It's interesting as people get out of CRTs..
jkruger
Posted: Thu Nov 20, 2008 5:18 pm    Post subject:
I think it was phenobarbital.
Posted: Thu Nov 20, 2008 6:23 pm    Post subject:
Angus_rg wrote:
And when cd players were first released, audiophiles swore up and down the continuous analog signal was much better than a digital signal since it was just 0's and ones that didn't produce a continuous line but a nice DAC can probably do a better job now.
no they can't, red book CD is still red book CD. there's DVD audio and SACD but they're still far from Analog
Person99 wrote:
Uow, you got me thinking. This is a GREAT point and you may be right.
A digital recording is actually a more accurate representation of the source than vinyl--it is far closer to actually being there.
wow, It's not like you to talk out of your ass and i generally respect your opinions but your really off in left field on this one. Untill you sit down in font of a high quality vinly system and do an A/B with a CD player your opnion means nothing. Hypothesizing about why digital music "should be better" is meaningless.
Person99 wrote:
However, for nostalgic or other reasons, a small group of people prefer the "coloring" of the source material that occurs with a vinyl presentation. So, although vinyl is technically an inferior presentation, it is loved by few (I think mostly for non-musical reasons).
this is pathetic, why do you come here if your going to spew crap like this?
Person99
Posted: Thu Nov 20, 2008 6:58 pm    Post subject:
No, the simple fact is accuracy to source can be objectively measured (and has been). If you measure a person singing for instance, record it and put on CD and put on vinyl, you can OBJECTIVELY (we have the measuring equipment and it has been done) determine which one's sound wave is actually closer to the original. And here is the spoiler for you:
It is CD.
Go learn about the wonders of science and technology my friend!
So, there is no point debating accuracy to source. That has been objectively measured and proven, our opinion does not matter in this point.
Now, if you note, my point was all about the accuracy of the representation to the original source and preference. Obviously, the implication is the closer is better (since it is logical to want to capture the true original presentation); however, that may not subjectively be the case. You, for instance, may actually prefer the less accurate production of vinyl (i.e. the "warmer" sound or however else you want to say about it). Others may, heck, everyone may. But, that does not alter the fact that CD is more accurate and you are preferring a less accurate presentation. THAT IS THE POINT.
Look at it this way. I can make the statement that blue is a higher frequency of light then red. That is a factual statement that is objectively verifiable. It makes no value judgment that you are right or wrong to like one better than the other.
Nothing in these last four paragraphs are debatable. All statements of fact. So, let's clarify the "realization" that my referenced post led me to:
1) Even though CD is more accurate than vinyl, if you sit people down in front of two really good set ups, many, many people prefer the vinyl.
2) The point was made the CRTs may be like this. And it is true that digitals already excede CRTs on almost every PQ parameter and soon will on EVERY PQ parameter. However, that does not mean that some will not prefer the "look" of CRT.
So, I'm honestly unclear as to what you are objecting to.
As pointed out above, you will have to clearly delineate the "crap" as I only listed several facts, and one opinion (point 2 above) derived from those facts. I'm not sure how this opinion would be labeled "crap" but that is all I can see you objecting to.
Posted: Thu Nov 20, 2008 7:21 pm    Post subject:
Dave, can you point to the studies that objectively measured CD & vinyl vs. original? (And how did they measure the "original" -- via an analog recording, or a digital recording, or...??) It would be very interesting to see how they measured it. You would hope they did it competently and didn't introduce their own measurement errors.
Person99
Posted: Thu Nov 20, 2008 8:18 pm    Post subject:
Let me find some. The ones I've seen they measure the wave in the analog domain. In the case of playback, it is the sound waves coming out of the speakers.
Posted: Thu Nov 20, 2008 8:26 pm    Post subject:
It is CD.
oh really? I just read an article in the leading Audio magazine in the industry that says the exact opposite.
If you put aside peoples listening preferences red book is still inferior. Did you know CD cuts off all frequency response below 20Hz and above 20Khz, you call that accurate?
did you know that all Redbook encoding utilizes an anti-jitter filter to compensate for a flaw in all A/D/A conversion, without which it would be unlistenable. You call that accurate?
your argument is akin to Faxing a Picaso painting to someone and calling it " just like the original".
Posted: Thu Nov 20, 2008 8:36 pm    Post subject:
No question CD audio butchers the original, especially in high freqs. It only samples at 44.1kHz. The highest freq it can represent is 22.05kHz. Which is higher than most humans can hear, so you might think it's "good enough." But it can only represent triangle waves (or at best sine waves if they reconstruct it carefully) at that frequency. Any higher freqs are lost. Is that audible to humans? I honestly don't know. In the actual human-hearable range it may be "good enough." But more accurate than an analog recording? That I find hard to believe.
Of course, I'm not saying vinyl is perfect either. Records introduce their own coloration and distortion. Which one is "closer" to the original? I'm not sure that's the relevant question. "Which do you prefer" is probably more important as a purchaser.
blue_z
Posted: Thu Nov 20, 2008 9:05 pm    Post subject:
Hi there
Even before the vinyl versus CD debate began, there was the much older debate of vacuum tube (or valve) versus solid state for audio amplifiers (which still goes on today). One aspect of the debates that is similar is that proponents of the "modern" side often are not familiar with the "older" technology. Also there is heavy use of "measurement" to claim superiority. The problem that is often overlooked is that measurements of various audio or visual parameters cannot fully quantify human sensory perception or predict a mental/emotional response.
Regards
Posted: Thu Nov 20, 2008 9:10 pm    Post subject:
vinyl is far from perfect, that's for sure. I just know with a good vinyl set-up the illusion of reality is vey high while CD snaps me out if in just a few minutes. BTW, Gary my old friend from AZ is coming into town and we'll be giving my system a run-through. He's bringing a new Ortofon 2M Black cartridge for demo, you should come down and listen to why CD sucks so bad. Wink
Person99
Posted: Thu Nov 20, 2008 9:28 pm    Post subject:
draganm wrote:
It is CD.
Would that be one of those magazines that says you need cryogenically frozen cables and cable elevators and other such nonsense?
What is their "proof"? Did they measure or just say a bunch of nonsense about sample slices are too wide (i.e. they would be asserting that the human audio perception system can tell the difference between a sound which lasts 1/44,100 of a second and one that lasts 1/46,0000 of a second--which it cannot). If this was the assertion, I'd like to see the testing evidence. Or, was it that 16 bit accuracy is not enough to capture the dynamic range that humans can percieve? And even if those conditions were true, how did they prove the negatives of vinyl were less than the negetives of these two factors?
Are you seriously trying to make me laugh? Is your dog listening to it?!?!? What you just said was: "Did you know CD cuts off frequency response for all frequencies outside of the human hearing range?" It is completely hilarious that you would think this matters. It does that simply because IT DOES NOT MATTER (BTW, very few peoples hearing even goes up to 20KHz, most only hit 18 or so, so exactly why are you worried about information that only your dog can hear?)
I'm sorry, I can't get off this, this is literally the funniest counterpoint I've ever read!
Does not matter. All that matters is if if works. Basically you are assuming that a technology cannot work because you "think" it can't. I only care about measurable facts.
You seemed to be confused STILL. First, neither the vinyl nor the CD is the original (i.e. neither is the Picasso)--both are representations. If you think the vinyl is the original, then you are lost in the camp of "I'm so cool and better than you because I listen to vinyl" that you won't even try to understand. I'm talking about which is a closer approximation of the original when measured--period.
Person99
Posted: Thu Nov 20, 2008 9:47 pm    Post subject:
blue_z wrote:
Hi there
Regards
AGAIN!!!! WHY THE F*CK CAN'T ANYONE UNDERSTAND WHAT I'M SAYING?!?!? It is not hard. There are two distinct discussions here:
1) Is CD or Vinyl a more accurate reproduction of the source?
2) Which do most (or all) people prefer the sound of?
It is quite logically possible to for the answers to be:
1) CD
2) Vinyl
There is no logical contradiction here. I even think it is true! The problem I have is using a subjective preference (number 2) to assert an incorrect assumption for number 1. I'm still searching for some test and have to find them, but I did come across a guy who summed it up perfectly:
Vinyl has limited dynamic range and a whole host of
distortions besides, but some of those distortions give it a wonderful,
resonant sound. Some audiophiles mistake this resonance for "accuracy,"
which is a technical term referring to the relationship between the
recording and the output. But many people who love vinyl don't want to
admit that what they love about it is, technically speaking,
distortion. So they invent all sorts of pseudoscientific theories about
how vinyl must somehow be technically superior to CD.
Person99
Posted: Thu Nov 20, 2008 9:51 pm    Post subject:
Exactly! That was the whole original point, that even though digital may completely surpass CRT in accuracy (similar to CD and vinyl), many people may still prefer CRT (like they do vinyl). Which I thought it was an excellent point.
blue_z
Posted: Thu Nov 20, 2008 11:13 pm    Post subject:
1) CD
2) Vinyl
Hi there
You seem to have a preconceived definition of "accurate" for audio reproduction.
For the subjectivist, "accuracy" is listening and how close is the reproduction to the live event.
For the objectivist , "accuracy" is measurement and how much "distortion" has been introduced.
It's not just semantics, it is point of view.
The set of "measurements" to define "accuracy" is another point of contention. One can chose a measurement to make one technology appear "better" (i.e. "more accurate"). For example in video reproduction CRTs have geometric distortion; but there are also digital artifacts that do not occur in analog video. (Note that word "distortion" has been replaced with "artifact" in the digital domain.) Or the technology can be tweaked to produce good numerical results for that measurement (e.g. the race to super-low audio "distortion" as measured by THD in the 1970/80s stereo components, and the dynamic iris to improve contrast in digital PJs).
Regards
BTW I really don't care if CD or vinyl is better or more accurate.
You can listen to whatever.
Just let me listen to both w/o passing judgment.
Posted: Thu Nov 20, 2008 11:23 pm    Post subject:
it's not even worth arguing this with you Dave, you convenientely toss out the facts that contradict your stupid argument. Who cares if ADA has errors that are attempted to be compensated for by software" hey it works, it must be good". any intellignet person would grasp that something that has have a filter has something inherently worng with it and couldn't possible be HI Fidelity. guess what, my turntable/cartridge has no filters of any kind. The fact that you think i listen to it for some sense of superiority is just sad.
It has been scientifically proven that just because you can't hear above 20Khz means it doesn't add anythign to the music, when it's been shown humans take subtle cue's on timing from this inforamtion which affects your perception of how the music flows. The fact that you completely ignored the 20Hz and below part of the argument proves your just here to argue and your argument is FOS. Your emmediate and pointless reference to cryogenic cables just makes my point. BTW, Streophile tests all sort of gear including CD players that cost as much as a new car. They provide more data and facts than a medical laboratory, including spectral decay, cabinet resonance (for speakers), anechoic chamber, phase accuracy, frequency linearity,response adjusted for room, etc. I doubt you would be intertested in any of this though, you seem determined to just fling poo like a monkey at the zoo.
BTW, there are graphs showing spectral plots of vinyl Vs. CD, but I don't know if it's even worth posting them since you seem unable to have an calm and rational conversation and have to rely on conjecture. I tell you what, post some links to real data and then we can continue.
mike calcott
Posted: Thu Nov 20, 2008 11:45 pm    Post subject:
I do not wish to Hi-Jack this thread into an audio thread, But people who argue that cd's will give a performance equal to vinyl have obviously not ever heard a good vinyl system. I was selling top end audio in the 70's with turntables like Linn and Oracle, and I have never heard a cd that has the presence of a good vinyl system yet. I wish I could reproduce that sound in my HT.
Old dog learning new tricks
Posted: Fri Nov 21, 2008 12:05 am    Post subject:
Whenever I read these debates, whether audio or video (another good cable debate going on at avs high end section), I realize there are too many variables to properly audition ANYTHING.
Ideally to me, a large screen image should be as close to looking out the window as possible. To me, no digitals can do that, the colors are all oversaturated. Most digitals look too sharp as well. To me, CRT's colors, blacks and lack of artifacts most closely represent real life.
When it comes to audio, ideally you should be able to close your eyes and imagine the band/orchestra in front of you. Unfortunately, with the amount of procesing that goes on in the studios now, you the listener have NO idea what the recording engineer has in mind when recording the bands now (Ok, I'm mostly talking rock and roll here I guess).
We're long gone from the days where bands were recorded by two overhead mics onto a Crown reel to reel.
With travesties occurring now such as Metallica's Rock Band version of their new album sounding better than the actual CD, who knows what the hell the engineers are thinking.
Turns out now that a lot of people in the sound industry that are in the know think that the old Bose GM Place sound system that I posted about last week sounds better than the new $2.5 million one. Apparently rumor has it that speakers are also popping on the new system.
Go figure. (sorry, that was a bit off track..Wink)
So.. do we REALLY know what good sound is any more?
Cousin.It
Posted: Fri Nov 21, 2008 12:59 am    Post subject:
My laserdisc sounds better than your DVD. Just so you know......
Shocked
Posted: Fri Nov 21, 2008 1:05 am    Post subject:
Shocked
Oh yeah well my 2 tin cans strung together with 100% pure Egyptian cotton oxygen free string sounds better than your monofiliment clothes line Mr. Green
jkruger
Posted: Fri Nov 21, 2008 1:32 am    Post subject:
Shocked
Maybe so but wait til you hear my braided titanium string and tampon boxes!
blue_z
Posted: Fri Nov 21, 2008 1:41 am    Post subject:
Hi there
That IMO is an interesting, unusual viewpoint. I presume most/all audiophiles agree that the goal is aural recreation of the live event. But I was not aware that the video equivalent is the goal for videophiles. From reading "The Perfect Vision" his goal for home theater was to reproduce film images as close as possible. Film rarely resembles real life images, and is probably more attainable.
Regards
Page 3 of 4
