Person99
| Posted: Fri Dec 12, 2008 3:54 pm Post subject: |
Don's point was that you need to do a full set up (or copy then tweak) for the 72 since it is a different memory block.
| dropzone7 wrote: | | Don, the first setup was done at 60hz since the only source I have that will do 1080p/24 is the Blu Ray player. When it's first turned on it's sending 1080p/60, then switches to 1080p/24 when the movie starts. |
I'm not sure if you can do this with the VP50 and your player, but here is something to try. My set up is an LG combo player and a Lumagen.
My Lumagen has 4 output configurations:
16:9 60 Hz
16:9 72 Hz
2.35 60 Hz
2.35 72 Hz
The LG does not send 1080p/60 (which is good that I don't have to mess with that because it is a useless resolution!) only 1080p/24 or 1080i/60 or the other "normal" ones.
When I'm watching a movie from BD (or HD DVD), the Lumagen uses one of the memory blocks with a 72 Hz output. Many of the menus of BDs can be put out at 1080p/24, when they are, all is great.
However, when they cannot, the LG falls back to 1080i/60. But the Lumagen is still outputting 72 Hz--so, the menus and pre-movie stuff might be jumpy (but who cares). Once the movie starts, the Lumagen framerate locks to the 1080p/24 and all is wonderful.
Since the Lumi is always outputting 72, there is not sync switching in the PJ.
_________________ Dave
wallace123456
Joined: 14 Aug 2006 Posts: 2236 Location: Northwest VA area
| Posted: Fri Dec 12, 2008 5:20 pm Post subject: |
| dropzone7 wrote: | | Don, the first setup was done at 60hz since the only source I have that will do 1080p/24 is the Blu Ray player. When it's first turned on it's sending 1080p/60, then switches to 1080p/24 when the movie starts. That's when the 72hz signal entry kicks in. It's kind of a pain too because the projector is jumping back and forth between that 60hz and 72hz entry depending on what is being displayed at the time. For instance, I played some of Kung Fu Panda the other night and the projector would jump back and forth between entries when the previews, green screens were playing. |
Hhhmmm.. When Ken set-up mine, he used a 60hz source for the 60hz setting in the nec, and a 24hz source for the 72hz setting in the nec. Again, my set-up is a little different in that everything going to the Moome EXt box is 720p.
But, yes, the pj display will jump back and forth between 60hz and 72hz when I play a BD-DVD. I don't like it either and it sounds back hearing the pj click and snap back and forth. (In my mind, that can't be good .) So, what I do is plug in a BD-DVD, and give it about 45-60 seconds before switching my Pioneer AVR to the BD output.
BTW, I also always run the nec warm-up screen at least twice (15 minutes each time) before watching anything. Everything gets warmed up, nice and slowwwww.
wallace
_________________ Life Is Good, But BBQ Is Better! BBQ Competition Team
Person99
| Posted: Fri Dec 12, 2008 5:23 pm Post subject: |
| wallace123456 wrote: | | dropzone7 wrote: | | Don, the first setup was done at 60hz since the only source I have that will do 1080p/24 is the Blu Ray player. When it's first turned on it's sending 1080p/60, then switches to 1080p/24 when the movie starts. That's when the 72hz signal entry kicks in. It's kind of a pain too because the projector is jumping back and forth between that 60hz and 72hz entry depending on what is being displayed at the time. For instance, I played some of Kung Fu Panda the other night and the projector would jump back and forth between entries when the previews, green screens were playing. |
I'm confused. Why not just have the VP output 72 the whole time when you are doing BD? Why are you letting it jump between 60 and 72? This is the part I don't understand.
dropzone7
Joined: 12 Jun 2007 Posts: 1069 Location: Charlotte, NC
| Posted: Fri Dec 12, 2008 6:15 pm Post subject: |
| Person99 wrote: | | wallace123456 wrote: | | dropzone7 wrote: | | Don, the first setup was done at 60hz since the only source I have that will do 1080p/24 is the Blu Ray player. When it's first turned on it's sending 1080p/60, then switches to 1080p/24 when the movie starts. That's when the 72hz signal entry kicks in. It's kind of a pain too because the projector is jumping back and forth between that 60hz and 72hz entry depending on what is being displayed at the time. For instance, I played some of Kung Fu Panda the other night and the projector would jump back and forth between entries when the previews, green screens were playing. |
I'm confused. Why not just have the VP output 72 the whole time when you are doing BD? Why are you letting it jump between 60 and 72? This is the part I don't understand. |
Dave, I'm not disagreeing but would that not mean that the scaler would need all output profiles but the 72hz one deleted? I'm still learning how to use this thing but the way I'm using the VP50 now is like this:
Output Display Profile 1:
1080i/72hz
4:2:2 colorspace
Video
Output Display Profile 2:
1080i/60hz
4:2:2 colorspace
Video
At the projector end I have a signal entry for 60hz and a signal entry for 72hz. I have to have that 60hz entry for my HD DVD player and cable box because those won't send 24p to the scaler.
Maybe I have something setup wrong in the VP50 so that it is AUTO selecting whatever frequency the source sends it. Maybe I need to take this whole thing back to the drawing board and slow down.
_________________ "Coffee is for Closers."
wallace123456
| Posted: Fri Dec 12, 2008 6:16 pm Post subject: |
The thought is: info shot using video = 60hz; info shot using film = 24hz(72hz). "Old timey" as my wife calls SD-DVDs now, are 60hz; not that big of a deal for me since I use the xa2 for SD-DVD playback. My David Gilmour - Remember The Night BD-DVD still outputs 60hz cause it was done in video.
All film info is 72hz. That was my grip why I was not getting 72hz out from the xa2 as I knew it would do it. But, when I had the xa2 ouput set for "auto", it would only output 60hz. Then I changed it to 1080/24 (fixed), I get 24hz from it. . To make it correct with the source info, I will need to change the setting back to "auto" for 60hz stuff.
No big deal.
wallace
Person99
| Posted: Fri Dec 12, 2008 6:40 pm Post subject: |
Either I'm not understanding what you guys are saying or you are not understanding what I'm saying.
This is what I think you guys are saying:
1) When you turn on the BD player it is sending 60 and the projector is "seeing" 60.
2) When the movie starts, the BD player is sending 24 and the projector is "seeing" 72.
Is this correct?
If so, then why? When you know you are going to watch a BD in 24, put the VP in the output config for 72. When the player sends 60 for the start up screen and menus and any of that, it WILL be jumpy because the VP can't frame lock--but your PJ will "see" 72. When the movie starts, the player outputs 24, now the VP can frame lock and starts putting out a smooth 72.
In my scenario (which is the way I do it), there are no re-syncs at the PJ. The downside is the memus and stuff might not be smooth--but who cares, the movie is and I have no re-syncs.
60 Hz content is a completely different story!!! I have a 60Hz output config for that stuff--lets just stay with turning on the BD player through BD movie playback--why do you send 60 to the PJ then have to have it resync to 72 when the movie starts?!?!?! This is what I'm confused about.
wallace123456
| Posted: Fri Dec 12, 2008 6:54 pm Post subject: |
| Person99 wrote: | Either I'm not understanding what you guys are saying or you are not understanding what I'm saying.
Is this correct?
60 Hz content is a completely different story!!! I have a 60Hz output config for that stuff--lets just stay with turning on the BD player through BD movie playback--why do you send 60 to the PJ then have to have it resync to 72 when the movie starts?!?!?! This is what I'm confused about. |
All the above is correct for me. But I only have 1 input into the vp50; the ps3, xa2 and dish dvr feed into my pioneer avr and I have 1 output from the avr into the vp50). The pioneer of course is just pass-thru and does nothing more than be a HDMI switcher along with grabing the audio. The ps3 and xa2 are set to output 24 or 60hz depending on the source DVD.
My thought is to view 60hz stuff at a 60hz frame rate; and to watch 24hz stuff at a 72hz frame rate.
And of course the jumping between 60 and 72 hz frame rate at the begining of movies is that all the Federal Copying warnings, menus, and previews are usually in 60hz frame rate.
I hope I am making sense...
wallace
Person99
| Posted: Fri Dec 12, 2008 7:01 pm Post subject: |
| wallace123456 wrote: | | Person99 wrote: | Either I'm not understanding what you guys are saying or you are not understanding what I'm saying.
Is this correct?
wallace |
Yes you are, hopefully I am. With regard to what I bolded above, my question is WHY?!?!?
Since you know you are going to watch the movie at 72, why not watch the stupid warnings in 72? You don't care if they are smooth, then the PJ does not have to resync from 60 to 72. That really is ALL I'm saying.
dropzone7
Is this correct?
wallace |
That's exactly the way I am using mine Don. All sources run into the AVR via HDMI and then one HDMI cable to the VP50 and one HDMI cable to the Moome card in my XG.
wallace123456
| Posted: Fri Dec 12, 2008 7:09 pm Post subject: |
| Person99 wrote: | | wallace123456 wrote: | | Person99 wrote: | Either I'm not understanding what you guys are saying or you are not understanding what I'm saying.
Is this correct?
wallace |
Since you know you are going to watch the movie at 72, why not watch the stupid warnings in 72? You don't care if they are smooth, then the PJ does not have to resync from 60 to 72. That really is ALL I'm saying. |
But I don't watch 60hz material at 72hz frame rate. Only film stuff thats recorded in 24hz do I watch at the 72hz frame rate.
If you put in a SD-DVD, do you view it at the 72hz frame rate?
wallace
Person99
| Posted: Fri Dec 12, 2008 8:31 pm Post subject: |
| wallace123456 wrote: | | Person99 wrote: | | wallace123456 wrote: | | Person99 wrote: | Either I'm not understanding what you guys are saying or you are not understanding what I'm saying.
Is this correct?
wallace |
wallace |
You are still missing it.
Let me try one more time.
Let's consider 2 types of "content"
A) Content - movies, TV shows, etc. I.e. the things you want to watch.
B) Non-content - device start up screens, FBI warnings on discs, disc menus, etc.
OK, so with these, let's consider three types of source material:
1) 60 Hz "content" source material.
2) 24 Hz "content" source material (e.g. BD movies).
3) 60 Hz "non-content" source material (e.g. BD FBI warnings, etc).
OK, lets forget about number 1--no problem here: watched at 60 Hz.
Let's forget about number 2 - nor problem here: watched at 72 Hz.
So, number 3. Number 3 is generally seen before viewing number 1 or 2. It is not the objective. So typically you have 2 scenerios:
a) See some of number 3, then number 1 (e.g. a DVD, cable DVR show, etc).
b) See some of number 3, then number 2 (e.g. a blu-ray or HD DVD).
Forget a. We don't care about that--all is fine. Lets talk about b. There are two ways to watch b:
i) Show number 3 (the non-content) at 60 Hz [which is what it is authored at]), followed by number 2 (the movie) at 72 Hz.
ii) Show number 3 (the non-content) at 72 Hz, followed by number 2 at 72 Hz.
If you do i, then both types of content are smooth, but the PJ has to resync.
If you do ii, then the FBI warning and other BS are not necessarily smooth, but the PJ does not have to resync.
You seem to be saying that you guys do "i". I do "ii". My question to you is, why don't you do "ii"?
Am I making sense?
wallace123456
| Posted: Fri Dec 12, 2008 10:17 pm Post subject: |
| Person99 wrote: | | wallace123456 wrote: | | Person99 wrote: | | wallace123456 wrote: | | Person99 wrote: | Either I'm not understanding what you guys are saying or you are not understanding what I'm saying.
Is this correct?
wallace |
wallace |
Am I making sense? |
LOL!!! I figured out what you were saying about 45 minutes ago while I was in physical therapy for my shoulder..
I need to see if the vp50 will let me set it up so that a 72hz output stays that way and doesn't jump back and forth depending on the input (24 or 60hz).
wallace
dropzone7
| Posted: Sat Dec 13, 2008 1:12 pm Post subject: |
Great explanation Dave and I totally agree with what you are saying. I think the only problem now for me and maybe Don as well, is how we implement this in the VP50. I think I may have figured out half of this while messing with the menus in the VP50. As I had said earlier, I have two display profiles saved. Profile 1: 60hz. Profile 2:72hz. There is a setting under the display profile menu for "AUTO" which I had set previously. So, when "content" be it either #1, 2, or 3 as in your example starts up, the VP50 is automatically selecting one of my display profiles based on the frequency of the "content". Aside from a bit of horizontal shift adjustment, and the 60hz and 72hz frame rates, my two profiles are identical. So, I turned OFF the "AUTO" setting for display profiles and no more projector syncing clicks. I get a blue screen between "content" changes but no clicks or annoying noises. I think I also have improved the vertical banding problem I had. Not with what I just described but with some careful convergence and geometry adjustments. I pretty much started over last night running an external pattern (INHD crosshatch pattern for HD Cable) and (DVE Blu Ray crosshatch for the BD player). The issue is much improved not to mention my convergence and setup are much better. I can still see the vertical banding but it's back to the level it was always at which is to say, "very tolerable" and only slightly distracting in a scene with white backgrounds or lighter colors. I think I'm obsessing over it at this point and I doubt that anyone else that comes in my theater would notice. So, more progress made and the next step may be to build something into my remote which automatically selects the appropriate VP50 profile when I turn on a particular source. For example, I always want to use Profile #1 when I view an HD-DVD or HD Cable show and I always want to use Profile #2 when I watch a Blu Ray movie (yes Dave, all of the disc at 72hz, previews, warnings and all).
VideoGrabber
| Posted: Sat Dec 13, 2008 3:06 pm Post subject: |
dropzone7,
> the next step may be to build something into my remote which automatically selects the appropriate VP50 profile when I turn on a particular source. For example, I always want to use Profile #1 when I view an HD-DVD or HD Cable show and I always want to use Profile #2 when I watch a Blu Ray movie <
I might not be understanding exactly what you're trying to achieve here, but the VP50 already provides for very flexible switching and parameter setting, and should be able to achieve that without external remote assist. The memory architecture is a bit complex (as it is on the Lumagens) and not completely clear from the documentation. It can do a lot, but can be a challenge to understand and utilize.
At the top-most level (and they don't start here... they describe it bottom-up), there is a bank of memory settings for each input, combined with every different source signal it can handle. These are Input Format Settings. E.g., a composite input would have only 2 banks (NTSC-60-480, and PAL-50-576), while HDMI has 10 banks (interlaced & progressive inputs, from 480 to 1080), component inputs have 6 banks, and RGB has 8 banks. These tend to be "invisible" in the sense that you can't select or alter them manually. They go online automatically based on the source selected and input signal seen. There are a total of 66 Input/Format memory banks, which you never actually "see".
Within each I/F bank, you have lots of settings, that are specific to only that bank (inp/fmt):
- Picture Controls - brightness, contrast, etc.
- Input Adjustments:
o audio source, lipsync delay, etc.
o deinterlacing, overscan, colorspace, etc.
- Active Input Preset (one of 4 system fixed, 10 memories, or User*)
- Active Display Profile (one of 10 memories, or User) - if AutoLinking is enabled (optional)
The 10 saveable Input Presets hold aspect ratio controls:
- frame AR and active input AR
- pan, zoom, borders
(*According to the manual, while there are 10 saveable memory slots for these, there are also 66 more memories = the User setting for each of the individual Input/Format combinations. If you change the User Preset settings for one input/videoFormat, then switch to another and select User, then modify that User setting, when you return to the first, it is preserved.)
The 10 saveable Display Profiles store output config info:
(these are only available if UserMode = Advanced)
- analog or digital output select
- format (base rez & timing info)
- output AR for Display and Screen, imageShift, underscan
- output level, syncType, colorSpace
- frameRate conversion
- gamma correction
Even if the Display Profile (output config) is auto-linked to the Input selection (optional), you can still select a different DisplayProfile afterwards, while on the same input.
I'll have to admit that I'm not clear on why you're running everything into the Onkyo first, and then a single HDMI into the VP50. That minimizes your ability to utilize the VP50 to dynamically compensate on a per source basis. Essentially then, with everything merged into a single input, the only disciminator you have left is the video signal format. If two of those happen to be the same, the only way to adapt is to manually select a different DisplayProfile.
> So, when "content" be it either #1, 2, or 3 as in your example starts up, the VP50 is automatically selecting one of my display profiles based on the frequency of the "content". Aside from a bit of horizontal shift adjustment, and the 60hz and 72hz frame rates, my two profiles are identical. <
Yes, but one of the characteristics of each DisplayProfile is the framerate, and you could still have 2 different DPs with some adaptive settings, but the same framerate (72 Hz locked, here).
One of the nice things the Lumagens have that DVDO lacks, is a Copy operation. So (nearly) duplicate entries have to be set up by manually by hand, vs a quck clone. It's also not always obvious what configuration possibilities you have available. A trait the Lumagens share as well.
_________________ - Tim
VideoGrabber
| Posted: Sat Dec 13, 2008 3:20 pm Post subject: |
My comment:
> Yes, but one of the characteristics of each DisplayProfile is the framerate, and you could still have 2 different DPs with some adaptive settings, but the same framerate (72 Hz locked, here). <
could reflect one of the confusing aspects of the VP50. When your multi-source switches from 60 to 24 Hz, the I/F memory bank changes, but you don't see that directly. You could input a 60 Hz source, then select Profile N. Then input a 24 Hz source, and ALSO select Profile N. As mentioned above, each HDMI input has 10 completely independent memory banks (dependent on signal frequency, etc.) and you can assign whatever Profile you want to each of them. Or you could have 2 nearly identical Profiles, both at 72 Hz locked, differing only in the Shift setting. And assign the appropriate one to each.
If you assign a 60 Hz Profile to one and 72 locked to another, then the output will change dynamically as you change inputs (as you discovered). But you don't have to config it that way, and you can still retain some auto-adaptability.
If you have a (1) and (3) scenario, with 60 Hz signals coming from multiple (merged) sources going to the SAME input, and want to display them differently depending on content or context, you will have to switch Profiles manually, unless you bypass the Onkyo and go directly into the VP50. That's because you removed the only way the VP50 could have been able to tell the difference. So then it's your job.
MikeEby
| Posted: Sat Dec 13, 2008 3:25 pm Post subject: |
| VideoGrabber wrote: | dropzone7,
- gamma correction
One of the nice things the Lumagens have that DVDO lacks, is a Copy operation. So (nearly) duplicate entries have to be set up by manually by hand, vs a quck clone. It's also not always obvious what configuration possibilities you have available. A trait the Lumagens share as well. |
Glad to know a scaler is less complex then an HTPC
VideoGrabber
| Posted: Sat Dec 13, 2008 3:33 pm Post subject: |
That's a good point, Mike.
In one sense, as soon as you provide for extreme flexibility, the burden of controlling all that power becomes your responsibility. And that's going to be true on a PC or a standalone box.
But I think the biggest problem with the VP50 isn't intrinsic complexity, but rather documentation that makes more sense to the Implementers than to the Users. That's bound to confuse the crap out of people. If you describe all the low-level tech details (which they do), without providing a clear overview (which they don't), people are bound to get lost. Some pictures and diagrams of how the settings interrelate would be helpful as well.
Couple that with the fact that the UI on a standalone box (or OSD) can never hope to compete with what a PC (could) offer in the way of making things visually understandable (or adjustable, box remote limited basically to up/down/left/right), and the PC still holds some cards.
Person99
| Posted: Sun Dec 14, 2008 1:55 am Post subject: |
But I think the biggest problem with the VP50 isn't intrinsic complexity, but rather documentation that makes more sense to the Implementers than to the Users. That's bound to confuse the crap out of people. If you describe all the low-level tech details (which they do), without providing a clear overview (which they don't), people are bound to get lost. Some pictures and diagrams of how the settings interrelate would be helpful as well. |
Or as in the Lumagen's case, you get documentation of only the basic features, no real documentation of the advanced features at all.
wallace123456
| Posted: Sun Dec 14, 2008 3:46 pm Post subject: |
- gamma correction
I have a LOT of learning to do..
| Quote: | | I'll have to admit that I'm not clear on why you're running everything into the Onkyo first, and then a single HDMI into the VP50. |
I have 3 HDMI sources and the vp50 only has 2 HDMI inputs. And, I also thought it best to get the audio from the sources first (not sure why). Is there another way?
wallace
dropzone7
| Posted: Sun Dec 14, 2008 4:11 pm Post subject: |
wallace |
This is what I'm doing as well Don. The reason I do it is because I want to bitsream the newer audio formats such as Dolby TrueHD and DTS-MA, DTS-HD from the Blu Ray player to my receiver. So, the audio gets handled by the receiver before the VP50 (which won't process those formats the way I want) ever sees them. The scaler is for video. One expensive piece of equipment for audio processing (receiver) and one expensive piece of equipment for video processing (VP50). On a lower level function, the receiver is switching these HDMI sources for me but the video passes through untouched as it should.
CurtPalme.com Forum Index
-> Video Processors, Converters, Switchers, Cables |
| Page 6 of 10 |
