or so it started to go crazy. I got garbled mess all of the screen starting at the bottom and gradually working it's way up the screen as I increased the framerate.
MikeEby
| Posted: Fri Jan 30, 2009 2:49 pm Post subject: |
| dropzone7 wrote: | I'm so desperate to fix it that I was considering going to a smaller screen size. I would rather not do that at this point. I suppose moving the rasters to a position that is not centered on the tube face is an option since I will likely be the last owner of this projector. It kind of goes against everything we are told regarding centering the rasters and maximizing the phosphur. Raster centering is a global adjustment right? So if I change where they are right now then it's going to affect all of my signal entries right? Duh, I guess that's what you said in your last statement. I suppose I could just right down my current settings and go back to them if I foul it all up.
Oh, speaking of high refresh rates, I tried to use 96hz and could not get it to work. Is this a limitation of my XG (852)? I went into the VP50 using a 1080i/60hz format and then went to "framerate" and hit "60hz unlocked". Then I cranked that number up trying to get to 96hz. Somewhere around 86 or so it started to go crazy. I got garbled mess all of the screen starting at the bottom and gradually working it's way up the screen as I increased the framerate. |
Drop, IMO the rasters them self cause very little wear. It's the bright image that wears the tube, and that will still be centered unless you move the projector. The 852 should be able to handle 1080i@96Hz but you probably need to use Kai's custom timings, I have no idea how you set them in a VP50.
dropzone7
| Posted: Thu Feb 12, 2009 3:22 pm Post subject: |
Okay, so I'm back with more dumb questions. Just fiddling around with the VP50 scaler I notice that I don't have any 1080p output resolutions availabe. They are in the list but are grayed out for some reason. I'm sending 1080p/24 from my Blu Ray player to the VP50 and outputing 1080i/72hz. Is this a limitation of the XG (852), the XGFULLHD card, or the scaler? Am I doing someting wrong? I realize 1080p on an XG is problematic but I have also read that it's workable with a scaler or HTPC. What am I missing? I would think that the 1080p resolutions would at least show up in my VP50 menu even if I was not using them. I read the manual last night and could not find anything that answered my question.
MikeEby
| Posted: Thu Feb 12, 2009 3:43 pm Post subject: |
You may have to back the refresh rate to 60Hz then the 1080p option might be available.
dropzone7
| Posted: Thu Feb 12, 2009 3:52 pm Post subject: |
| MikeEby wrote: | You may have to back the refresh rate to 60Hz then the 1080p option might be available.
Mike |
Thanks Mike, I will give that a try. How much bandwidth should the 1080p/60hz resolution require? If 852 means 85mhz is that my limit on this XG?
dropzone7
| Posted: Fri Feb 13, 2009 1:13 pm Post subject: |
| dropzone7 wrote: | | MikeEby wrote: | You may have to back the refresh rate to 60Hz then the 1080p option might be available.
Mike |
Thanks Mike, I will give that a try. How much bandwidth should the 1080p/60hz resolution require? If 852 means 85mhz is that my limit on this XG? |
Mike, as usual you were correct. I changed my output framerate to 60hz and "unlocked" and 1080p/60 showed up in my list of available output formats. The projector synced to a really nasty image with foldover and mirroring just as I suspected it might. I dug up some timings from a link you posted somewhere previously (not yours but a user with a Crystalio scaler?) and plugged those into my VP50. It cleaned up the image a bit but I still had about a grid blocks width of foldover on each side of the image. After several hours playing with this last night I got it decent but not perfect by any means. I suddenly remembered that raster centering is a global adjustment and that I was screwing up my 1080i entry by trying to get the 1080p entry working. I gave up then and switched back to 1080i where of course I was out of convergence due to moving my rasters around. I had taken note of the horizontal number on my green raster centering and set it back to that. I then moved everything back on top of the green just as I had it before. So, a few hours spent messing around with 1080p and I'm not worse off but still interested in getting a workable image. I watched some of the DVE Blu Ray with my new 1080p entry and even with the poorly converged image, foldover and something that looked like ringing in certain spots, I have to say that it wasn't all bad. Maybe I was'nt seeing scan lines because everything seemed more "put together", I know that's a terrible explanation but I don't know how to say it. Basically, if I could work out the foldover and get the thing converged properly then I might be able to make a more informed decision. At the very least, my interest is perked now.
MikeEby
| Posted: Fri Feb 13, 2009 2:15 pm Post subject: |
| dropzone7 wrote: | | dropzone7 wrote: | | MikeEby wrote: | You may have to back the refresh rate to 60Hz then the 1080p option might be available.
Mike |
Yes I think thats correct. You should be well under the limit at 1080p/60hz. If I had a VP-50 I would consider 1920X800p like Gary M ran for scope flixs. Perhaps stick with 1080i72 for the 1:78 & 1:85 stuff then for widescreen switch to 1920X800p stretch the image and save a little bandwidth. Gary also knows the VP-50 so well I think he setup some macros with his remote that makes switching res and refresh pretty seamless.
dropzone7
| Posted: Fri Feb 13, 2009 4:51 pm Post subject: |
So, are there any users with an XG, VP50 combo running 1080p? I'm looking for the correct timings to input into the VP50. I'm not a PC guy so all of this is foreign to me. As stated earlier, I copied some settings I found in another thread but they were through a Crystalio scaler I believe. Will the timings differ from one scaler/HTPC to another or should I just be able to copy someone elses assuming they are using the same projector?
MikeEby
| Posted: Fri Feb 13, 2009 6:32 pm Post subject: |
| dropzone7 wrote: | | So, are there any users with an XG, VP50 combo running 1080p? I'm looking for the correct timings to input into the VP50. I'm not a PC guy so all of this is foreign to me. As stated earlier, I copied some settings I found in another thread but they were through a Crystalio scaler I believe. Will the timings differ from one scaler/HTPC to another or should I just be able to copy someone elses assuming they are using the same projector? |
Was it this post?
http://www.curtpalme.com/forum/posting.php?mode=quote&p=124835
| rickycleung wrote: | I hook up XG1350 with a Crystalio I scaler. The 1080P timing are:
1920 x 1080 @ 60.05Hz (True 59.94Hz)
Horizontal total active 1920
Horizontal front porch 057
Horizontal sync width 096
Horizontal back porch 184
Vertical refresh rate 060.05Hz
Vertical lines 1080
Vertical front porch 003
Vertical sync width 005
Vertical back porch 032
Ricky |
Yes, I can plug in Kai, 1080i96hz timings and they work on both my PC and projector. Gary or Gino I think both know how to setup a custom timing in a VP-50.
dropzone7
| Posted: Fri Feb 13, 2009 7:05 pm Post subject: |
| MikeEby wrote: | | dropzone7 wrote: | | So, are there any users with an XG, VP50 combo running 1080p? I'm looking for the correct timings to input into the VP50. I'm not a PC guy so all of this is foreign to me. As stated earlier, I copied some settings I found in another thread but they were through a Crystalio scaler I believe. Will the timings differ from one scaler/HTPC to another or should I just be able to copy someone elses assuming they are using the same projector? |
Was it this post?
Vertical lines 1080
Ricky |
Mike |
Yep, that looks like what I used. It helped but did not totally solve my issues. Perhaps I'm not doing something in the correct order? I did all kinds of image shift, image size, blanking adjustments and it seemed almost as if the projected test pattern (from BD DVE) was too wide to resolve the image properly. In other words, to avoid the foldover on one side I would have to add it on the other side. Do I need to do the projector position adjustments before changing the VP50 timings or vice versa, or does it matter? I think I might have been getting close last night but moving my rasters around freaked me out so I gave up.
dropzone7
| Posted: Sat Feb 14, 2009 3:34 pm Post subject: |
Stayed up LATE last night trying to get 1080p working. Mike, I used your numbers and Boom! It works! The geometry still needs work and I may have to do grayscale for this entry but I like what I'm seeing so far. I'm sending 1080p/24hz from the Blu Ray to the VP50 and outputting 1080p/48hz from the VP50. I'm not sure this is the optimal refresh rate but it synced up to the XG with no troubles and using your timings Mike, the image was much more centered than before and I did not have to do any raster movement at all, well maybe a bit of static on the red but that's it. My DVE Blu Ray revealed a much smoother image than what I'm used to seeing. I'm sure it's probably softer than my 1080i/72hz but overall there seems to be more detail. Could this be because I'm no longer seeing the scan lines? I sit about 12-14' back from my 108" wide screen. Well, I'm off for Valentine's Day lunch with the wife so I need to go. I just wanted to post here and say thanks to Mike again! I owe you man. You clued me in on the great price of the VP50 at SecondAct and have been very helpful with my questions as always. That's what I love about this site. All of you guys are so willing to help people like me that don't get it right away and need some hand holding.
dropzone7
| Posted: Tue Feb 17, 2009 2:52 pm Post subject: |
Well...perhaps I spoke too soon. We sat down for our first movie since I had setup the 1080p entry and my wife had to leave the room. She said, "what did you do? It's flickering or something". Great, just great. She told me should could not watch a movie if it was going to look like that so we had to revert back to my 1080i/72hz settings. So, I guess 1080p/48hz is not a high enough refresh rate to avoid the flicker. I noticed it just slightly but perhaps I was just so excited to have it working that I didn't focus on it as much. I don't think this XG will allow me to sync to 1080p/72hz so I may be out of luck. I know the next thing you guys are going to say is why not use 1080i/96hz. Well, I don't think I can do that either. I even tried turning off 24p in my Blu Ray player and just sending 1080p/60. The scaler showed I was ouputting a bit under 60hz, like maybe 55 or 57, don't remember exactly. It seemed to like 1080p/48hz and if not for the flicker I think this would be perfect. Oh well.
CurtPalme.com Forum Index
-> Video Processors, Converters, Switchers, Cables |
| Page 8 of 10 |
