Need soldering advice on how to proceed with a big IC chip
JustGreg
Posted: Fri Nov 14, 2008 7:36 pm    Post subject:
Yeah!!! A rework Hot Air station is where its at, I got mine new for 159 dollars IIRC, bought the tweezer Iron too, Now Id like to get that IC suction thing in that one video, that is neat !
I saw that too...that was slick! My wife would KILL me for getting a HARS...only because I'd be pulling sh*t apart that wasn't even broken. Laughing
A little side track here, I downloaded the free ExpressPCB software today to start learning on. It should make a good winter hobby if nothing else. http://www.expresspcb.com/ExpressPCBHtm/Tips.htm
3 boards for $51 for 2 and 4 layer! Unless you print and etch your own, which I'm going to take a shot at.
Greg
Posted: Fri Nov 14, 2008 8:40 pm    Post subject:
The eagle software is better i think. and AP circuits in alberta works great with the Eagle files.
JustGreg
Posted: Fri Nov 14, 2008 9:28 pm    Post subject:
Thanks for the tip...I'll check that out too. One can't have too much to play with one doesn't understand, can one? Wink
Greg
Posted: Fri Nov 14, 2008 11:36 pm    Post subject:
LOL Razz
lostmandan
Posted: Sat Nov 15, 2008 1:12 am    Post subject:
RVonse wrote:
The closest I could come to piano wire was unwraveling an old coil off an old junk tv chassis I happen to have. It was really thin and somehow made it under the pins.
It worked perfect! The chip is now off and the board still looks in decent shape. Now the challenge is to get the new chip on it but I think I'll probably manage.
Thanks very much Dan, that wire idea worked out perfect!
Hey, no problem! I am glad to hear it worked out, especially first time through.
I wish I had one of the proper rework stations - but I just don't do enough to justify it. Maybe someday Smile Until then, I'll use my shoestring budget Wink
Posted: Sat Nov 15, 2008 5:52 am    Post subject:
I don't even have a shoestring budget these days. I've graduated to velcro.
tommo2
Posted: Mon Nov 17, 2008 1:58 pm    Post subject:
I'm surprised no-one has mentioned a solder sucker. Simply melt the solder, suck the solder right outta there and move onto the next pin. Keep the soldering iron as hot as hell, it makes it melt quicker, so you can take the heat away quicker.
It's better to apply a huge heat for a very short time, than a more gentle heat for longer. I used a soldering gun once. It was a POS. It took ages to melt the solder. By the time the solder melted, the heat had conducted to the whole board and melted nearly everything.
pull up the handbrake and walk away
Barco Data 701s
iScan HD scaler with sdi mod
Oppo 981HD with sdi mod
Xbox 360
Playstation 2
Denon AVR 1507 7.1 AV receiver
Wharfedale Diamond 9.4 floorstanders (front)
Wharfedale EVO2 (center)
Pioneer 100W (sides)
Wharfedale Diamond 9.1 (rear)
Wharfedale SW150 active subwoofer
Photos on the way!
Posted: Mon Nov 17, 2008 3:06 pm    Post subject:
A solder sucker will not work on a SM chip. A solder sucker leaves a little solder behind and this is enough to keep every single leg of the IC attached to the board getting you nowhere unfortunately.
Tinman
Posted: Mon Nov 17, 2008 7:31 pm    Post subject:
I have a complete Metcal system as well as a Hakko hot air system. Still, I cut the pins on the edge of the chips, remove the chip itself, and then wipe the pins away with flux and a little solder. Leaves the board totally clean and perfectly tinned for the new chip. And it's FAST.
I used to replace large VLSI chips at a shop. I was accused of not actually doing the replacement, so I sat my supervisor down next to me and showed him. The cut and remove method works very well. When you then re-flow the new chip and clean up the flux, it's hard to tell it was replaced.
Marc
This space for rent.
Posted: Sat Jan 14, 2012 2:40 am    Post subject:
Bumping this old thread to the top. I am about to make the plunge into SMT stuff. Time to be able to solder and desolder SMT stuff. I do have a desoldering station, I will post a pix this weekend of it. It's one I bought from Australia about 5 years ago, but never got around to getting the 220 volt stepup transformer for it. I'm about to do that, and wanted to see what the latest recommendations were for soldering irons. Anything new hit the market since this thread?
Posted: Sat Jan 14, 2012 6:39 am    Post subject:
Curt, if you got it from Australia, you can run it from any two phases, which will be about 220 volts ( we are 230v and 400v here in Australia by the way Wink ). You should have 2 phases coming into your main switchboard, so connnect the active to an active, and the neutral to a different active, earth obviously goes to earth.
Posted: Sat Jan 14, 2012 8:17 am    Post subject:
it's sqrt(3)*110V= 190V, it still sounds a bit little to me.
Posted: Sat Jan 14, 2012 9:51 am    Post subject:
I know the equation, but thanks all the same you raise a good point. Its 120v and 208v are nominal there, however there is also 120v and 240v split phase systems. Having never looked into it id imagine they use a capacitor bank to lift the phase angle to leading in order to give them the split phase supply. ( simular to capacitor start and capacitor run split phase motors )
I shouldve been more specific about what i meant. Maybe someone else will know exactly how they do it for their larger appliances.
The way we do it here when we hook up some US items ( comercial grade cooking equipment is one reasonably common, the high output charger for an electric car is another ) on our supply is connect L1 to L1 and L2 goes to neutral, which gives 230 volts ( nominal ). If the device has an electric motor, it wont work properly here anyway due to the frequency being 50Hz and not 60Hz, so the motor will spin slower here even though youre feeding it a higher voltage. ( 120xF / no. poles= syncronous speed )
Posted: Sat Jan 14, 2012 2:47 pm    Post subject:
Newest model and on sale...... Very Happy
http://www.radioshack.com/product/index.jsp?productId=2062738
Posted: Sat Jan 14, 2012 3:46 pm    Post subject:
Ya, totally illegal wiring if I do that. I'd need to run a new 14/3 wire from the panel to the bench, not an easy task. A $100 upconversion transformer is going to be cheaper..
Posted: Sat Jan 14, 2012 6:00 pm    Post subject:
Get some spare transformer from a matching rated-power amplifier which has switchable primary windings and use it as autotransformer
Posted: Sun Jan 15, 2012 2:38 am    Post subject:
Oh so they do have some common sense when it comes to unlicenced electrical wiring in Canada do they? Thank god for that. Laughing
